Не работает захват с микрофона
ttyS32
31 авг 2025, 04:36
$ inxi -Fxz
Kernel: 5.15.0-153-generic x86_64 bits: 64 compiler: gcc v: 11.4.0
Desktop: Xfce 4.18.1 Distro: Linux Mint 21.3 Virginia
base: Ubuntu 22.04 jammy
Type: Desktop Mobo: ASUSTeK model: P5KPL-AM EPU v: x.0x
serial: <superuser required> BIOS: American Megatrends v: 0403
date: 07/02/2009
Info: quad core model: Intel Core2 Quad Q9300 bits: 64 type: MCP
arch: Core Yorkfield rev: 7 cache: L1: 256 KiB L2: 6 MiB
Speed (MHz): avg: 2000 high: 2008 min/max: 1998/2497 cores: 1: 1998
2: 1998 3: 1998 4: 2008 bogomips: 19979
Flags: ht lm nx pae sse sse2 sse3 sse4_1 ssse3 vmx
Device-1: NVIDIA GT215 [GeForce GT 240] vendor: ASUSTeK driver: nvidia
v: 340.108 bus-ID: 01:00.0
Display: x11 server: X.Org v: 1.21.1.4 driver: X: loaded: nvidia
gpu: nvidia resolution: 1024x768~60Hz
OpenGL: renderer: GeForce GT 240/PCIe/SSE2 v: 3.3.0 NVIDIA 340.108
Device-1: Intel NM10/ICH7 Family High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Device-2: NVIDIA High Definition Audio vendor: ASUSTeK
Sound Server-1: ALSA v: k5.15.0-153-generic running: yes
Device-1: Qualcomm Atheros AR8121/AR8113/AR8114 Gigabit or Fast Ethernet
vendor: ASUSTeK driver: ATL1E v: N/A port: ec00 bus-ID: 02:00.0
Device-2: Qualcomm Atheros AR5212/5213/2414 Wireless Network Adapter
vendor: D-Link System AirPremier DWL-G550 driver: ath5k v: kernel
bus-ID: 04:01.0
IF: wlp4s1 state: up mac: <filter>
Local Storage: total: 894.25 GiB used: 319.16 GiB (35.7%)
ID-1: /dev/sda vendor: Patriot model: Burst Elite 960GB size: 894.25 GiB
ID-1: / size: 48.91 GiB used: 20.39 GiB (41.7%) fs: ext4 dev: /dev/sda2
ID-2: /home size: 822.03 GiB used: 298.77 GiB (36.3%) fs: ext4
dev: /dev/sda3
Swap:
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) dev: /dev/sda1
System Temperatures: cpu: 39.0 C mobo: 42.0 C gpu: nvidia temp: 53 C
Fan Speeds (RPM): cpu: 1196 psu: 0 case-1: 0
Power: 12v: 12.14 5v: N/A 3.3v: 2.94 vbat: N/A
Processes: 191 Uptime: 2h 4m Memory: 3.82 GiB used: 936.2 MiB (23.9%)
Init: systemd runlevel: 5 Compilers: gcc: 11.4.0 clang: 14.0.0-1ubuntu1.1
Packages: 2978 Shell: Bash v: 5.1.16 inxi: 3.3.13
Воспроизведение1
┌────────────────────────────────────── AlsaMixer v1.2.6 ──────────────────────────────────────┐
│   Карта: HDA Intel                                                  F1: Помощь               │
│     Чип: VIA VT1708S                                                F2: Системная информация │
│     Вид: F3:[Воспроизведение] F4: Захват  F5: Все                   F6: Выбор звуковой карты │
│ Элемент: Master [Усиление дБ: -42.00]                               Esc: Выход               │
│    │OO│     │MM│              │OO│     │MM│              │OO│     │OO│     │OO│     │MM│     │
│     20      0<>0   100<>100 100<>100   0<>0     0<>0   100<>100   100      100      0<>0     │
│ < Master >Headphon   PCM     Front   Front Mi Front Mi Surround  Center    LFE      Line     │
Воспроизведение2
│ Элемент: Rear Mic Boost [Усиление дБ: 20.50, 0.00]                  Esc: Выход               │
│    ├──┤     ┌──┐     ┌──┐   Disabled   2ch    Disabled Disabled Enabled    ├──┤     └──┘     │
│    │MM│     │MM│     │MM│                                                  │OO│              │
│    0<>0        81<>0    53<>0     │
│     CD     S/PDIF  S/PDIF D Auto-Mut Channel  Dynamic  Independ Loopback Rear Mic<Rear Mic>  │
Захват
│     Вид: F3: Воспроизведение  F4:[Захват] F5: Все                   F6: Выбор звуковой карты │
│ Элемент: Front Mic [Выкл.]                                          Esc: Выход               │
│              └──┘                        ЛВ└──┘ПР    └──┘    ЛВ    ПР    └──┘                │
│   ------              ------    ------    ЗАХВАТ              ЗАХВАТ              ------     │
│              0<>0                         87<>0      0<>0               53<>0                │
│ <Front Mic>Front Mic   Line       CD      Capture   Digital  Rear Mic  Rear Mic  Stereo Mi   │
Привет всем! Помогите починить.
Не работает захват с микрофона, при этом микрофон подключён и работает
т.е. я себя слышу (см. Воспроизведение2).
Но после перехода в режим systemctl suspend и потом если
включить компьютер, то все работает.
Если отключить ssd и подключить к другому компьютеру
(материнская плата тоже ASUSTeK, но немного посвежее),
при этом ни каких настроек не меняю, захват с микрофона работает.
Вернуться в «Звуковые карты»
