Помогите разобраться с Самбой
Решено: 215
Благодарил (а): 815 раз
#21
28 мар 2017, 09:42
Этот факап заодно можно притянуть к вопросу безобидности обновлений третьего уровня :smile:
superfish
#22
01 апр 2017, 22:41
не получается создать общую папку в манджаро просто расшарил_thunar-share)
smb.conf
# Sample configuration file for the Samba suite for Debian GNU/Linux.
# This is the main Samba configuration file. You should read the
# smb.conf(5) manual page in order to understand the options listed
# here. Samba has a huge number of configurable options most of which
# are not shown in this example
# Some options that are often worth tuning have been included as
# commented-out examples in this file.
#  - When such options are commented with ";", the proposed setting
#    differs from the default Samba behaviour
#  - When commented with "#", the proposed setting is the default
#    behaviour of Samba but the option is considered important
#    enough to be mentioned here
# NOTE: Whenever you modify this file you should run the command
# "testparm" to check that you have not made any basic syntactic
# errors.
#======================= Global Settings =======================
[global]
## Browsing/Identification ###
# Change this to the workgroup/NT-domain name your Samba server will part of
	workgroup = superfish
# server string is the equivalent of the NT Description field
	server string = %h server (Samba, Ubuntu)
# Windows Internet Name Serving Support Section:
# WINS Support - Tells the NMBD component of Samba to enable its WINS Server
#   wins support = no
# WINS Server - Tells the NMBD components of Samba to be a WINS Client
# Note: Samba can be either a WINS Server, or a WINS Client, but NOT both
;   wins server = w.x.y.z
# This will prevent nmbd to search for NetBIOS names through DNS.
	dns proxy = no
#### Networking ####
# The specific set of interfaces / networks to bind to
# This can be either the interface name or an IP address/netmask;
# interface names are normally preferred
;   interfaces = 127.0.0.0/8 eth0
# Only bind to the named interfaces and/or networks; you must use the
# 'interfaces' option above to use this.
# It is recommended that you enable this feature if your Samba machine is
# not protected by a firewall or is a firewall itself.  However, this
# option cannot handle dynamic or non-broadcast interfaces correctly.
;   bind interfaces only = yes
#### Debugging/Accounting ####
# This tells Samba to use a separate log file for each machine
# that connects
	log file = /var/log/samba/log.%m
# Cap the size of the individual log files (in KiB).
	max log size = 1000
# If you want Samba to only log through syslog then set the following
# parameter to 'yes'.
#   syslog only = no
# We want Samba to log a minimum amount of information to syslog. Everything
# should go to /var/log/samba/log.{smbd,nmbd} instead. If you want to log
# through syslog you should set the following parameter to something higher.
	syslog = 0
# Do something sensible when Samba crashes: mail the admin a backtrace
	panic action = /usr/share/samba/panic-action %d
####### Authentication #######
# Server role. Defines in which mode Samba will operate. Possible
# values are "standalone server", "member server", "classic primary
# domain controller", "classic backup domain controller", "active
# directory domain controller".
# Most people will want "standalone sever" or "member server".
# Running as "active directory domain controller" will require first
# running "samba-tool domain provision" to wipe databases and create a
# new domain.
	server role = standalone server
# If you are using encrypted passwords, Samba will need to know what
# password database type you are using.
;	passdb backend = tdbsam
	obey pam restrictions = yes
# This boolean parameter controls whether Samba attempts to sync the Unix
# password with the SMB password when the encrypted SMB password in the
# passdb is changed.
	unix password sync = yes
# For Unix password sync to work on a Debian GNU/Linux system, the following
# parameters must be set (thanks to Ian Kahan <<kahan@informatik.tu-muenchen.de> for
# sending the correct chat script for the passwd program in Debian Sarge).
	passwd program = /usr/bin/passwd %u
	passwd chat = *Enter\snew\s*\spassword:* %n\n *Retype\snew\s*\spassword:* %n\n *password\supdated\ssuccessfully* .
# This boolean controls whether PAM will be used for password changes
# when requested by an SMB client instead of the program listed in
# 'passwd program'. The default is 'no'.
	pam password change = yes
# This option controls how unsuccessful authentication attempts are mapped
# to anonymous connections
	map to guest = bad user
########## Domains ###########
# The following settings only takes effect if 'server role = primary
# classic domain controller', 'server role = backup domain controller'
# or 'domain logons' is set
# It specifies the location of the user's
# profile directory from the client point of view) The following
# required a [profiles] share to be setup on the samba server (see
# below)
;   logon path = \\%N\profiles\%U
# Another common choice is storing the profile in the user's home directory
# (this is Samba's default)
#   logon path = \\%N\%U\profile
# The following setting only takes effect if 'domain logons' is set
# It specifies the location of a user's home directory (from the client
# point of view)
;   logon drive = H:
#   logon home = \\%N\%U
# It specifies the script to run during logon. The script must be stored
# in the [netlogon] share
# NOTE: Must be store in 'DOS' file format convention
;   logon script = logon.cmd
# This allows Unix users to be created on the domain controller via the SAMR
# RPC pipe.  The example command creates a user account with a disabled Unix
# password; please adapt to your needs
; add user script = /usr/sbin/adduser --quiet --disabled-password --gecos "" %u
# This allows machine accounts to be created on the domain controller via the
# SAMR RPC pipe.
# The following assumes a "machines" group exists on the system
; add machine script  = /usr/sbin/useradd -g machines -c "%u machine account" -d /var/lib/samba -s /bin/false %u
# This allows Unix groups to be created on the domain controller via the SAMR
# RPC pipe.
; add group script = /usr/sbin/addgroup --force-badname %g
############ Misc ############
# Using the following line enables you to customise your configuration
# on a per machine basis. The %m gets replaced with the netbios name
# of the machine that is connecting
;   include = /home/samba/etc/smb.conf.%m
# Some defaults for winbind (make sure you're not using the ranges
# for something else.)
;   idmap uid = 10000-20000
;   idmap gid = 10000-20000
;   template shell = /bin/bash
# Setup usershare options to enable non-root users to share folders
# with the net usershare command.
# Maximum number of usershare. 0 (default) means that usershare is disabled.
;	usershare max shares = 100
# Allow users who've been granted usershare privileges to create
# public shares, not just authenticated ones
	usershare allow guests = yes
	username map = /etc/samba/smbusers
	security = user
;	encrypt passwords = yes
;	guest ok = no
;	guest account = nobody
#======================= Share Definitions =======================
# Un-comment the following (and tweak the other settings below to suit)
# to enable the default home directory shares. This will share each
# user's home directory as \\server\username
;[homes]
;   comment = Home Directories
;   browseable = no
# By default, the home directories are exported read-only. Change the
# next parameter to 'no' if you want to be able to write to them.
;   read only = yes
# File creation mask is set to 0700 for security reasons. If you want to
# create files with group=rw permissions, set next parameter to 0775.
;   create mask = 0700
# Directory creation mask is set to 0700 for security reasons. If you want to
# create dirs. with group=rw permissions, set next parameter to 0775.
;   directory mask = 0700
# By default, \\server\username shares can be connected to by anyone
# with access to the samba server.
# Un-comment the following parameter to make sure that only "username"
# can connect to \\server\username
# This might need tweaking when using external authentication schemes
;   valid users = %S
# Un-comment the following and create the netlogon directory for Domain Logons
# (you need to configure Samba to act as a domain controller too.)
;[netlogon]
;   comment = Network Logon Service
;   path = /home/samba/netlogon
;   guest ok = yes
;   read only = yes
# Un-comment the following and create the profiles directory to store
# users profiles (see the "logon path" option above)
# The path below should be writable by all users so that their
# profile directory may be created the first time they log on
;[profiles]
;   comment = Users profiles
;   path = /home/samba/profiles
;   guest ok = no
;   browseable = no
;   create mask = 0600
[printers]
	comment = All Printers
	browseable = no
	path = /var/spool/samba
	printable = yes
;	guest ok = no
;	read only = yes
	create mask = 0700
# Windows clients look for this share name as a source of downloadable
# printer drivers
[print$]
	comment = Printer Drivers
	path = /var/lib/samba/printers
;	browseable = yes
	writeable = yes
	guest ok = yes
# Uncomment to allow remote administration of Windows print drivers.
# You may need to replace 'lpadmin' with the name of the group your
# admin users are members of.
# Please note that you also need to set appropriate Unix permissions
# to the drivers directory for these users to have write rights in it
;   write list = root, @lpadmin
[fish]
	comment = fish
	path = /home/superfish/fish
	writeable = yes
;	browseable = yes
	valid users = superfish
компы 2 linux mint 1 win xp
Благодарил (а): 1312 раз
#23
23 июл 2017, 13:59
superfish, ваш вопрос был оставлен без ответа скорее всего по той причине, что 1 - он никак не связан с ОС Limux Mint, но это не главное...пользователи здесь добрые и подсказывают по возможности всем независимо от имени и архитектуры. 2 - вопрос не имеет конкретики, т.е. задан он конечно конкретно, но вот с конфигом переборщили. а) - весь конфиг никому неинтересен (хотя можно было его под отдельный спойлер). б) надо было скопировать из него те строки, по которым возник вопрос. с) ну или хотя бы привести к сухому остатку, а именно
[global]
   dns proxy = no
   max log size = 1000
   syslog = 0
   security = user
[printers]
   browseable = no
   printable = yes
   create mask = 0700
[print$]
   writeable = yes
   guest ok = yes
[fish]
   comment = fish
   writeable = yes
Ну и если уж его рассматривать, то мы видим, что параметр browsable для вашей папки fish отсутствует, насчет разрешения для отдельного пользователя сказать не могу. Мой рабочий конфиг выглядит так
[global]
netbios name = Dja
workgroup = working-company
server string = Dja
security = user
dns proxy = no
[pub]
comment = This is a folder accessible from everyone
path = /home/dja/samba/pub
browsable = yes
guest ok = yes
read only = yes
create mask = 0755
[incoming]
path = /home/dja/samba/incoming
browsable = yes
guest ok = yes
read only = no
create mask = 0755
2 папки. Одна только для чтения, другая для обмена.
____________________
и да... лучше было создать новую тему, чем задавать вопрос в теме, на которой уже стоит отметка "Решено". :vic:
StarMAUGLI
Решено: 19
Благодарил (а): 697 раз
#24
19 фев 2018, 17:00
di_mok писал(а):
28 мар 2017, 09:04
Всплыло, в памяти, что примерно год назад тоже у всех самба попадала после обновления
Похоже это у них ежегодная традиция. Каждый год - ходить в баню. ((
Вернуться в «Работа с сетью»
