Переодически пропадает интернет
Kamikaze
Благодарил (а): 6 раз
27 сен 2023, 16:08
Ubuntu 22.04 / Gnome
  Kernel: 6.2.0-33-generic x86_64 bits: 64 compiler: N/A Desktop: GNOME 42.9
    Distro: Ubuntu 22.04.3 LTS (Jammy Jellyfish)
  Type: Desktop System: LENOVO product: 90RE00HKRS
    v: IdeaCentre Gaming5 14IOB6 serial: <superuser required>
  Mobo: LENOVO model: 3730 v: NOK serial: <superuser required> UEFI: LENOVO
    v: M3GKT3BA date: 07/25/2022
  Info: 6-core model: 11th Gen Intel Core i5-11400F bits: 64 type: MT MCP
    arch: Rocket Lake rev: 1 cache: L1: 480 KiB L2: 3 MiB L3: 12 MiB
  Speed (MHz): avg: 1790 high: 2600 min/max: 800/4400 cores: 1: 1268
    2: 2600 3: 2600 4: 1246 5: 1265 6: 2600 7: 1218 8: 2600 9: 1237 10: 2600
    11: 1150 12: 1100 bogomips: 62208
  Device-1: NVIDIA TU116 [GeForce GTX 1660 SUPER] vendor: Micro-Star MSI
    driver: nvidia v: 470.199.02 bus-ID: 01:00.0
  Display: x11 server: X.Org v: 1.21.1.4 driver: X: loaded: nvidia
    unloaded: fbdev,modesetting,nouveau,vesa gpu: nvidia resolution: 1920x1080
  OpenGL: renderer: NVIDIA GeForce GTX 1660 SUPER/PCIe/SSE2
    v: 4.6.0 NVIDIA 470.199.02 direct render: Yes
  Device-1: Intel Tiger Lake-H HD Audio vendor: Lenovo driver: snd_hda_intel
    v: kernel bus-ID: 00:1f.3
  Device-2: NVIDIA TU116 High Definition Audio vendor: Micro-Star MSI
  Sound Server-1: ALSA v: k6.2.0-33-generic running: yes
    vendor: Lenovo driver: r8169 v: kernel port: 3000 bus-ID: 03:00.0
Bluetooth:
  Device-1: TP-Link UB500 Adapter type: USB driver: btusb v: 0.8
    bus-ID: 1-6:3
    bt-v: 3.0 lmp-v: 5.1
  Local Storage: total: 238.47 GiB used: 28.84 GiB (12.1%)
  ID-1: /dev/nvme0n1 vendor: Samsung model: MZALQ256HBJD-00BL1
    size: 238.47 GiB temp: 30.9 C
  ID-1: / size: 233.18 GiB used: 28.83 GiB (12.4%) fs: ext4
    dev: /dev/nvme0n1p2
  ID-2: /boot/efi size: 511 MiB used: 6.1 MiB (1.2%) fs: vfat
    dev: /dev/nvme0n1p1
Swap:
  ID-1: swap-1 type: file size: 2 GiB used: 512 KiB (0.0%) file: /swapfile
  System Temperatures: cpu: 48.0 C mobo: N/A gpu: nvidia temp: 37 C
  Fan Speeds (RPM): N/A gpu: nvidia fan: 22%
  Processes: 307 Uptime: 14m Memory: 7.53 GiB used: 1.86 GiB (24.7%)
  Init: systemd runlevel: 5 Compilers: gcc: N/A Packages: 1784 Shell: Bash
  v: 5.1.16 inxi: 3.3.13
Проблема заключается в том, что переодически пропадает интернет (подключение по кабелю) и его возможно вернуть только перезагрузкий системы.
Пропадает абсолютно случайно при работе/игре/в простое.
Куда копать?
27 сен 2023, 16:10
Kamikaze писал(а):
27 сен 2023, 16:08
Куда копать?
Очевидно в логи
journalctl -r
Последние строки окажутся сверху. Там есть временная метка. Засекаешь когда случилось и смотришь по времени.
28 сен 2023, 03:10
Kamikaze писал(а):
27 сен 2023, 16:08
Чтобы самому специально не отслеживать время пропадания соединения можно это поручить машине. У меня в своё время была проблема с потерей связи wifi компьютера с роутером по случайному закону. Для вычисления примерно когда случилось через cron периодически запускал опрос наличия ответа сети. При отсутствии сети в ходе очередного опроса в файл будет записано примерное время когда пропало соединение. Интервал устанавливается из своих соображений (у меня, напр., было 10 минут). Пример куска скрипта под спойлером. Вместо router.vot можно указать IP своего роутера.
echo -e "GET http://router.vot HTTP/1.0\n\n" | nc router.vot 80 > /dev/null 2>&1
if [ $? -eq 0 ]; then
else
echo "$(date '+%H.%M.%S') ‒ нет сети" >> /home/minter/network.txt
fi
P.S. А обязательно ли перезагружать систему, м.б. достаточно перезапускать сетевое соединение или сам Network Manager?
Kamikaze
28 сен 2023, 14:55
madesta писал(а):
28 сен 2023, 03:10
Обязательно.
Это было первое, что я пытался сделать.
Dja писал(а):
27 сен 2023, 16:10
Очевидно в логи
Вчера интернет больше не пропадал, сейчас только включил ПК, так что буду наблюдать, спасибо.
Kamikaze
08 окт 2023, 23:28
Спустя полторы недели я таки нашел решение, хотя, на мой взгляд, крайне не надежное.
Проблема крылась, судя по всему, в ядре. Как и почему - я не знаю, но после смены ядра с 6.2 на, внимание, 6.1 xanmod (LTS) всё заработало.
Стандартные ядра не давали положительного результата. Ни более старые, ни более новые.
Уже 6 дней как всё работает стабильно.
Логи смотрел и там, как я выяснил, при самовольном отключении интернета система считала, что я как бы сам его выключил. Выключал и сам, картина буквально одна и та же в логах.
Решение не нравится тем, что во-первых, ядро не родное, во-вторых, я так и не понял в чем причина такого поведения.
09 окт 2023, 04:51
А откуда там взялось ядро 6.2, если Ubuntu 22.04 комплектовалось ядром 5.15 ?
09 окт 2023, 05:31
madesta писал(а):
09 окт 2023, 04:51
Взялось не только 6.2 но и 5.19 . Всё из убунты. из 22.10 и 23.04 .
Благодарил (а): 1228 раз
09 окт 2023, 07:37
Kamikaze писал(а):
08 окт 2023, 23:28
У меня всё заработало только на ядре 6.4.8/ Система на других ядрах вообще не запускалась
Как правильно установить LM 21.2 Mate Victoria 64-bit на новое железо (Пост hellonet #134744).4.8#p134744
09 окт 2023, 07:49
Kamikaze писал(а):
08 окт 2023, 23:28
Ну и что. Не всем нравится родное ядро. Не у всех оно нормально работает(у тебя, на пример). Так что взять ядро собранное сторонними энтузиастами или чистое ядро без сторонних патчей - это нормально.
Для Ubuntu(и всех основанных на ней) ядро без патчей можно взять тут ubuntu mainline kernel, либо воспользоваться утилитой
