Долгая загрузка после обновления
Baldie27
Благодарил (а): 9 раз
24 июл 2023, 21:23
Друзья, после обновления до 21.2 система начала очень долго грузиться. Обычно 34-35 сек, но бывает и больше.
при загрузке выдает согласно картинке во вложении.
Вывод :
Kernel: 5.15.0-78-generic x86_64 bits: 64 compiler: gcc v: 11.3.0
Desktop: Cinnamon 5.8.4 Distro: Linux Mint 21.2 Victoria
base: Ubuntu 22.04 jammy
Type: Laptop System: HP product: HP 255 G7 Notebook PC
v: Type1ProductConfigId serial: <superuser required>
Mobo: HP model: 87CE v: 51.27 serial: <superuser required> UEFI: Insyde
v: F.35 date: 02/02/2021
ID-1: BAT1 charge: 40.1 Wh (99.0%) condition: 40.5/40.9 Wh (99.1%)
volts: 13.0 min: 11.3 model: Hewlett-Packard PABAS0241231 status: Charging
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M280/320/275
charge: 55% (should be ignored) status: Discharging
Info: dual core model: AMD Athlon Silver 3050U with Radeon Graphics
bits: 64 type: MCP arch: Zen/Zen+ note: check rev: 1 cache: L1: 192 KiB
L2: 1024 KiB L3: 4 MiB
Speed (MHz): avg: 2443 high: 2542 min/max: 1400/2300 boost: enabled
cores: 1: 2344 2: 2542 bogomips: 9182
Device-1: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
vendor: Hewlett-Packard driver: amdgpu v: kernel bus-ID: 03:00.0
Device-2: Cheng Uei Precision Industry (Foxlink) HP TrueVision HD Camera
type: USB driver: uvcvideo bus-ID: 1-6.1:6
Display: x11 server: X.Org v: 1.21.1.4 driver: X: loaded: amdgpu,ati
unloaded: fbdev,modesetting,vesa gpu: amdgpu resolution: 1920x1080~60Hz
OpenGL: renderer: RAVEN2 (raven2 LLVM 15.0.7 DRM 3.42 5.15.0-78-generic)
v: 4.6 Mesa 22.2.5-0ubuntu0.1~22.04.3 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 03:00.1
vendor: Hewlett-Packard driver: snd_pci_acp3x v: kernel bus-ID: 03:00.5
Device-3: AMD Family 17h HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 03:00.6
Sound Server-1: ALSA v: k5.15.0-78-generic running: yes
vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus-ID: 01:00.0
IF: eno1 state: down mac: <filter>
Device-2: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw_8821ce v: N/A port: 2000
bus-ID: 02:00.0
Bluetooth:
Device-1: Realtek Bluetooth 4.2 Adapter type: USB driver: N/A
bus-ID: 1-6.3:7
Local Storage: total: 238.47 GiB used: 118.2 GiB (49.6%)
ID-1: /dev/sda vendor: Micron model: MTFDDAV256TDL-1AW1ZABHA
ID-1: / size: 74.54 GiB used: 15.01 GiB (20.1%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 488 MiB used: 6.1 MiB (1.2%) fs: vfat
dev: /dev/sda1
ID-3: /home size: 143.16 GiB used: 103.19 GiB (72.1%) fs: ext4
dev: /dev/sda4
Swap:
ID-1: swap-1 type: partition size: 15.18 GiB used: 0 KiB (0.0%)
dev: /dev/sda3
System Temperatures: cpu: 20.0 C mobo: 10.0 C gpu: amdgpu temp: 56.0 C
Processes: 240 Uptime: 4m Memory: 13.59 GiB used: 2.21 GiB (16.3%)
Init: systemd runlevel: 5 Compilers: gcc: 11.3.0 Packages: 2610 Shell: Bash
v: 5.1.16 inxi: 3.3.13
1.564s systemd-udev-settle.service
978ms networkd-dispatcher.service
787ms dev-sda2.device
586ms ubuntu-system-adjustments.service
535ms udisks2.service
505ms e2scrub_reap.service
456ms accounts-daemon.service
397ms systemd-logind.service
378ms networking.service
356ms gpu-manager.service
340ms lightdm.service
299ms apparmor.service
296ms NetworkManager.service
274ms ModemManager.service
249ms kerneloops.service
234ms zfs-load-module.service
224ms polkit.service
214ms grub-common.service
212ms switcheroo-control.service
203ms systemd-rfkill.service
193ms lm-sensors.service
193ms systemd-udev-trigger.service
192ms preload.service
174ms user@1000.service
166ms wpa_supplicant.service
157ms systemd-journald.service
153ms upower.service
142ms rsyslog.service
126ms systemd-resolved.service
123ms systemd-timesyncd.service
119ms systemd-udevd.service
114ms keyboard-setup.service
106ms update-notifier-download.service
81ms lvm2-monitor.service
81ms thermald.service
77ms systemd-journal-flush.service
74ms systemd-fsck@dev-disk-by\x2duuid-0eeb8dba\x2df493\x2d43c7\x2d840a\x2de33>
72ms systemd-fsck@dev-disk-by\x2duuid-34EE\x2d79F6.service
69ms alsa-restore.service
59ms systemd-modules-load.service
45ms zfs-share.service
44ms dev-hugepages.mount
43ms dev-mqueue.mount
42ms sys-kernel-debug.mount
42ms sys-kernel-tracing.mount
39ms kmod-static-nodes.service
35ms modprobe@configfs.service
34ms modprobe@drm.service
33ms sys-fs-fuse-connections.mount
33ms modprobe@fuse.service
32ms sys-kernel-config.mount
31ms modprobe@chromeos_pstore.service
29ms grub-initrd-fallback.service
29ms dev-disk-by\x2duuid-7412dfb9\x2d7237\x2d4625\x2d8043\x2d7b334d82ba4c.swap
29ms colord.service
29ms systemd-random-seed.service
28ms systemd-tmpfiles-setup.service
28ms zfs-volume-wait.service
27ms systemd-sysusers.service
25ms systemd-remount-fs.service
23ms dns-clean.service
21ms setvtrgb.service
16ms user-runtime-dir@1000.service
16ms home.mount
15ms zfs-mount.service
13ms plymouth-read-write.service
12ms console-setup.service
12ms boot-efi.mount
11ms systemd-tmpfiles-setup-dev.service
11ms finalrd.service
10ms systemd-update-utmp.service
10ms systemd-update-utmp-runlevel.service
10ms systemd-backlight@backlight:amdgpu_bl0.service
9ms casper-md5check.service
8ms systemd-user-sessions.service
7ms systemd-sysctl.service
7ms modprobe@ramoops.service
7ms modprobe@pstore_zone.service
6ms ifupdown-pre.service
6ms rtkit-daemon.service
6ms modprobe@efi_pstore.service
4ms openvpn.service
4ms ufw.service
3ms modprobe@pstore_blk.service
2ms plymouth-quit-wait.service
26us blk-availability.service
В чем может быть проблема?
24 июл 2023, 21:55
Baldie27 писал(а):
24 июл 2023, 21:23
В представленных материалах криминала не видно. Покажи вывод systemd-analyze , без blame
Baldie27
25 июл 2023, 00:09
24 июл 2023, 21:55
Startup finished in 23.958s (firmware) + 2.232s (loader) + 3.993s (kernel) + 3.827s (userspace) = 34.011s
graphical.target reached after 3.814s in userspace
До обновления обычно было 17 - 19 сек
25 июл 2023, 06:10
Baldie27 писал(а):
25 июл 2023, 00:09
Покажи вывод journalctl -b | grep firmware , должно быть видно что именно подгружается.
Baldie27
25 июл 2023, 21:09
25 июл 2023, 06:10
июл 25 21:06:44 malov-PC kernel: Spectre V2 : Enabling Speculation Barrier for firmware calls
июл 25 21:06:44 malov-PC kernel: [drm] Found VCN firmware Version ENC: 1.13 DEC: 2 VEP: 0 Revision: 3
июл 25 21:06:44 malov-PC kernel: amdgpu 0000:03:00.0: amdgpu: Will use PSP to load VCN firmware
июл 25 21:06:48 malov-PC NetworkManager[684]: <info> [1690308408.4326] manager[0x55b9a8574040]: monitoring kernel firmware directory '/lib/firmware'.
июл 25 21:06:49 malov-PC systemd[1]: Startup finished in 20.522s (firmware) + 2.263s (loader) + 4.304s (kernel) + 5.204s (userspace) = 32.294s.
Baldie27
26 июл 2023, 19:01
сегодня было еще хуже
Startup finished in 23.993s (firmware) + 3.887s (loader) + 4.452s (kernel) + 25.043s (userspace) = 57.376s
graphical.target reached after 25.015s in userspace
