Длительный "старт" системы Linux Mint 21.3
Благодарил (а): 3 раза
Сообщение 600422 » 11 май 2024, 09:38
сейчас перейду на LM и тоже inxi -Fxz скину
Ну вот. Это уже LM:
Kernel: 5.15.0-106-generic x86_64 bits: 64 compiler: gcc v: 11.4.0
base: Ubuntu 22.04 jammy
Type: Desktop System: ASUS product: N/A v: N/A serial: <superuser required>
Mobo: ASUSTeK model: TUF GAMING B550-PRO v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 3607
date: 03/18/2024
Info: 6-core model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3
rev: 0 cache: L1: 384 KiB L2: 3 MiB L3: 32 MiB
Speed (MHz): avg: 4186 high: 4211 min/max: 2200/4200 boost: disabled
cores: 1: 4194 2: 4154 3: 4199 4: 4197 5: 4211 6: 4192 7: 4170 8: 4202
9: 4157 10: 4201 11: 4204 12: 4160 bogomips: 100797
Device-1: AMD Pitcairn XT [Radeon HD 7870 GHz Edition] vendor: PC Partner
driver: radeon v: kernel bus-ID: 07:00.0
Display: x11 server: X.Org v: 1.21.1.4 driver: X: loaded: ati,radeon
unloaded: fbdev,modesetting,vesa gpu: radeon resolution: 1920x1200~60Hz
OpenGL: renderer: PITCAIRN ( LLVM 15.0.7 DRM 2.50 5.15.0-106-generic)
v: 4.5 Mesa 23.2.1-1ubuntu3.1~22.04.2 direct render: Yes
Device-1: AMD Oland/Hainan/Cape Verde/Pitcairn HDMI Audio [Radeon HD 7000
Series]
vendor: PC Partner driver: snd_hda_intel v: kernel bus-ID: 07:00.1
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 09:00.4
Sound Server-1: ALSA v: k5.15.0-106-generic running: yes
Device-1: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
port: f000 bus-ID: 06:00.0
IF: enp6s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 1.36 TiB used: 17.76 GiB (1.3%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 980 PRO 250GB
size: 232.89 GiB temp: 41.9 C
ID-2: /dev/sda vendor: Seagate model: ST1000DM010-2EP102 size: 931.51 GiB
ID-3: /dev/sdb vendor: Crucial model: CT240BX500SSD1 size: 223.57 GiB
ID-4: /dev/sdc type: USB model: General USB Flash Disk size: 3.73 GiB
ID-1: / size: 41.04 GiB used: 17.7 GiB (43.1%) fs: ext4 dev: /dev/sdb5
ID-2: /boot/efi size: 98.2 MiB used: 36.1 MiB (36.8%) fs: vfat
dev: /dev/nvme0n1p1
Swap:
ID-1: swap-1 type: file size: 1.95 GiB used: 0 KiB (0.0%) file: /swapfile
System Temperatures: cpu: N/A mobo: N/A gpu: radeon temp: 52.0 C
Processes: 325 Uptime: 3m Memory: 31.25 GiB used: 1.99 GiB (6.4%)
Init: systemd runlevel: 5 Compilers: gcc: 11.4.0 Packages: 2391 Shell: Bash
v: 5.1.16 inxi: 3.3.13
Благодарил (а): 54 раза
Сообщение slant » 11 май 2024, 12:50
А что на проблемной машине в USB порты воткнуто? Судя по логу - оно пытается нечто инициализровать, и ~20 секунд тупо ждет отклика от этого нечто. Потом делает ресет на порт и продолжает загрузку...
Теоретически с такими симптомами полудохлый девайс может быть чем угодно - даже вроде бы работающей клавиатурой или мышью...
Решено: 31
Сообщение madesta » 11 май 2024, 14:03
В вашем логе LM обратите внимание на строки 1251-1255. Время (минут) с 20:07 до 20:37
мая 11 04:20:07 600422 kernel: usb 1-5: reset high-speed USB device number 2 using xhci_hcd
мая 11 04:20:21 600422 systemd[1]: systemd-fsckd.service: Deactivated successfully.
мая 11 04:20:22 600422 kernel: usb 1-5: reset high-speed USB device number 2 using xhci_hcd
мая 11 04:20:37 600422 kernel: usb 1-5: reset high-speed USB device number 2 using xhci_hcd
мая 11 04:20:37 600422 systemd[1]: Finished Wait for udev To Complete Device Initialization.
В логе Debian никаких ругательств на kernel: usb 1-5 не наблюдается.
Если логи LM и Debian с одной и той же машины и на ней, как вы говорили, в LM пробовали 6 ядро, то шайтан какой-то ... Может быть крутая беспроводная мышь или клава у вас по usb используется, которую LM плохо воспринимает?
Сообщение 600422 » 11 май 2024, 14:19
11 май 2024, 12:50
А вот как раз именно поэтому и вчера и переустанавливал систему, вытащив все из портов. В данный момент воткнута клавиатура (раритетная, между прочим: Genius конца 90-х годов) через переходник с PS/2 на USB, т.к. на современных матерях PS/2 уже нет, ну и мышка USB ...
Торчит, правда, флешка в порту для перепрошивки UEFI: осталась с тех пор, когда я .... СТОП!!! А не она ли это мозг выносит??? Минутку! Сейчас проверим!
Сообщение 600422 » 11 май 2024, 14:27
ХА!!! Точно она!!! Вот, блт, козявка :)))
systemd-analyze
Startup finished in 8.101s (firmware) + 7.050s (loader) + 5.047s (kernel) + 3.421s (userspace) = 23.621s
graphical.target reached after 3.394s in userspace
systemd-analyze blame
2.118s NetworkManager-wait-online.service
532ms networkd-dispatcher.service
486ms systemd-udev-settle.service
401ms blueman-mechanism.service
347ms udisks2.service
242ms dev-sdb5.device
237ms accounts-daemon.service
180ms ModemManager.service
166ms polkit.service
163ms lightdm.service
162ms plymouth-quit-wait.service
160ms avahi-daemon.service
159ms ubuntu-system-adjustments.service
158ms NetworkManager.service
149ms switcheroo-control.service
147ms thermald.service
146ms systemd-logind.service
145ms wpa_supplicant.service
144ms systemd-journal-flush.service
128ms zfs-load-module.service
117ms gpu-manager.service
117ms networking.service
111ms secureboot-db.service
lines 1-23
ВСЕМ ОГРОМНОЕ СПАСИБО!!! А slant - отдельное спасибо!!!
Как же это я ночью, когда переустанавливал систему, выдернул все, кроме этой козявки на 4 ГБ!!! Вот я балбес ...
Сообщение 600422 » 11 май 2024, 14:33
madesta писал(а):
11 май 2024, 14:03
Все оказалось проще: это не клавиатура 90-х годов, и не заурядная мышь, а флешка на 4 ГБ, засунутая в порт, который специально предназначен для прошивки UEFI (BIOS) и забытая в нем :)))) Она малюсенькая, поэтому я вчера ее и не увидел :))) Она больше на заглушку или на кнопку похожа ... А учитывая то, что блок стоит под столом, а весит он почти 20 кг + мой радикулит, то я не вытаскивал его оттуда, а все выдергивал, можно сказать, за шнуры, а эта козявка без шнурка :))) Вот:
