проблемы с SSD
1o4ka
Благодарил (а): 23 раза
проблемы с SSD
26 май 2023, 13:41
NAME="Linux Mint"
VERSION="21.1 (Vera)"
железо:
Kernel: 5.15.0-72-generic x86_64 bits: 64 compiler: gcc v: 11.3.0
base: Ubuntu 22.04 jammy
Type: Laptop System: HP product: HP Laptop 15s-eq1xxx v: N/A
serial: <superuser required>
Mobo: HP model: 8706 v: 99.42 serial: <superuser required> UEFI: AMI
v: F.67 date: 12/29/2022
ID-1: BAT0 charge: 41.4 Wh (100.0%) condition: 41.4/41.4 Wh (100.0%)
volts: 12.9 min: 11.3 model: Hewlett-Packard Primary status: Full
Info: dual core model: AMD Ryzen 3 3250U with Radeon Graphics bits: 64
type: MT MCP arch: Zen/Zen+ note: check rev: 1 cache: L1: 192 KiB
L2: 1024 KiB L3: 4 MiB
Speed (MHz): avg: 1895 high: 2709 min/max: 1400/2600 boost: enabled
cores: 1: 1208 2: 1209 3: 2456 4: 2709 bogomips: 20760
Device-1: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
vendor: Hewlett-Packard driver: amdgpu v: kernel bus-ID: 04:00.0
Device-2: Quanta HP TrueVision HD Camera type: USB driver: uvcvideo
bus-ID: 1-5.2:5
Display: x11 server: X.Org v: 1.21.1.4 driver: X: loaded: amdgpu,ati
unloaded: fbdev,modesetting,vesa gpu: amdgpu resolution: 1920x1080~60Hz
OpenGL: renderer: AMD Radeon Vega 3 Graphics (raven2 LLVM 15.0.7 DRM 3.42
5.15.0-72-generic)
v: 4.6 Mesa 22.2.5 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 04:00.1
vendor: Hewlett-Packard driver: snd_pci_acp3x v: kernel bus-ID: 04:00.5
Device-3: AMD Family 17h HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 04:00.6
Sound Server-1: ALSA v: k5.15.0-72-generic running: yes
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw_8821ce v: N/A port: f000
bus-ID: 02:00.0
Bluetooth:
Device-1: Realtek Bluetooth 4.2 Adapter type: USB driver: btusb v: 0.8
bus-ID: 1-4:3
Report: hciconfig ID: hci0 rfk-id: 2 state: up address: <filter>
bt-v: 2.1 lmp-v: 4.2
Local Storage: total: 238.47 GiB used: 107.9 GiB (45.2%)
ID-1: /dev/nvme0n1 vendor: SK Hynix model: BC711 HFM256GD3JX013N
size: 238.47 GiB temp: 28.9 C
ID-1: / size: 38.32 GiB used: 13.78 GiB (35.9%) fs: ext4
dev: /dev/nvme0n1p6
ID-2: /boot/efi size: 96 MiB used: 55.4 MiB (57.7%) fs: vfat
dev: /dev/nvme0n1p1
ID-3: /home size: 157.36 GiB used: 94.07 GiB (59.8%) fs: ext4
dev: /dev/nvme0n1p5
Swap:
ID-1: swap-1 type: file size: 1.82 GiB used: 0 KiB (0.0%) file: /swapfile
System Temperatures: cpu: 47.0 C mobo: N/A gpu: amdgpu temp: 60.0 C
Processes: 241 Uptime: 1h 11m Memory: 5.71 GiB used: 1.72 GiB (30.1%)
Init: systemd runlevel: 5 Compilers: gcc: 11.3.0 Packages: 2331 Shell: Bash
v: 5.1.16 inxi: 3.3.13
SSD Patriot Burst 2,5" 6Gb/s SATA III 480 GB
В результате аппаратного сбоя, ОСь, установленная на SSD, перестала входить в DE. Т.е., Grub загружался, но в Cunnamon зайти - никак.
Пробовал восстановить ОСь из Timeshift, никакого результата. Пробовал установить ОСь по-новой на SSD, никакого результата. Ось не устанавливается. Пробовал форматировать SSD, удалять разделы, затирать диск, никакого результата. Ни Gparted, ни Paragon не помогли. Paragon выдал резюме:
Файловая система содержит ошибки разметки из-за пересекающихся файлов.
Попытки отыскать решение проблемы по сети ни к чему не привели.
На сегодняшний день SSD лежит мёртвым грузом. С него ничего не получается ни удалить, ни добавить.
Проще всего было бы купить новый SSD, разметить, и восстановить ОСь. Но здесь не продаются SSD.
Помогите решить проблему с SSD. Как его можно отформатировать?
...bis dat qui cito dat
проблемы с SSD
26 май 2023, 13:56
Можно попробовать записать его нулями. Но это будет долго, т.к. объем не маленький. И не факт что будет результат, т.к. есть подозрение что ssd отправился в в электронный рай
Чтоб затереть нулями
sudo dd if=/dev/zero of=/dev/sdX bs=1M status=progress
X заменить на свой индекс, который будет присвоен системой
Посмотреть можно так
sudo fdisk -l
проблемы с SSD
26 май 2023, 14:23
А у меня вообще в глазах раздваивается. В описании железа вижу диск nvme0n1 vendor: SK Hynix model: BC711 HFM256GD3JX013N со странным распределением разделов. А на скрине вроде SSD SATA .
И как его по фотографии лечить ?
1o4ka
проблемы с SSD
26 май 2023, 15:38
rogoznik,
sudo dd if=/dev/zero of=/dev/sda bs=1M status=progress
[sudo] пароль для oleg:
480092618752 байт (480 GB, 447 GiB) скопирован, 1374 s, 349 MB/s
dd: ошибка записи '/dev/sda': На устройстве не осталось свободного места
457863+0 записей получено
457862+0 записей отправлено
480103981056 байт (480 GB, 447 GiB) скопирован, 1374,04 s, 349 MB/s[/icode]
[icode]sudo fdisk -l
Диск /dev/nvme0n1: 238,47 GiB, 256060514304 байт, 500118192 секторов
Disk model: SK hynix BC711 HFM256GD3JX013N
Размер I/O (минимальный/оптимальный): 512 байт / 512 байт
Тип метки диска: gpt
Идентификатор диска: 48FBC0F5-F37D-4691-A21F-8E9D7A0761AB
Устр-во           начало     Конец   Секторы Размер Тип
/dev/nvme0n1p1      2048    206847    204800   100M EFI
/dev/nvme0n1p2    206848    239615     32768    16M Зарезервированный раздел Mic
/dev/nvme0n1p3    239616  79196541  78956926  37,6G Microsoft basic data
/dev/nvme0n1p4  79198208  80306175   1107968   541M Среда для восстановления Mic
/dev/nvme0n1p5 162588672 500117503 337528832 160,9G Файловая система Linux
/dev/nvme0n1p6  80306176 162588671  82282496  39,2G Файловая система Linux
Элементы таблицы разделов упорядочены не так, как на диске.
Диск /dev/sda: 447,13 GiB, 480103981056 байт, 937703088 секторов
Disk model: Super Speed
Размер сектора (логический/физический): 512 байт / 4096 байт
Размер I/O (минимальный/оптимальный): 4096 байт / 4096 байт
Как всё было, так и осталось:
проблемы с SSD
26 май 2023, 15:46
1o4ka, А если сейчас в том же gparted создать на нем gpt разметку, и затем раздел с файловой системой?
он явно врет на скрине, что на sda есть разделы после dd)
1o4ka
проблемы с SSD
26 май 2023, 15:50
26 май 2023, 14:23
Ну...снимают же, как-то, судимость по фотороботу. А тут, всего-то делов: отформатировать диск. Неужто, никак?
Ну, а если серьёзно, я всего лишь выполнил требования форума к задаваемым вопросам:
Пришлось показать железо ноута. А SSD - выносной (внешний) диск. Проблема с ним.
Странное распределение разделов nvme0n1 - вполне объяснимо. Когда полетел SSD, пришлось от /хомяка на nvme отрывать кусок для установки /. / вообще за /хомяком стоял, пока я его не передвинул вперёд. А вот цифру так и не получилось поменять. Да бог с ним, лишь бы работало. Хотя бы, до возвращения из поездки.
проблемы с SSD
26 май 2023, 16:12
1o4ka писал(а):
26 май 2023, 15:38
Иногда бывает необходимо переподключить диск или даже перезагрузиться.
1o4ka
проблемы с SSD
26 май 2023, 16:15
26 май 2023, 15:46
Нет, не врёт. Вот скрины после dd. Специально выделил "неубиваемую" убунту:
Скрин grub'a от LM на SSD:
Но вместо DE вот чего пишется на входе:
Команда
fsck /dev/sda2 -y
найденная по сети, ничего не исправляет. Хотя, по идее, должна. В сети много сайтов расхваливают эту команду, как решение ошибки BusyBox.
Я готов премию выделить тому, кто сумеет отформатировать сей диск.
1o4ka
проблемы с SSD
26 май 2023, 16:16
26 май 2023, 16:12
Конечно же перезагрузился.
проблемы с SSD
26 май 2023, 16:19
Если dd не помогла - значит диску конец. Контроллер ушел в режим readonly.
Можешь конечно поискать по сети утилитки, которые помогут оживить контроллер, но они исключительно для винды, но не факт что найдешь.
проблемы с SSD
26 май 2023, 16:30
26 май 2023, 16:19
должен бы ругнуться при попытках записи, обычно в никуда операции записи не должны улететь)
проблемы с SSD
26 май 2023, 16:33
1o4ka, dmesg | grep sda покажи
проблемы с SSD
26 май 2023, 16:35
26 май 2023, 16:30
Согласен. Но по-другому как еще объяснить что после dd структура ФС осталась
проблемы с SSD
26 май 2023, 16:39
1o4ka писал(а):
26 май 2023, 16:15
Это запись в nvram а не убунта. efibootmgr в помощь.
На скрине gparted примонтированы разделы. Не влияет на dd ?
1o4ka
проблемы с SSD
26 май 2023, 16:45
26 май 2023, 16:33
$ dmesg | grep sda
[ 2.674752] sd 0:0:0:0: [sda] 937703088 512-byte logical blocks: (480 GB/447 GiB)
[ 2.674755] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 2.674950] sd 0:0:0:0: [sda] Write Protect is off
[ 2.674952] sd 0:0:0:0: [sda] Mode Sense: 53 00 00 08
[ 2.675297] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.675635] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes not a multiple of physical block size (4096 bytes)
[ 2.680420] sda: sda1 sda2 sda3 sda4
[ 2.682653] sd 0:0:0:0: [sda] Attached SCSI disk
[ 19.767891] EXT4-fs warning (device sda4): ext4_clear_journal_err:5584: Filesystem error recorded from previous mount: IO failure
[ 19.767898] EXT4-fs warning (device sda4): ext4_clear_journal_err:5586: Marking fs in need of filesystem check.
[ 19.769811] EXT4-fs (sda4): warning: mounting fs with errors, running e2fsck is recommended
[ 19.770589] EXT4-fs warning (device sda2): ext4_clear_journal_err:5584: Filesystem error recorded from previous mount: IO failure
[ 19.770594] EXT4-fs warning (device sda2): ext4_clear_journal_err:5586: Marking fs in need of filesystem check.
[ 19.771448] EXT4-fs (sda2): warning: mounting fs with errors, running e2fsck is recommended
[ 19.772704] EXT4-fs (sda2): recovery complete
[ 19.772710] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: errors=remount-ro. Quota mode: none.
[ 19.780434] EXT4-fs (sda4): recovery complete
[ 19.780446] EXT4-fs (sda4): mounted filesystem with ordered data mode. Opts: errors=remount-ro. Quota mode: none.
[ 23.361315] EXT4-fs error (device sda4): ext4_validate_block_bitmap:390: comm ext4lazyinit: bg 118: bad block bitmap checksum
[ 23.361323] Aborting journal on device sda4-8.
[ 23.361867] EXT4-fs (sda4): Remounting filesystem read-only
[ 24.395481] EXT4-fs error (device sda2): ext4_validate_block_bitmap:390: comm ext4lazyinit: bg 249: bad block bitmap checksum
[ 24.395495] Aborting journal on device sda2-8.
[ 24.396196] EXT4-fs (sda2): Remounting filesystem read-only
[ 24.404188] EXT4-fs error (device sda2): ext4_validate_block_bitmap:390: comm ext4lazyinit: bg 313: bad block bitmap checksum
[ 24.410455] EXT4-fs error (device sda2): ext4_validate_block_bitmap:390: comm ext4lazyinit: bg 485: bad block bitmap checksum
[ 332.685359] EXT4-fs (sda4): error count since last fsck: 13
[ 332.685360] EXT4-fs (sda2): error count since last fsck: 39
[ 332.685366] EXT4-fs (sda4): initial error at time 1684903162: ext4_validate_block_bitmap:390
[ 332.685370] EXT4-fs (sda4): last error at time 1685105956: ext4_validate_block_bitmap:390
[ 332.685371] EXT4-fs (sda2): initial error at time 1684903162: ext4_validate_block_bitmap:390
[ 332.685378] EXT4-fs (sda2): last error at time 1685105957: ext4_validate_block_bitmap:390
[ 1631.094384] sd 0:0:0:0: [sda] tag#25 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD IN
[ 1631.094394] sd 0:0:0:0: [sda] tag#25 CDB: Read(10) 28 00 0b b3 76 f8 00 00 08 00
[ 1631.094499] sd 0:0:0:0: [sda] tag#21 uas_eh_abort_handler 0 uas-tag 2 inflight: CMD IN
[ 1631.094501] sd 0:0:0:0: [sda] tag#21 CDB: Read(10) 28 00 0c a1 df f8 00 00 08 00
[ 1631.094578] sd 0:0:0:0: [sda] tag#17 uas_eh_abort_handler 0 uas-tag 4 inflight: CMD IN
[ 1631.094580] sd 0:0:0:0: [sda] tag#17 CDB: Read(10) 28 00 00 00 08 20 00 00 08 00
[ 1659.774047] sd 0:0:0:0: [sda] tag#13 uas_eh_abort_handler 0 uas-tag 3 inflight: CMD
[ 1659.774054] sd 0:0:0:0: [sda] tag#13 CDB: Synchronize Cache(10) 35 00 00 00 00 00 00 00 00 00
[ 1696.629635] sd 0:0:0:0: [sda] tag#8 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD
[ 1696.629646] sd 0:0:0:0: [sda] tag#8 CDB: Unmap/Read sub-channel 42 00 00 00 00 00 00 00 18 00
[ 1706.857504] sd 0:0:0:0: [sda] tag#8 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD
[ 1706.857510] sd 0:0:0:0: [sda] tag#8 CDB: Test Unit Ready 00 00 00 00 00 00
[ 1707.007193] sd 0:0:0:0: [sda] tag#8 FAILED Result: hostbyte=DID_TIME_OUT driverbyte=DRIVER_OK cmd_age=42s
[ 1707.007198] sd 0:0:0:0: [sda] tag#8 CDB: Unmap/Read sub-channel 42 00 00 00 00 00 00 00 18 00
[ 1707.007200] blk_update_request: I/O error, dev sda, sector 999424 op 0x3:(DISCARD) flags 0x800 phys_seg 1 prio class 0
[ 1707.007514] blk_update_request: I/O error, dev sda, sector 999424 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 1707.007550] blk_update_request: I/O error, dev sda, sector 999424 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 1707.008792] blk_update_request: I/O error, dev sda, sector 999424 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 1707.008801] Buffer I/O error on dev sda2, logical block 0, async page read
[ 1707.008826] blk_update_request: I/O error, dev sda, sector 999424 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 1707.008831] Buffer I/O error on dev sda2, logical block 0, async page read
[ 1707.008862] blk_update_request: I/O error, dev sda, sector 999424 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 1707.008886] blk_update_request: I/O error, dev sda, sector 999424 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 1707.008921] blk_update_request: I/O error, dev sda, sector 196310912 op 0x9:(WRITE_ZEROES) flags 0x800800 phys_seg 0 prio class 0
[ 1707.008942] blk_update_request: I/O error, dev sda, sector 196310912 op 0x1:(WRITE) flags 0x800 phys_seg 16 prio class 0
[ 1707.008963] blk_update_request: I/O error, dev sda, sector 196310912 op 0x9:(WRITE_ZEROES) flags 0x800 phys_seg 0 prio class 0
[ 1707.216571] Buffer I/O error on dev sda2, logical block 7, lost async page write
[ 1707.216600] Buffer I/O error on dev sda2, logical block 8, lost async page write
[ 1707.216603] Buffer I/O error on dev sda2, logical block 9, lost async page write
[ 1707.216606] Buffer I/O error on dev sda2, logical block 10, lost async page write
[ 1707.216609] Buffer I/O error on dev sda2, logical block 11, lost async page write
[ 1707.216611] Buffer I/O error on dev sda2, logical block 12, lost async page write
[ 1707.216614] Buffer I/O error on dev sda2, logical block 13, lost async page write
[ 1707.216616] Buffer I/O error on dev sda2, logical block 14, lost async page write
[ 1820.482051] blk_update_request: I/O error, dev sda, sector 0 op 0x1:(WRITE) flags 0x800 phys_seg 0 prio class 0
[ 1849.953740] blk_update_request: I/O error, dev sda, sector 0 op 0x1:(WRITE) flags 0x800 phys_seg 0 prio class 0
[ 1849.959362] blk_update_request: I/O error, dev sda, sector 211935240 op 0x0:(READ) flags 0x80700 phys_seg 4 prio class 0
[ 1849.959388] blk_update_request: I/O error, dev sda, sector 211935240 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 1849.959394] Buffer I/O error on dev sda4, logical block 1, async page read
[ 1849.959412] blk_update_request: I/O error, dev sda, sector 211935240 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 1849.959416] Buffer I/O error on dev sda4, logical block 1, async page read
[ 1849.966583] blk_update_request: I/O error, dev sda, sector 827385728 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
[ 1849.966620] blk_update_request: I/O error, dev sda, sector 827385728 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 1849.966625] Buffer I/O error on dev sda4, logical block 76931312, async page read
[ 1857.803873] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[ 1858.051811] sd 0:0:0:0: [sda] Synchronize Cache(10) failed: Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK
[ 1863.001249] sd 0:0:0:0: [sda] 937703088 512-byte logical blocks: (480 GB/447 GiB)
[ 1863.001257] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 1863.001442] sd 0:0:0:0: [sda] Write Protect is off
[ 1863.001446] sd 0:0:0:0: [sda] Mode Sense: 53 00 00 08
[ 1863.001779] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1863.002116] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes not a multiple of physical block size (4096 bytes)
[ 1863.007471] sda: sda1 sda2 sda3 sda4
[ 1863.009431] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1863.287905] EXT4-fs warning (device sda2): ext4_clear_journal_err:5584: Filesystem error recorded from previous mount: IO failure
[ 1863.287911] EXT4-fs warning (device sda2): ext4_clear_journal_err:5586: Marking fs in need of filesystem check.
[ 1863.296892] EXT4-fs (sda2): warning: mounting fs with errors, running e2fsck is recommended
[ 1863.302582] EXT4-fs (sda2): recovery complete
[ 1863.302588] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: errors=remount-ro. Quota mode: none.
[ 1863.310501] EXT4-fs warning (device sda4): ext4_clear_journal_err:5584: Filesystem error recorded from previous mount: IO failure
[ 1863.310507] EXT4-fs warning (device sda4): ext4_clear_journal_err:5586: Marking fs in need of filesystem check.
[ 1863.320025] EXT4-fs (sda4): warning: mounting fs with errors, running e2fsck is recommended
[ 1863.331328] EXT4-fs (sda4): recovery complete
[ 1863.331336] EXT4-fs (sda4): mounted filesystem with ordered data mode. Opts: errors=remount-ro. Quota mode: none.
[ 1867.885423] EXT4-fs error (device sda4): ext4_validate_block_bitmap:390: comm ext4lazyinit: bg 118: bad block bitmap checksum
[ 1867.885434] Aborting journal on device sda4-8.
[ 1867.892433] EXT4-fs (sda4): Remounting filesystem read-only
[ 1867.917606] EXT4-fs error (device sda2): ext4_validate_block_bitmap:390: comm ext4lazyinit: bg 249: bad block bitmap checksum
[ 1867.917616] Aborting journal on device sda2-8.
[ 1867.924450] EXT4-fs (sda2): Remounting filesystem read-only
[ 1867.938425] EXT4-fs error (device sda2): ext4_validate_block_bitmap:390: comm ext4lazyinit: bg 313: bad block bitmap checksum
[ 1867.954295] EXT4-fs error (device sda2): ext4_validate_block_bitmap:390: comm ext4lazyinit: bg 485: bad block bitmap checksum
[ 2167.652738] EXT4-fs (sda2): error count since last fsck: 39
[ 2167.652738] EXT4-fs (sda4): error count since last fsck: 13
[ 2167.652775] EXT4-fs (sda4): initial error at time 1684903162: ext4_validate_block_bitmap:390
[ 2167.652778] EXT4-fs (sda2): initial error at time 1684903162: ext4_validate_block_bitmap:390
[ 2167.652786] EXT4-fs (sda4): last error at time 1685107801: ext4_validate_block_bitmap:390
[ 2167.652793] EXT4-fs (sda2): last error at time 1685107801: ext4_validate_block_bitmap:390
26 май 2023, 16:39
Это я пошутил. Неважно, что там написано. Важно, что "неубиваемая".
проблемы с SSD
26 май 2023, 16:49
1o4ka писал(а):
26 май 2023, 16:15
Команда
fsck /dev/sda2 -y
сделай по всем разделам... sda1, sda2, sda4
проблемы с SSD
26 май 2023, 16:52
1o4ka писал(а):
26 май 2023, 16:45
А я не пошутил. Даже обнулив диск начисто эта запись останется , она не на диске а на материнской плате.
1o4ka
проблемы с SSD
26 май 2023, 17:17
26 май 2023, 16:49
Не помогло. Хотя, победную реляцию я получил:
*****File System Was Modified*****
26 май 2023, 16:52
А я не пошутил.
По теме что-либо есть? Или, так и будешь буквоедством заниматься?
проблемы с SSD
26 май 2023, 17:28
1o4ka писал(а):
26 май 2023, 17:17
выхлоп бы посмотреть...
а что не помогло?
vpn-master
проблемы с SSD
26 май 2023, 17:38
1o4ka писал(а):
26 май 2023, 13:41
(Acronis Disk Director - ДИСК В ТВОЁМ РАСПОРЯЖЕНИИ )
(Rufus)
Для создания загрузочной флешки: Rufus Rufus
P.S
Никаких Paragon-ов, и DD... !!!
Делай с диском, всё, что захочешь !
ПЕРЕУСТАНОВКА НЕИЗБЕЖНА !!!
 ! Сообщение из: Chocobo
ссылки заменены с левых файлообменников на официальные
