VirtualBox не пробрасывает USB
reactor30
03 май 2020, 14:20
Добрый день,есть проблема.Подключил виртуальную машину с win7 в нутри,все прекрассно работает,но вот есть одна беда,win 7 не видит usb устройств,как быть помогите может что не так делаю.
Вывод.
boris@boris-Easynote-ENTG71BM:~$ inxi -Fxz
  Host: boris-Easynote-ENTG71BM Kernel: 5.3.0-51-generic x86_64 bits: 64
  compiler: gcc v: 7.5.0 Desktop: Xfce 4.14.1 Distro: Linux Mint 19.3 Tricia
  base: Ubuntu 18.04 bionic
  Type: Laptop System: Packard Bell product: Easynote ENTG71BM v: V1.10
  serial: <filter>
  Mobo: Packard Bell model: Easynote ENTG71BM v: V1.10 serial: <filter>
  UEFI [Legacy]: Insyde v: 1.10 date: 12/15/2014
  ID-1: BAT0 charge: 17.0 Wh condition: 29.3/36.7 Wh (80%)
  model: LGC AC14B18J status: Charging
  Topology: Dual Core model: Intel Celeron N2840 bits: 64 type: MCP
  arch: Silvermont rev: 8 L2 cache: 1024 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 8663
  Speed: 852 MHz min/max: 500/2582 MHz Core speeds (MHz): 1: 726 2: 708
  Device-1: Intel Atom Processor Z36xxx/Z37xxx Series Graphics & Display
  Display: x11 server: X.Org 1.20.5 driver: modesetting unloaded: fbdev,vesa
  resolution: 1366x768~60Hz
  OpenGL: renderer: Mesa DRI Intel Bay Trail v: 4.2 Mesa 19.2.8
  Device-1: Intel Atom Processor Z36xxx/Z37xxx Series High Definition Audio
  bus ID: 00:1b.0
  Sound Server: ALSA v: k5.3.0-51-generic
  Device-1: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
  vendor: Foxconn driver: ath9k v: kernel port: 2000 bus ID: 02:00.0
  IF: wls2 state: up mac: <filter>
  vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 1000
  bus ID: 03:00.0
  IF: ens3 state: down mac: <filter>
  Local Storage: total: 229.79 GiB used: 33.51 GiB (14.6%)
  ID-1: /dev/sda vendor: Kingston model: SA400S37120G size: 111.79 GiB
  ID-2: /dev/sdb model: V-Color VSS100 Series size: 118.00 GiB
  ID-1: / size: 109.53 GiB used: 33.51 GiB (30.6%) fs: ext4 dev: /dev/sda1
  System Temperatures: cpu: 45.0 C mobo: N/A
  Processes: 175 Uptime: 1h 39m Memory: 3.73 GiB used: 839.2 MiB (22.0%)
  inxi: 3.0.32
PS.Извените,как прятать вывод под спойлер пока не понял.Так что не ругайте.
 ! Сообщение из: symon2014
https://linuxmint.com.ru/viewtopic.php?t=738#p10923
Помогите пожалуйста.
03 май 2020, 14:34
reactor30 писал(а):
03 май 2020, 14:20
Есть ещё приложения гостевой ос , и экстрапак с расширениями.
03 май 2020, 15:10
03 май 2020, 14:34
Для начала надо уточнить о какой виртуалке речь. vmware, virtualbox, qemu, xen, Hyper-V? В половине из них проброс USB никак от установленных в гостевой системе компонентов не зависит - вопрос именно в правильной настройке самой VM и/или хоста.
И вот этот вопрос не мешало бы отселить в отдельную тему...
reactor30
03 май 2020, 15:58
03 май 2020, 15:10
03 май 2020, 14:34
Виртуальная машина virtualbox,расширение экстрапак устанавливал через консоль,вроде установились,но порты юсб так и не пробросились.Может эти расширения надо с оф сайта скачать?
03 май 2020, 16:03
reactor30 писал(а):
03 май 2020, 15:58
Это как? Покажи команду.
reactor30
03 май 2020, 16:33
03 май 2020, 16:03
Вот команда- sudo apt install virtualbox-ext-pack
03 май 2020, 16:36
reactor30, а виртуалбокс откуда брал?
03 май 2020, 17:03
reactor30, поиск по форуму и интернету - отличная вещь. Пользуйся VirtualBox не пробрасывает флешки
Решено: 36
03 май 2020, 17:05
reactor30, дык они и не пробросятся все автоматом... ты или вручную на ходу должен указать что хочу вот это пробросить (внизу на панели запущенной машины ищи значок usb) или в настройках машины добавить устройство что б автоматом пробрасывалось
reactor30
03 май 2020, 17:07
03 май 2020, 17:05
reactor30, дык они и не пробросятся все автоматом... ты или вручную должен указать что хочу вот это пробросить или в настройках машины добавить устройство что б автоматом пробрасывалось
Ладно буду сейчас пробовать,походу плагин буду с оф сайта скачивать .Получится отпишусь.
reactor30
03 май 2020, 18:13
Всем спасибо все получилось,просто надо было в фильтр добавить флешку.
Andy_K64
Благодарил (а): 3 раза
26 июл 2020, 09:35
Тоже столкнулся с потерей проброса USB-устройств в гостевую систему (Windows 7 64bit). Случилось после обновления с Virtualbox с версии 6.1.? на версию 6.1.10. Устанавливал все из репозитория (Virtualbox, virtualbox-ext-pak). До обновления работа с USB была без проблем. После обновления гостевая система перестала видеть устройства. При попытке включить фильтры устройств получаю "нет доступных устройств", т.е. VM Manager их тоже не видит.
$ VBoxManage list usbhost
Host USB Devices:
<none>
Где искать?
Параметры системы:
  Kernel: 5.4.0-42-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
  Desktop: Cinnamon 4.6.6 Distro: Linux Mint 20 Ulyana
  base: Ubuntu 20.04 focal
  Type: Desktop System: Gigabyte product: N/A v: N/A serial: <filter>
  Mobo: Gigabyte model: H77-DS3H v: x.x serial: <filter>
  UEFI: American Megatrends v: F10 date: 11/14/2013
  Device-1: hidpp_battery_0
  model: Logitech G305 Lightspeed Wireless Gaming Mouse
  charge: 100% (should be ignored) status: Discharging
  Device-2: hidpp_battery_1 model: Logitech MK700
  charge: 70% (should be ignored) status: Discharging
  Topology: Quad Core model: Intel Core i5-3470 bits: 64 type: MCP
  arch: Ivy Bridge rev: 9 L2 cache: 6144 KiB
  flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 25541
  Speed: 1596 MHz min/max: 1600/3600 MHz Core speeds (MHz): 1: 1596 2: 1596
  3: 1596 4: 1596
  Device-1: NVIDIA GK107 [GeForce GTX 650] vendor: Micro-Star MSI
  driver: nvidia v: 440.100 bus ID: 05:00.0
  Display: x11 server: X.Org 1.20.8 driver: nvidia
  unloaded: fbdev,modesetting,nouveau,vesa resolution: 1920x1080~60Hz
  OpenGL: renderer: GeForce GTX 650/PCIe/SSE2 v: 4.6.0 NVIDIA 440.100
  Device-1: Intel 7 Series/C216 Family High Definition Audio
  vendor: Gigabyte driver: snd_hda_intel v: kernel bus ID: 00:1b.0
  Device-2: NVIDIA GK107 HDMI Audio vendor: Micro-Star MSI
  driver: snd_hda_intel v: kernel bus ID: 05:00.1
  Device-3: Microsoft type: USB driver: snd-usb-audio,uvcvideo
  bus ID: 1-1.4:5
  Sound Server: ALSA v: k5.4.0-42-generic
  Device-1: Broadcom and subsidiaries BCM4360 802.11ac Wireless Network
  Adapter
  vendor: ASUSTeK driver: wl v: kernel port: f020 bus ID: 01:00.0
  IF: wlp1s0 state: dormant mac: <filter>
  Device-2: Qualcomm Atheros AR8161 Gigabit Ethernet vendor: Gigabyte
  driver: alx v: kernel port: e000 bus ID: 02:00.0
  IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Local Storage: total: 6.46 TiB used: 2.44 TiB (37.8%)
  ID-1: /dev/sda vendor: Western Digital model: WD10EZRZ-22HTKB0
  size: 931.51 GiB temp: 31 C
  ID-2: /dev/sdb vendor: Western Digital model: WD10EZRZ-22HTKB0
  size: 931.51 GiB temp: 33 C
  ID-3: /dev/sdc vendor: Samsung model: HD103UJ size: 931.51 GiB temp: 28 C
  ID-4: /dev/sdd type: USB vendor: Western Digital model: WD Elements 25A3
  ID-5: /dev/sde type: USB model: Multi Flash Reader size: 29.55 GiB
  ID-6: /dev/sdf type: USB vendor: Samsung model: Flash Drive
  ID-7: /dev/sdg type: USB vendor: Generic model: Flash Disk size: 7.50 GiB
  ID-1: / size: 274.01 GiB used: 16.22 GiB (5.9%) fs: ext4 dev: /dev/sda2
  ID-2: /home size: 626.64 GiB used: 256.82 GiB (41.0%) fs: ext4
  dev: /dev/sda4
  ID-3: swap-1 size: 13.97 GiB used: 4.8 MiB (0.0%) fs: swap dev: /dev/sda3
  System Temperatures: cpu: 41.0 C mobo: N/A gpu: nvidia temp: 47 C
  Fan Speeds (RPM): N/A gpu: nvidia fan: 40%
  Processes: 271 Uptime: 1h 16m Memory: 7.74 GiB used: 4.23 GiB (54.7%)
  inxi: 3.0.38
26 июл 2020, 09:54
Andy_K64, да что ж вы ленивые то такие. Пользуйтесь поиском. Все ведь уже решено. VirtualBox не пробрасывает флешки
Andy_K64
26 июл 2020, 10:16
26 июл 2020, 09:54
Прошу прощения, но давайте сбавим тон. Там, куда Вы меня посылали, я уже был. Вернулся ни с чем. Не помогло. Да и не могло помочь, так проблема в обновлении. До обновления vb проблем не было. Значит и права пользователей были прописаны. Вряд ли обновление изменило членство в группах.
26 июл 2020, 11:49
Andy_K64, обновись до 6.1.12 https://www.virtualbox.org/wiki/Linux_Downloads
Andy_K64
28 июл 2020, 21:43
Проблему удалось решить. Удалил Virtualbox с пакетом расширения и заново установил его из репозитория. Все встало на свои места. Спасибо! :smile:
Благодарил (а): 26 раз
31 июл 2020, 15:14
На всякий случай приведу официальную репу виртуалбокса.
deb https://download.virtualbox.org/virtualbox/debian bionic contrib
(заменить bionic на соответствующее имя, если у вас не минт 19 / убунта 18.04)
Импорт ключа:
wget -qO - https://www.virtualbox.org/download/ora ... x_2016.asc | sudo apt-key add -
Который год использую. Глюки древних версий из репы убунты забыл, как страшный сон.
Последний раз редактировалось пользователем 1 027; всего редактировалось раз: 31
31 июл 2020, 15:17
027, так выше ссылку дал на их сайт с инструкцией по установке
31 июл 2020, 15:24
А, действительно.
Ну, считайте, что подтверждаю положительный опыт.
Может, кому пригодится — мои записки по итогам траханья с вбоксом.
Каждый пункт важен.
И — внимательно смотрим текущую версию минта и вбокса, правим команды соответственно.
Записки
Установка свежей версии из репы оракла:
https://help.ubuntu.ru/wiki/virtualbox
Репа для 18.04:
Ключ для 18.04:
wget -q https://www.virtualbox.org/download/ora ... x_2016.asc -O- | sudo apt-key add -
apt install virtualbox-6.0
Добавить вашего пользователя в группу vboxusers.
sudo usermod -a -G vboxusers `whoami`
Для применения изменений необходимо завершить сеанс и повторить вход в систему, либо перезагрузиться.
В меню запущенной виртуалки с вендом:
1. Устройства → Установить дополнение гостевой ОС.
Спустя некоторое время в гостевой Windows должен появится диаллог запуска программы. Если этого не произошло - зайдите в CD-ROM и запустите ее вручную.
Во время установки могут появится предупреждения о несовместимости драйверов. Везде соглашайтесь с установкой. После того как программа установится - перегрузите гостевую ОС. После этого появится нормальное разрешение экрана и другие возможности.
2. Устройства → Общие папки → Настроить общие папки.
папки машины → иконка с плюсиком → выбрать каталог хоста.
Выбрать автоподключение и постоянную папку.
В сетевом окружении винды будет комп \\Vboxsvr, в нем расшарен выбранный каталог хоста.
Либо (VirtualBox 6.1) уже подключен, как диск Z.
3. USB
https://www.virtualbox.org/wiki/Downloads
Скачать и установить VirtualBox 6.0.8 Oracle VM VirtualBox Extension Pack (он ассоциирован в гуе с виртуалбоксом).
Выключить виртуальную машину.
В настройках машины включаем поддержку USB.
Добавляем фильтр устройств (это можно и при запущенной машине).
Запустить машину. В панели внизу иконка USB, выбираем устройство. При этом оно отключится от хоста.
