Razer Comms
Модератор: WWolf
andrew0304
Благодарил (а): 3 раза
Razer Comms
23 апр 2017, 11:36
Над установить Comms на Mint 17.3
Устанавил с помощью PlayOnLinux с Wine 1.7.35, установка успешна, при запуске Comms:
POL обнаружила ошибку... бла бла бла...
Error in main
RazerComms прекратил свою работу.
Нажмите "Отладка" ("Debug"), чтобы узнать подробности.
Отладка:
[04/23/17 11:30:44] - Running wine-1.7.35 RazerComms.exe (Working directory : /home/andrew/.PlayOnLinux/wineprefix/comms/drive_c/Program Files/Razer/Comms)
fixme:mscoree:parse_supported_runtime sku=L".NETFramework,Version=v4.0" not implemented
Unhandled Exception:
System.TypeInitializationException: An exception was thrown by the type initializer for Razer.GameScannerService.Program ---> System.TypeInitializationException: An exception was thrown by the type in at System.TimeZoneInfo.get_Local () [0x00000] in <filename unknown>:0
at System.CurrentSystemTimeZone.GetUtcOffset (DateTime time) [0x00000] in <filename unknown>:0
at System.TimeZone.GetLocalTimeDiff (DateTime time) [0x00000] in <filename unknown>:0
at System.DateTime.get_Now () [0x00000] in <filename unknown>:0
at log4net.Util.SystemInfo..cctor () [0x00000] in <filename unknown>:0
--- End of inner exception stack trace ---
at log4net.Core.LoggerManager.GetVersionInfo () [0x00000] in <filename unknown>:0
at log4net.Core.LoggerManager..cctor () [0x00000] in <filename unknown>:0
at log4net.LogManager.GetLogger (System.Reflection.Assembly repositoryAssembly, System.String name) [0x00000] in <filename unknown>:0
at log4net.LogManager.GetLogger (System.String name) [0x00000] in <filename unknown>:0
at Razer.GameScannerService.Program..cctor () [0x00000] in <filename unknown>:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.TypeInitializationException: An exception was thrown by the type initializer for Razer.GameScannerService.Program ---> System.TypeInitializationException: An at System.TimeZoneInfo.get_Local () [0x00000] in <filename unknown>:0
err:service:service_send_start_message service L"Razer Game Scanner Service" failed to start
fixme:service:scmdatabase_autostart_services Auto-start service L"Razer Game Scanner Service" failed to start: 1053
fixme:ntoskrnl:KeInitializeEvent stub: 0x1127e8 1 0
fixme:ntoskrnl:PsSetCreateProcessNotifyRoutine stub: 0x5411e0 0
fixme:ntoskrnl:PsSetCreateThreadNotifyRoutine stub: 0x541210
fixme:ntoskrnl:MmGetSystemRoutineAddress L"RtlIsNtDdiVersionAvailable" not found
fixme:ntoskrnl:PsSetCreateProcessNotifyRoutine stub: 0x540ac0 0
fixme:mscoree:ConfigFileHandler_startElement Unknown element L"configSections" in state 2
fixme:mscoree:ConfigFileHandler_startElement Unknown element L"sectionGroup" in state 6
fixme:mscoree:ConfigFileHandler_startElement Unknown element L"section" in state 6
fixme:mscoree:parse_supported_runtime sku=L".NETFramework,Version=v4.5" not implemented
fixme:mscoree:ConfigFileHandler_startElement Unknown element L"applicationSettings" in state 2
fixme:mscoree:ConfigFileHandler_startElement Unknown element L"Razer.Storage.Properties.Settings" in state 6
fixme:mscoree:ConfigFileHandler_startElement Unknown element L"setting" in state 6
fixme:mscoree:ConfigFileHandler_startElement Unknown element L"value" in state 6
fixme:mscoree:ConfigFileHandler_startElement Unknown element L"system.data" in state 2
fixme:mscoree:ConfigFileHandler_startElement Unknown element L"DbProviderFactories" in state 6
fixme:mscoree:ConfigFileHandler_startElement Unknown element L"remove" in state 6
fixme:mscoree:ConfigFileHandler_startElement Unknown element L"add" in state 6
fixme:mscoree:ConfigFileHandler_startElement Unknown element L"connectionStrings" in state 2
fixme:mscoree:ConfigFileHandler_startElement Unknown element L"dependentAssembly" in state 0
fixme:mscoree:ConfigFileHandler_startElement Unknown element L"assemblyIdentity" in state 6
fixme:mscoree:ConfigFileHandler_startElement Unknown element L"bindingRedirect" in state 6
The entry point method could not be loaded
Што делоть?
Razer Comms
23 апр 2017, 14:03
andrew0304, похоже заставить её работать под вайном пока маловероятно - https://appdb.winehq.org/objectManager. ... &iId=15147
andrew0304
Razer Comms
26 апр 2017, 16:41
Все же хочется что сделать
Bill Williamson
Решено: 34
Благодарил (а): 288 раз
Razer Comms
26 апр 2017, 16:51
Гугл говорит есть аналоги: Discord Mumble TeamSpeak Wire GameVox. Они уступают по функционалу?
Вернуться в «Wine»
