Тор не подключается к интернету
_Pokoi_
Решено: 6
Благодарил (а): 9 раз
24 мар 2023, 16:48
Скачал Тор, сам браузер запускается, но вот к интернету подключения нет. Нажимаю "connecting" а дальше ничего не происходит
Как решить?
Kernel: 6.2.7-x64v3-xanmod1 x86_64 bits: 64 compiler: gcc v: 12.2.0
Desktop: Xfce 4.16.0 Distro: Linux Mint 21.1 Vera base: Ubuntu 22.04 jammy
Type: Laptop System: Acer product: Extensa 2520G v: V1.15
serial: <superuser required>
Mobo: Acer model: BA50_SL v: V1.15 serial: <superuser required>
UEFI-[Legacy]: Insyde v: 1.15 date: 05/13/2016
ID-1: BAT1 charge: 27.6 Wh (97.2%) condition: 28.4/37.0 Wh (76.8%)
volts: 17.4 min: 14.8 model: SANYO AL15A32 status: Charging
Info: dual core model: Intel Core i5-6200U bits: 64 type: MT MCP
arch: Skylake rev: 3 cache: L1: 128 KiB L2: 512 KiB L3: 3 MiB
Speed (MHz): avg: 600 min/max: 400/2800 cores: 1: 600 2: 600 3: 600
4: 600 bogomips: 19200
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Acer Incorporated ALI
driver: i915 v: kernel bus-ID: 00:02.0
Device-2: NVIDIA GK208BM [GeForce 920M] vendor: Acer Incorporated ALI
driver: N/A bus-ID: 01:00.0
Device-3: Realtek HD Webcam - type: USB driver: uvcvideo bus-ID: 1-7:3
Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: modesetting
unloaded: fbdev,vesa gpu: i915 resolution: 1366x768~60Hz
OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 22.2.5
Device-1: Intel Sunrise Point-LP HD Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
Device-2: NVIDIA GK208 HDMI/DP Audio vendor: Acer Incorporated ALI
Sound Server-1: ALSA v: k6.2.7-x64v3-xanmod1 running: yes
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 3000
bus-ID: 02:00.0
Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
vendor: Lite-On driver: ath9k v: kernel bus-ID: 03:00.0
Bluetooth:
Device-1: Lite-On Qualcomm Atheros Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-5:5
Report: hciconfig ID: hci0 rfk-id: 3 state: up address: <filter>
bt-v: 2.1 lmp-v: 4.0
Local Storage: total: 465.76 GiB used: 157.08 GiB (33.7%)
ID-1: /dev/sda vendor: Seagate model: ST500LT012-1DG142 size: 465.76 GiB
ID-1: / size: 423.06 GiB used: 157.07 GiB (37.1%) fs: ext4 dev: /dev/sda4
ID-2: /boot/efi size: 512 MiB used: 6.1 MiB (1.2%) fs: vfat
dev: /dev/sda1
Swap:
ID-1: swap-1 type: file size: 2 GiB used: 143.5 MiB (7.0%) file: /swapfile
ID-2: swap-2 type: zram size: 3.81 GiB used: 277.8 MiB (7.1%)
dev: /dev/zram0
System Temperatures: cpu: 46.0 C pch: 46.0 C mobo: N/A
Processes: 221 Uptime: 3h 19m Memory: 7.63 GiB used: 4.2 GiB (55.1%)
Init: systemd runlevel: 5 Compilers: gcc: 11.3.0 Packages: 2582 Shell: Bash
v: 5.1.16 inxi: 3.3.13
Решение Certion » 28 мар 2023, 09:57
_Pokoi_ писал(а):
24 мар 2023, 16:48
Как решить?
Скачать Tor: https://tor.invidious.site/ru/download/
Добавить мост вручную
Мост
obfs4 84.214.111.31:443 8BA34530612592439610C20A630415F822A6651A cert=/jp9jtq+Q6YnVCiWx4dCMSNlUygileCvSuTKbDlz85PVl4y73LvhvBcOVdoTPVxmS11BTg iat-mode=0
(если подключится к интернету, сделай запрос нового моста)
Мне этот способ помог
После обновления и перезагрузки
24 мар 2023, 17:08
_Pokoi_ писал(а):
24 мар 2023, 16:48
_Pokoi_ писал(а):
24 мар 2023, 16:48
Не слишком пафосное ядро для старого ноута?
А по теме , где брал тор ? Я сейчас взял здесь - https://www.torproject.org/ru/download/
Результаты.
24 мар 2023, 17:21
_Pokoi_ писал(а):
24 мар 2023, 16:48
Как решить?
Посмотреть в логах - что именно происходит. Скриншот конечно красивый, но полезной информации на нем - ноль.
journalctl -b и вперед...
P.S. качать отдельно, скорее всего было не обязательно. TOR доступен в репах большинства дистрибутивов, в Ubuntu в том числе, так что должен по идее быть и в минте доступен.
P.S.S. У вас zram криво сконфигурирован. При доступной памяти, использованям должен быть только zram, а у вас еще и обычный свап затронут. Скорее всего приоритет не выставлен.
24 мар 2023, 17:23
24 мар 2023, 17:21
Может быть. Но привычка есть. В репах может быть запаздывание. Телеграм тоже не ставлю из реп а качаю с ихнего сайта.
vase4kin
Благодарил (а): 13 раз
24 мар 2023, 18:08
Для обхода блокировок, поди? Регион какой? TOR уже наловчились блокировать. У меня, по крайней мере, наглухо.
Вся эта возня в итоге оттолкнула от использования Tor.
Хотя раньше он у меня на виртуалке с Debian крутился и использовался регулярно не только в браузере.
Смешно, но виртуалка с доступом по ssh жрала намного меньше ресурсов чем ТОР-брузер
В итоге перешёл на WireGuard + PBR.
Неожиданностей меньше, а выхлоп более осязаем.
_Pokoi_
Решено: 6
24 мар 2023, 22:23
24 мар 2023, 17:08
_Pokoi_ писал(а):
24 мар 2023, 16:48
_Pokoi_ писал(а):
24 мар 2023, 16:48
Результаты.
Гитхаб, версия на 64 бита.
_Pokoi_
Решено: 6
24 мар 2023, 22:26
24 мар 2023, 17:21
_Pokoi_ писал(а):
24 мар 2023, 16:48
Как решить?
journalctl -b
мар 25 00:06:23 ui-Extensa-2520G kernel: microcode: microcode updated early to revision 0xf0, date = 2021-11-12
мар 25 00:06:23 ui-Extensa-2520G kernel: Linux version 6.2.7-x64v3-xanmod1 (root@mascote) (gcc-12 (Debian 12.2.0-14) 12.2.0, GNU ld (GNU Binutils for Debian) 2.40) #0~>
мар 25 00:06:23 ui-Extensa-2520G kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-6.2.7-x64v3-xanmod1 root=UUID=46516d33-84e2-4fae-917e-b0262dd34387 ro quiet splash
мар 25 00:06:23 ui-Extensa-2520G kernel: KERNEL supported cpus:
мар 25 00:06:23 ui-Extensa-2520G kernel: Intel GenuineIntel
мар 25 00:06:23 ui-Extensa-2520G kernel: AMD AuthenticAMD
мар 25 00:06:23 ui-Extensa-2520G kernel: Hygon HygonGenuine
мар 25 00:06:23 ui-Extensa-2520G kernel: Centaur CentaurHauls
мар 25 00:06:23 ui-Extensa-2520G kernel: zhaoxin Shanghai
мар 25 00:06:23 ui-Extensa-2520G kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
мар 25 00:06:23 ui-Extensa-2520G kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
мар 25 00:06:23 ui-Extensa-2520G kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
мар 25 00:06:23 ui-Extensa-2520G kernel: x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
мар 25 00:06:23 ui-Extensa-2520G kernel: x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
мар 25 00:06:23 ui-Extensa-2520G kernel: x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
мар 25 00:06:23 ui-Extensa-2520G kernel: x86/fpu: xstate_offset[3]: 832, xstate_sizes[3]: 64
мар 25 00:06:23 ui-Extensa-2520G kernel: x86/fpu: xstate_offset[4]: 896, xstate_sizes[4]: 64
мар 25 00:06:23 ui-Extensa-2520G kernel: x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
мар 25 00:06:23 ui-Extensa-2520G kernel: signal: max sigframe size: 2032
мар 25 00:06:23 ui-Extensa-2520G kernel: BIOS-provided physical RAM map:
мар 25 00:06:23 ui-Extensa-2520G kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009e7ff] usable
мар 25 00:06:23 ui-Extensa-2520G kernel: BIOS-e820: [mem 0x000000000009e800-0x000000000009ffff] reserved
мар 25 00:06:23 ui-Extensa-2520G kernel: BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
мар 25 00:06:23 ui-Extensa-2520G kernel: BIOS-e820: [mem 0x0000000000100000-0x000000006834bfff] usable
мар 25 00:06:23 ui-Extensa-2520G kernel: BIOS-e820: [mem 0x000000006834c000-0x000000006834cfff] ACPI NVS
мар 25 00:06:23 ui-Extensa-2520G kernel: BIOS-e820: [mem 0x000000006834d000-0x0000000068376fff] reserved
мар 25 00:06:23 ui-Extensa-2520G kernel: BIOS-e820: [mem 0x0000000068377000-0x0000000068427fff] usable
мар 25 00:06:23 ui-Extensa-2520G kernel: BIOS-e820: [mem 0x0000000068428000-0x0000000068d28fff] reserved
мар 25 00:06:23 ui-Extensa-2520G kernel: BIOS-e820: [mem 0x0000000068d29000-0x0000000075c3dfff] usable
мар 25 00:06:23 ui-Extensa-2520G kernel: BIOS-e820: [mem 0x0000000075c3e000-0x000000007662dfff] reserved
мар 25 00:06:23 ui-Extensa-2520G kernel: BIOS-e820: [mem 0x000000007662e000-0x0000000077fadfff] ACPI NVS
мар 25 00:06:23 ui-Extensa-2520G kernel: BIOS-e820: [mem 0x0000000077fae000-0x0000000077ffdfff] ACPI data
мар 25 00:06:23 ui-Extensa-2520G kernel: BIOS-e820: [mem 0x0000000077ffe000-0x0000000077ffefff] usable
мар 25 00:06:23 ui-Extensa-2520G kernel: BIOS-e820: [mem 0x0000000077fff000-0x00000000780fffff] reserved
мар 25 00:06:23 ui-Extensa-2520G kernel: BIOS-e820: [mem 0x0000000079000000-0x000000007c7fffff] reserved
мар 25 00:06:23 ui-Extensa-2520G kernel: BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
мар 25 00:06:23 ui-Extensa-2520G kernel: BIOS-e820: [mem 0x00000000fd000000-0x00000000fe7fffff] reserved
мар 25 00:06:23 ui-Extensa-2520G kernel: BIOS-e820: [mem 0x00000000feb00000-0x00000000feb03fff] reserved
С менеджера программ та же история, не подключается к интернету
_Pokoi_
Решено: 6
24 мар 2023, 22:32
24 мар 2023, 17:08
Попробовал зайти, сайт не открывается, под Vpn тоже
24 мар 2023, 23:10
_Pokoi_ писал(а):
24 мар 2023, 22:26
journalctl -b
Это обрезок без нужных частей. Я писал сокращенно - куда смотреть самостоятельно. Если хотите предоставить лог - нужно так:
1. После того как запускали TOR и убедились что не соединяется - journalctl -b > tor-log.txt
2. Получившийся файл tor-log.txt (скорее всего десятки килобайт) залить куда-нить на хостинг и дать ссылку на скачивание. Или прикрепить к сообщению, если файл все же получится небольшой и форум пропустит.
vase4kin
25 мар 2023, 00:38
_Pokoi_ писал(а):
24 мар 2023, 22:32
сделайте пока проще:
скачайте на рабочий стол или куда-то ещё:
wget -S "https://antizapret.prostovpn.org/proxy.pac"
Если всё ОК, в Firefox/Настройки/Основные/Настройки сети/Настроить
Указываете путь к своему файлу как на этом скрине (выделено яркостью) Путь, понятно свой.
http://ipic.su/7z0SNG.png
ОК.
И открывайте https://www.torproject.org/ru/
Если proxy.pac не скачается, выложите сюда вывод wget'a (он небольшой будет). Мы потому и не указываем Лису url в Сети, т.к. в случае сбоя не узнаем причину.
upd> не забудьте потом выключить проксирование в Firefox - на той же странице/без прокси/ОК.
_Pokoi_
Решено: 6
28 мар 2023, 04:51
24 мар 2023, 23:10
_Pokoi_ писал(а):
24 мар 2023, 22:26
journalctl -b
tor-log.pdf
(293.41 КБ) 33 скачивания
_Pokoi_
Решено: 6
28 мар 2023, 05:01
vase4kin писал(а):
25 мар 2023, 00:38
_Pokoi_ писал(а):
24 мар 2023, 22:32
ОК.
Cделал как указано было , браузер скачал, но картина та же , не подключается . Просто connecting и все
28 мар 2023, 05:26
_Pokoi_, Я про какой файл говорил? Ну и нахрена здесь PDF в котором похерено форматирование, и невозможно нормально провести поиск через grep? Еще раз повторю - для анализа нужен простой .txt файл.
Без излишеств, как есть.
28 мар 2023, 06:48
_Pokoi_, И не нужно цитировать пост полностью , у всех есть глаза и нет склероза. Достаточно пары слов или обращения по нику.
Vaspet
Благодарил (а): 31 раз
28 мар 2023, 08:18
У меня была похожая ситуация. Стала после блокировки ГКН. VPN не помог. (или не правильно использовал). А как на скрине нажал "отменить" -"настроить"- "использовать мост" - " запросить новый мост"- заполнить вопросы, что не робот- "соединиться". Приходилось и раньше так делать (до блокировки). И если раньше подключался после 2 - 4 запросов, то после блокировки от 4 - 10. Но на удивление соединялся без VPN. (мне надо было на рутор), а после сохранял страницу в закладках. И теперь сразу открывается нужная. Правда на одном компе удалось только поздно вечером. Браузер FF. Может и здесь такое прокатит? Хотя удалось обойти блокировку ТОРа и Rutora
Мигрант От win10 к Linux Mint 21.1
Certion
28 мар 2023, 09:57
_Pokoi_ писал(а):
24 мар 2023, 16:48
Как решить?
Мост
Последний раз редактировалось пользователем 1 rogoznik; всего редактировалось раз: 28
Причина: bbcode
_Pokoi_
Решено: 6
28 мар 2023, 18:27
28 мар 2023, 05:26
https://drive.google.com/file/d/1xDPxmf ... sp=sharing
Последний раз редактировалось пользователем 1 _Pokoi_; всего редактировалось раз: 28
28 мар 2023, 18:30
_Pokoi_, ссылка типа для того чтоб каждый посмотрел свой диск ? Про pastebin слышал ?
_Pokoi_
Решено: 6
28 мар 2023, 18:36
Certion писал(а):
28 мар 2023, 09:57
_Pokoi_ писал(а):
24 мар 2023, 16:48
Как решить?
Мост
Большое спасибо !
Вернуться в «Работа с сетью»
