Kernel: 6.8.0-38-generic arch: x86_64 bits: 64 compiler: gcc v: 13.2.0
Desktop: Cinnamon v: 6.2.7 Distro: Linux Mint 22 Wilma
base: Ubuntu 24.04 noble
Type: Desktop Mobo: Acer model: Aspire Z5763 serial: <superuser required>
BIOS: American Megatrends v: P01-B3 date: 07/22/2011
Info: quad core model: Intel Core i7-2600S bits: 64 type: MT MCP
arch: Sandy Bridge rev: 7 cache: L1: 256 KiB L2: 1024 KiB L3: 8 MiB
Speed (MHz): avg: 1599 high: 1600 min/max: 1600/3800 cores: 1: 1600
2: 1600 3: 1600 4: 1600 5: 1596 6: 1600 7: 1600 8: 1600 bogomips: 44695
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Device-1: NVIDIA GP108 [GeForce GT 1030] vendor: ASUSTeK driver: nouveau
v: kernel arch: Pascal bus-ID: 01:00.0 temp: 46.0 C
Device-2: Chicony CNFB219 driver: snd-usb-audio,uvcvideo type: USB
bus-ID: 1-1.5:7
Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.6 driver: X:
loaded: modesetting unloaded: fbdev,vesa dri: nouveau gpu: nouveau
resolution: 1920x1080~60Hz
API: EGL v: 1.5 drivers: nouveau,swrast platforms:
active: x11,surfaceless,device inactive: gbm,wayland
API: OpenGL v: 4.5 compat-v: 4.3 vendor: mesa v: 24.0.9-0ubuntu0.1
glx-v: 1.4 direct-render: yes renderer: NV138
vendor: Acer Incorporated ALI 6 driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0
Device-2: NVIDIA GP108 High Definition Audio vendor: ASUSTeK
Device-3: Philips s SAA7231 vendor: Avermedia driver: N/A bus-ID: 03:00.0
Device-4: Chicony CNFB219 driver: snd-usb-audio,uvcvideo type: USB
bus-ID: 1-1.5:7
API: ALSA v: k6.8.0-38-generic status: kernel-api
Server-1: PipeWire v: 1.0.5 status: active
Device-1: Intel 82579V Gigabit Network vendor: Acer Incorporated ALI
driver: e1000e v: kernel port: f040 bus-ID: 00:19.0
IF: eno1 state: down mac: <filter>
Device-2: Realtek RTL8191SU 802.11n WLAN Adapter driver: r8712u type: USB
bus-ID: 1-1.4:6
IF: wlx68a3c4e668a7 state: down mac: <filter>
Bluetooth:
Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
v: 0.8 type: USB bus-ID: 1-1.2:4
Report: hciconfig ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 2.1
lmp-v: 4
Local Storage: total: 1.94 TiB used: 1012.11 GiB (51.1%)
ID-1: /dev/sda vendor: Seagate model: ST2000DM008-2FR102 size: 1.82 TiB
ID-2: /dev/sdb vendor: Plextor model: PX-128M5Pro size: 119.24 GiB
ID-1: / size: 78.19 GiB used: 7.03 GiB (9.0%) fs: ext4 dev: /dev/sda2
ID-2: /home size: 44.48 GiB used: 2.9 MiB (0.0%) fs: ext4 dev: /dev/sda3
Swap:
Alert: No swap data was found.
System Temperatures: cpu: 40.0 C mobo: N/A gpu: nouveau temp: 46.0 C
Fan Speeds (rpm): N/A
Memory: total: 16 GiB available: 15.6 GiB used: 1.16 GiB (7.4%)
Processes: 315 Uptime: 2m Init: systemd target: graphical (5)
Packages: 1880 Compilers: gcc: 13.2.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
