Linux Mint, rEFInd, Windows 11
HayAlai
Благодарил (а): 2 раза
23 май 2025, 18:50
Всем доброго времени суток, у меня есть вопрос.
Мои данные:
ОС Linux Mint 22.1 Cinnamon x64
Версия Cinnamon 6.4.8
Ядро Linux 6.8.0-60-generic
Вот моё железо:
Kernel: 6.8.0-60-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
Desktop: Cinnamon v: 6.4.8 Distro: Linux Mint 22.1 Xia
base: Ubuntu 24.04 noble
Type: Desktop Mobo: ASRock model: B450M Pro4 R2.0
serial: <superuser required> UEFI: American Megatrends v: P5.70
date: 10/20/2022
Info: 6-core model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+
rev: 2 cache: L1: 384 KiB L2: 3 MiB L3: 32 MiB
Speed (MHz): avg: 2302 high: 2795 min/max: 2200/4650 boost: enabled cores:
1: 2795 2: 2235 3: 2237 4: 2236 5: 2236 6: 2235 7: 2519 8: 2235 9: 2200
10: 2235 11: 2236 12: 2235 bogomips: 88634
Device-1: NVIDIA GA104 [GeForce RTX 3070 Ti] vendor: Palit Microsystems
driver: nvidia v: 570.133.07 arch: Ampere bus-ID: 07:00.0
Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.6 driver: X:
loaded: nvidia unloaded: fbdev,modesetting,nouveau,vesa
gpu: nvidia,nvidia-nvswitch resolution: 2560x1440
API: EGL v: 1.5 drivers: nvidia,swrast platforms:
active: gbm,x11,surfaceless,device inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 570.133.07
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3070 Ti/PCIe/SSE2
Device-1: NVIDIA GA104 High Definition Audio vendor: Palit Microsystems
driver: snd_hda_intel v: kernel bus-ID: 07:00.1
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
driver: snd_hda_intel v: kernel bus-ID: 09:00.4
Device-3: HAOBO USB Composite Device
driver: hid-generic,snd-usb-audio,usbhid type: USB bus-ID: 1-3:2
Device-4: KTMicro fifine Chat driver: hid-generic,snd-usb-audio,usbhid
type: USB bus-ID: 1-4:3
API: ALSA v: k6.8.0-60-generic status: kernel-api
Server-1: PipeWire v: 1.0.5 status: active
Device-1: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
vendor: ASRock driver: r8169 v: kernel port: f000 bus-ID: 05:00.0
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 1.14 TiB used: 43.43 GiB (3.7%)
ID-1: /dev/nvme0n1 vendor: Kingston model: SNV2S1000G size: 931.51 GiB
temp: 33.9 C
ID-2: /dev/sda vendor: TeamGroup model: T253X2256G size: 238.47 GiB
ID-1: / size: 45.64 GiB used: 29.4 GiB (64.4%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 1.9 GiB used: 106 MiB (5.4%) fs: vfat dev: /dev/sda1
ID-3: /home size: 182.1 GiB used: 13.92 GiB (7.6%) fs: ext4 dev: /dev/sda4
Swap:
ID-1: swap-1 type: partition size: 3.81 GiB used: 0 KiB (0.0%)
dev: /dev/sda3
System Temperatures: cpu: 40.1 C mobo: N/A gpu: nvidia temp: 43 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
Memory: total: 16 GiB available: 15.54 GiB used: 2.53 GiB (16.3%)
Processes: 324 Uptime: 8m Init: systemd target: graphical (5)
Packages: 2196 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
После выбора Windows 11 в rEFInd вылазит такое:
Собственно нужно что бы запускалась винда...
Если какую то информацию нужно, спрашивайте(желательно если что то нужно делать напишите что делать).
Я новичок, пытаюсь освоить тут всё, так что не ругайтесь :)
Решение HayAlai » 25 май 2025, 21:05
Я обосрался....
Я нашёл проблему, я ввёл в конфиге refind не то что нужно, я ввёл туда volume раздела, а не UUID, поменял конфиг там и всё заработало....
Извините кого потревожил своей мелочной проблемкой.
23 май 2025, 20:31
HayAlai писал(а):
23 май 2025, 18:50
Начинать надо с проверки - "а был ли мальчик?". Т.е. - есть ли виндовый загрузчик на месте вообще. Загрузитесь в линукс, откройте консоль, и введите там это: find /boot/efi. Вывод - сюда.
ilikethat
Решено: 10
Благодарил (а): 129 раз
23 май 2025, 22:31
HayAlai, а что не устраивает в grub?
Задача использовать мультизагрузку Linux\Win11 ?
Или задача поиграться с rEFInd ?
23 май 2025, 23:21
ilikethat, rEFInd проще в настройках и надежнее (т.к. многое делает сам, автодетектом, и может даже вообще без настроек справиться). Если он уже стоит - нет никакого смысла менять на GRUB. А уж в случае dualboot - и подавно.
HayAlai
25 май 2025, 20:01
23 май 2025, 20:31
HayAlai писал(а):
23 май 2025, 18:50
Вот что выдало, без sudo кстати отказывал в доступе.
/boot/efi
/boot/efi/EFI
/boot/efi/EFI/ubuntu
/boot/efi/EFI/ubuntu/grubx64.efi
/boot/efi/EFI/ubuntu/shimx64.efi
/boot/efi/EFI/ubuntu/mmx64.efi
/boot/efi/EFI/ubuntu/BOOTX64.CSV
/boot/efi/EFI/ubuntu/grub.cfg
/boot/efi/EFI/tools
/boot/efi/EFI/BOOT
/boot/efi/EFI/BOOT/BOOTX64.EFI
/boot/efi/EFI/BOOT/fbx64.efi
/boot/efi/EFI/BOOT/mmx64.efi
/boot/efi/EFI/refind
/boot/efi/EFI/refind/refind_x64.efi
/boot/efi/EFI/refind/drivers_x64
/boot/efi/EFI/refind/drivers_x64/ext4_x64.efi
/boot/efi/EFI/refind/keys
/boot/efi/EFI/refind/keys/refind_local.cer
/boot/efi/EFI/refind/keys/refind_local.crt
/boot/efi/EFI/refind/keys/altlinux.cer
/boot/efi/EFI/refind/keys/canonical-uefi-ca.cer
/boot/efi/EFI/refind/keys/centossecureboot201.cer
/boot/efi/EFI/refind/keys/centossecurebootca2.cer
/boot/efi/EFI/refind/keys/debian.cer
/boot/efi/EFI/refind/keys/fedora-ca.cer
/boot/efi/EFI/refind/keys/microsoft-kekca-public.cer
/boot/efi/EFI/refind/keys/microsoft-pca-public.cer
/boot/efi/EFI/refind/keys/microsoft-uefica-public.cer
/boot/efi/EFI/refind/keys/openSUSE-UEFI-CA-Certificate-4096.cer
/boot/efi/EFI/refind/keys/openSUSE-UEFI-CA-Certificate.cer
/boot/efi/EFI/refind/keys/redhatsecureboot003.cer
/boot/efi/EFI/refind/keys/redhatsecureboot401.cer
/boot/efi/EFI/refind/keys/redhatsecurebootca2.cer
/boot/efi/EFI/refind/keys/redhatsecurebootca4.cer
/boot/efi/EFI/refind/keys/refind.cer
/boot/efi/EFI/refind/keys/SLES-UEFI-CA-Certificate.cer
/boot/efi/EFI/refind/icons
/boot/efi/EFI/refind/icons/README
/boot/efi/EFI/refind/icons/arrow_left.png
/boot/efi/EFI/refind/icons/arrow_right.png
/boot/efi/EFI/refind/icons/boot_linux.png
/boot/efi/EFI/refind/icons/boot_win.png
/boot/efi/EFI/refind/icons/func_about.png
/boot/efi/EFI/refind/icons/func_bootorder.png
/boot/efi/EFI/refind/icons/func_csr_rotate.png
/boot/efi/EFI/refind/icons/func_exit.png
/boot/efi/EFI/refind/icons/func_firmware.png
/boot/efi/EFI/refind/icons/func_hidden.png
/boot/efi/EFI/refind/icons/func_install.png
/boot/efi/EFI/refind/icons/func_reset.png
/boot/efi/EFI/refind/icons/func_shutdown.png
/boot/efi/EFI/refind/icons/mouse.png
/boot/efi/EFI/refind/icons/os_arch.png
/boot/efi/EFI/refind/icons/os_artful.png
/boot/efi/EFI/refind/icons/os_bionic.png
/boot/efi/EFI/refind/icons/os_centos.png
/boot/efi/EFI/refind/icons/os_chakra.png
/boot/efi/EFI/refind/icons/os_chrome.png
/boot/efi/EFI/refind/icons/os_clover.png
/boot/efi/EFI/refind/icons/os_crunchbang.png
/boot/efi/EFI/refind/icons/os_debian.png
/boot/efi/EFI/refind/icons/os_devuan.png
/boot/efi/EFI/refind/icons/os_elementary.png
/boot/efi/EFI/refind/icons/os_endeavouros.png
/boot/efi/EFI/refind/icons/os_fedora.png
/boot/efi/EFI/refind/icons/os_freebsd.png
/boot/efi/EFI/refind/icons/os_frugalware.png
/boot/efi/EFI/refind/icons/os_gentoo.png
/boot/efi/EFI/refind/icons/os_gummiboot.png
/boot/efi/EFI/refind/icons/os_haiku.png
/boot/efi/EFI/refind/icons/os_hwtest.png
/boot/efi/EFI/refind/icons/os_kubuntu.png
/boot/efi/EFI/refind/icons/os_legacy.png
/boot/efi/EFI/refind/icons/os_linux.png
/boot/efi/EFI/refind/icons/os_linuxmint.png
/boot/efi/EFI/refind/icons/os_lubuntu.png
/boot/efi/EFI/refind/icons/os_mac.png
/boot/efi/EFI/refind/icons/os_mageia.png
/boot/efi/EFI/refind/icons/os_mandriva.png
/boot/efi/EFI/refind/icons/os_manjaro.png
/boot/efi/EFI/refind/icons/os_netbsd.png
/boot/efi/EFI/refind/icons/os_network.png
/boot/efi/EFI/refind/icons/os_opensuse.png
/boot/efi/EFI/refind/icons/os_redhat.png
/boot/efi/EFI/refind/icons/os_refind.png
/boot/efi/EFI/refind/icons/os_refit.png
/boot/efi/EFI/refind/icons/os_slackware.png
/boot/efi/EFI/refind/icons/os_suse.png
/boot/efi/EFI/refind/icons/os_systemd.png
/boot/efi/EFI/refind/icons/os_trusty.png
/boot/efi/EFI/refind/icons/os_ubuntu.png
/boot/efi/EFI/refind/icons/os_uefi.png
/boot/efi/EFI/refind/icons/os_unknown.png
/boot/efi/EFI/refind/icons/os_void.png
/boot/efi/EFI/refind/icons/os_win.png
/boot/efi/EFI/refind/icons/os_win8.png
/boot/efi/EFI/refind/icons/os_xenial.png
/boot/efi/EFI/refind/icons/os_xubuntu.png
/boot/efi/EFI/refind/icons/os_zesty.png
/boot/efi/EFI/refind/icons/tool_apple_rescue.png
/boot/efi/EFI/refind/icons/tool_fwupdate.png
/boot/efi/EFI/refind/icons/tool_memtest.png
/boot/efi/EFI/refind/icons/tool_mok_tool.png
/boot/efi/EFI/refind/icons/tool_netboot.png
/boot/efi/EFI/refind/icons/tool_part.png
/boot/efi/EFI/refind/icons/tool_rescue.png
/boot/efi/EFI/refind/icons/tool_shell.png
/boot/efi/EFI/refind/icons/tool_windows_rescue.png
/boot/efi/EFI/refind/icons/transparent.png
/boot/efi/EFI/refind/icons/vol_efi.png
/boot/efi/EFI/refind/icons/vol_external.png
/boot/efi/EFI/refind/icons/vol_internal.png
/boot/efi/EFI/refind/icons/vol_net.png
/boot/efi/EFI/refind/icons/vol_optical.png
/boot/efi/EFI/refind/refind.conf
/boot/efi/EFI/refind/BOOT.CSV
/boot/efi/EFI/refind/icons-backup
/boot/efi/EFI/refind/icons-backup/README
/boot/efi/EFI/refind/icons-backup/arrow_left.png
/boot/efi/EFI/refind/icons-backup/arrow_right.png
/boot/efi/EFI/refind/icons-backup/boot_linux.png
/boot/efi/EFI/refind/icons-backup/boot_win.png
/boot/efi/EFI/refind/icons-backup/func_about.png
/boot/efi/EFI/refind/icons-backup/func_bootorder.png
/boot/efi/EFI/refind/icons-backup/func_csr_rotate.png
/boot/efi/EFI/refind/icons-backup/func_exit.png
/boot/efi/EFI/refind/icons-backup/func_firmware.png
/boot/efi/EFI/refind/icons-backup/func_hidden.png
/boot/efi/EFI/refind/icons-backup/func_install.png
/boot/efi/EFI/refind/icons-backup/func_reset.png
/boot/efi/EFI/refind/icons-backup/func_shutdown.png
/boot/efi/EFI/refind/icons-backup/mouse.png
/boot/efi/EFI/refind/icons-backup/os_arch.png
/boot/efi/EFI/refind/icons-backup/os_artful.png
/boot/efi/EFI/refind/icons-backup/os_bionic.png
/boot/efi/EFI/refind/icons-backup/os_centos.png
/boot/efi/EFI/refind/icons-backup/os_chakra.png
/boot/efi/EFI/refind/icons-backup/os_chrome.png
/boot/efi/EFI/refind/icons-backup/os_clover.png
/boot/efi/EFI/refind/icons-backup/os_crunchbang.png
/boot/efi/EFI/refind/icons-backup/os_debian.png
/boot/efi/EFI/refind/icons-backup/os_devuan.png
/boot/efi/EFI/refind/icons-backup/os_elementary.png
/boot/efi/EFI/refind/icons-backup/os_endeavouros.png
/boot/efi/EFI/refind/icons-backup/os_fedora.png
/boot/efi/EFI/refind/icons-backup/os_freebsd.png
/boot/efi/EFI/refind/icons-backup/os_frugalware.png
/boot/efi/EFI/refind/icons-backup/os_gentoo.png
/boot/efi/EFI/refind/icons-backup/os_gummiboot.png
/boot/efi/EFI/refind/icons-backup/os_haiku.png
/boot/efi/EFI/refind/icons-backup/os_hwtest.png
/boot/efi/EFI/refind/icons-backup/os_kubuntu.png
/boot/efi/EFI/refind/icons-backup/os_legacy.png
/boot/efi/EFI/refind/icons-backup/os_linux.png
/boot/efi/EFI/refind/icons-backup/os_linuxmint.png
/boot/efi/EFI/refind/icons-backup/os_lubuntu.png
/boot/efi/EFI/refind/icons-backup/os_mac.png
/boot/efi/EFI/refind/icons-backup/os_mageia.png
/boot/efi/EFI/refind/icons-backup/os_mandriva.png
/boot/efi/EFI/refind/icons-backup/os_manjaro.png
/boot/efi/EFI/refind/icons-backup/os_netbsd.png
/boot/efi/EFI/refind/icons-backup/os_network.png
/boot/efi/EFI/refind/icons-backup/os_opensuse.png
/boot/efi/EFI/refind/icons-backup/os_redhat.png
/boot/efi/EFI/refind/icons-backup/os_refind.png
/boot/efi/EFI/refind/icons-backup/os_refit.png
/boot/efi/EFI/refind/icons-backup/os_slackware.png
/boot/efi/EFI/refind/icons-backup/os_suse.png
/boot/efi/EFI/refind/icons-backup/os_systemd.png
/boot/efi/EFI/refind/icons-backup/os_trusty.png
/boot/efi/EFI/refind/icons-backup/os_ubuntu.png
/boot/efi/EFI/refind/icons-backup/os_uefi.png
/boot/efi/EFI/refind/icons-backup/os_unknown.png
/boot/efi/EFI/refind/icons-backup/os_void.png
/boot/efi/EFI/refind/icons-backup/os_win.png
/boot/efi/EFI/refind/icons-backup/os_win8.png
/boot/efi/EFI/refind/icons-backup/os_xenial.png
/boot/efi/EFI/refind/icons-backup/os_xubuntu.png
/boot/efi/EFI/refind/icons-backup/os_zesty.png
/boot/efi/EFI/refind/icons-backup/tool_apple_rescue.png
/boot/efi/EFI/refind/icons-backup/tool_fwupdate.png
/boot/efi/EFI/refind/icons-backup/tool_memtest.png
/boot/efi/EFI/refind/icons-backup/tool_mok_tool.png
/boot/efi/EFI/refind/icons-backup/tool_netboot.png
/boot/efi/EFI/refind/icons-backup/tool_part.png
/boot/efi/EFI/refind/icons-backup/tool_rescue.png
/boot/efi/EFI/refind/icons-backup/tool_shell.png
/boot/efi/EFI/refind/icons-backup/tool_windows_rescue.png
/boot/efi/EFI/refind/icons-backup/transparent.png
/boot/efi/EFI/refind/icons-backup/vol_efi.png
/boot/efi/EFI/refind/icons-backup/vol_external.png
/boot/efi/EFI/refind/icons-backup/vol_internal.png
/boot/efi/EFI/refind/icons-backup/vol_net.png
/boot/efi/EFI/refind/icons-backup/vol_optical.png
/boot/efi/EFI/refind/refind.conf-sample
/boot/efi/EFI/refind/refind.conf.bak
/boot/efi/EFI/refind/linux
/boot/efi/EFI/refind/linux/vmlinuz-6.8.0-60-generic
/boot/efi/EFI/refind/linux/initrd.img-6.8.0-60-generic
/boot/efi/EFI/refind/vars
/boot/efi/EFI/refind/vars/PreviousBoot
/boot/efi/EFI/refind/themes
/boot/efi/EFI/refind/themes/deer
/boot/efi/EFI/refind/themes/deer/.github
/boot/efi/EFI/refind/themes/deer/.github/LICENSE
/boot/efi/EFI/refind/themes/deer/.github/README.md
/boot/efi/EFI/refind/themes/deer/.github/screenshot.bmp
/boot/efi/EFI/refind/themes/deer/background.png
/boot/efi/EFI/refind/themes/deer/icons
/boot/efi/EFI/refind/themes/deer/icons/func_about.png
/boot/efi/EFI/refind/themes/deer/icons/func_exit.png
/boot/efi/EFI/refind/themes/deer/icons/func_firmware.png
/boot/efi/EFI/refind/themes/deer/icons/func_hidden.png
/boot/efi/EFI/refind/themes/deer/icons/func_reset.png
/boot/efi/EFI/refind/themes/deer/icons/func_shutdown.png
/boot/efi/EFI/refind/themes/deer/icons/os_android.png
/boot/efi/EFI/refind/themes/deer/icons/os_antergos.png
/boot/efi/EFI/refind/themes/deer/icons/os_arch.png
/boot/efi/EFI/refind/themes/deer/icons/os_centos.png
/boot/efi/EFI/refind/themes/deer/icons/os_debian.png
/boot/efi/EFI/refind/themes/deer/icons/os_deepin.png
/boot/efi/EFI/refind/themes/deer/icons/os_elementary.png
/boot/efi/EFI/refind/themes/deer/icons/os_fedora.png
/boot/efi/EFI/refind/themes/deer/icons/os_freebsd.png
/boot/efi/EFI/refind/themes/deer/icons/os_gentoo.png
/boot/efi/EFI/refind/themes/deer/icons/os_kali.png
/boot/efi/EFI/refind/themes/deer/icons/os_kubuntu.png
/boot/efi/EFI/refind/themes/deer/icons/os_linux.png
/boot/efi/EFI/refind/themes/deer/icons/os_linuxmint.png
/boot/efi/EFI/refind/themes/deer/icons/os_mac.png
/boot/efi/EFI/refind/themes/deer/icons/os_manjaro.png
/boot/efi/EFI/refind/themes/deer/icons/os_mx.png
/boot/efi/EFI/refind/themes/deer/icons/os_neon.png
/boot/efi/EFI/refind/themes/deer/icons/os_openbsd.png
/boot/efi/EFI/refind/themes/deer/icons/os_parabola.png
/boot/efi/EFI/refind/themes/deer/icons/os_solus.png
/boot/efi/EFI/refind/themes/deer/icons/os_ubuntu.png
/boot/efi/EFI/refind/themes/deer/icons/os_ubuntugnome.png
/boot/efi/EFI/refind/themes/deer/icons/os_unknown.png
/boot/efi/EFI/refind/themes/deer/icons/os_void.png
/boot/efi/EFI/refind/themes/deer/icons/os_win.png
/boot/efi/EFI/refind/themes/deer/icons/os_win10.png
/boot/efi/EFI/refind/themes/deer/icons/os_win8.png
/boot/efi/EFI/refind/themes/deer/icons/os_win8_official.png
/boot/efi/EFI/refind/themes/deer/icons/os_zorin.png
/boot/efi/EFI/refind/themes/deer/icons/tool_mok_tool.png
/boot/efi/EFI/refind/themes/deer/selection_big.png
/boot/efi/EFI/refind/themes/deer/selection_small.png
/boot/efi/EFI/refind/themes/deer/theme.conf
UPD:
Я так понимаю, что в efi/refind должен быть bootmgfw.efi верно ?, Я так посмотрел ничего связанного там в виндой нету, кроме иконок.
Я открыл efi раздел на диске С (где винда) и там нужные bootmgfw.efi есть, и даже такой же только с .mui в конце.
UPD1.0:
Как я понял должен быть смонтироват efi раздел с виндой, но вопрос, почему когда я запускаю комп он не смонтирован получается? Отсюда и ошибка, верно ? А если это так то что делать что бы он запускался ?
HayAlai
25 май 2025, 21:05
Я обосрался....
25 май 2025, 21:14
HayAlai писал(а):
25 май 2025, 21:05
Норм. Главное разобрался
25 май 2025, 21:21
HayAlai писал(а):
25 май 2025, 20:01
Не совсем. Не в refind - у винды отдельный каталог на этом разделе, где этот файл (ее собственный загрузчик) и живет. Как и у каждой системы/загрузчика. Но efi разделов может быть больше одного - это тоже нормально.
HayAlai писал(а):
25 май 2025, 20:01
Нет, efi раздел не обязателен к монтированию, чтобы ядро работало и система грузилась (во время загрузки оттуда все нужное читается еще до старта ядра - непосредственно прошивкой мат-платы). Системой он монтируется для того, чтобы апдейты системы могли и загрузчик обновлять в случае надобности. Ну и не только апдейты - если что-то устанавливается вроде того же refind'а которому как раз EFI нужен для установки. А второй efi вообще не монтируется, разумеется. Только тот, где загрузчик текущей системы.
