Проблемы после обновлений
1o4ka
Благодарил (а): 23 раза
07 июн 2024, 20:21
Linux Mint 21.3 Cinnamon
$ inxi -Fxz
Kernel: 5.15.0-112-generic x86_64 bits: 64 compiler: gcc v: 11.4.0
base: Ubuntu 22.04 jammy
Type: Laptop System: HP product: HP Laptop 15s-eq1xxx v: N/A
serial: <superuser required>
Mobo: HP model: 8706 v: 99.42 serial: <superuser required> UEFI: AMI
v: F.67 date: 12/29/2022
ID-1: BAT0 charge: 41.0 Wh (100.0%) condition: 41.0/41.0 Wh (100.0%)
volts: 12.9 min: 11.3 model: Hewlett-Packard Primary status: Full
Info: dual core model: AMD Ryzen 3 3250U with Radeon Graphics bits: 64
type: MT MCP arch: Zen/Zen+ note: check rev: 1 cache: L1: 192 KiB
L2: 1024 KiB L3: 4 MiB
Speed (MHz): avg: 2896 high: 3229 min/max: 1400/2600 boost: enabled
cores: 1: 3229 2: 3190 3: 2551 4: 2614 bogomips: 20761
Device-1: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
vendor: Hewlett-Packard driver: N/A bus-ID: 04:00.0
Device-2: Quanta HP TrueVision HD Camera type: USB driver: uvcvideo
bus-ID: 1-5.2:5
Display: x11 server: X.Org v: 1.21.1.4 driver: X: loaded: ati,vesa
unloaded: fbdev,modesetting,radeon gpu: N/A resolution: 1920x1080~77Hz
OpenGL: renderer: llvmpipe (LLVM 15.0.7 256 bits)
v: 4.5 Mesa 23.2.1-1ubuntu3.1~22.04.2 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 04:00.1
vendor: Hewlett-Packard driver: snd_pci_acp3x v: kernel bus-ID: 04:00.5
Device-3: AMD Family 17h HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 04:00.6
Sound Server-1: ALSA v: k5.15.0-112-generic running: yes
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw_8821ce v: N/A port: f000
bus-ID: 02:00.0
IF-ID-1: virbr0 state: down mac: <filter>
Bluetooth:
Device-1: Realtek Bluetooth 4.2 Adapter type: USB driver: btusb v: 0.8
bus-ID: 1-4:3
Report: hciconfig ID: hci0 rfk-id: 0 state: down
bt-service: enabled,running rfk-block: hardware: no software: yes
address: <filter>
Local Storage: total: 238.47 GiB used: 86.79 GiB (36.4%)
ID-1: /dev/nvme0n1 vendor: SK Hynix model: BC711 HFM256GD3JX013N
size: 238.47 GiB temp: 25.9 C
ID-1: / size: 74.34 GiB used: 62.02 GiB (83.4%) fs: ext4
dev: /dev/nvme0n1p6
ID-2: /boot/efi size: 96 MiB used: 55.4 MiB (57.7%) fs: vfat
dev: /dev/nvme0n1p1
ID-3: /home size: 89.05 GiB used: 24.72 GiB (27.8%) fs: ext4
dev: /dev/nvme0n1p5
Swap:
ID-1: swap-1 type: file size: 1.82 GiB used: 0 KiB (0.0%) file: /swapfile
System Temperatures: cpu: 90.0 C mobo: N/A
Processes: 248 Uptime: 12m Memory: 5.7 GiB used: 2.46 GiB (43.2%)
Init: systemd runlevel: 5 Compilers: gcc: 11.4.0 Packages: 3048 Shell: Bash
v: 5.1.16 inxi: 3.3.13
После установки последних обновлений, не получается запустить ОСь:
Получается запустить только из Дополнительных параметров (recovery mode):
Причём, после выбора RM, достаточно нажать ОК
и ОСь нормально загружается.
После перезагрузки, или выключения, всю процедуру надо проделывать сначала.
Что можно предпринять в создавшейся ситуации, дабы заходить в ОСь нормально, без лишних телодвижений?
...bis dat qui cito dat
07 июн 2024, 21:12
Тебя бьют если ты делаешь нормальные снимки телефоном?
BIM
07 июн 2024, 21:32
Так же не грузилось после последнего обновления. А рецепт простой - загрузится с флешки, хоть тем же минтом, и вернуться в сохраненный образ. Стандартный Таймшифт вполне справляется. Как чайника вполне устраивает, не вникая чего там закоротило.
08 июн 2024, 04:59
1o4ka, грузись на предыдущем ядре, заходи в менеджер обновлений - ядра и удаляй это 112. Потом в менеджере обновлений скажи что не хочешь 112 ядро и жди следующее.
1o4ka
08 июн 2024, 10:30
rogoznik, а как по-вашему, я смог бы снять скрины? В систему зайти не получается, а нужно хотя бы что-то показать. Так что, объяснил проблему, как смог.
BIM писал(а):
07 июн 2024, 21:32
В общем-то, я так и сделал. Всё восстановилось. Но тут же - обновления и... опять всё сначала.
08 июн 2024, 04:59
А вот это, пожалуй, стоит попробовать.
1o4ka
08 июн 2024, 10:44
WWolf, в общем-то, всё получилось. Но вот, МО настойчиво предлагает обновиться:
Как быть? Игнорировать, или - попробовать?
08 июн 2024, 15:29
1o4ka писал(а):
08 июн 2024, 10:30
У тебя телефон что из 2-х тысячных с камерой 0.3 MP? Современный телефон может делать снимки четкие и разрешением минимум 1080p. А на этих не видно ничего.
08 июн 2024, 15:43
1o4ka писал(а):
08 июн 2024, 10:44
Может быть до установки последних обновлений вы что-либо ковыряли в системе? У меня после обновления ядра никаких проблем нету.
$ uname -r
5.15.0-112-generic
1o4ka
08 июн 2024, 20:18
08 июн 2024, 15:29
У тебя телефон
Какой есть. И другого не будет.
madesta писал(а):
08 июн 2024, 15:43
Нет. Ничего я не ковырял.
$ uname -r
5.15.0-101-generic
В общем, от 112-го ядра пришлось отказаться:
т.к., после его установки, не могу зайти в систему.
Советы ещё будут?
09 июн 2024, 00:04
Вы несколько месяцев не обновлялись? Странно, но у меня на второй машине, на которой ещё не отрабатывалось автоудаление ядер через скрипт (раз в месяц) ядро 101 к установке, вроде бы, никогда не предлагалось. На ней имеющиеся ядра имеют номера 112, 107, 92.
1o4ka
09 июн 2024, 11:02
madesta писал(а):
09 июн 2024, 00:04
Нет. МО выведен на панель задач:
ну и, когда он "маякует", тогда и обновляюсь.
Leshiy65
09 июн 2024, 16:07
Такая же проблема была на Runtu Light. Также, решил проблему с заходом с ядра 5.15.0-107 и удалением ядра 112. На другой машине, на Минте даже не пытался обновляться, видимо, с ядром 112 имеются какие-то траблы.
Благодарил (а): 1228 раз
09 июн 2024, 17:23
1o4ka писал(а):
09 июн 2024, 11:02
На скрине апплет погоды. А какой? У меня не работает стандартный. Идёт постоянное обновление, но ничего не обновляется
BIM
09 июн 2024, 20:01
1o4ka писал(а):
08 июн 2024, 10:30
Дык обновление ядра поломало чего-то. Ставите на нём в менеджере правой кнопкой "пропустить данное обновление" и ждёте следующего, которое не такое кривое будет для вашего железа. Снимок системы восстановленный сам по-себе ничего ведь там не исправляет. Обычно ничего срочного в тех версиях нет, и без него ведь работало все. Менджер обновлений может вам обновлять и то, чего вам и не нужно совершенно.
BIM
09 июн 2024, 20:08
hellonet писал(а):
09 июн 2024, 17:23
Так это хорошо, значит не обделён вниманием разработчиков ))).
09 июн 2024, 20:45
BIM писал(а):
09 июн 2024, 20:08
Да нет, просто при наведении мышкой на значок апплета выскакивает окошко "Обновляется", но на самом деле ничего не происходит и погоду не показывает
stasAiver
Благодарил (а): 312 раз
09 июн 2024, 22:36
1o4ka, у меня на старом нотабуке 5.4.0-91, и не хворает. Просто выше не тянет.
09 июн 2024, 22:48
stasAiver писал(а):
09 июн 2024, 22:36
А как будете с LM22, у которого ядро 6... ?
1o4ka
10 июн 2024, 09:39
hellonet писал(а):
09 июн 2024, 17:23
Специально для вас выделил МО (менеджер обновлений) красным цветом. Вы знаете, отлично работает.
BIM писал(а):
09 июн 2024, 20:01
Я тоже так думаю.
madesta писал(а):
09 июн 2024, 22:48
Доживём - увидим.
10 июн 2024, 13:15
1o4ka писал(а):
10 июн 2024, 09:39
Попытался пошутить? Каким боком тут менеджер обновлений. Даже объяснять не хочется
