После установки перевернут экран и отзеркалена работа курсора мышки.
Abdulkareem
05 май 2023, 22:16
Всем доброго дня.
Установил на Teclast Tbook 16 Power, ID:M5F6 Linux Mint 21.1 Cinnamon
  Kernel: 5.15.0-71-generic x86_64 bits: 64 compiler: gcc v: 11.3.0
    base: Ubuntu 22.04 jammy
  Type: Laptop System: TECLAST product: TbooK 16 Power v: N/A
    serial: <superuser required>
  Mobo: TECLAST model: TbooK 16 Power serial: <superuser required>
    UEFI: American Megatrends v: 5.11 date: 04/10/2017
  ID-1: max170xx_battery charge: 27.2 Wh (98.6%)
    condition: 27.6/29.9 Wh (92.2%) volts: 4.2 min: 3.5 model: N/A status: N/A
  Info: quad core model: Intel Atom x7-Z8750 bits: 64 type: MCP arch: Airmont
    rev: 4 cache: L1: 224 KiB L2: 2 MiB
  Speed (MHz): avg: 480 min/max: 480/2560 cores: 1: 480 2: 480 3: 480
    4: 480 bogomips: 12800
  Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
  Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx
    Integrated Graphics
    driver: i915 v: kernel bus-ID: 00:02.0
    unloaded: fbdev,vesa gpu: i915 resolution: 1920x1080~60Hz
  OpenGL: renderer: Mesa Intel HD Graphics (CHV) v: 4.6 Mesa 22.2.5
  Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series
    Imaging Unit
    driver: N/A bus-ID: 00:03.0
  Sound Server-1: ALSA v: k5.15.0-71-generic running: yes
  Sound Server-2: PulseAudio v: 15.99.1 running: no
  Message: No device data found.
  IF-ID-1: wlan0 state: up mac: <filter>
  Local Storage: total: 58.24 GiB used: 11.27 GiB (19.3%)
  ID-1: /dev/mmcblk0 vendor: Samsung model: CWBC3R size: 58.24 GiB
  ID-1: / size: 15.45 GiB used: 11.24 GiB (72.8%) fs: ext4
    dev: /dev/mmcblk0p6
  ID-2: /boot/efi size: 96 MiB used: 30.5 MiB (31.7%) fs: vfat
    dev: /dev/mmcblk0p1
Swap:
  ID-1: swap-1 type: file size: 749.6 MiB used: 0 KiB (0.0%) file: /swapfile
  System Temperatures: cpu: 48.0 C mobo: N/A
  Processes: 216 Uptime: 18m Memory: 7.48 GiB used: 1.06 GiB (14.1%)
  Init: systemd runlevel: 5 Compilers: gcc: 11.3.0 Packages: 2089 Shell: Bash
  v: 5.1.16 inxi: 3.3.13
Информация о системе в меню
Тут немного больше информации.
    tk: GTK 3.24.33 wm: muffin dm: LightDM Distro: Linux Mint 21.1 Vera
  Type: Laptop System: TECLAST product: TbooK 16 Power v: N/A serial: <superuser required>
  Mobo: TECLAST model: TbooK 16 Power serial: <superuser required> UEFI: American Megatrends
  ID-1: max170xx_battery charge: 22.7 Wh (82.2%) condition: 27.6/29.9 Wh (92.2%) volts: 3.8
    min: 3.5 model: N/A serial: N/A status: Discharging
  Info: quad core model: Intel Atom x7-Z8750 bits: 64 type: MCP arch: Airmont rev: 4 cache:
  Speed (MHz): avg: 2550 high: 2560 min/max: 480/2560 cores: 1: 2522 2: 2560 3: 2560 4: 2560
    bogomips: 12800
  Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Integrated Graphics
    driver: N/A bus-ID: 00:02.0 chip-ID: 8086:22b0
  Display: x11 server: X.Org v: 1.21.1.4 driver: X: loaded: vesa unloaded: fbdev,modesetting
    gpu: N/A display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96
  Monitor-1: default res: 1920x1080 size: N/A
  OpenGL: renderer: llvmpipe (LLVM 15.0.7 128 bits)
    v: 4.5 Mesa 23.2.0-devel (git-775e42e 2023-04-30 jammy-oibaf-ppa) direct render: Yes
  Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series Imaging Unit
    driver: N/A bus-ID: 00:03.0 chip-ID: 8086:22b8
  IF-ID-1: wlan0 state: down mac: <filter>
  Local Storage: total: 58.24 GiB used: 12.69 GiB (21.8%)
  ID-1: /dev/mmcblk0 vendor: Samsung model: CWBC3R size: 58.24 GiB serial: <filter>
  ID-1: / size: 15.45 GiB used: 12.66 GiB (82.0%) fs: ext4 dev: /dev/mmcblk0p6
  ID-2: /boot/efi size: 96 MiB used: 30.5 MiB (31.7%) fs: vfat dev: /dev/mmcblk0p1
Swap:
  ID-1: swap-1 type: file size: 749.6 MiB used: 0 KiB (0.0%) priority: -2 file: /swapfile
USB:
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 7 rev: 2.0 speed: 480 Mb/s
    chip-ID: 1d6b:0002
  Device-1: 1-2:4 info: SINO WEALTH USB KEYBOARD type: Keyboard,HID driver: hid-generic,usbhid
    rev: 1.1 speed: 1.5 Mb/s chip-ID: 6080:8061
  Device-2: 1-4:3 info: Novatek Micro HID Compliant Device type: Keyboard,Mouse
    driver: hid-generic,usbhid rev: 1.1 speed: 1.5 Mb/s chip-ID: 0603:1605
  Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s chip-ID: 1d6b:0003
  System Temperatures: cpu: 57.0 C mobo: N/A
Repos:
  Packages: 2151 apt: 2150 flatpak: 1
  No active apt repos in: /etc/apt/sources.list
  Active apt repos in: /etc/apt/sources.list.d/atareao-telegram-jammy.list
    1: deb [arch=amd64 signed-by=/etc/apt/keyrings/atareao-telegram-jammy.gpg] https: //ppa.launchpadcontent.net/atareao/telegram/ubuntu jammy main
    1: deb http: //packages.linuxmint.com vera main upstream import backport
    2: deb http: //archive.ubuntu.com/ubuntu jammy main restricted universe multiverse
    3: deb http: //archive.ubuntu.com/ubuntu jammy-updates main restricted universe multiverse
    4: deb http: //archive.ubuntu.com/ubuntu jammy-backports main restricted universe multiverse
    5: deb http: //security.ubuntu.com/ubuntu/ jammy-security main restricted universe multiverse
  Active apt repos in: /etc/apt/sources.list.d/oibaf-graphics-drivers-jammy.list
    1: deb [arch=amd64 signed-by=/etc/apt/keyrings/oibaf-graphics-drivers-jammy.gpg] https: //ppa.launchpadcontent.net/oibaf/graphics-drivers/ubuntu jammy main
  Processes: 235 Uptime: 2h 44m Memory: 7.48 GiB used: 1.42 GiB (19.0%) Init: systemd v: 249
  runlevel: 5 Compilers: gcc: 11.3.0 alt: 11/12 Client: Unknown python3.10 client inxi: 3.3.13
После установки столкнулся со следующей проблемой:
Сперва загружается экран ввода пароля.
Дисплей имеет нормальную ориентацию, мышь работает не корректно.
Если я двигаю мышь на себя и влево(вниз и влево), то курсор движется вверх и вправо.
После ввода пароля загружается рабочий стол и экран переворачивается.
На гуглил команду:
 xrandr -o normal
Экран переворацивается в нормальное состояние.
Мышь работает не корректно.
Далее по проблеме с мышью нашел на форумах про команду xinput.
xinput list
Вывод:
⎡ Virtual core pointer                    	id=2	[master pointer  (3)]
⎜   ↳ Virtual core XTEST pointer              	id=4	[slave  pointer  (2)]
⎜   ↳ SINO WEALTH USB KEYBOARD Mouse          	id=10	[slave  pointer  (2)]
⎣ Virtual core keyboard                   	id=3	[master keyboard (2)]
    ↳ Virtual core XTEST keyboard             	id=5	[slave  keyboard (3)]
    ↳ Power Button                            	id=6	[slave  keyboard (3)]
    ↳ Video Bus                               	id=7	[slave  keyboard (3)]
    ↳ Power Button                            	id=8	[slave  keyboard (3)]
    ↳ SINO WEALTH USB KEYBOARD                	id=9	[slave  keyboard (3)]
    ↳ SINO WEALTH USB KEYBOARD System Control 	id=11	[slave  keyboard (3)]
    ↳ SINO WEALTH USB KEYBOARD Wireless Radio Control	id=12	[slave  keyboard (3)]
    ↳ SINO WEALTH USB KEYBOARD Consumer Control	id=13	[slave  keyboard (3)]
    ↳ Intel HID events                        	id=14	[slave  keyboard (3)]
    ↳ gpio-keys                               	id=15	[slave  keyboard (3)]
    ↳ gpio-keys                               	id=16	[slave  keyboard (3)]
свойства мыши
xinput --list-props 10
Device 'SINO WEALTH USB KEYBOARD Mouse':
	Device Enabled (181):	1
	Coordinate Transformation Matrix (183):	1.000000, 0.000000, 0.000000, 0.000000, 1.000000, 0.000000, 0.000000, 0.000000, 1.000000
	libinput Natural Scrolling Enabled (320):	0
	libinput Natural Scrolling Enabled Default (321):	0
	libinput Scroll Methods Available (322):	0, 0, 1
	libinput Scroll Method Enabled (323):	0, 0, 0
	libinput Scroll Method Enabled Default (324):	0, 0, 0
	libinput Button Scrolling Button (325):	2
	libinput Button Scrolling Button Default (326):	2
	libinput Button Scrolling Button Lock Enabled (327):	0
	libinput Button Scrolling Button Lock Enabled Default (328):	0
	libinput Middle Emulation Enabled (329):	0
	libinput Middle Emulation Enabled Default (330):	0
	libinput Accel Speed (331):	-0.280000
	libinput Accel Speed Default (332):	0.000000
	libinput Accel Profiles Available (333):	1, 1
	libinput Accel Profile Enabled (334):	1, 0
	libinput Accel Profile Enabled Default (335):	1, 0
	libinput Left Handed Enabled (336):	0
	libinput Left Handed Enabled Default (337):	0
	libinput Send Events Modes Available (305):	1, 0
	libinput Send Events Mode Enabled (306):	0, 0
	libinput Send Events Mode Enabled Default (307):	0, 0
	Device Node (308):	"/dev/input/event5"
	Device Product ID (309):	24704, 32865
	libinput Drag Lock Buttons (338):	<no items>
	libinput Horizontal Scroll Enabled (339):	1
	libinput Scrolling Pixel Distance (340):	15
	libinput Scrolling Pixel Distance Default (341):	15
	libinput High Resolution Wheel Scroll Enabled (342):	1
И далее редактировать Coordinate Transformation Matrix
xinput set-prop 10 183 1 0 0 0 1 0 0 0 -1
Курсор начинает нормально следовать за движениями мышью, но всеравно что бы кликнуть в левый нижний угол, нужно курсор установить в правый верхний угол, курсор будет находится в правом верхнем углу, а клик произойдет в левом нижнем(на меню "пуск")
Я скачивал несколько диструбьютивов Mint, Monjaro, Ubuntu.
С флешки в режиме live Ubuntu не запустилась, висла во время загрузки
.Monjaro запускалась, но переернутый экран и реверсия курсора мышки.
А Mint имел два режима первый обычный загружался с перевернутым дисплеем и реверсией мишки.
Второй Linux Mint compatibility mode загружался нормально, с нормальной ориентацией дисплея и нормально работающей мышью.
После чего я и остановил свой выбор на Linux Mint
Потом попробовал загрузится в recovery mode:
GNU GRUB version 2.06
* Advanced option for Linux Mint 21.1 Cinnamon
  Window Boot Manager (on /def/mmcblk0p1)
  UEFI Firmware Settings
затем
  Linux Mint 21.1 Cinnamon, with Linux 5.15.0-71-generic
* Linux Mint 21.1 Cinnamon, with Linux 5.15.0-71-generic (recovery mode)
Затем:
Recovery menu (filesystem state: read only)
resume      Resume normal boot
clean          Try to make free space
dpkg           Repair broken packages
fsck            Check all file systems
grub           Update grub bootloader
network     Enable networking
root            Drop to root shell promt
system-summary System summary
Жмем OK и загружаемся normal boot
после этого экран имеет нормальную ориентацию и мышь работает нормально, как надо, без инверсий.
Помогите настроить систему что бы в нормалном режиме все работало правильно.
Сейчас пишу из recovery mode. В нормальном режиме с неправильной мышью не возможно пользоваться системой.
Еще вопрос. пробовал смотреть видео, на диске и YouTube, видео идет рывками, звук при этом нормальный, лишь иногда бывает звук зависнет, появляется писк что-то на подобии тонового сигнала 1000 Гц, потом отвиснет и снова все норм. И так может повторятся. Но это сейчас не первостепенно.
Огромное спасибо всем откликнувшимся.
BikeKot
05 май 2023, 22:44
Приветствую!
Относительно недавно боролся с подобным на своём нетбуке.
Судя по описанному - двигаешься в правильном направлении, но, (сейчас уже точно не скажу) когда я решил проблему ориентации экрана, курсора и тача на "рабочем столе" и принялся за lightdm, то выяснилось, что по отдельности они работают, но вместе ломаются.
На данный момент у меня настройки выполнены так:
"рабочий стол" - настройки - экран -> Тут выбрано масштабирование, нужный поворот и во второй вкладке активирован автоматический поворот жкрана т.к. есть акселерометр, который поворачивает экран.
Далее как в этой теме (viewtopic.php?t=7906).
06 май 2023, 06:40
Abdulkareem писал(а):
05 май 2023, 22:16
Насколько помню это при загрузке с флешки есть такой пункт. Устанавливал в систему отсюда ?
Abdulkareem
06 май 2023, 17:14
06 май 2023, 06:40
Да compatibility mode (режим совместимости как я это понял) это пункт на загрузочной флешке.
Загрузился в compatibility mode и там был ярлык, установить Linux Mint.
Я на него нажал и система установилась на emmc-диск.
Сейчас у меня там еще винда, но она прожорливая по накопителю, 64Gb ей не хватает, постоянная нехватка дискового пространства.
Но основна причина, хочется ознакомится с Linux.
Вопрос в чем, в каком файле можно посмотреть настройки экрана и мыши. Что бы применить их к "нормальному режиму", и система сразу загружалась с нормальной ориентацией дисплея и нормально работающей мышкой?
В нормальном режиме мне доступна только консоль.
Поскольку мышка работает не правильно, и ей невозможно пользоваться.
Можно ли как-то откопировать настройки из recovery mode в основной режим?
06 май 2023, 17:44
06 май 2023, 17:14
Если забанен в гугле , то вот ссылка с некоторыми подсказками. Переведёшь сам.
https://forums.linuxmint.com/viewtopic.php?t=198531
17 авг 2023, 13:11
Относительно названия. Работа курсора не отзеркалена. Она нормальна. А вот если бы она была таковой при нормальной ориентации экрана, тогда бы была отзеркалена.
sveta13
Благодарил (а): 47 раз
18 авг 2023, 10:25
sudo apt install --reinstall cinnamon-mouse-settings
Может так, правда у меня xfce.
Debian 12 xfce:LM-22.1 xfce:
Abdulkareem
03 янв 2024, 19:59
Проблему так и не решил. На YouTube нашел видео с точно такой же проблемой как у меня.
https://youtu.be/d9_s9r6jNpA?si=kx5sNBzqBnOM--y5
fdd
06 фев 2024, 09:46
Столкнуося с той же проблемой, что и автор, ставил mint на планшет трансформер irbis tw 103, единственным для меня решением использование версии mint 19.1 , 19.3. При попытке обновиться выше, до 20 версии возникает та же проблема
06 фев 2024, 13:28
fdd, Проблема может быть и та же , но причины могут быть разные. Создай свою отдельную тему.
Сейчас этот форум просматривают: milkchan и 1 гость
