Kernel: 6.8.0-38-generic arch: x86_64 bits: 64 compiler: gcc v: 13.2.0
Desktop: Xfce v: 4.18.1 Distro: Linux Mint 22 Wilma
base: Ubuntu 24.04 noble
Type: Desktop Mobo: MICRO-STAR model: GF615M-P33 (MS-7597) v: 1.0
serial: <superuser required> BIOS: American Megatrends v: 2.7
date: 12/13/2010
Info: dual core model: AMD Athlon II X2 220 bits: 64 type: MCP arch: K10
rev: 3 cache: L1: 256 KiB L2: 1024 KiB
Speed (MHz): avg: 800 min/max: 800/2800 boost: disabled cores: 1: 800
2: 800 bogomips: 11251
Flags: ht lm nx pae sse sse2 sse3 sse4a svm
Device-1: NVIDIA GK208B [GeForce GT 710] driver: nouveau v: kernel
arch: Fermi 2 bus-ID: 02:00.0 temp: 33.0 C
Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.6 driver: X:
loaded: modesetting unloaded: fbdev,vesa dri: nouveau gpu: nouveau
resolution: 1024x768~60Hz
API: EGL v: 1.5 drivers: nouveau,swrast platforms:
active: gbm,x11,surfaceless,device inactive: wayland
API: OpenGL v: 4.5 compat-v: 4.3 vendor: mesa v: 24.0.9-0ubuntu0.1
glx-v: 1.4 direct-render: yes renderer: NV106
Device-1: NVIDIA MCP61 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 00:05.0
Device-2: NVIDIA GK208 HDMI/DP Audio driver: snd_hda_intel v: kernel
bus-ID: 02:00.1
API: ALSA v: k6.8.0-38-generic status: kernel-api
Server-1: PipeWire v: 1.0.5 status: active
Device-1: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
vendor: Micro-Star MSI RTL8111/8168/8411 driver: r8169 v: kernel port: e800
bus-ID: 04:00.0
Local Storage: total: 74.56 GiB used: 9.09 GiB (12.2%)
ID-1: /dev/sda vendor: Samsung model: SP0802N size: 74.56 GiB
ID-1: / size: 72.34 GiB used: 9.08 GiB (12.6%) fs: ext4 dev: /dev/sda3
ID-2: /boot/efi size: 512 MiB used: 6.1 MiB (1.2%) fs: vfat dev: /dev/sda2
Swap:
System Temperatures: cpu: 12.4 C mobo: N/A gpu: nouveau temp: 33.0 C
Fan Speeds (rpm): N/A
Memory: total: 8 GiB available: 7.76 GiB used: 911.6 MiB (11.5%)
Processes: 204 Uptime: 6m Init: systemd target: graphical (5)
Packages: 1846 Compilers: gcc: 13.2.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
bolk@bolk-MS-7597:~$ lspci -knn | grep -A3 -i "Eth"
04:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 06)
Subsystem: Micro-Star International Co., Ltd. [MSI] RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [1462:7597]
Kernel driver in use: r8169
Kernel modules: r8169, r8168
Я решил выбрать этот драйвер потому что такие же цифры есть в названии моей сетевухи. Я ставил драйвер неувернно, поэтому чувствую что я запорол всё, и скачал не то что нужно. Проверьте этот момент пожалуйста, правильно ли нет, я не шарю ваще!
