Linux Mint 21.2 пропал Wi-Fi
Lehora67
03 янв 2024, 04:42
Всё отлично работало и вдруг после очередной загрузки, попал Wi-Fi. Подключился к интернету по кабелю через телефон. Прошу подсказать в чём проблема.
lehora@lehora-XiaoMai6-Plus:~$ inxi -Fxz
  Kernel: 5.15.0-91-generic x86_64 bits: 64 compiler: gcc v: 11.4.0
    Desktop: Cinnamon 5.8.4 Distro: Linux Mint 21.2 Victoria
    base: Ubuntu 22.04 jammy
  Type: Laptop System: Maibenben product: XiaoMai6 Plus v: 5.13_VEB_1AUOK038
    serial: <superuser required>
  Mobo: Maibenben model: XiaoMai6 Plus v: 0.2 serial: <superuser required>
    UEFI: American Megatrends v: 204 date: 09/17/2019
  ID-1: BAT0 charge: 38.7 Wh (98.0%) condition: 39.5/41.6 Wh (95.0%)
    volts: 12.8 min: 11.4 model: M173137 status: N/A
  Info: dual core model: Intel Pentium 5405U bits: 64 type: MT MCP
    arch: Comet/Whiskey Lake note: check rev: C cache: L1: 128 KiB L2: 512 KiB
    L3: 2 MiB
  Speed (MHz): avg: 800 min/max: 400/2300 cores: 1: 800 2: 800 3: 800
    4: 800 bogomips: 18399
  Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
  Device-1: Intel vendor: Pegatron driver: i915 v: kernel bus-ID: 00:02.0
  Device-2: Chicony USB2.0 HD UVC WebCam type: USB driver: uvcvideo
    bus-ID: 1-7:4
    unloaded: fbdev,vesa gpu: i915 resolution: 1920x1080~60Hz
  OpenGL: renderer: Mesa Intel UHD Graphics 610 (WHL GT1)
    v: 4.6 Mesa 23.0.4-0ubuntu1~22.04.1 direct render: Yes
  Device-1: Intel Cannon Point-LP High Definition Audio vendor: Pegatron
    driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
  Sound Server-1: ALSA v: k5.15.0-91-generic running: yes
  Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi
    v: iwlwifi-stack-public:master:9858:4c7cba27 bus-ID: 00:14.3
  IF-ID-1: usb0 state: unknown speed: -1 duplex: half mac: <filter>
Bluetooth:
  Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
    driver: btusb v: 0.8 bus-ID: 1-10:5
  Report: hciconfig ID: hci0 rfk-id: 0 state: down
    bt-service: enabled,running rfk-block: hardware: no software: yes
    address: <filter>
  Device-2: Huawei FLA-LX1 type: USB driver: rndis_host v: kernel
    bus-ID: 1-3:9
  Local Storage: total: 625.99 GiB used: 349.25 GiB (55.8%)
  ID-1: /dev/nvme0n1 vendor: BIWIN model: SSD size: 476.94 GiB temp: 43.9 C
  ID-2: /dev/sda vendor: Hitachi model: HTS541616J9SA00 size: 149.05 GiB
  ID-1: / size: 48.91 GiB used: 37.87 GiB (77.4%) fs: ext4
    dev: /dev/nvme0n1p3
  ID-2: /boot/efi size: 511 MiB used: 8.6 MiB (1.7%) fs: vfat
    dev: /dev/nvme0n1p1
  ID-3: /home size: 414.74 GiB used: 311.07 GiB (75.0%) fs: ext4
    dev: /dev/nvme0n1p4
Swap:
  ID-1: swap-1 type: partition size: 4 GiB used: 310.2 MiB (7.6%)
    dev: /dev/nvme0n1p2
  System Temperatures: cpu: 48.0 C pch: 48.0 C mobo: N/A
  Processes: 236 Uptime: 1h 49m Memory: 7.64 GiB used: 2.05 GiB (26.8%)
  Init: systemd runlevel: 5 Compilers: gcc: 11.4.0 Packages: 2995 Shell: Bash
  v: 5.1.16 inxi: 3.3.13
lehora@lehora-XiaoMai6-Plus:~$ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
3: usb0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UNKNOWN group default qlen 1000
    link/ether 46:bb:63:6c:64:87 brd ff:ff:ff:ff:ff:ff
    inet 192.168.42.234/24 brd 192.168.42.255 scope global dynamic noprefixroute usb0
       valid_lft 2508sec preferred_lft 2508sec
    inet6 fe80::d6db:741c:d8b3:1cda/64 scope link noprefixroute
lehora@lehora-XiaoMai6-Plus:~$ sudo iwconfig
[sudo] пароль для lehora:
lo        no wireless extensions.
usb0      no wireless extensions.
lehora@lehora-XiaoMai6-Plus:~$ sudo lspci
00:00.0 Host bridge: Intel Corporation Coffee Lake Host Bridge/DRAM Registers (rev 0c)
00:02.0 VGA compatible controller: Intel Corporation Device 3ea1 (rev 02)
00:04.0 Signal processing controller: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem (rev 0c)
00:08.0 System peripheral: Intel Corporation Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th/8th Gen Core Processor Gaussian Mixture Model
00:12.0 Signal processing controller: Intel Corporation Cannon Point-LP Thermal Controller (rev 30)
00:14.0 USB controller: Intel Corporation Cannon Point-LP USB 3.1 xHCI Controller (rev 30)
00:14.2 RAM memory: Intel Corporation Cannon Point-LP Shared SRAM (rev 30)
00:14.3 Network controller: Intel Corporation Cannon Point-LP CNVi [Wireless-AC] (rev 30)
00:15.0 Serial bus controller: Intel Corporation Cannon Point-LP Serial IO I2C Controller #0 (rev 30)
00:15.2 Serial bus controller: Intel Corporation Device 9dea (rev 30)
00:16.0 Communication controller: Intel Corporation Cannon Point-LP MEI Controller #1 (rev 30)
00:1d.0 PCI bridge: Intel Corporation Cannon Point-LP PCI Express Root Port #9 (rev f0)
00:1d.7 PCI bridge: Intel Corporation Device 9db7 (rev f0)
00:1f.0 ISA bridge: Intel Corporation Device 9d85 (rev 30)
00:1f.3 Audio device: Intel Corporation Cannon Point-LP High Definition Audio Controller (rev 30)
00:1f.4 SMBus: Intel Corporation Cannon Point-LP SMBus Controller (rev 30)
00:1f.5 Serial bus controller: Intel Corporation Cannon Point-LP SPI Controller (rev 30)
01:00.0 Non-Volatile memory controller: Silicon Motion, Inc. SM2263EN/SM2263XT SSD Controller (rev 03)
02:00.0 SATA controller: ASMedia Technology Inc. ASM1062 Serial ATA Controller (rev 02)
lehora@lehora-XiaoMai6-Plus:~$ rfkill list
0: hci0: Bluetooth
	Soft blocked: yes
	Hard blocked: no
lehora@lehora-XiaoMai6-Plus:~$ lspci -knn | grep net -a2
	Subsystem: Pegatron Cannon Point-LP Shared SRAM [1b0a:2414]
00:14.3 Network controller [0280]: Intel Corporation Cannon Point-LP CNVi [Wireless-AC] [8086:9df0] (rev 30)
	DeviceName: Onboard - Ethernet
	Subsystem: Intel Corporation Cannon Point-LP CNVi [Wireless-AC] [8086:0000]
	Kernel driver in use: iwlwifi
03 янв 2024, 16:59
Lehora67, поищи кнопку на клавиатуре включения/выключения wifi
03 янв 2024, 17:01
rogoznik, Вряд ли на этом ноуте будет такая кнопка.
03 янв 2024, 17:07
symon2014, почему нет. Там точно есть кнопка "самолет"(режим полета), она может вырубать все беспроводные соединения. Вон у него
Lehora67 писал(а):
03 янв 2024, 04:42
0: hci0: Bluetooth
	Soft blocked: yes
Хотя это скорее всего программно вырублено.
Но с чем черт не шутит
03 янв 2024, 17:12
rogoznik, не верю я в такое совпадение. А вот по поводу драйверов iwlwifi много обсуждений. Я уже где то такое встречал. Но в формате переписке на форуме это очень проблематично при скорости реагирования ТС на свою проблему.
Lehora67
04 янв 2024, 02:16
Спасибо за совет по "самолёту", но увы реакции никакой. А вообще функциональные кнопки у меня работают. Яркость экрана и громкость регулируют.
Загружался с флешки тоже вай-фай не включается. Драйвера не требуются в менеджере прверял.
