Запуск .exe файла . Ошибки
Вопросы настройки, запуска любых Windows-программ, кроме игр
Модератор: WWolf
_Pokoi_
Решено: 6
Благодарил (а): 9 раз
Сообщение _Pokoi_ » 05 июн 2023, 16:40
Inxi:
System: Kernel: 5.4.0-150-generic x86_64 bits: 64 compiler: gcc v: 9.4.0 Desktop: Xfce 4.16.0
Distro: Linux Mint 20.2 Uma base: Ubuntu 20.04 focal
Machine: Type: Laptop System: Acer product: Extensa 2520G v: V1.15 serial: <filter>
Mobo: Acer model: BA50_SL v: V1.15 serial: <filter> UEFI [Legacy]: Insyde v: 1.15
date: 05/13/2016
Battery: ID-1: BAT1 charge: 27.7 Wh condition: 27.7/37.0 Wh (75%) model: SANYO AL15A32 status: Full
CPU: Topology: Dual Core model: Intel Core i5-6200U bits: 64 type: MT MCP arch: Skylake rev: 3
L2 cache: 3072 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 19200
Speed: 754 MHz min/max: 400/2301 MHz Core speeds (MHz): 1: 875 2: 880 3: 1051 4: 988
Graphics: Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Acer Incorporated ALI driver: i915
v: kernel bus ID: 00:02.0
Device-2: NVIDIA GK208BM [GeForce 920M] vendor: Acer Incorporated ALI driver: nvidia
v: 470.182.03 bus ID: 01:00.0
Display: x11 server: X.Org 1.20.13 driver: modesetting,nvidia unloaded: fbdev,nouveau,vesa
resolution: 1366x768~60Hz
OpenGL: renderer: NVIDIA GeForce 920M/PCIe/SSE2 v: 4.6.0 NVIDIA 470.182.03 direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: Acer Incorporated ALI driver: snd_hda_intel
v: kernel bus ID: 00:1f.3
Device-2: NVIDIA GK208 HDMI/DP Audio vendor: Acer Incorporated ALI driver: snd_hda_intel
v: kernel bus ID: 01:00.1
Sound Server: ALSA v: k5.4.0-150-generic
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Acer Incorporated ALI
driver: r8169 v: kernel port: 3000 bus ID: 02:00.0
Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter vendor: Lite-On
driver: ath9k v: kernel port: 3000 bus ID: 03:00.0
Device-3: Lite-On Qualcomm Atheros Bluetooth type: USB driver: btusb bus ID: 1-5:6
Drives: Local Storage: total: 238.47 GiB used: 63.13 GiB (26.5%)
ID-1: /dev/sda vendor: Samsung model: P3-256 size: 238.47 GiB temp: 52 C
Partition: ID-1: / size: 233.18 GiB used: 63.13 GiB (27.1%) fs: ext4 dev: /dev/sda5
Sensors: System Temperatures: cpu: 48.5 C mobo: N/A gpu: nvidia temp: 49 C
Info: Processes: 228 Uptime: 52m Memory: 7.64 GiB used: 4.09 GiB (53.6%) Init: systemd runlevel: 5
Compilers: gcc: 9.4.0 Shell: bash v: 5.0.17 inxi: 3.0.38
Ошибки:
wine '/home/leo/.wine/Total War - ROME II by xatab/setup.exe'
002c:fixme:winediag:LdrInitializeThunk wine-staging 8.9 is a testing version containing experimental patches.
002c:fixme:winediag:LdrInitializeThunk Please mention your exact version when filing bug reports on winehq.org.
0084:fixme:hid:handle_IRP_MN_QUERY_ID Unhandled type 00000005
MESA-INTEL: warning: Performance support disabled, consider sysctl dev.i915.perf_stream_paranoid=0
0024:err:module:import_dll Library msvcrt.dll (which is needed by L"C:\\windows\\syswow64\\advapi32.dll") not found
0024:err:module:import_dll Library advapi32.dll (which is needed by L"C:\\windows\\syswow64\\aclui.dll") not found
0024:err:module:import_dll Library advapi32.dll (which is needed by L"C:\\windows\\syswow64\\comctl32.dll") not found
0024:err:module:import_dll Library advapi32.dll (which is needed by L"C:\\windows\\syswow64\\gdi32.dll") not found
0024:err:module:import_dll Library advapi32.dll (which is needed by L"C:\\windows\\syswow64\\user32.dll") not found
0024:err:module:import_dll Library user32.dll (which is needed by L"C:\\windows\\syswow64\\gdi32.dll") not found
0024:err:module:import_dll Library gdi32.dll (which is needed by L"C:\\windows\\syswow64\\comctl32.dll") not found
0024:err:module:import_dll Library advapi32.dll (which is needed by L"C:\\windows\\syswow64\\imm32.dll") not found
0024:err:module:import_dll Library gdi32.dll (which is needed by L"C:\\windows\\syswow64\\imm32.dll") not found
0024:err:module:import_dll Library gdi32.dll (which is needed by L"C:\\windows\\syswow64\\user32.dll") not found
0024:err:module:import_dll Library user32.dll (which is needed by L"C:\\windows\\syswow64\\imm32.dll") not found
0024:err:module:import_dll Library imm32.dll (which is needed by L"C:\\windows\\syswow64\\comctl32.dll") not found
0024:err:module:import_dll Library user32.dll (which is needed by L"C:\\windows\\syswow64\\comctl32.dll") not found
0024:err:module:import_dll Library comctl32.dll (which is needed by L"C:\\windows\\syswow64\\aclui.dll") not found
0024:err:module:import_dll Library gdi32.dll (which is needed by L"C:\\windows\\syswow64\\aclui.dll") not found
0024:err:module:import_dll Library user32.dll (which is needed by L"C:\\windows\\syswow64\\aclui.dll") not found
0024:err:module:import_dll Library aclui.dll (which is needed by L"C:\\windows\\syswow64\\shell32.dll") not found
0024:err:module:import_dll Library advapi32.dll (which is needed by L"C:\\windows\\syswow64\\shell32.dll") not found
0024:err:module:import_dll Library gdi32.dll (which is needed by L"C:\\windows\\syswow64\\shell32.dll") not found
0024:err:module:import_dll Library advapi32.dll (which is needed by L"C:\\windows\\syswow64\\shlwapi.dll") not found
0024:err:module:import_dll Library gdi32.dll (which is needed by L"C:\\windows\\syswow64\\shlwapi.dll") not found
0024:err:module:import_dll Library advapi32.dll (which is needed by L"C:\\windows\\syswow64\\shcore.dll") not found
0024:err:module:import_dll Library shcore.dll (which is needed by L"C:\\windows\\syswow64\\shlwapi.dll") not found
0024:err:module:import_dll Library user32.dll (which is needed by L"C:\\windows\\syswow64\\shlwapi.dll") not found
0024:err:module:import_dll Library shlwapi.dll (which is needed by L"C:\\windows\\syswow64\\shell32.dll") not found
0024:err:module:import_dll Library user32.dll (which is needed by L"C:\\windows\\syswow64\\shell32.dll") not found
0024:err:module:import_dll Library shell32.dll (which is needed by L"C:\\windows\\syswow64\\start.exe") not found
0024:err:module:import_dll Library user32.dll (which is needed by L"C:\\windows\\syswow64\\start.exe") not found
0024:err:module:LdrInitializeThunk Importing dlls for L"C:\\windows\\syswow64\\start.exe" failed, status c0000135
leo@leo-Extensa-2520G:~$ sudo winetricks --self-update
Executing cd /tmp/winetricks.Evz6WEKO
Downloading https://raw.githubusercontent.com/Winet ... winetricks to /tmp/winetricks.Evz6WEKO
--2023-06-05 21:33:12-- https://raw.githubusercontent.com/Winet ... winetricks
Распознаётся raw.githubusercontent.com (raw.githubusercontent.com)… 185.199.110.133, 185.199.109.133, 185.199.108.133, ...
Подключение к raw.githubusercontent.com (raw.githubusercontent.com)|185.199.110.133|:443... соединение установлено.
HTTP-запрос отправлен. Ожидание ответа… 200 OK
Длина: 795784 (777K) [text/plain]
Сохранение в: «winetricks»
winetricks 100%[==========================================>] 777,13K 1,22MB/s за 0,6s
2023-06-05 21:33:12 (1,22 MB/s) - «winetricks» сохранён [795784/795784]
Executing cd /home/leo
Executing mv /tmp/winetricks.Evz6WEKO/winetricks /usr/bin/winetricks.update
Executing rmdir /tmp/winetricks.Evz6WEKO
Executing cp /usr/bin/winetricks /usr/bin/winetricks.bak
Executing chmod -x /usr/bin/winetricks.bak
Executing mv /usr/bin/winetricks.update /usr/bin/winetricks
Executing chmod +x /usr/bin/winetricks
warning: Update finished! The current version is 20230212-next - sha256sum: 38156a2b155ce6a42850aff06c2676c2a03158386b1f9b0ac10c88ccc8cbfb75. Use 'winetricks --update-rollback' to return to the previous version.
leo@leo-Extensa-2520G:~$ wine '/home/leo/.wine/Total War - ROME II by xatab/setup.exe'
Что пробовал, но не помогло :
winetricks vb6run
winetricks vcrun6
winetricks wsh57
winetricks corefonts
Версия Wine:
wine --version
wine-8.9 (Staging)
Решение _Pokoi_ » 06 июн 2023, 08:08
Решение ошибки не было найдено поскольку пропала необходимость в решении этой ошибки ввиду того , что игра запустилась через Portproton . см. эту тему Установка игры через Proton. Код ошибки: -5 (Пост _Pokoi_ #132704)
Благодарил (а): 802 раза
Сообщение rogoznik » 06 июн 2023, 04:03
_Pokoi_, не делай голову ни себе ни нам. У тебя в PortProton запустилось и играет - вот и играй.
_Pokoi_
Решено: 6
Сообщение _Pokoi_ » 06 июн 2023, 08:05
06 июн 2023, 04:03
Я эту тему одновременно выложил с протоном , потом уснул, я никому голву не делаю , вт щас ток за комп сел , удаляю
_Pokoi_
Решено: 6
Сообщение _Pokoi_ » 06 июн 2023, 08:08
Вернуться в «Wine»
