Playonlinux не подгружет wine
Модератор: WWolf
ravial555
Благодарил (а): 16 раз
14 май 2017, 14:35
Поставил на LMDE playonlinux, делаю бутылку на 64 бита - не выходит. Прошу помочь разобрать выхлоп
vicdeb@vicdeb ~ $ playonlinux
Looking for python... 2.7.9 - selected
[main] Message: PlayOnLinux (4.2.5) is starting
[clean_tmp] Message: Cleaning temp directory
[POL_System_CheckFS] Message: Checking filesystem for /home/vicdeb/.PlayOnLinux/
[main] Message: Filesystem is compatible
[maj_check] Message: Web version : 1494599859
[maj_check] Message: Current local version : 1494307709
[maj_check] Message: Updating list
[install_plugins] Message: Проверка плагина: ScreenCap...
[install_plugins] Message: Проверка плагина: PlayOnLinux Vault...
[POL_Config_Write] Message: Config write: LAST_TIMESTAMP 1494599859
[POL_SetupWindow_Init] Message: Creating new window for pid 5145
[POL_SetupWindow_menu_num] Message: menu_num answer: 1
[POL_System_SetArch] Message: POL_ARCH set to amd64
find: `/home/vicdeb/.PlayOnLinux//wine/linux-amd64/*': Нет такого файла или каталога
[POL_SetupWindow_Init] Message: Creating new window for pid 5266
[POL_SetupWindow_Init] Message: Creating new window for pid 5346
[POL_Wine_InstallVersion] Message: Installing wine version path: 2.0.1, amd64
Server sha1 : e230967f59f5510d9b5a16ce072b610520789db8
Client sha1 : e230967f59f5510d9b5a16ce072b610520789db8
PlayOnLinux пакетный менеджер: 4.2.5
Opening /home/vicdeb/.PlayOnLinux/tmp/PlayOnLinux-wine-2.0.1-linux-amd64.pol
Извлечение: /home/vicdeb/.PlayOnLinux/tmp/PlayOnLinux-wine-2.0.1-linux-amd64.pol...
Запуск...
Очистка...
[POL_Wine_Install_resources] Message: Installing gecko for wine 2.0.1 amd64
[POL_Wine_Install_resources] Message: Linking gecko
[POL_Wine_Install_resources] Message: wine_gecko-2.40-x86.msi already installed. Skipping
[POL_Wine_Install_resources] Message: Installing wine_gecko-2.40-x86_64.msi
[POL_Download] Message: Downloading http://www.playonlinux.com/wine/gecko/a ... x86_64.msi
[POL_Download] Message: Download MD5 matches
[POL_Wine_Install_resources] Message: Installing mono for wine 2.0.1 amd64
[POL_Wine_Install_resources] Message: Linking mono
[POL_Wine_Install_resources] Message: wine-mono-4.5.6.msi already installed. Skipping
[POL_SetupWindow_Close] Message: Closing window for pid 5346
[POL_SetupWindow_Init] Message: Creating new window for pid 5935
[POL_SetupWindow_menu] Message: menu answer: 2.0.1
[POL_SetupWindow_textbox] Message: textbox answer: x
[POL_Wine_SelectPrefix] Message: Selecting prefix: x
[POL_Wine_PrefixCreate] Message: POL_WINEVERSION is already set to 2.0.1. Using it
[POL_Wine_PrefixCreate] Message: Creating prefix (2.0.1)...
[POL_Wine_PrefixCreate] Message: Using wine 2.0.1
[POL_Config_PrefixWrite] Message: Prefix config write: ARCH amd64
[POL_Config_PrefixWrite] Message: Prefix config write: VERSION 2.0.1
[POL_Wine] Message: Running wine-2.0.1 --version (Working directory : /usr/share/playonlinux/python)
[POL_Wine] Message: Notice: PlayOnLinux deliberately disables winemenubuilder. See http://www.playonlinux.com/fr/page-26-W ... ilder.html
/usr/share/playonlinux/lib/wine.lib: line 527: /home/vicdeb/.PlayOnLinux//wine/linux-amd64/2.0.1/bin/wine: Нет такого файла или каталога
[POL_Wine] Error: Похоже, Wine прервала работу.
Если Ваша программа работает, просто не обращайте внимания на это сообщение.
[POL_Wine] Message: Wine return: 127
[POL_SetupWindow_Init] Message: Creating new window for pid 6481
24 дек 2018, 23:44
:hm:
26 дек 2018, 20:22
Немного смущает двойная косая в пути //
А пробовали эту папку создать вручную? Это первое что приходит в голову, остальное надо гуглить.
Вернуться в «Wine»
