Прерывается звук
Aktavius
Прерывается звук
#21
10 авг 2023, 18:19
Dja писал(а):
10 авг 2023, 16:53
А что говорит
[ 0.000000] microcode: microcode updated early to revision 0x2f, date = 2019-02-17
[ 0.000000] Linux version 5.15.0-78-generic (buildd@lcy02-amd64-008) (gcc (Ubuntu 11.3.0-1ubuntu1~22.04.1) 11.3.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #85-Ubuntu SMP Fri Jul 7 15:25:09 UTC 2023 (Ubuntu 5.15.0-78.85-generic 5.15.99)
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.15.0-78-generic root=UUID=3307016d-9359-4c6d-9244-13258cba7df0 ro quiet splash
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] Hygon HygonGenuine
[ 0.000000] Centaur CentaurHauls
[ 0.000000] zhaoxin Shanghai
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[ 0.000000] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.000000] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'standard' format.
[ 0.000000] signal: max sigframe size: 1776
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009ffff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000befc1fff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000befc2000-0x00000000bf014fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000bf015000-0x00000000bf5a0fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000bf5a1000-0x00000000bf5b1fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000bf5b2000-0x00000000bf5c8fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000bf5c9000-0x00000000bf5c9fff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000bf5ca000-0x00000000bf5cafff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000bf5cb000-0x00000000bf5cbfff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000bf5cc000-0x00000000bf5d3fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000bf5d4000-0x00000000bf5ddfff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000bf5de000-0x00000000bf639fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000bf63a000-0x00000000bf67cfff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000bf67d000-0x00000000bf7fffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000023f7fffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] e820: update [mem 0x0270a018-0x0272aa57] usable ==> usable
[ 0.000000] e820: update [mem 0x0272b018-0x02737857] usable ==> usable
[ 0.000000] e820: update [mem 0x02738018-0x0273e457] usable ==> usable
[ 0.000000] extended physical RAM map:
[ 0.000000] reserve setup_data: [mem 0x0000000000000000-0x000000000009ffff] usable
[ 0.000000] reserve setup_data: [mem 0x0000000000100000-0x000000000270a017] usable
[ 0.000000] reserve setup_data: [mem 0x000000000270a018-0x000000000272aa57] usable
[ 0.000000] reserve setup_data: [mem 0x000000000272aa58-0x000000000272b017] usable
[ 0.000000] reserve setup_data: [mem 0x000000000272b018-0x0000000002737857] usable
[ 0.000000] reserve setup_data: [mem 0x0000000002737858-0x0000000002738017] usable
[ 0.000000] reserve setup_data: [mem 0x0000000002738018-0x000000000273e457] usable
[ 0.000000] reserve setup_data: [mem 0x000000000273e458-0x00000000befc1fff] usable
[ 0.000000] reserve setup_data: [mem 0x00000000befc2000-0x00000000bf014fff] ACPI NVS
[ 0.000000] reserve setup_data: [mem 0x00000000bf015000-0x00000000bf5a0fff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000bf5a1000-0x00000000bf5b1fff] ACPI NVS
[ 0.000000] reserve setup_data: [mem 0x00000000bf5b2000-0x00000000bf5c8fff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000bf5c9000-0x00000000bf5c9fff] usable
[ 0.000000] reserve setup_data: [mem 0x00000000bf5ca000-0x00000000bf5cafff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000bf5cb000-0x00000000bf5cbfff] ACPI NVS
[ 0.000000] reserve setup_data: [mem 0x00000000bf5cc000-0x00000000bf5d3fff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000bf5d4000-0x00000000bf5ddfff] ACPI NVS
[ 0.000000] reserve setup_data: [mem 0x00000000bf5de000-0x00000000bf639fff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000bf63a000-0x00000000bf67cfff] ACPI NVS
[ 0.000000] reserve setup_data: [mem 0x00000000bf67d000-0x00000000bf7fffff] usable
[ 0.000000] reserve setup_data: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ 0.000000] reserve setup_data: [mem 0x0000000100000000-0x000000023f7fffff] usable
[ 0.000000] efi: EFI v2.00 by American Megatrends
[ 0.000000] efi: SMBIOS=0xbf638a18 ACPI=0xbf00c000 ACPI 2.0=0xbf00c000 MOKvar=0xbf5ca000
[ 0.000000] secureboot: Secure boot disabled
[ 0.000000] SMBIOS 2.6 present.
[ 0.000000] DMI: System manufacturer System Product Name/P8P67, BIOS 1503 03/10/2011
[ 0.000000] tsc: Fast TSC calibration using PIT
[ 0.000000] tsc: Detected 3399.780 MHz processor
[ 0.000710] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000713] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000722] last_pfn = 0x23f800 max_arch_pfn = 0x400000000
[ 0.001202] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.001719] total RAM covered: 8184M
[ 0.001870] Found optimal setting for mtrr clean up
[ 0.001870] gran_size: 64K chunk_size: 16M num_reg: 5 lose cover RAM: 0G
[ 0.002473] e820: update [mem 0xc0000000-0xffffffff] usable ==> reserved
[ 0.002481] last_pfn = 0xbf800 max_arch_pfn = 0x400000000
[ 0.011388] found SMP MP-table at [mem 0x000fcf00-0x000fcf0f]
[ 0.011887] secureboot: Secure boot disabled
[ 0.011888] RAMDISK: [mem 0xb2040000-0xbefc1fff]
[ 0.011894] ACPI: Early table checksum verification disabled
[ 0.011897] ACPI: RSDP 0x00000000BF00C000 000024 (v02 ALASKA)
[ 0.011901] ACPI: XSDT 0x00000000BF00C068 00004C (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.011907] ACPI: FACP 0x00000000BF0141D8 0000F4 (v04 ALASKA A M I 01072009 AMI 00010013)
[ 0.011912] ACPI: DSDT 0x00000000BF00C140 008092 (v02 ALASKA A M I 00000000 INTL 20051117)
[ 0.011916] ACPI: FACS 0x00000000BF5D5F80 000040
[ 0.011918] ACPI: APIC 0x00000000BF0142D0 000072 (v03 ALASKA A M I 01072009 AMI 00010013)
[ 0.011921] ACPI: SSDT 0x00000000BF014348 000102 (v01 AMICPU PROC 00000001 MSFT 03000001)
[ 0.011925] ACPI: MCFG 0x00000000BF014450 00003C (v01 ALASKA A M I 01072009 MSFT 00000097)
[ 0.011928] ACPI: HPET 0x00000000BF014490 000038 (v01 ALASKA A M I 01072009 AMI. 00000004)
[ 0.011930] ACPI: Reserving FACP table memory at [mem 0xbf0141d8-0xbf0142cb]
[ 0.011932] ACPI: Reserving DSDT table memory at [mem 0xbf00c140-0xbf0141d1]
[ 0.011933] ACPI: Reserving FACS table memory at [mem 0xbf5d5f80-0xbf5d5fbf]
[ 0.011934] ACPI: Reserving APIC table memory at [mem 0xbf0142d0-0xbf014341]
[ 0.011935] ACPI: Reserving SSDT table memory at [mem 0xbf014348-0xbf014449]
[ 0.011936] ACPI: Reserving MCFG table memory at [mem 0xbf014450-0xbf01448b]
[ 0.011937] ACPI: Reserving HPET table memory at [mem 0xbf014490-0xbf0144c7]
[ 0.012039] No NUMA configuration found
[ 0.012040] Faking a node at [mem 0x0000000000000000-0x000000023f7fffff]
[ 0.012048] NODE_DATA(0) allocated [mem 0x23f7d3000-0x23f7fcfff]
[ 0.012422] Zone ranges:
[ 0.012423] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.012425] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.012427] Normal [mem 0x0000000100000000-0x000000023f7fffff]
[ 0.012428] Device empty
[ 0.012429] Movable zone start for each node
[ 0.012432] Early memory node ranges
[ 0.012432] node 0: [mem 0x0000000000001000-0x000000000009ffff]
[ 0.012434] node 0: [mem 0x0000000000100000-0x00000000befc1fff]
[ 0.012435] node 0: [mem 0x00000000bf5c9000-0x00000000bf5c9fff]
[ 0.012436] node 0: [mem 0x00000000bf67d000-0x00000000bf7fffff]
[ 0.012437] node 0: [mem 0x0000000100000000-0x000000023f7fffff]
[ 0.012439] Initmem setup node 0 [mem 0x0000000000001000-0x000000023f7fffff]
[ 0.012444] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.012475] On node 0, zone DMA: 96 pages in unavailable ranges
[ 0.018385] On node 0, zone DMA32: 1543 pages in unavailable ranges
[ 0.018395] On node 0, zone DMA32: 179 pages in unavailable ranges
[ 0.028349] On node 0, zone Normal: 2048 pages in unavailable ranges
[ 0.028383] On node 0, zone Normal: 2048 pages in unavailable ranges
[ 0.028766] ACPI: PM-Timer IO Port: 0x408
[ 0.028774] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.028785] IOAPIC[0]: apic_id 0, version 32, address 0xfec00000, GSI 0-23
[ 0.028787] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.028789] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.028793] ACPI: Using ACPI (MADT) for SMP configuration information
[ 0.028794] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[ 0.028799] TSC deadline timer available
[ 0.028800] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
[ 0.028817] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.028819] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[ 0.028821] PM: hibernation: Registered nosave memory: [mem 0x0270a000-0x0270afff]
[ 0.028823] PM: hibernation: Registered nosave memory: [mem 0x0272a000-0x0272afff]
[ 0.028824] PM: hibernation: Registered nosave memory: [mem 0x0272b000-0x0272bfff]
[ 0.028826] PM: hibernation: Registered nosave memory: [mem 0x02737000-0x02737fff]
[ 0.028826] PM: hibernation: Registered nosave memory: [mem 0x02738000-0x02738fff]
[ 0.028828] PM: hibernation: Registered nosave memory: [mem 0x0273e000-0x0273efff]
[ 0.028830] PM: hibernation: Registered nosave memory: [mem 0xbefc2000-0xbf014fff]
[ 0.028831] PM: hibernation: Registered nosave memory: [mem 0xbf015000-0xbf5a0fff]
[ 0.028832] PM: hibernation: Registered nosave memory: [mem 0xbf5a1000-0xbf5b1fff]
[ 0.028832] PM: hibernation: Registered nosave memory: [mem 0xbf5b2000-0xbf5c8fff]
[ 0.028834] PM: hibernation: Registered nosave memory: [mem 0xbf5ca000-0xbf5cafff]
[ 0.028835] PM: hibernation: Registered nosave memory: [mem 0xbf5cb000-0xbf5cbfff]
[ 0.028836] PM: hibernation: Registered nosave memory: [mem 0xbf5cc000-0xbf5d3fff]
[ 0.028837] PM: hibernation: Registered nosave memory: [mem 0xbf5d4000-0xbf5ddfff]
[ 0.028837] PM: hibernation: Registered nosave memory: [mem 0xbf5de000-0xbf639fff]
[ 0.028838] PM: hibernation: Registered nosave memory: [mem 0xbf63a000-0xbf67cfff]
[ 0.028840] PM: hibernation: Registered nosave memory: [mem 0xbf800000-0xfed1bfff]
[ 0.028841] PM: hibernation: Registered nosave memory: [mem 0xfed1c000-0xfed1ffff]
[ 0.028842] PM: hibernation: Registered nosave memory: [mem 0xfed20000-0xfeffffff]
[ 0.028842] PM: hibernation: Registered nosave memory: [mem 0xff000000-0xffffffff]
[ 0.028844] [mem 0xbf800000-0xfed1bfff] available for PCI devices
[ 0.028846] Booting paravirtualized kernel on bare hardware
[ 0.028849] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[ 0.028856] setup_percpu: NR_CPUS:8192 nr_cpumask_bits:4 nr_cpu_ids:4 nr_node_ids:1
[ 0.028996] percpu: Embedded 60 pages/cpu s208896 r8192 d28672 u524288
[ 0.029002] pcpu-alloc: s208896 r8192 d28672 u524288 alloc=1*2097152
[ 0.029004] pcpu-alloc: [0] 0 1 2 3
[ 0.029033] Built 1 zonelists, mobility grouping on. Total pages: 2058400
[ 0.029035] Policy zone: Normal
[ 0.029036] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.15.0-78-generic root=UUID=3307016d-9359-4c6d-9244-13258cba7df0 ro quiet splash
[ 0.029101] Unknown kernel command line parameters "splash BOOT_IMAGE=/boot/vmlinuz-5.15.0-78-generic", will be passed to user space.
[ 0.029462] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.029635] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.029687] mem auto-init: stack:off, heap alloc:on, heap free:off
[ 0.056589] Memory: 7838840K/8364948K available (16393K kernel code, 4383K rwdata, 10844K rodata, 3248K init, 18832K bss, 525848K reserved, 0K cma-reserved)
[ 0.056864] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.056879] Kernel/User page tables isolation: enabled
[ 0.056896] ftrace: allocating 50600 entries in 198 pages
[ 0.077454] ftrace: allocated 198 pages with 4 groups
[ 0.077565] rcu: Hierarchical RCU implementation.
[ 0.077567] rcu: RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=4.
[ 0.077568] Rude variant of Tasks RCU enabled.
[ 0.077569] Tracing variant of Tasks RCU enabled.
[ 0.077569] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.077570] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.081628] NR_IRQS: 524544, nr_irqs: 456, preallocated irqs: 16
[ 0.081852] Console: colour dummy device 80x25
[ 0.081866] printk: console [tty0] enabled
[ 0.081886] ACPI: Core revision 20210730
[ 0.081963] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
[ 0.081976] APIC: Switch to symmetric I/O mode setup
[ 0.082365] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.101975] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x31017e984af, max_idle_ns: 440795283502 ns
[ 0.101980] Calibrating delay loop (skipped), value calculated using timer frequency.. 6799.56 BogoMIPS (lpj=13599120)
[ 0.101983] pid_max: default: 32768 minimum: 301
[ 0.106019] LSM: Security Framework initializing
[ 0.106031] landlock: Up and running.
[ 0.106032] Yama: becoming mindful.
[ 0.106056] AppArmor: AppArmor initialized
[ 0.106113] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.106127] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.106397] CPU0: Thermal monitoring enabled (TM1)
[ 0.106414] process: using mwait in idle threads
[ 0.106416] Last level iTLB entries: 4KB 512, 2MB 8, 4MB 8
[ 0.106417] Last level dTLB entries: 4KB 512, 2MB 32, 4MB 32, 1GB 0
[ 0.106421] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.106422] Spectre V2 : Mitigation: Retpolines
[ 0.106423] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.106424] Spectre V2 : Spectre v2 / SpectreRSB : Filling RSB on VMEXIT
[ 0.106424] Spectre V2 : Enabling Restricted Speculation for firmware calls
[ 0.106426] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.106427] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[ 0.106430] MDS: Mitigation: Clear CPU buffers
[ 0.106430] MMIO Stale Data: Unknown: No mitigations
[ 0.124750] Freeing SMP alternatives memory: 44K
[ 0.126080] smpboot: Estimated ratio of average max frequency by base frequency (times 1024): 1830
[ 0.126087] smpboot: CPU0: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz (family: 0x6, model: 0x2a, stepping: 0x7)
[ 0.126250] Performance Events: PEBS fmt1+, SandyBridge events, 16-deep LBR, full-width counters, Intel PMU driver.
[ 0.126258] ... version: 3
[ 0.126259] ... bit width: 48
[ 0.126259] ... generic registers: 8
[ 0.126260] ... value mask: 0000ffffffffffff
[ 0.126261] ... max period: 00007fffffffffff
[ 0.126262] ... fixed-purpose events: 3
[ 0.126262] ... event mask: 00000007000000ff
[ 0.126381] rcu: Hierarchical SRCU implementation.
[ 0.126954] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.127010] smp: Bringing up secondary CPUs ...
[ 0.127119] x86: Booting SMP configuration:
[ 0.127121] .... node #0, CPUs: #1 #2 #3
[ 0.134043] smp: Brought up 1 node, 4 CPUs
[ 0.134043] smpboot: Max logical packages: 1
[ 0.134043] smpboot: Total of 4 processors activated (27198.24 BogoMIPS)
[ 0.136741] devtmpfs: initialized
[ 0.136741] x86/mm: Memory block size: 128MB
[ 0.136741] ACPI: PM: Registering ACPI NVS region [mem 0xbefc2000-0xbf014fff] (339968 bytes)
[ 0.136741] ACPI: PM: Registering ACPI NVS region [mem 0xbf5a1000-0xbf5b1fff] (69632 bytes)
[ 0.136741] ACPI: PM: Registering ACPI NVS region [mem 0xbf5cb000-0xbf5cbfff] (4096 bytes)
[ 0.136741] ACPI: PM: Registering ACPI NVS region [mem 0xbf5d4000-0xbf5ddfff] (40960 bytes)
[ 0.136741] ACPI: PM: Registering ACPI NVS region [mem 0xbf63a000-0xbf67cfff] (274432 bytes)
[ 0.136741] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.136741] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.136741] pinctrl core: initialized pinctrl subsystem
[ 0.136741] PM: RTC time: 14:55:09, date: 2023-08-10
[ 0.138051] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.138192] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.138254] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.138319] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.138326] audit: initializing netlink subsys (disabled)
[ 0.138332] audit: type=2000 audit(1691679309.056:1): state=initialized audit_enabled=0 res=1
[ 0.138332] thermal_sys: Registered thermal governor 'fair_share'
[ 0.138332] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.138332] thermal_sys: Registered thermal governor 'step_wise'
[ 0.138332] thermal_sys: Registered thermal governor 'user_space'
[ 0.138332] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.138332] EISA bus registered
[ 0.138332] cpuidle: using governor ladder
[ 0.138332] cpuidle: using governor menu
[ 0.138332] ACPI: bus type PCI registered
[ 0.138332] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.138332] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xe0000000-0xe3ffffff] (base 0xe0000000)
[ 0.138332] PCI: not using MMCONFIG
[ 0.138332] PCI: Using configuration type 1 for base access
[ 0.138332] core: PMU erratum BJ122, BV98, HSD29 workaround disabled, HT off
[ 0.138489] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.139263] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[ 0.139267] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.139267] ACPI: Added _OSI(Module Device)
[ 0.139267] ACPI: Added _OSI(Processor Device)
[ 0.139267] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.139267] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.139267] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.139267] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.139267] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 0.143220] ACPI: 2 ACPI AML tables successfully acquired and loaded
[ 0.146187] ACPI: Dynamic OEM Table Load:
[ 0.146193] ACPI: SSDT 0xFFFFA02E4028EC00 00038C (v01 AMI IST 00000001 MSFT 03000001)
[ 0.146574] ACPI: Dynamic OEM Table Load:
[ 0.146578] ACPI: SSDT 0xFFFFA02E40B959C0 000084 (v01 AMI CST 00000001 MSFT 03000001)
[ 0.147260] ACPI: EC: EC started
[ 0.147261] ACPI: EC: interrupt blocked
[ 0.147266] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.147268] ACPI: \_SB_.PCI0.SBRG.EC0_: Boot DSDT EC used to handle transactions
[ 0.147269] ACPI: Interpreter enabled
[ 0.147283] ACPI: PM: (supports S0 S1 S3 S4 S5)
[ 0.147284] ACPI: Using IOAPIC for interrupt routing
[ 0.147309] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xe0000000-0xe3ffffff] (base 0xe0000000)
[ 0.147377] PCI: MMCONFIG at [mem 0xe0000000-0xe3ffffff] reserved in ACPI motherboard resources
[ 0.147386] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.147387] PCI: Using E820 reservations for host bridge windows
[ 0.147519] ACPI: Enabled 5 GPEs in block 00 to 3F
[ 0.147721] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 0.152865] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.152870] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.153030] acpi PNP0A08:00: _OSC: platform does not support [PCIeHotplug SHPCHotplug LTR DPC]
[ 0.153180] acpi PNP0A08:00: _OSC: OS now controls [PME AER PCIeCapability]
[ 0.153187] acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-3f] only partially covers this bridge
[ 0.153293] acpi PNP0A08:00: ignoring host bridge window [mem 0x000c8000-0x000dffff window] (conflicts with Video ROM [mem 0x000c0000-0x000ce5ff])
[ 0.153434] PCI host bridge to bus 0000:00
[ 0.153436] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.153438] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.153439] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.153441] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.153442] pci_bus 0000:00: root bus resource [mem 0xc0000000-0xffffffff window]
[ 0.153473] pci 0000:00:00.0: [8086:0100] type 00 class 0x060000
[ 0.153597] pci 0000:00:01.0: [8086:0101] type 01 class 0x060400
[ 0.153627] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.153737] pci 0000:00:16.0: [8086:1c3a] type 00 class 0x078000
[ 0.153757] pci 0000:00:16.0: reg 0x10: [mem 0xfb508000-0xfb50800f 64bit]
[ 0.153824] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[ 0.153945] pci 0000:00:1a.0: [8086:1c2d] type 00 class 0x0c0320
[ 0.153961] pci 0000:00:1a.0: reg 0x10: [mem 0xfb507000-0xfb5073ff]
[ 0.154038] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
[ 0.154136] pci 0000:00:1b.0: [8086:1c20] type 00 class 0x040300
[ 0.154151] pci 0000:00:1b.0: reg 0x10: [mem 0xfb500000-0xfb503fff 64bit]
[ 0.154214] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.154337] pci 0000:00:1c.0: [8086:1c10] type 01 class 0x060400
[ 0.154421] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.154541] pci 0000:00:1c.1: [8086:1c12] type 01 class 0x060400
[ 0.154625] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[ 0.154751] pci 0000:00:1c.2: [8086:1c14] type 01 class 0x060400
[ 0.154834] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[ 0.154955] pci 0000:00:1c.3: [8086:1c16] type 01 class 0x060400
[ 0.155038] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[ 0.155157] pci 0000:00:1c.4: [8086:1c18] type 01 class 0x060400
[ 0.155240] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
[ 0.155366] pci 0000:00:1c.5: [8086:1c1a] type 01 class 0x060400
[ 0.155449] pci 0000:00:1c.5: PME# supported from D0 D3hot D3cold
[ 0.155573] pci 0000:00:1c.6: [8086:244e] type 01 class 0x060401
[ 0.155656] pci 0000:00:1c.6: PME# supported from D0 D3hot D3cold
[ 0.155777] pci 0000:00:1c.7: [8086:1c1e] type 01 class 0x060400
[ 0.155860] pci 0000:00:1c.7: PME# supported from D0 D3hot D3cold
[ 0.155980] pci 0000:00:1d.0: [8086:1c26] type 00 class 0x0c0320
[ 0.155995] pci 0000:00:1d.0: reg 0x10: [mem 0xfb506000-0xfb5063ff]
[ 0.156073] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 0.156190] pci 0000:00:1f.0: [8086:1c46] type 00 class 0x060100
[ 0.156396] pci 0000:00:1f.2: [8086:1c02] type 00 class 0x010601
[ 0.156408] pci 0000:00:1f.2: reg 0x10: [io 0xf070-0xf077]
[ 0.156415] pci 0000:00:1f.2: reg 0x14: [io 0xf060-0xf063]
[ 0.156421] pci 0000:00:1f.2: reg 0x18: [io 0xf050-0xf057]
[ 0.156428] pci 0000:00:1f.2: reg 0x1c: [io 0xf040-0xf043]
[ 0.156434] pci 0000:00:1f.2: reg 0x20: [io 0xf020-0xf03f]
[ 0.156441] pci 0000:00:1f.2: reg 0x24: [mem 0xfb505000-0xfb5057ff]
[ 0.156476] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.156559] pci 0000:00:1f.3: [8086:1c22] type 00 class 0x0c0500
[ 0.156576] pci 0000:00:1f.3: reg 0x10: [mem 0xfb504000-0xfb5040ff 64bit]
[ 0.156594] pci 0000:00:1f.3: reg 0x20: [io 0xf000-0xf01f]
[ 0.156694] pci 0000:01:00.0: [10de:1407] type 00 class 0x030000
[ 0.156705] pci 0000:01:00.0: reg 0x10: [mem 0xfa000000-0xfaffffff]
[ 0.156715] pci 0000:01:00.0: reg 0x14: [mem 0xc0000000-0xcfffffff 64bit pref]
[ 0.156724] pci 0000:01:00.0: reg 0x1c: [mem 0xd0000000-0xd1ffffff 64bit pref]
[ 0.156730] pci 0000:01:00.0: reg 0x24: [io 0xe000-0xe07f]
[ 0.156736] pci 0000:01:00.0: reg 0x30: [mem 0xfb000000-0xfb07ffff pref]
[ 0.156741] pci 0000:01:00.0: enabling Extended Tags
[ 0.156752] pci 0000:01:00.0: BAR 3: assigned to efifb
[ 0.156756] pci 0000:01:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.156826] pci 0000:01:00.0: 32.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x16 link at 0000:00:01.0 (capable of 126.016 Gb/s with 8.0 GT/s PCIe x16 link)
[ 0.156868] pci 0000:01:00.1: [10de:0fba] type 00 class 0x040300
[ 0.156880] pci 0000:01:00.1: reg 0x10: [mem 0xfb080000-0xfb083fff]
[ 0.156914] pci 0000:01:00.1: enabling Extended Tags
[ 0.156994] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.156997] pci 0000:00:01.0: bridge window [io 0xe000-0xefff]
[ 0.156998] pci 0000:00:01.0: bridge window [mem 0xfa000000-0xfb0fffff]
[ 0.157001] pci 0000:00:01.0: bridge window [mem 0xc0000000-0xd1ffffff 64bit pref]
[ 0.157038] pci 0000:00:1c.0: PCI bridge to [bus 02]
[ 0.157106] pci 0000:03:00.0: [1033:0194] type 00 class 0x0c0330
[ 0.157137] pci 0000:03:00.0: reg 0x10: [mem 0xfb400000-0xfb401fff 64bit]
[ 0.157290] pci 0000:03:00.0: PME# supported from D0 D3hot D3cold
[ 0.157415] pci 0000:00:1c.1: PCI bridge to [bus 03]
[ 0.157420] pci 0000:00:1c.1: bridge window [mem 0xfb400000-0xfb4fffff]
[ 0.157463] pci 0000:00:1c.2: PCI bridge to [bus 04]
[ 0.157507] pci 0000:00:1c.3: PCI bridge to [bus 05]
[ 0.157574] pci 0000:06:00.0: [1033:0194] type 00 class 0x0c0330
[ 0.157605] pci 0000:06:00.0: reg 0x10: [mem 0xfb300000-0xfb301fff 64bit]
[ 0.157758] pci 0000:06:00.0: PME# supported from D0 D3hot D3cold
[ 0.157881] pci 0000:00:1c.4: PCI bridge to [bus 06]
[ 0.157886] pci 0000:00:1c.4: bridge window [mem 0xfb300000-0xfb3fffff]
[ 0.157953] pci 0000:07:00.0: [10ec:8168] type 00 class 0x020000
[ 0.157979] pci 0000:07:00.0: reg 0x10: [io 0xd000-0xd0ff]
[ 0.158011] pci 0000:07:00.0: reg 0x18: [mem 0xd2104000-0xd2104fff 64bit pref]
[ 0.158031] pci 0000:07:00.0: reg 0x20: [mem 0xd2100000-0xd2103fff 64bit pref]
[ 0.158149] pci 0000:07:00.0: supports D1 D2
[ 0.158150] pci 0000:07:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.158282] pci 0000:00:1c.5: PCI bridge to [bus 07]
[ 0.158285] pci 0000:00:1c.5: bridge window [io 0xd000-0xdfff]
[ 0.158292] pci 0000:00:1c.5: bridge window [mem 0xd2100000-0xd21fffff 64bit pref]
[ 0.158355] pci 0000:08:00.0: [1b21:1080] type 01 class 0x060401
[ 0.158536] pci 0000:00:1c.6: PCI bridge to [bus 08-09] (subtractive decode)
[ 0.158540] pci 0000:00:1c.6: bridge window [io 0xc000-0xcfff]
[ 0.158543] pci 0000:00:1c.6: bridge window [mem 0xfb200000-0xfb2fffff]
[ 0.158548] pci 0000:00:1c.6: bridge window [io 0x0000-0x0cf7 window] (subtractive decode)
[ 0.158549] pci 0000:00:1c.6: bridge window [io 0x0d00-0xffff window] (subtractive decode)
[ 0.158551] pci 0000:00:1c.6: bridge window [mem 0x000a0000-0x000bffff window] (subtractive decode)
[ 0.158552] pci 0000:00:1c.6: bridge window [mem 0xc0000000-0xffffffff window] (subtractive decode)
[ 0.158583] pci_bus 0000:09: extended config space not accessible
[ 0.158616] pci 0000:09:03.0: [1106:3044] type 00 class 0x0c0010
[ 0.158648] pci 0000:09:03.0: reg 0x10: [mem 0xfb200000-0xfb2007ff]
[ 0.158665] pci 0000:09:03.0: reg 0x14: [io 0xc000-0xc07f]
[ 0.158794] pci 0000:09:03.0: supports D2
[ 0.158795] pci 0000:09:03.0: PME# supported from D2 D3hot D3cold
[ 0.158901] pci 0000:08:00.0: PCI bridge to [bus 09] (subtractive decode)
[ 0.158910] pci 0000:08:00.0: bridge window [io 0xc000-0xcfff]
[ 0.158915] pci 0000:08:00.0: bridge window [mem 0xfb200000-0xfb2fffff]
[ 0.158924] pci 0000:08:00.0: bridge window [io 0xc000-0xcfff] (subtractive decode)
[ 0.158925] pci 0000:08:00.0: bridge window [mem 0xfb200000-0xfb2fffff] (subtractive decode)
[ 0.158927] pci 0000:08:00.0: bridge window [io 0x0000-0x0cf7 window] (subtractive decode)
[ 0.158928] pci 0000:08:00.0: bridge window [io 0x0d00-0xffff window] (subtractive decode)
[ 0.158929] pci 0000:08:00.0: bridge window [mem 0x000a0000-0x000bffff window] (subtractive decode)
[ 0.158930] pci 0000:08:00.0: bridge window [mem 0xc0000000-0xffffffff window] (subtractive decode)
[ 0.158998] pci 0000:0a:00.0: [1b4b:9172] type 00 class 0x010601
[ 0.159020] pci 0000:0a:00.0: reg 0x10: [io 0xb040-0xb047]
[ 0.159031] pci 0000:0a:00.0: reg 0x14: [io 0xb030-0xb033]
[ 0.159043] pci 0000:0a:00.0: reg 0x18: [io 0xb020-0xb027]
[ 0.159054] pci 0000:0a:00.0: reg 0x1c: [io 0xb010-0xb013]
[ 0.159066] pci 0000:0a:00.0: reg 0x20: [io 0xb000-0xb00f]
[ 0.159077] pci 0000:0a:00.0: reg 0x24: [mem 0xfb110000-0xfb1101ff]
[ 0.159089] pci 0000:0a:00.0: reg 0x30: [mem 0xfb100000-0xfb10ffff pref]
[ 0.159106] pci 0000:0a:00.0: Enabling fixed DMA alias to 00.1
[ 0.159156] pci 0000:0a:00.0: PME# supported from D3hot
[ 0.159248] pci 0000:00:1c.7: PCI bridge to [bus 0a]
[ 0.159251] pci 0000:00:1c.7: bridge window [io 0xb000-0xbfff]
[ 0.159254] pci 0000:00:1c.7: bridge window [mem 0xfb100000-0xfb1fffff]
[ 0.159791] ACPI: PCI: Interrupt link LNKA configured for IRQ 11
[ 0.159840] ACPI: PCI: Interrupt link LNKB configured for IRQ 10
[ 0.159888] ACPI: PCI: Interrupt link LNKC configured for IRQ 11
[ 0.159936] ACPI: PCI: Interrupt link LNKD configured for IRQ 10
[ 0.159984] ACPI: PCI: Interrupt link LNKE configured for IRQ 5
[ 0.160031] ACPI: PCI: Interrupt link LNKF configured for IRQ 5
[ 0.160079] ACPI: PCI: Interrupt link LNKG configured for IRQ 7
[ 0.160127] ACPI: PCI: Interrupt link LNKH configured for IRQ 3
[ 0.160219] ACPI: EC: interrupt unblocked
[ 0.160220] ACPI: EC: event unblocked
[ 0.160224] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.160225] ACPI: EC: GPE=0x18
[ 0.160226] ACPI: \_SB_.PCI0.SBRG.EC0_: Boot DSDT EC initialization complete
[ 0.160228] ACPI: \_SB_.PCI0.SBRG.EC0_: EC: Used to handle transactions and events
[ 0.160288] iommu: Default domain type: Translated
[ 0.160288] iommu: DMA domain TLB invalidation policy: lazy mode
[ 0.160288] SCSI subsystem initialized
[ 0.160288] libata version 3.00 loaded.
[ 0.160288] pci 0000:01:00.0: vgaarb: setting as boot VGA device
[ 0.160288] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.160288] pci 0000:01:00.0: vgaarb: bridge control possible
[ 0.160288] vgaarb: loaded
[ 0.160288] ACPI: bus type USB registered
[ 0.160288] usbcore: registered new interface driver usbfs
[ 0.160288] usbcore: registered new interface driver hub
[ 0.160288] usbcore: registered new device driver usb
[ 0.160288] pps_core: LinuxPPS API ver. 1 registered
[ 0.160288] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.160288] PTP clock support registered
[ 0.160288] EDAC MC: Ver: 3.0.0
[ 0.160288] Registered efivars operations
[ 0.160288] NetLabel: Initializing
[ 0.160288] NetLabel: domain hash size = 128
[ 0.160288] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.160288] NetLabel: unlabeled traffic allowed by default
[ 0.160288] PCI: Using ACPI for IRQ routing
[ 0.161980] PCI: pci_cache_line_size set to 64 bytes
[ 0.161980] e820: reserve RAM buffer [mem 0x0270a018-0x03ffffff]
[ 0.161980] e820: reserve RAM buffer [mem 0x0272b018-0x03ffffff]
[ 0.161980] e820: reserve RAM buffer [mem 0x02738018-0x03ffffff]
[ 0.161980] e820: reserve RAM buffer [mem 0xbefc2000-0xbfffffff]
[ 0.161980] e820: reserve RAM buffer [mem 0xbf5ca000-0xbfffffff]
[ 0.161980] e820: reserve RAM buffer [mem 0xbf800000-0xbfffffff]
[ 0.161980] e820: reserve RAM buffer [mem 0x23f800000-0x23fffffff]
[ 0.163111] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 0.163120] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[ 0.165176] clocksource: Switched to clocksource tsc-early
[ 0.172442] VFS: Disk quotas dquot_6.6.0
[ 0.172459] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.172567] AppArmor: AppArmor Filesystem Enabled
[ 0.172590] pnp: PnP ACPI init
[ 0.172743] system 00:00: [mem 0xfed10000-0xfed19fff] has been reserved
[ 0.172747] system 00:00: [mem 0xe0000000-0xe3ffffff] has been reserved
[ 0.172748] system 00:00: [mem 0xfed90000-0xfed93fff] has been reserved
[ 0.172750] system 00:00: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.172751] system 00:00: [mem 0xfee00000-0xfee0ffff] has been reserved
[ 0.172849] system 00:01: [io 0x0290-0x029f] has been reserved
[ 0.172924] system 00:03: [io 0x04d0-0x04d1] has been reserved
[ 0.173153] pnp 00:04: [dma 0 disabled]
[ 0.173370] system 00:05: [io 0x0400-0x0453] has been reserved
[ 0.173372] system 00:05: [io 0x0458-0x047f] has been reserved
[ 0.173373] system 00:05: [io 0x0500-0x057f] has been reserved
[ 0.173375] system 00:05: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.173376] system 00:05: [mem 0xfec00000-0xfecfffff] could not be reserved
[ 0.173378] system 00:05: [mem 0xfed08000-0xfed08fff] has been reserved
[ 0.173379] system 00:05: [mem 0xff000000-0xffffffff] has been reserved
[ 0.173439] system 00:06: [io 0x0454-0x0457] has been reserved
[ 0.173632] pnp: PnP ACPI: found 7 devices
[ 0.179301] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.179364] NET: Registered PF_INET protocol family
[ 0.179458] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.180576] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 0.180603] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.180638] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.180769] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.180843] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.180909] MPTCP token hash table entries: 8192 (order: 5, 196608 bytes, linear)
[ 0.180949] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.180973] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.181021] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.181026] NET: Registered PF_XDP protocol family
[ 0.181042] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.181045] pci 0000:00:01.0: bridge window [io 0xe000-0xefff]
[ 0.181048] pci 0000:00:01.0: bridge window [mem 0xfa000000-0xfb0fffff]
[ 0.181050] pci 0000:00:01.0: bridge window [mem 0xc0000000-0xd1ffffff 64bit pref]
[ 0.181053] pci 0000:00:1c.0: PCI bridge to [bus 02]
[ 0.181062] pci 0000:00:1c.1: PCI bridge to [bus 03]
[ 0.181066] pci 0000:00:1c.1: bridge window [mem 0xfb400000-0xfb4fffff]
[ 0.181073] pci 0000:00:1c.2: PCI bridge to [bus 04]
[ 0.181083] pci 0000:00:1c.3: PCI bridge to [bus 05]
[ 0.181092] pci 0000:00:1c.4: PCI bridge to [bus 06]
[ 0.181096] pci 0000:00:1c.4: bridge window [mem 0xfb300000-0xfb3fffff]
[ 0.181103] pci 0000:00:1c.5: PCI bridge to [bus 07]
[ 0.181105] pci 0000:00:1c.5: bridge window [io 0xd000-0xdfff]
[ 0.181111] pci 0000:00:1c.5: bridge window [mem 0xd2100000-0xd21fffff 64bit pref]
[ 0.181116] pci 0000:08:00.0: PCI bridge to [bus 09]
[ 0.181119] pci 0000:08:00.0: bridge window [io 0xc000-0xcfff]
[ 0.181126] pci 0000:08:00.0: bridge window [mem 0xfb200000-0xfb2fffff]
[ 0.181139] pci 0000:00:1c.6: PCI bridge to [bus 08-09]
[ 0.181141] pci 0000:00:1c.6: bridge window [io 0xc000-0xcfff]
[ 0.181145] pci 0000:00:1c.6: bridge window [mem 0xfb200000-0xfb2fffff]
[ 0.181152] pci 0000:00:1c.7: PCI bridge to [bus 0a]
[ 0.181154] pci 0000:00:1c.7: bridge window [io 0xb000-0xbfff]
[ 0.181158] pci 0000:00:1c.7: bridge window [mem 0xfb100000-0xfb1fffff]
[ 0.181165] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.181167] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.181168] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.181169] pci_bus 0000:00: resource 7 [mem 0xc0000000-0xffffffff window]
[ 0.181171] pci_bus 0000:01: resource 0 [io 0xe000-0xefff]
[ 0.181172] pci_bus 0000:01: resource 1 [mem 0xfa000000-0xfb0fffff]
[ 0.181173] pci_bus 0000:01: resource 2 [mem 0xc0000000-0xd1ffffff 64bit pref]
[ 0.181174] pci_bus 0000:03: resource 1 [mem 0xfb400000-0xfb4fffff]
[ 0.181176] pci_bus 0000:06: resource 1 [mem 0xfb300000-0xfb3fffff]
[ 0.181177] pci_bus 0000:07: resource 0 [io 0xd000-0xdfff]
[ 0.181178] pci_bus 0000:07: resource 2 [mem 0xd2100000-0xd21fffff 64bit pref]
[ 0.181180] pci_bus 0000:08: resource 0 [io 0xc000-0xcfff]
[ 0.181181] pci_bus 0000:08: resource 1 [mem 0xfb200000-0xfb2fffff]
[ 0.181182] pci_bus 0000:08: resource 4 [io 0x0000-0x0cf7 window]
[ 0.181183] pci_bus 0000:08: resource 5 [io 0x0d00-0xffff window]
[ 0.181185] pci_bus 0000:08: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.181186] pci_bus 0000:08: resource 7 [mem 0xc0000000-0xffffffff window]
[ 0.181187] pci_bus 0000:09: resource 0 [io 0xc000-0xcfff]
[ 0.181188] pci_bus 0000:09: resource 1 [mem 0xfb200000-0xfb2fffff]
[ 0.181190] pci_bus 0000:09: resource 4 [io 0xc000-0xcfff]
[ 0.181191] pci_bus 0000:09: resource 5 [mem 0xfb200000-0xfb2fffff]
[ 0.181192] pci_bus 0000:09: resource 6 [io 0x0000-0x0cf7 window]
[ 0.181193] pci_bus 0000:09: resource 7 [io 0x0d00-0xffff window]
[ 0.181194] pci_bus 0000:09: resource 8 [mem 0x000a0000-0x000bffff window]
[ 0.181195] pci_bus 0000:09: resource 9 [mem 0xc0000000-0xffffffff window]
[ 0.181197] pci_bus 0000:0a: resource 0 [io 0xb000-0xbfff]
[ 0.181198] pci_bus 0000:0a: resource 1 [mem 0xfb100000-0xfb1fffff]
[ 0.314032] pci 0000:00:1a.0: quirk_usb_early_handoff+0x0/0x160 took 129665 usecs
[ 0.446023] pci 0000:00:1d.0: quirk_usb_early_handoff+0x0/0x160 took 128871 usecs
[ 0.446062] pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
[ 0.446324] pci 0000:08:00.0: Disabling ASPM L0s/L1
[ 0.446334] PCI: CLS 64 bytes, default 64
[ 0.446340] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.446341] software IO TLB: mapped [mem 0x00000000ae040000-0x00000000b2040000] (64MB)
[ 0.446399] Trying to unpack rootfs image as initramfs...
[ 0.446846] Initialise system trusted keyrings
[ 0.446860] Key type blacklist registered
[ 0.446890] workingset: timestamp_bits=36 max_order=21 bucket_order=0
[ 0.448160] zbud: loaded
[ 0.448431] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.448592] fuse: init (API version 7.34)
[ 0.448746] integrity: Platform Keyring initialized
[ 0.457422] Key type asymmetric registered
[ 0.457426] Asymmetric key parser 'x509' registered
[ 0.457450] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 0.457476] io scheduler mq-deadline registered
[ 0.457732] pcieport 0000:00:01.0: PME: Signaling with IRQ 24
[ 0.457875] pcieport 0000:00:1c.0: PME: Signaling with IRQ 25
[ 0.457971] pcieport 0000:00:1c.1: PME: Signaling with IRQ 26
[ 0.458110] pcieport 0000:00:1c.2: PME: Signaling with IRQ 27
[ 0.458243] pcieport 0000:00:1c.3: PME: Signaling with IRQ 28
[ 0.458334] pcieport 0000:00:1c.4: PME: Signaling with IRQ 29
[ 0.458460] pcieport 0000:00:1c.5: PME: Signaling with IRQ 30
[ 0.458588] pcieport 0000:00:1c.6: PME: Signaling with IRQ 31
[ 0.458713] pcieport 0000:00:1c.7: PME: Signaling with IRQ 32
[ 0.458793] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.459180] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 0.459219] ACPI: button: Power Button [PWRB]
[ 0.459249] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 0.459269] ACPI: button: Power Button [PWRF]
[ 0.462708] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.483206] 00:04: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[ 0.485017] Linux agpgart interface v0.103
[ 0.486694] loop: module loaded
[ 0.486927] tun: Universal TUN/TAP device driver, 1.6
[ 0.486948] PPP generic driver version 2.4.2
[ 0.486990] VFIO - User Level meta-driver version: 0.3
[ 0.487088] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.487094] ehci-pci: EHCI PCI platform driver
[ 0.487205] ehci-pci 0000:00:1a.0: EHCI Host Controller
[ 0.487211] ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 1
[ 0.487221] ehci-pci 0000:00:1a.0: debug port 2
[ 0.491147] ehci-pci 0000:00:1a.0: irq 23, io mem 0xfb507000
[ 0.506008] ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[ 0.506067] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 0.506070] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.506071] usb usb1: Product: EHCI Host Controller
[ 0.506073] usb usb1: Manufacturer: Linux 5.15.0-78-generic ehci_hcd
[ 0.506074] usb usb1: SerialNumber: 0000:00:1a.0
[ 0.506247] hub 1-0:1.0: USB hub found
[ 0.506255] hub 1-0:1.0: 2 ports detected
[ 0.506462] ehci-pci 0000:00:1d.0: EHCI Host Controller
[ 0.506467] ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 0.506477] ehci-pci 0000:00:1d.0: debug port 2
[ 0.510390] ehci-pci 0000:00:1d.0: irq 23, io mem 0xfb506000
[ 0.526009] ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[ 0.526068] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 0.526070] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.526072] usb usb2: Product: EHCI Host Controller
[ 0.526073] usb usb2: Manufacturer: Linux 5.15.0-78-generic ehci_hcd
[ 0.526074] usb usb2: SerialNumber: 0000:00:1d.0
[ 0.526249] hub 2-0:1.0: USB hub found
[ 0.526257] hub 2-0:1.0: 2 ports detected
[ 0.526386] ehci-platform: EHCI generic platform driver
[ 0.526398] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.526402] ohci-pci: OHCI PCI platform driver
[ 0.526411] ohci-platform: OHCI generic platform driver
[ 0.526416] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.526463] i8042: PNP: No PS/2 controller found.
[ 0.526615] mousedev: PS/2 mouse device common for all mice
[ 0.526887] rtc_cmos 00:02: RTC can wake from S4
[ 0.527115] rtc_cmos 00:02: registered as rtc0
[ 0.527147] rtc_cmos 00:02: setting system clock to 2023-08-10T14:55:10 UTC (1691679310)
[ 0.527174] rtc_cmos 00:02: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[ 0.527182] i2c_dev: i2c /dev entries driver
[ 0.527278] device-mapper: core: CONFIG_IMA_DISABLE_HTABLE is disabled. Duplicate IMA measurements will not be recorded in the IMA log.
[ 0.527303] device-mapper: uevent: version 1.0.3
[ 0.527380] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
[ 0.527398] platform eisa.0: Probing EISA bus 0
[ 0.527400] platform eisa.0: EISA: Cannot allocate resource for mainboard
[ 0.527401] platform eisa.0: Cannot allocate resource for EISA slot 1
[ 0.527402] platform eisa.0: Cannot allocate resource for EISA slot 2
[ 0.527403] platform eisa.0: Cannot allocate resource for EISA slot 3
[ 0.527404] platform eisa.0: Cannot allocate resource for EISA slot 4
[ 0.527405] platform eisa.0: Cannot allocate resource for EISA slot 5
[ 0.527406] platform eisa.0: Cannot allocate resource for EISA slot 6
[ 0.527407] platform eisa.0: Cannot allocate resource for EISA slot 7
[ 0.527408] platform eisa.0: Cannot allocate resource for EISA slot 8
[ 0.527409] platform eisa.0: EISA: Detected 0 cards
[ 0.527441] intel_pstate: Intel P-state driver initializing
[ 0.527800] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.527824] efifb: probing for efifb
[ 0.527836] efifb: No BGRT, not showing boot graphics
[ 0.527836] efifb: framebuffer at 0xd1000000, using 1876k, total 1875k
[ 0.527837] efifb: mode is 800x600x32, linelength=3200, pages=1
[ 0.527838] efifb: scrolling: redraw
[ 0.527839] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.527868] fbcon: Deferring console take-over
[ 0.527869] fb0: EFI VGA frame buffer device
[ 0.527874] EFI Variables Facility v0.08 2004-May-17
[ 0.568155] drop_monitor: Initializing network drop monitor service
[ 0.568292] NET: Registered PF_INET6 protocol family
[ 0.842014] usb 1-1: new high-speed USB device number 2 using ehci-pci
[ 0.862017] usb 2-1: new high-speed USB device number 2 using ehci-pci
[ 0.998445] usb 1-1: New USB device found, idVendor=8087, idProduct=0024, bcdDevice= 0.00
[ 0.998450] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 0.998680] hub 1-1:1.0: USB hub found
[ 0.998813] hub 1-1:1.0: 6 ports detected
[ 1.018441] usb 2-1: New USB device found, idVendor=8087, idProduct=0024, bcdDevice= 0.00
[ 1.018446] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.018717] hub 2-1:1.0: USB hub found
[ 1.018812] hub 2-1:1.0: 8 ports detected
[ 1.150024] Freeing initrd memory: 212488K
[ 1.154891] Segment Routing with IPv6
[ 1.154908] In-situ OAM (IOAM) with IPv6
[ 1.154929] NET: Registered PF_PACKET protocol family
[ 1.155055] Key type dns_resolver registered
[ 1.155461] microcode: sig=0x206a7, pf=0x2, revision=0x2f
[ 1.155485] microcode: Microcode Update Driver: v2.2.
[ 1.155490] IPI shorthand broadcast: enabled
[ 1.155503] sched_clock: Marking stable (1155221979, 154058)->(1260322498, -104946461)
[ 1.155661] registered taskstats version 1
[ 1.155889] Loading compiled-in X.509 certificates
[ 1.156547] Loaded X.509 cert 'Build time autogenerated kernel key: 9d82e5e7ad5edec3b7fd52847c6ba9a5bea7ed9c'
[ 1.157048] Loaded X.509 cert 'Canonical Ltd. Live Patch Signing: 14df34d1a87cf37625abec039ef2bf521249b969'
[ 1.157543] Loaded X.509 cert 'Canonical Ltd. Kernel Module Signing: 88f752e560a1e0737e31163a466ad7b70a850c19'
[ 1.157544] blacklist: Loading compiled-in revocation X.509 certificates
[ 1.157561] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing: 61482aa2830d0ab2ad5af10b7250da9033ddcef0'
[ 1.157573] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (2017): 242ade75ac4a15e50d50c84b0d45ff3eae707a03'
[ 1.157586] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (ESM 2018): 365188c1d374d6b07c3c8f240f8ef722433d6a8b'
[ 1.157597] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (2019): c0746fd6c5da3ae827864651ad66ae47fe24b3e8'
[ 1.157615] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (2021 v1): a8d54bbb3825cfb94fa13c9f8a594a195c107b8d'
[ 1.157630] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (2021 v2): 4cf046892d6fd3c9a5b03f98d845f90851dc6a8c'
[ 1.157642] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (2021 v3): 100437bb6de6e469b581e61cd66bce3ef4ed53af'
[ 1.157657] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (Ubuntu Core 2019): c1d57b8f6b743f23ee41f4f7ee292f06eecadfb9'
[ 1.157751] zswap: loaded using pool lzo/zbud
[ 1.157882] Key type .fscrypt registered
[ 1.157884] Key type fscrypt-provisioning registered
[ 1.159819] Key type encrypted registered
[ 1.159821] AppArmor: AppArmor sha1 policy hashing enabled
[ 1.173636] integrity: Loading X.509 certificate: UEFI:MokListRT (MOKvar table)
[ 1.173910] integrity: Loaded X.509 cert 'Canonical Ltd. Master Certificate Authority: ad91990bc22ab1f517048c23b6655a268e345a63'
[ 1.173913] ima: No TPM chip found, activating TPM-bypass!
[ 1.173916] Loading compiled-in module X.509 certificates
[ 1.174431] Loaded X.509 cert 'Build time autogenerated kernel key: 9d82e5e7ad5edec3b7fd52847c6ba9a5bea7ed9c'
[ 1.174433] ima: Allocated hash algorithm: sha1
[ 1.174438] ima: No architecture policies found
[ 1.174445] evm: Initialising EVM extended attributes:
[ 1.174445] evm: security.selinux
[ 1.174446] evm: security.SMACK64
[ 1.174447] evm: security.SMACK64EXEC
[ 1.174447] evm: security.SMACK64TRANSMUTE
[ 1.174448] evm: security.SMACK64MMAP
[ 1.174448] evm: security.apparmor
[ 1.174449] evm: security.ima
[ 1.174449] evm: security.capability
[ 1.174450] evm: HMAC attrs: 0x1
[ 1.174733] PM: Magic number: 3:140:940
[ 1.174936] RAS: Correctable Errors collector initialized.
[ 1.175959] Freeing unused decrypted memory: 2036K
[ 1.176352] Freeing unused kernel image (initmem) memory: 3248K
[ 1.214017] Write protecting the kernel read-only data: 30720k
[ 1.214552] Freeing unused kernel image (text/rodata gap) memory: 2036K
[ 1.214774] Freeing unused kernel image (rodata/data gap) memory: 1444K
[ 1.248490] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.248492] x86/mm: Checking user space page tables
[ 1.281007] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.281010] Run /init as init process
[ 1.281011] with arguments:
[ 1.281012] /init
[ 1.281013] splash
[ 1.281014] with environment:
[ 1.281014] HOME=/
[ 1.281015] TERM=linux
[ 1.281015] BOOT_IMAGE=/boot/vmlinuz-5.15.0-78-generic
[ 1.285999] usb 1-1.1: new high-speed USB device number 3 using ehci-pci
[ 1.309994] usb 2-1.5: new full-speed USB device number 3 using ehci-pci
[ 1.334019] tsc: Refined TSC clocksource calibration: 3399.621 MHz
[ 1.334026] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x3100e91704b, max_idle_ns: 440795337747 ns
[ 1.334037] clocksource: Switched to clocksource tsc
[ 1.338730] usb 2-1.5: device descriptor read/64, error -32
[ 1.338736] fbcon: Taking over console
[ 1.338788] Console: switching to colour frame buffer device 100x37
[ 1.349520] xhci_hcd 0000:03:00.0: xHCI Host Controller
[ 1.349526] xhci_hcd 0000:03:00.0: new USB bus registered, assigned bus number 3
[ 1.349641] xhci_hcd 0000:03:00.0: hcc params 0x014042cb hci version 0x96 quirks 0x0000000000000004
[ 1.349867] xhci_hcd 0000:03:00.0: xHCI Host Controller
[ 1.349869] xhci_hcd 0000:03:00.0: new USB bus registered, assigned bus number 4
[ 1.349871] xhci_hcd 0000:03:00.0: Host supports USB 3.0 SuperSpeed
[ 1.353132] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 1.353134] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.353136] usb usb3: Product: xHCI Host Controller
[ 1.353137] usb usb3: Manufacturer: Linux 5.15.0-78-generic xhci-hcd
[ 1.353138] usb usb3: SerialNumber: 0000:03:00.0
[ 1.353232] hub 3-0:1.0: USB hub found
[ 1.353241] hub 3-0:1.0: 2 ports detected
[ 1.353322] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.353338] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[ 1.353339] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.353340] usb usb4: Product: xHCI Host Controller
[ 1.353341] usb usb4: Manufacturer: Linux 5.15.0-78-generic xhci-hcd
[ 1.353342] usb usb4: SerialNumber: 0000:03:00.0
[ 1.353396] hub 4-0:1.0: USB hub found
[ 1.353403] hub 4-0:1.0: 2 ports detected
[ 1.353541] xhci_hcd 0000:06:00.0: xHCI Host Controller
[ 1.353546] xhci_hcd 0000:06:00.0: new USB bus registered, assigned bus number 5
[ 1.353664] xhci_hcd 0000:06:00.0: hcc params 0x014042cb hci version 0x96 quirks 0x0000000000000004
[ 1.353881] xhci_hcd 0000:06:00.0: xHCI Host Controller
[ 1.353884] xhci_hcd 0000:06:00.0: new USB bus registered, assigned bus number 6
[ 1.353885] xhci_hcd 0000:06:00.0: Host supports USB 3.0 SuperSpeed
[ 1.356933] ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x000000000000057F (\_SB.PCI0.SBRG.GPBX) (20210730/utaddress-204)
[ 1.356938] ACPI: OSL: Resource conflict; ACPI support missing from driver?
[ 1.356939] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x000000000000057F (\_SB.PCI0.SBRG.GPBX) (20210730/utaddress-204)
[ 1.356941] ACPI: OSL: Resource conflict; ACPI support missing from driver?
[ 1.356942] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x000000000000057F (\_SB.PCI0.SBRG.GPBX) (20210730/utaddress-204)
[ 1.356944] ACPI: OSL: Resource conflict; ACPI support missing from driver?
[ 1.356944] lpc_ich: Resource conflict(s) found affecting gpio_ich
[ 1.357255] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 1.357257] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.357258] usb usb5: Product: xHCI Host Controller
[ 1.357259] usb usb5: Manufacturer: Linux 5.15.0-78-generic xhci-hcd
[ 1.357260] usb usb5: SerialNumber: 0000:06:00.0
[ 1.357345] hub 5-0:1.0: USB hub found
[ 1.357355] hub 5-0:1.0: 2 ports detected
[ 1.357433] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.357447] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[ 1.357448] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.357449] usb usb6: Product: xHCI Host Controller
[ 1.357450] usb usb6: Manufacturer: Linux 5.15.0-78-generic xhci-hcd
[ 1.357451] usb usb6: SerialNumber: 0000:06:00.0
[ 1.357524] hub 6-0:1.0: USB hub found
[ 1.357531] hub 6-0:1.0: 2 ports detected
[ 1.360587] ahci 0000:00:1f.2: version 3.0
[ 1.361344] i801_smbus 0000:00:1f.3: enabling device (0001 -> 0003)
[ 1.361399] i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
[ 1.361461] i2c i2c-0: 4/4 memory slots populated (from DMI)
[ 1.361765] i2c i2c-0: Successfully instantiated SPD at 0x50
[ 1.362005] r8169 0000:07:00.0 eth0: RTL8168e/8111e, f4:6d:04:99:55:51, XID 2c2, IRQ 43
[ 1.362008] r8169 0000:07:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
[ 1.362097] i2c i2c-0: Successfully instantiated SPD at 0x51
[ 1.362437] i2c i2c-0: Successfully instantiated SPD at 0x52
[ 1.362756] i2c i2c-0: Successfully instantiated SPD at 0x53
[ 1.364267] usb 1-1.1: New USB device found, idVendor=058f, idProduct=6362, bcdDevice= 1.29
[ 1.364269] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.364270] usb 1-1.1: Product: Mass Storage Device
[ 1.364271] usb 1-1.1: Manufacturer: Generic
[ 1.364271] usb 1-1.1: SerialNumber: 058F312D81B
[ 1.370749] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0x10 impl SATA mode
[ 1.370753] ahci 0000:00:1f.2: flags: 64bit ncq sntf pm led clo pio slum part ems apst
[ 1.371720] scsi host0: ahci
[ 1.371849] scsi host1: ahci
[ 1.371970] scsi host2: ahci
[ 1.372066] scsi host3: ahci
[ 1.372137] scsi host4: ahci
[ 1.372253] scsi host5: ahci
[ 1.372282] ata1: DUMMY
[ 1.372283] ata2: DUMMY
[ 1.372284] ata3: DUMMY
[ 1.372284] ata4: DUMMY
[ 1.372286] ata5: SATA max UDMA/133 abar m2048@0xfb505000 port 0xfb505300 irq 44
[ 1.372287] ata6: DUMMY
[ 1.372459] ahci 0000:0a:00.0: AHCI 0001.0000 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
[ 1.372462] ahci 0000:0a:00.0: flags: 64bit ncq sntf led only pmp fbs pio slum part sxs
[ 1.372649] scsi host6: ahci
[ 1.372715] scsi host7: ahci
[ 1.372746] ata7: SATA max UDMA/133 abar m512@0xfb110000 port 0xfb110100 irq 45
[ 1.372749] ata8: SATA max UDMA/133 abar m512@0xfb110000 port 0xfb110180 irq 45
[ 1.390675] cryptd: max_cpu_qlen set to 1000
[ 1.398397] r8169 0000:07:00.0 enp7s0: renamed from eth0
[ 1.401158] usb-storage 1-1.1:1.0: USB Mass Storage device detected
[ 1.401294] scsi host8: usb-storage 1-1.1:1.0
[ 1.401351] usbcore: registered new interface driver usb-storage
[ 1.430076] firewire_ohci 0000:09:03.0: added OHCI v1.10 device as card 0, 4 IR + 8 IT contexts, quirks 0x11
[ 1.560816] usb 2-1.5: New USB device found, idVendor=09da, idProduct=7b10, bcdDevice= 0.3b
[ 1.560819] usb 2-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.560820] usb 2-1.5: Product: USB Device
[ 1.560821] usb 2-1.5: Manufacturer: COMPANY
[ 1.566337] hid: raw HID events driver (C) Jiri Kosina
[ 1.642116] usb 2-1.6: new low-speed USB device number 4 using ehci-pci
[ 1.684421] ata8: SATA link down (SStatus 0 SControl 300)
[ 1.684458] ata7: SATA link down (SStatus 0 SControl 300)
[ 1.688476] ata5: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 1.690013] ata5.00: ATA-8: ST1000DM010-2EP102, CC43, max UDMA/133
[ 1.690169] ata5.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[ 1.691075] ata5.00: configured for UDMA/133
[ 1.691305] scsi 4:0:0:0: Direct-Access ATA ST1000DM010-2EP1 CC43 PQ: 0 ANSI: 5
[ 1.691639] sd 4:0:0:0: Attached scsi generic sg0 type 0
[ 1.691659] sd 4:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ 1.691661] sd 4:0:0:0: [sda] 4096-byte physical blocks
[ 1.691667] sd 4:0:0:0: [sda] Write Protect is off
[ 1.691668] sd 4:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.691677] sd 4:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.747157] sda: sda1 sda2 sda3 sda4 sda5 sda6
[ 1.762918] usb 2-1.6: New USB device found, idVendor=258a, idProduct=0001, bcdDevice= 1.00
[ 1.762921] usb 2-1.6: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.762931] usb 2-1.6: Product: USB KEYBOARD
[ 1.762933] usb 2-1.6: Manufacturer: SINO WEALTH
[ 1.766100] sd 4:0:0:0: [sda] Attached SCSI disk
[ 1.770222] usbcore: registered new interface driver uas
[ 1.771220] asus_wmi: ASUS WMI generic driver loaded
[ 1.772275] AVX version of gcm_enc/dec engaged.
[ 1.772294] AES CTR mode by8 optimization enabled
[ 1.786533] usbcore: registered new interface driver usbhid
[ 1.786536] usbhid: USB HID core driver
[ 1.788193] input: COMPANY USB Device as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.5/2-1.5:1.0/0003:09DA:7B10.0001/input/input2
[ 1.841997] usb 2-1.7: new full-speed USB device number 5 using ehci-pci
[ 1.846147] hid-generic 0003:09DA:7B10.0001: input,hidraw0: USB HID v1.11 Keyboard [COMPANY USB Device ] on usb-0000:00:1d.0-1.5/input0
[ 1.846244] input: COMPANY USB Device as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.5/2-1.5:1.1/0003:09DA:7B10.0002/input/input3
[ 1.846452] hid-generic 0003:09DA:7B10.0002: input,hidraw1: USB HID v1.11 Mouse [COMPANY USB Device ] on usb-0000:00:1d.0-1.5/input1
[ 1.846600] input: COMPANY USB Device Keyboard as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.5/2-1.5:1.2/0003:09DA:7B10.0003/input/input4
[ 1.906104] input: COMPANY USB Device as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.5/2-1.5:1.2/0003:09DA:7B10.0003/input/input5
[ 1.906427] hid-generic 0003:09DA:7B10.0003: input,hiddev0,hidraw2: USB HID v1.11 Keyboard [COMPANY USB Device ] on usb-0000:00:1d.0-1.5/input2
[ 1.906562] input: SINO WEALTH USB KEYBOARD as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.6/2-1.6:1.0/0003:258A:0001.0004/input/input6
[ 1.950919] usb 2-1.7: New USB device found, idVendor=0cf3, idProduct=3005, bcdDevice= 0.01
[ 1.950923] usb 2-1.7: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.966091] hid-generic 0003:258A:0001.0004: input,hidraw3: USB HID v1.10 Keyboard [SINO WEALTH USB KEYBOARD] on usb-0000:00:1d.0-1.6/input0
[ 1.966200] input: SINO WEALTH USB KEYBOARD System Control as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.6/2-1.6:1.1/0003:258A:0001.0005/input/input7
[ 2.026054] input: SINO WEALTH USB KEYBOARD Consumer Control as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.6/2-1.6:1.1/0003:258A:0001.0005/input/input8
[ 2.026110] hid-generic 0003:258A:0001.0005: input,hiddev1,hidraw4: USB HID v1.10 Device [SINO WEALTH USB KEYBOARD] on usb-0000:00:1d.0-1.6/input1
[ 2.036761] firewire_core 0000:09:03.0: created device fw0: GUID 001e8c000045d3d9, S400
[ 2.290418] nvidia: loading out-of-tree module taints kernel.
[ 2.290427] nvidia: module license 'NVIDIA' taints kernel.
[ 2.290428] Disabling lock debugging due to kernel taint
[ 2.303636] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 2.322595] nvidia-nvlink: Nvlink Core is being initialized, major device number 234
[ 2.323501] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
[ 2.414795] scsi 8:0:0:0: Direct-Access Generic USB SD Reader 1.00 PQ: 0 ANSI: 0
[ 2.415293] scsi 8:0:0:1: Direct-Access Generic USB CF Reader 1.01 PQ: 0 ANSI: 0
[ 2.415888] scsi 8:0:0:2: Direct-Access Generic USB SM Reader 1.02 PQ: 0 ANSI: 0
[ 2.416405] scsi 8:0:0:3: Direct-Access Generic USB MS Reader 1.03 PQ: 0 ANSI: 0
[ 2.416545] sd 8:0:0:0: Attached scsi generic sg1 type 0
[ 2.416662] sd 8:0:0:1: Attached scsi generic sg2 type 0
[ 2.416732] sd 8:0:0:2: Attached scsi generic sg3 type 0
[ 2.416792] sd 8:0:0:3: Attached scsi generic sg4 type 0
[ 2.417268] sd 8:0:0:0: [sdb] Media removed, stopped polling
[ 2.418033] sd 8:0:0:1: [sdc] Media removed, stopped polling
[ 2.421999] sd 8:0:0:0: [sdb] Attached SCSI removable disk
[ 2.423887] sd 8:0:0:1: [sdc] Attached SCSI removable disk
[ 2.425762] sd 8:0:0:2: [sdd] Media removed, stopped polling
[ 2.426388] sd 8:0:0:3: [sde] Media removed, stopped polling
[ 2.428262] sd 8:0:0:3: [sde] Attached SCSI removable disk
[ 2.430410] sd 8:0:0:2: [sdd] Attached SCSI removable disk
[ 2.439175] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 535.86.05 Fri Jul 14 20:46:33 UTC 2023
[ 2.455216] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 535.86.05 Fri Jul 14 20:20:58 UTC 2023
[ 2.457387] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[ 3.169711] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 0
[ 3.582732] random: lvm: uninitialized urandom read (4 bytes read)
[ 3.662991] random: lvm: uninitialized urandom read (4 bytes read)
[ 3.798003] raid6: sse2x4 gen() 19113 MB/s
[ 3.866003] raid6: sse2x4 xor() 11317 MB/s
[ 3.934002] raid6: sse2x2 gen() 19344 MB/s
[ 4.002002] raid6: sse2x2 xor() 11492 MB/s
[ 4.070002] raid6: sse2x1 gen() 17478 MB/s
[ 4.138002] raid6: sse2x1 xor() 10534 MB/s
[ 4.138003] raid6: using algorithm sse2x2 gen() 19344 MB/s
[ 4.138003] raid6: .... xor() 11492 MB/s, rmw enabled
[ 4.138004] raid6: using ssse3x2 recovery algorithm
[ 4.141234] xor: automatically using best checksumming function avx
[ 4.165661] Btrfs loaded, crc32c=crc32c-intel, zoned=yes, fsverity=yes
[ 4.505303] EXT4-fs (sda6): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 5.610550] systemd[1]: Inserted module 'autofs4'
[ 5.965538] systemd[1]: systemd 249.11-0ubuntu3.9 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[ 5.982118] systemd[1]: Detected architecture x86-64.
[ 7.050649] random: crng init done
[ 8.352888] systemd[1]: Queued start job for default target Graphical Interface.
[ 8.353799] systemd[1]: Created slice Slice /system/modprobe.
[ 8.354050] systemd[1]: Created slice Slice /system/systemd-fsck.
[ 8.354222] systemd[1]: Created slice User and Session Slice.
[ 8.354281] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 8.354410] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 8.354461] systemd[1]: Reached target User and Group Name Lookups.
[ 8.354477] systemd[1]: Reached target Remote File Systems.
[ 8.354486] systemd[1]: Reached target Slice Units.
[ 8.354512] systemd[1]: Reached target Local Verity Protected Volumes.
[ 8.354577] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 8.354656] systemd[1]: Listening on LVM2 poll daemon socket.
[ 8.367807] systemd[1]: Listening on Syslog Socket.
[ 8.369144] systemd[1]: Listening on Process Core Dump Socket.
[ 8.369215] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 8.369260] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 8.369409] systemd[1]: Listening on Journal Audit Socket.
[ 8.369482] systemd[1]: Listening on Journal Socket (/dev/log).
[ 8.369568] systemd[1]: Listening on Journal Socket.
[ 8.377240] systemd[1]: Listening on udev Control Socket.
[ 8.377327] systemd[1]: Listening on udev Kernel Socket.
[ 8.377905] systemd[1]: Mounting Huge Pages File System...
[ 8.378413] systemd[1]: Mounting POSIX Message Queue File System...
[ 8.378953] systemd[1]: Mounting Kernel Debug File System...
[ 8.379462] systemd[1]: Mounting Kernel Trace File System...
[ 8.380600] systemd[1]: Starting Journal Service...
[ 8.380726] systemd[1]: Finished Availability of block devices.
[ 8.381463] systemd[1]: Starting Set the console keyboard layout...
[ 8.382069] systemd[1]: Starting Create List of Static Device Nodes...
[ 8.382591] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 8.383219] systemd[1]: Starting Load Kernel Module chromeos_pstore...
[ 8.383877] systemd[1]: Starting Load Kernel Module configfs...
[ 8.384595] systemd[1]: Starting Load Kernel Module drm...
[ 8.385203] systemd[1]: Starting Load Kernel Module efi_pstore...
[ 8.387323] systemd[1]: Starting Load Kernel Module fuse...
[ 8.388665] systemd[1]: Starting Load Kernel Module pstore_blk...
[ 8.389300] systemd[1]: Starting Load Kernel Module pstore_zone...
[ 8.389928] systemd[1]: Starting Load Kernel Module ramoops...
[ 8.390037] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 8.391974] systemd[1]: Starting Load Kernel Modules...
[ 8.392655] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 8.393205] systemd[1]: Starting Coldplug All udev Devices...
[ 8.394725] systemd[1]: Mounted Huge Pages File System.
[ 8.394822] systemd[1]: Mounted POSIX Message Queue File System.
[ 8.394907] systemd[1]: Mounted Kernel Debug File System.
[ 8.394991] systemd[1]: Mounted Kernel Trace File System.
[ 8.402542] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 8.402699] systemd[1]: Finished Load Kernel Module configfs.
[ 8.402919] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 8.403068] systemd[1]: Finished Load Kernel Module drm.
[ 8.403672] systemd[1]: Mounting Kernel Configuration File System...
[ 8.403939] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 8.404085] systemd[1]: Finished Load Kernel Module fuse.
[ 8.404640] systemd[1]: Mounting FUSE Control File System...
[ 8.405197] systemd[1]: Mounted Kernel Configuration File System.
[ 8.405888] systemd[1]: Mounted FUSE Control File System.
[ 8.445810] systemd[1]: Finished Create List of Static Device Nodes.
[ 8.500631] pstore: Using crash dump compression: deflate
[ 8.500636] pstore: Registered efi as persistent store backend
[ 8.501060] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[ 8.501213] systemd[1]: Finished Load Kernel Module efi_pstore.
[ 8.530186] systemd[1]: modprobe@pstore_zone.service: Deactivated successfully.
[ 8.530326] systemd[1]: Finished Load Kernel Module pstore_zone.
[ 8.532108] systemd[1]: modprobe@pstore_blk.service: Deactivated successfully.
[ 8.532249] systemd[1]: Finished Load Kernel Module pstore_blk.
[ 8.534030] systemd[1]: modprobe@ramoops.service: Deactivated successfully.
[ 8.534166] systemd[1]: Finished Load Kernel Module ramoops.
[ 8.570544] systemd[1]: modprobe@chromeos_pstore.service: Deactivated successfully.
[ 8.570714] systemd[1]: Finished Load Kernel Module chromeos_pstore.
[ 8.586580] systemd[1]: Started Journal Service.
[ 8.699476] EXT4-fs (sda6): re-mounted. Opts: errors=remount-ro. Quota mode: none.
[ 8.729670] systemd-journald[394]: Received client request to flush runtime journal.
[ 8.965379] lp: driver loaded but no devices found
[ 9.070102] ppdev: user-space parallel port driver
[ 9.260058] Adding 2097148k swap on /swapfile. Priority:-2 extents:6 across:2260988k FS
[ 11.902188] nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
[ 11.905938] nvidia-uvm: Loaded the UVM driver, major device number 510.
[ 11.923082] asus_wmi: Initialization: 0x0
[ 11.923108] asus_wmi: BIOS WMI version: 0.9
[ 11.923146] asus_wmi: SFUN value: 0x0
[ 11.923148] eeepc-wmi eeepc-wmi: Detected ASUSWMI, use DCTS
[ 11.923654] input: Eee PC WMI hotkeys as /devices/platform/eeepc-wmi/input/input9
[ 11.946662] RAPL PMU: API unit is 2^-32 Joules, 2 fixed counters, 163840 ms ovfl timer
[ 11.946665] RAPL PMU: hw unit of domain pp0-core 2^-16 Joules
[ 11.946666] RAPL PMU: hw unit of domain package 2^-16 Joules
[ 12.443279] at24 0-0050: supply vcc not found, using dummy regulator
[ 12.443840] at24 0-0050: 256 byte spd EEPROM, read-only
[ 12.443855] at24 0-0051: supply vcc not found, using dummy regulator
[ 12.444394] at24 0-0051: 256 byte spd EEPROM, read-only
[ 12.444405] at24 0-0052: supply vcc not found, using dummy regulator
[ 12.444942] at24 0-0052: 256 byte spd EEPROM, read-only
[ 12.444952] at24 0-0053: supply vcc not found, using dummy regulator
[ 12.445488] at24 0-0053: 256 byte spd EEPROM, read-only
[ 12.646544] intel_rapl_common: Found RAPL domain package
[ 12.646548] intel_rapl_common: Found RAPL domain core
[ 12.646552] intel_rapl_common: RAPL package-0 domain package locked by BIOS
[ 12.850463] Bluetooth: Core ver 2.22
[ 12.850482] NET: Registered PF_BLUETOOTH protocol family
[ 12.850483] Bluetooth: HCI device and connection manager initialized
[ 12.850486] Bluetooth: HCI socket layer initialized
[ 12.850487] Bluetooth: L2CAP socket layer initialized
[ 12.850490] Bluetooth: SCO socket layer initialized
[ 13.054704] usbcore: registered new interface driver btusb
[ 13.278279] snd_hda_intel 0000:00:1b.0: enabling device (0000 -> 0002)
[ 13.278577] snd_hda_intel 0000:01:00.1: Disabling MSI
[ 13.278581] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[ 13.318632] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input10
[ 13.318677] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input11
[ 13.318709] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input12
[ 13.318736] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input13
[ 13.318763] input: HDA NVidia HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input14
[ 13.318801] input: HDA NVidia HDMI/DP,pcm=11 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input15
[ 13.318833] input: HDA NVidia HDMI/DP,pcm=12 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input16
[ 13.515067] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC892: line_outs=4 (0x14/0x15/0x16/0x17/0x0) type:line
[ 13.515077] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 13.515081] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[ 13.515084] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 13.515086] snd_hda_codec_realtek hdaudioC0D0: dig-out=0x11/0x1e
[ 13.515088] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 13.515091] snd_hda_codec_realtek hdaudioC0D0: Front Mic=0x19
[ 13.515094] snd_hda_codec_realtek hdaudioC0D0: Rear Mic=0x18
[ 13.515096] snd_hda_codec_realtek hdaudioC0D0: Line=0x1a
[ 13.529425] input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input17
[ 13.529482] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input18
[ 13.529523] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input19
[ 13.529553] input: HDA Intel PCH Line Out Front as /devices/pci0000:00/0000:00:1b.0/sound/card0/input20
[ 13.529587] input: HDA Intel PCH Line Out Surround as /devices/pci0000:00/0000:00:1b.0/sound/card0/input21
[ 13.529616] input: HDA Intel PCH Line Out CLFE as /devices/pci0000:00/0000:00:1b.0/sound/card0/input22
[ 13.529653] input: HDA Intel PCH Line Out Side as /devices/pci0000:00/0000:00:1b.0/sound/card0/input23
[ 13.529680] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input24
[ 16.342718] ZFS: Loaded module v2.1.5-1ubuntu6~22.04.1, ZFS pool version 5000, ZFS filesystem version 5
[ 18.532656] audit: type=1400 audit(1691679328.498:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=848 comm="apparmor_parser"
[ 18.532973] audit: type=1400 audit(1691679328.498:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=849 comm="apparmor_parser"
[ 18.532975] audit: type=1400 audit(1691679328.498:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=849 comm="apparmor_parser"
[ 18.641594] audit: type=1400 audit(1691679328.606:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=866 comm="apparmor_parser"
[ 18.641598] audit: type=1400 audit(1691679328.606:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=866 comm="apparmor_parser"
[ 18.641600] audit: type=1400 audit(1691679328.606:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=866 comm="apparmor_parser"
[ 18.878571] audit: type=1400 audit(1691679328.846:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="tcpdump" pid=868 comm="apparmor_parser"
[ 18.898615] audit: type=1400 audit(1691679328.866:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-oosplash" pid=871 comm="apparmor_parser"
[ 18.900006] audit: type=1400 audit(1691679328.866:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/redshift" pid=867 comm="apparmor_parser"
[ 18.900978] audit: type=1400 audit(1691679328.866:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-senddoc" pid=872 comm="apparmor_parser"
[ 21.918513] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 21.918516] Bluetooth: BNEP filters: protocol multicast
[ 21.918520] Bluetooth: BNEP socket layer initialized
[ 22.058242] NET: Registered PF_ALG protocol family
[ 25.847492] RTL8211DN Gigabit Ethernet r8169-0-700:00: attached PHY driver (mii_bus:phy_addr=r8169-0-700:00, irq=MAC)
[ 26.126656] r8169 0000:07:00.0 enp7s0: Link is Down
[ 27.196433] kauditd_printk_skb: 13 callbacks suppressed
[ 27.196439] audit: type=1400 audit(1691679337.162:25): apparmor="DENIED" operation="capable" profile="/usr/sbin/cupsd" pid=1119 comm="cupsd" capability=12 capname="net_admin"
[ 28.083318] r8169 0000:07:00.0 enp7s0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 28.083329] IPv6: ADDRCONF(NETDEV_CHANGE): enp7s0: link becomes ready
[ 38.140210] audit: type=1400 audit(1691679348.106:26): apparmor="DENIED" operation="capable" profile="/usr/sbin/cups-browsed" pid=1287 comm="cups-browsed" capability=23 capname="sys_nice"
[ 87.302116] [UFW BLOCK] IN=enp7s0 OUT= MAC=f4:6d:04:99:55:51:74:a7:8e:cd:fe:d0:08:00 SRC=62.217.191.2 DST=192.168.0.6 LEN=52 TOS=0x00 PREC=0x00 TTL=121 ID=40913 DF PROTO=TCP SPT=20527 DPT=31992 WINDOW=64240 RES=0x00 SYN URGP=0
[ 88.290377] [UFW BLOCK] IN=enp7s0 OUT= MAC=f4:6d:04:99:55:51:74:a7:8e:cd:fe:d0:08:00 SRC=62.217.191.2 DST=192.168.0.6 LEN=52 TOS=0x00 PREC=0x00 TTL=121 ID=40914 DF PROTO=TCP SPT=20527 DPT=31992 WINDOW=64240 RES=0x00 SYN URGP=0
[ 90.289993] [UFW BLOCK] IN=enp7s0 OUT= MAC=f4:6d:04:99:55:51:74:a7:8e:cd:fe:d0:08:00 SRC=62.217.191.2 DST=192.168.0.6 LEN=52 TOS=0x00 PREC=0x00 TTL=121 ID=40915 DF PROTO=TCP SPT=20527 DPT=31992 WINDOW=64240 RES=0x00 SYN URGP=0
[ 94.294725] [UFW BLOCK] IN=enp7s0 OUT= MAC=f4:6d:04:99:55:51:74:a7:8e:cd:fe:d0:08:00 SRC=62.217.191.2 DST=192.168.0.6 LEN=52 TOS=0x00 PREC=0x00 TTL=121 ID=40916 DF PROTO=TCP SPT=20527 DPT=31992 WINDOW=64240 RES=0x00 SYN URGP=0
[ 102.297289] [UFW BLOCK] IN=enp7s0 OUT= MAC=f4:6d:04:99:55:51:74:a7:8e:cd:fe:d0:08:00 SRC=62.217.191.2 DST=192.168.0.6 LEN=52 TOS=0x00 PREC=0x00 TTL=121 ID=40917 DF PROTO=TCP SPT=20527 DPT=31992 WINDOW=64240 RES=0x00 SYN URGP=0
[ 179.804005] [UFW BLOCK] IN=enp7s0 OUT= MAC=f4:6d:04:99:55:51:74:a7:8e:cd:fe:d0:08:00 SRC=91.239.112.25 DST=192.168.0.6 LEN=52 TOS=0x00 PREC=0x00 TTL=120 ID=17862 DF PROTO=TCP SPT=51092 DPT=31992 WINDOW=64240 RES=0x00 SYN URGP=0
[ 180.803597] [UFW BLOCK] IN=enp7s0 OUT= MAC=f4:6d:04:99:55:51:74:a7:8e:cd:fe:d0:08:00 SRC=91.239.112.25 DST=192.168.0.6 LEN=52 TOS=0x00 PREC=0x00 TTL=120 ID=17863 DF PROTO=TCP SPT=51092 DPT=31992 WINDOW=64240 RES=0x00 SYN URGP=0
[ 182.802798] [UFW BLOCK] IN=enp7s0 OUT= MAC=f4:6d:04:99:55:51:74:a7:8e:cd:fe:d0:08:00 SRC=91.239.112.25 DST=192.168.0.6 LEN=52 TOS=0x00 PREC=0x00 TTL=120 ID=17864 DF PROTO=TCP SPT=51092 DPT=31992 WINDOW=64240 RES=0x00 SYN URGP=0
[ 186.803456] [UFW BLOCK] IN=enp7s0 OUT= MAC=f4:6d:04:99:55:51:74:a7:8e:cd:fe:d0:08:00 SRC=91.239.112.25 DST=192.168.0.6 LEN=52 TOS=0x00 PREC=0x00 TTL=120 ID=17865 DF PROTO=TCP SPT=51092 DPT=31992 WINDOW=64240 RES=0x00 SYN URGP=0
[ 187.234954] [UFW BLOCK] IN=enp7s0 OUT= MAC=f4:6d:04:99:55:51:74:a7:8e:cd:fe:d0:08:00 SRC=171.33.253.208 DST=192.168.0.6 LEN=52 TOS=0x00 PREC=0x00 TTL=119 ID=22642 DF PROTO=TCP SPT=26818 DPT=31992 WINDOW=64240 RES=0x00 SYN URGP=0
[ 188.250673] [UFW BLOCK] IN=enp7s0 OUT= MAC=f4:6d:04:99:55:51:74:a7:8e:cd:fe:d0:08:00 SRC=171.33.253.208 DST=192.168.0.6 LEN=52 TOS=0x00 PREC=0x00 TTL=119 ID=22643 DF PROTO=TCP SPT=26818 DPT=31992 WINDOW=64240 RES=0x00 SYN URGP=0
[ 190.256638] [UFW BLOCK] IN=enp7s0 OUT= MAC=f4:6d:04:99:55:51:74:a7:8e:cd:fe:d0:08:00 SRC=171.33.253.208 DST=192.168.0.6 LEN=52 TOS=0x00 PREC=0x00 TTL=119 ID=22644 DF PROTO=TCP SPT=26818 DPT=31992 WINDOW=64240 RES=0x00 SYN URGP=0
[ 194.264654] [UFW BLOCK] IN=enp7s0 OUT= MAC=f4:6d:04:99:55:51:74:a7:8e:cd:fe:d0:08:00 SRC=171.33.253.208 DST=192.168.0.6 LEN=52 TOS=0x00 PREC=0x00 TTL=119 ID=22645 DF PROTO=TCP SPT=26818 DPT=31992 WINDOW=64240 RES=0x00 SYN URGP=0
[ 194.803106] [UFW BLOCK] IN=enp7s0 OUT= MAC=f4:6d:04:99:55:51:74:a7:8e:cd:fe:d0:08:00 SRC=91.239.112.25 DST=192.168.0.6 LEN=52 TOS=0x00 PREC=0x00 TTL=120 ID=17866 DF PROTO=TCP SPT=51092 DPT=31992 WINDOW=64240 RES=0x00 SYN URGP=0
[ 202.286975] [UFW BLOCK] IN=enp7s0 OUT= MAC=f4:6d:04:99:55:51:74:a7:8e:cd:fe:d0:08:00 SRC=171.33.253.208 DST=192.168.0.6 LEN=52 TOS=0x00 PREC=0x00 TTL=119 ID=22646 DF PROTO=TCP SPT=26818 DPT=31992 WINDOW=64240 RES=0x00 SYN URGP=0
[ 210.730166] [UFW BLOCK] IN=enp7s0 OUT= MAC=f4:6d:04:99:55:51:74:a7:8e:cd:fe:d0:08:00 SRC=185.90.102.45 DST=192.168.0.6 LEN=52 TOS=0x00 PREC=0x00 TTL=119 ID=7715 DF PROTO=TCP SPT=57446 DPT=31992 WINDOW=64240 RES=0x00 SYN URGP=0
[ 294.538251] [UFW BLOCK] IN=enp7s0 OUT= MAC=f4:6d:04:99:55:51:74:a7:8e:cd:fe:d0:08:00 SRC=62.217.191.2 DST=192.168.0.6 LEN=52 TOS=0x00 PREC=0x00 TTL=121 ID=40918 DF PROTO=TCP SPT=19613 DPT=31992 WINDOW=64240 RES=0x00 SYN URGP=0
[ 295.519362] [UFW BLOCK] IN=enp7s0 OUT= MAC=f4:6d:04:99:55:51:74:a7:8e:cd:fe:d0:08:00 SRC=62.217.191.2 DST=192.168.0.6 LEN=52 TOS=0x00 PREC=0x00 TTL=121 ID=40919 DF PROTO=TCP SPT=19613 DPT=31992 WINDOW=64240 RES=0x00 SYN URGP=0
[ 297.520443] [UFW BLOCK] IN=enp7s0 OUT= MAC=f4:6d:04:99:55:51:74:a7:8e:cd:fe:d0:08:00 SRC=62.217.191.2 DST=192.168.0.6 LEN=52 TOS=0x00 PREC=0x00 TTL=121 ID=40920 DF PROTO=TCP SPT=19613 DPT=31992 WINDOW=64240 RES=0x00 SYN URGP=0
[ 301.523664] [UFW BLOCK] IN=enp7s0 OUT= MAC=f4:6d:04:99:55:51:74:a7:8e:cd:fe:d0:08:00 SRC=62.217.191.2 DST=192.168.0.6 LEN=52 TOS=0x00 PREC=0x00 TTL=121 ID=40921 DF PROTO=TCP SPT=19613 DPT=31992 WINDOW=64240 RES=0x00 SYN URGP=0
[ 309.523685] [UFW BLOCK] IN=enp7s0 OUT= MAC=f4:6d:04:99:55:51:74:a7:8e:cd:fe:d0:08:00 SRC=62.217.191.2 DST=192.168.0.6 LEN=52 TOS=0x00 PREC=0x00 TTL=121 ID=40922 DF PROTO=TCP SPT=19613 DPT=31992 WINDOW=64240 RES=0x00 SYN URGP=0
[ 328.842232] [UFW BLOCK] IN=enp7s0 OUT= MAC=f4:6d:04:99:55:51:74:a7:8e:cd:fe:d0:08:00 SRC=171.33.253.208 DST=192.168.0.6 LEN=52 TOS=0x00 PREC=0x00 TTL=119 ID=10964 DF PROTO=TCP SPT=26819 DPT=31992 WINDOW=64240 RES=0x00 SYN URGP=0
[ 353.874722] [UFW BLOCK] IN=enp7s0 OUT= MAC=f4:6d:04:99:55:51:74:a7:8e:cd:fe:d0:08:00 SRC=185.90.102.45 DST=192.168.0.6 LEN=52 TOS=0x00 PREC=0x00 TTL=119 ID=7720 DF PROTO=TCP SPT=58208 DPT=31992 WINDOW=64240 RES=0x00 SYN URGP=0
[ 468.265881] [UFW BLOCK] IN=enp7s0 OUT= MAC=f4:6d:04:99:55:51:74:a7:8e:cd:fe:d0:08:00 SRC=125.164.217.72 DST=192.168.0.6 LEN=52 TOS=0x00 PREC=0x00 TTL=116 ID=11976 DF PROTO=TCP SPT=54065 DPT=31992 WINDOW=8192 RES=0x00 SYN URGP=0
[ 471.266366] [UFW BLOCK] IN=enp7s0 OUT= MAC=f4:6d:04:99:55:51:74:a7:8e:cd:fe:d0:08:00 SRC=125.164.217.72 DST=192.168.0.6 LEN=52 TOS=0x00 PREC=0x00 TTL=116 ID=12066 DF PROTO=TCP SPT=54065 DPT=31992 WINDOW=8192 RES=0x00 SYN URGP=0
[ 477.266559] [UFW BLOCK] IN=enp7s0 OUT= MAC=f4:6d:04:99:55:51:74:a7:8e:cd:fe:d0:08:00 SRC=125.164.217.72 DST=192.168.0.6 LEN=48 TOS=0x00 PREC=0x00 TTL=116 ID=12137 DF PROTO=TCP SPT=54065 DPT=31992 WINDOW=8192 RES=0x00 SYN URGP=0
[ 511.866706] [UFW BLOCK] IN=enp7s0 OUT= MAC=f4:6d:04:99:55:51:74:a7:8e:cd:fe:d0:08:00 SRC=111.88.34.110 DST=192.168.0.6 LEN=52 TOS=0x00 PREC=0x00 TTL=114 ID=20214 DF PROTO=TCP SPT=32862 DPT=31992 WINDOW=8192 RES=0x00 SYN URGP=0
[ 514.849701] [UFW BLOCK] IN=enp7s0 OUT= MAC=f4:6d:04:99:55:51:74:a7:8e:cd:fe:d0:08:00 SRC=111.88.34.110 DST=192.168.0.6 LEN=52 TOS=0x00 PREC=0x00 TTL=114 ID=22487 DF PROTO=TCP SPT=32862 DPT=31992 WINDOW=8192 RES=0x00 SYN URGP=0
[ 520.343253] [UFW BLOCK] IN=enp7s0 OUT= MAC=f4:6d:04:99:55:51:74:a7:8e:cd:fe:d0:08:00 SRC=171.33.253.208 DST=192.168.0.6 LEN=52 TOS=0x00 PREC=0x00 TTL=119 ID=14628 DF PROTO=TCP SPT=26818 DPT=31992 WINDOW=64240 RES=0x00 SYN URGP=0
[ 520.855902] [UFW BLOCK] IN=enp7s0 OUT= MAC=f4:6d:04:99:55:51:74:a7:8e:cd:fe:d0:08:00 SRC=111.88.34.110 DST=192.168.0.6 LEN=48 TOS=0x00 PREC=0x00 TTL=114 ID=26847 DF PROTO=TCP SPT=32862 DPT=31992 WINDOW=8192 RES=0x00 SYN URGP=0
[ 521.353325] [UFW BLOCK] IN=enp7s0 OUT= MAC=f4:6d:04:99:55:51:74:a7:8e:cd:fe:d0:08:00 SRC=171.33.253.208 DST=192.168.0.6 LEN=52 TOS=0x00 PREC=0x00 TTL=119 ID=14629 DF PROTO=TCP SPT=26818 DPT=31992 WINDOW=64240 RES=0x00 SYN URGP=0
[ 527.367014] [UFW BLOCK] IN=enp7s0 OUT= MAC=f4:6d:04:99:55:51:74:a7:8e:cd:fe:d0:08:00 SRC=171.33.253.208 DST=192.168.0.6 LEN=52 TOS=0x00 PREC=0x00 TTL=119 ID=14631 DF PROTO=TCP SPT=26818 DPT=31992 WINDOW=64240 RES=0x00 SYN URGP=0
[ 549.082302] [UFW BLOCK] IN=enp7s0 OUT= MAC=f4:6d:04:99:55:51:74:a7:8e:cd:fe:d0:08:00 SRC=185.90.102.45 DST=192.168.0.6 LEN=52 TOS=0x00 PREC=0x00 TTL=119 ID=7724 DF PROTO=TCP SPT=59232 DPT=31992 WINDOW=64240 RES=0x00 SYN URGP=0
[ 617.245091] [UFW BLOCK] IN=enp7s0 OUT= MAC=f4:6d:04:99:55:51:74:a7:8e:cd:fe:d0:08:00 SRC=196.190.222.91 DST=192.168.0.6 LEN=52 TOS=0x00 PREC=0x00 TTL=112 ID=22740 DF PROTO=TCP SPT=30462 DPT=31992 WINDOW=64240 RES=0x00 SYN URGP=0
[ 620.186504] [UFW BLOCK] IN=enp7s0 OUT= MAC=f4:6d:04:99:55:51:74:a7:8e:cd:fe:d0:08:00 SRC=196.190.222.91 DST=192.168.0.6 LEN=52 TOS=0x00 PREC=0x00 TTL=112 ID=22741 DF PROTO=TCP SPT=30462 DPT=31992 WINDOW=64240 RES=0x00 SYN URGP=0
[ 626.194641] [UFW BLOCK] IN=enp7s0 OUT= MAC=f4:6d:04:99:55:51:74:a7:8e:cd:fe:d0:08:00 SRC=196.190.222.91 DST=192.168.0.6 LEN=52 TOS=0x00 PREC=0x00 TTL=112 ID=22742 DF PROTO=TCP SPT=30462 DPT=31992 WINDOW=64240 RES=0x00 SYN URGP=0
[ 647.409469] [UFW BLOCK] IN=enp7s0 OUT= MAC=f4:6d:04:99:55:51:74:a7:8e:cd:fe:d0:08:00 SRC=111.88.34.110 DST=192.168.0.6 LEN=52 TOS=0x00 PREC=0x00 TTL=114 ID=15865 DF PROTO=TCP SPT=32474 DPT=31992 WINDOW=8192 RES=0x00 SYN URGP=0
[ 650.412636] [UFW BLOCK] IN=enp7s0 OUT= MAC=f4:6d:04:99:55:51:74:a7:8e:cd:fe:d0:08:00 SRC=111.88.34.110 DST=192.168.0.6 LEN=52 TOS=0x00 PREC=0x00 TTL=114 ID=16132 DF PROTO=TCP SPT=32474 DPT=31992 WINDOW=8192 RES=0x00 SYN URGP=0
[ 853.860520] [UFW BLOCK] IN=enp7s0 OUT= MAC=f4:6d:04:99:55:51:74:a7:8e:cd:fe:d0:08:00 SRC=111.88.34.110 DST=192.168.0.6 LEN=52 TOS=0x00 PREC=0x00 TTL=114 ID=27494 DF PROTO=TCP SPT=32205 DPT=31992 WINDOW=8192 RES=0x00 SYN URGP=0
[ 856.853123] [UFW BLOCK] IN=enp7s0 OUT= MAC=f4:6d:04:99:55:51:74:a7:8e:cd:fe:d0:08:00 SRC=111.88.34.110 DST=192.168.0.6 LEN=52 TOS=0x00 PREC=0x00 TTL=114 ID=27677 DF PROTO=TCP SPT=32205 DPT=31992 WINDOW=8192 RES=0x00 SYN URGP=0
[ 862.857208] [UFW BLOCK] IN=enp7s0 OUT= MAC=f4:6d:04:99:55:51:74:a7:8e:cd:fe:d0:08:00 SRC=111.88.34.110 DST=192.168.0.6 LEN=48 TOS=0x00 PREC=0x00 TTL=114 ID=27964 DF PROTO=TCP SPT=32205 DPT=31992 WINDOW=8192 RES=0x00 SYN URGP=0
[ 973.151299] Bluetooth: RFCOMM TTY layer initialized
[ 973.151307] Bluetooth: RFCOMM socket layer initialized
[ 973.151312] Bluetooth: RFCOMM ver 1.11
[ 999.735840] [UFW BLOCK] IN=enp7s0 OUT= MAC=f4:6d:04:99:55:51:74:a7:8e:cd:fe:d0:08:00 SRC=196.190.222.91 DST=192.168.0.6 LEN=52 TOS=0x00 PREC=0x00 TTL=112 ID=22772 DF PROTO=TCP SPT=29933 DPT=31992 WINDOW=64240 RES=0x00 SYN URGP=0
[ 1002.775675] [UFW BLOCK] IN=enp7s0 OUT= MAC=f4:6d:04:99:55:51:74:a7:8e:cd:fe:d0:08:00 SRC=196.190.222.91 DST=192.168.0.6 LEN=52 TOS=0x00 PREC=0x00 TTL=112 ID=22774 DF PROTO=TCP SPT=29933 DPT=31992 WINDOW=64240 RES=0x00 SYN URGP=0
[ 1008.738081] [UFW BLOCK] IN=enp7s0 OUT= MAC=f4:6d:04:99:55:51:74:a7:8e:cd:fe:d0:08:00 SRC=196.190.222.91 DST=192.168.0.6 LEN=52 TOS=0x00 PREC=0x00 TTL=112 ID=22776 DF PROTO=TCP SPT=29933 DPT=31992 WINDOW=64240 RES=0x00 SYN URGP=0
[ 1022.195857] [UFW BLOCK] IN=enp7s0 OUT= MAC=f4:6d:04:99:55:51:74:a7:8e:cd:fe:d0:08:00 SRC=91.240.112.159 DST=192.168.0.6 LEN=52 TOS=0x00 PREC=0x00 TTL=117 ID=36271 DF PROTO=TCP SPT=50307 DPT=31992 WINDOW=64240 RES=0x00 SYN URGP=0
[ 1023.199264] [UFW BLOCK] IN=enp7s0 OUT= MAC=f4:6d:04:99:55:51:74:a7:8e:cd:fe:d0:08:00 SRC=91.240.112.159 DST=192.168.0.6 LEN=52 TOS=0x00 PREC=0x00 TTL=117 ID=36272 DF PROTO=TCP SPT=50307 DPT=31992 WINDOW=64240 RES=0x00 SYN URGP=0
[ 1035.209608] [UFW BLOCK] IN=enp7s0 OUT= MAC=f4:6d:04:99:55:51:74:a7:8e:cd:fe:d0:08:00 SRC=91.240.112.159 DST=192.168.0.6 LEN=52 TOS=0x00 PREC=0x00 TTL=117 ID=42350 DF PROTO=TCP SPT=52742 DPT=31992 WINDOW=64240 RES=0x00 SYN URGP=0
[ 1036.210601] [UFW BLOCK] IN=enp7s0 OUT= MAC=f4:6d:04:99:55:51:74:a7:8e:cd:fe:d0:08:00 SRC=91.240.112.159 DST=192.168.0.6 LEN=52 TOS=0x00 PREC=0x00 TTL=117 ID=42351 DF PROTO=TCP SPT=52742 DPT=31992 WINDOW=64240 RES=0x00 SYN URGP=0
[ 1038.215368] [UFW BLOCK] IN=enp7s0 OUT= MAC=f4:6d:04:99:55:51:74:a7:8e:cd:fe:d0:08:00 SRC=91.240.112.159 DST=192.168.0.6 LEN=52 TOS=0x00 PREC=0x00 TTL=117 ID=42352 DF PROTO=TCP SPT=52742 DPT=31992 WINDOW=64240 RES=0x00 SYN URGP=0
[ 1042.221067] [UFW BLOCK] IN=enp7s0 OUT= MAC=f4:6d:04:99:55:51:74:a7:8e:cd:fe:d0:08:00 SRC=91.240.112.159 DST=192.168.0.6 LEN=52 TOS=0x00 PREC=0x00 TTL=117 ID=42353 DF PROTO=TCP SPT=52742 DPT=31992 WINDOW=64240 RES=0x00 SYN URGP=0
[ 1050.222900] [UFW BLOCK] IN=enp7s0 OUT= MAC=f4:6d:04:99:55:51:74:a7:8e:cd:fe:d0:08:00 SRC=91.240.112.159 DST=192.168.0.6 LEN=52 TOS=0x00 PREC=0x00 TTL=117 ID=42354 DF PROTO=TCP SPT=52742 DPT=31992 WINDOW=64240 RES=0x00 SYN URGP=0
Aktavius
Прерывается звук
#22
10 авг 2023, 18:25
Ара Магеддон,
1. С флешки в Live-режиме все так же. Но там у PulseAudio стоит yes
4. В Винде все работает нормально
Ара Магеддон
Решено: 18
Благодарил (а): 37 раз
Прерывается звук
#23
10 авг 2023, 19:00
У меня идей уже нет, разве что ядро поновей установить (Менеджер обновлений > Правка > Ядра Linux). Обычно это имеет смысл для нового оборудовния, но могли какой багфикс для Alsa завезти.
Aktavius
Прерывается звук
#24
10 авг 2023, 19:05
Ара Магеддон писал(а):
10 авг 2023, 19:00
Это ведь не повредит файлы и все прочее?
Ара Магеддон
Решено: 18
Прерывается звук
#25
10 авг 2023, 19:06
Aktavius писал(а):
10 авг 2023, 19:05
Практически исключено. Плюс, всегда можно вернуться на старое ядро.
Aktavius
Прерывается звук
#26
10 авг 2023, 19:34
Установил ядро 6.2.0-26 ничего не изменилось
Прерывается звук
#27
11 авг 2023, 08:07
Aktavius, а это?
Dja писал(а):
10 авг 2023, 17:03
я бы прописал данную команду в автозагрузку!
Aktavius
Прерывается звук
#28
11 авг 2023, 12:06
Dja, а как это сделать? Я только осваиваю линукс и слабо представляю как это делать.
Если нужно ввести
pulseaudio -D
то это не помогло
Прерывается звук
#29
11 авг 2023, 13:23
Aktavius писал(а):
10 авг 2023, 16:56
Dja, я вводил следуещие команды, проверял, он запускался, но после перезагруски системы опять слетел
sudo apt-get install pulseaudio
pulseaudio --start -D
Здесь вы написали, что помогло, но до перезагрузки!
Прерывается звук
#30
11 авг 2023, 13:25
Aktavius писал(а):
11 авг 2023, 12:06
Соответственно ту команду, которая нужна!
SHERI_FFF
Благодарил (а): 33 раза
Прерывается звук
#31
11 авг 2023, 14:32
Модераторы, исправьте наконец-то заголовок - прЕрывается, прЕрывается, прЕрывается...
Аж глаза режет :gun2:
________________________
Команды могу только копировать :hoho:
Ноутбук Acer Aspire 5 с Manjaro inxi -Fxz
ПК с Manjaro inxi -Fxz
