Проблемы с загрузкой
John-1
#21
12 май 2020, 17:50
Вот инфа по железу
root@mint:/home/mint# inxi -Fxz
  Host: mint Kernel: 5.0.0-32-generic i686 bits: 32 compiler: gcc v: 7.4.0
  Desktop: MATE 1.22.2 Distro: Linux Mint 19.3 Tricia
  base: Ubuntu 18.04 bionic
  Type: Laptop System: Infomash product: RoverBook v: N/A serial: <filter>
  Mobo: Intel model: MPAD-MSAE Customer Reference Boards serial: N/A
  BIOS: Phoenix v: NAPA0001.86C.0000.X.0000000000 date: 04/07/2006
  ID-1: BAT0 charge: 25.0 Wh condition: 25.0/48.8 Wh (51%)
  model: FIC 46EA0/ECZJG status: Full
  Topology: Dual Core model: Intel T2300 bits: 32 type: MCP arch: M Yonah
  rev: 8 L2 cache: 2048 KiB
  flags: nx pae sse sse2 sse3 vmx bogomips: 6649
  Speed: 998 MHz min/max: 1000/1667 MHz Core speeds (MHz): 1: 998 2: 997
  Device-1: Intel Mobile 945GM/GMS 943/940GML Express Integrated Graphics
  vendor: FIRST driver: i915 v: kernel bus ID: 00:02.0
  Display: server: X.Org 1.20.4 driver: intel
  unloaded: fbdev,modesetting,vesa resolution: 1280x800~60Hz
  OpenGL: renderer: Mesa DRI Intel 945GM x86/MMX/SSE2 v: 1.4 Mesa 19.0.8
  Device-1: Intel NM10/ICH7 Family High Definition Audio vendor: FIRST
  Device-1: Realtek RTL8723BE PCIe Wireless Network Adapter
  driver: rtl8723be v: kernel port: 2000 bus ID: 03:00.0
  Device-2: Broadcom and subsidiaries BCM4401-B0 100Base-TX vendor: FIRST
  driver: b44 v: 2.0 port: 2000 bus ID: 07:0d.0
  IF-ID-1: eth0 state: down mac: <filter>
  Local Storage: total: 7.50 GiB used: 2.19 GiB (29.2%)
  ID-1: /dev/sdb type: USB vendor: Generic model: Flash Disk size: 7.50 GiB
  ID-1: / size: 964.7 MiB used: 256.9 MiB (26.6%) fs: overlay
  source: ERR-102
  System Temperatures: cpu: 44.0 C mobo: N/A
  Processes: 169 Uptime: 52m Memory: 1.88 GiB used: 693.4 MiB (35.9%)
  inxi: 3.0.32
#22
12 май 2020, 17:55
John-1, вот перевод красной надписи. -- диск может скоро выйти из строя.
Кстати инфа неправильная , видимо иск снова заклинило. Снова гпартедом восстанови таблицу и повтори вывод железа. А с диском проблемы.
John-1
#23
12 май 2020, 17:58
А он теперь в гпартед неопределяется..
#24
12 май 2020, 17:58
John-1 писал(а):
12 май 2020, 17:58
скрииииииннн
John-1
#25
12 май 2020, 18:04
В выпадающем списке в правом верхнем углу, его нет
#26
12 май 2020, 18:07
John-1, Зер шлехт. Посмотри ещё раз sudo fdisk -l и если ничего не покажет , то перезагрузись в биос , помотри диск там и снова загрузись с флешки.
John-1
#27
12 май 2020, 18:10
mint@mint:~$ sudo fdisk -l
Disk /dev/loop0: 1.9 GiB, 2005463040 bytes, 3916920 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
Disk /dev/sdb: 7.5 GiB, 8054112256 bytes, 15730688 sectors
Disklabel type: dos
Disk identifier: 0x0f000837
Device     Boot Start      End  Sectors  Size Id Type
/dev/sdb1  *     2048 15730687 15728640  7.5G  c W95 FAT32 (LBA)
Буду перезагружаться...
#28
12 май 2020, 18:17
John-1, 1000 извинений что не в тему, но дико свербит ниже спины... А как этот бук себя чувствует под Windows10?
#29
12 май 2020, 18:18
di_mok, Судя по буку , ему не до десятки))
John-1
#30
12 май 2020, 18:23
Биос диск видит, но после загрузки биоса выдаёт какую то ошибку диска, нажимаю F1 и далее нормально загружаюсь с флешки..
#31
12 май 2020, 18:24
12 май 2020, 18:18
ему не до десятки))
Ога, а для Mint 19.3, да ещё с Cinnamon - он огурчик :-D Win10 - 2015гв, LM19.3 - 2020гв. Что-то мне подсказывает, что тут классика жанра - гуглёжка на тему "Linux для старого компьютера", и жирный крест на LM19.x
#32
12 май 2020, 18:25
И что сейчас показывает sudo fdisk -l и гпартед.
#33
12 май 2020, 18:26
di_mok, а диск убивается тоже от этого?
John-1
#34
12 май 2020, 18:28
12 май 2020, 18:25
Снова видят диск...
root@mint:/home/mint# fdisk -l
Disk /dev/sda: 55.9 GiB, 60011642880 bytes, 117210240 sectors
Disklabel type: dos
Disk identifier: 0x7504a1cc
/dev/sda1        2048 117209087 117207040 55.9G 83 Linux
Disklabel type: dos
#35
12 май 2020, 18:29
12 май 2020, 18:26
Да, от этого, от старости
#36
12 май 2020, 18:30
John-1, вернулись к началу. Восстанови таблицу , а дальше надо подумать.
John-1
#37
12 май 2020, 18:31
di_mok писал(а):
12 май 2020, 18:24
12 май 2020, 18:18
ему не до десятки))
Ну вообще я пытался поставить на него 10-ку но он намертво зависал на этапе логотипа.... :smile:
John-1
#38
12 май 2020, 18:32
12 май 2020, 18:30
Восстановил, сделал как в прошлый раз
#39
12 май 2020, 18:37
John-1, надо бы задуматься о замене диска. Как то я пробовал восстанавливать диск. Сначала нашёл винпе с викторией , сделал проход с записью , потом с флешки линукса низкоуровневым форматированием.
А сейчас создай раздел екст4 на весь диск в гпартед, отформатируй а потом из терминала устрой проверку диска fsck
John-1
#40
12 май 2020, 18:42
Gparte не дал даже возможности создать этот раздел...
Вернуться в «Mate»
