Установка 3D принтера Kingroon KP3S
volp
Благодарил (а): 35 раз
Сообщение volp » 14 мар 2023, 07:29
Все привет. Имеем такой принтер, установил Ultimaker Cura, хочется теперь печатать не с флешки, а напрямую.
Kernel: 5.15.0-67-generic x86_64 bits: 64 compiler: N/A
Desktop: MATE 1.26.0 Distro: Linux Mint 20.3 Una base: Ubuntu 20.04 focal
Type: Desktop Mobo: KLLISRE model: X79 v: V1.2 serial: <filter>
UEFI: American Megatrends v: 4.6.5 date: 11/15/2021
Topology: 8-Core model: Intel Xeon E5-2650L 0 bits: 64 type: MT MCP
arch: Sandy Bridge rev: 7 L2 cache: 20.0 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 57599
Speed: 1541 MHz min/max: 1200/2300 MHz Core speeds (MHz): 1: 1200 2: 1218
3: 1217 4: 1207 5: 1214 6: 1200 7: 1200 8: 1200 9: 1200 10: 1203 11: 1200
12: 1200 13: 1208 14: 1200 15: 1200 16: 1200
Device-1: NVIDIA GF116 [GeForce GTS 450 Rev. 2] driver: nvidia v: 390.157
bus ID: 03:00.0
Display: x11 server: X.Org 1.20.13 driver: nvidia
unloaded: fbdev,modesetting,nouveau,vesa
resolution: 1280x1024~60Hz, 1280x1024~60Hz
OpenGL: renderer: GeForce GTS 450/PCIe/SSE2 v: 4.6.0 NVIDIA 390.157
Device-1: Intel C600/X79 series High Definition Audio
Device-2: NVIDIA GF116 High Definition Audio driver: snd_hda_intel
v: kernel bus ID: 03:00.1
Sound Server: ALSA v: k5.15.0-67-generic
driver: r8169 v: kernel port: d000 bus ID: 07:00.0
IF: enp7s0 state: up speed: 100 Mbps duplex: full mac: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
IF-ID-2: virbr0-nic state: down mac: <filter>
Local Storage: total: 823.47 GiB used: 91.27 GiB (11.1%)
ID-1: /dev/nvme0n1 model: KLLISRE 256GB size: 238.47 GiB
ID-2: /dev/sda model: KSQ120 size: 111.79 GiB
ID-3: /dev/sdb vendor: Western Digital model: WD5000AAKX-001CA0
ID-4: /dev/sdc type: USB model: Mass Storage Device size: 7.44 GiB
ID-1: / size: 50.99 GiB used: 24.06 GiB (47.2%) fs: ext4
dev: /dev/nvme0n1p2
ID-2: /home size: 182.28 GiB used: 66.92 GiB (36.7%) fs: ext4
dev: /dev/nvme0n1p3
System Temperatures: cpu: 127.5 C mobo: 10.0 C gpu: nvidia temp: 47 C
Fan Speeds (RPM): fan-1: 0 fan-2: 1762 fan-3: 0 fan-4: 0 fan-5: 0
gpu: nvidia fan: 30%
Voltages: 12v: N/A 5v: N/A 3.3v: 3.36 vbat: 3.30
Processes: 343 Uptime: 1h 03m Memory: 15.56 GiB used: 2.24 GiB (14.4%)
Init: systemd runlevel: 5 Compilers: gcc: 9.4.0 Shell: bash v: 5.0.17
inxi: 3.0.38
$ lsusb
Bus 002 Device 007: ID 1a86:7523 QinHeng Electronics HL-340 USB-Serial adapter
Bus 002 Device 008: ID 14cd:1212 Super Top microSD card reader (SY-T18)
Bus 002 Device 004: ID 1a2c:4094 China Resource Semico Co., Ltd
Bus 002 Device 003: ID 09da:000a A4Tech Co., Ltd. Optical Mouse Opto 510D / OP-620D
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Система его видит как QinHeng Electronics HL-340
Вот что лежит в прилагаемом софте
volp@Xeon:/media/volp/disk/software drivers-串口驱动/FTDI USB Drivers$ ls -a -R
. amd64 ftdibus.cat ftdiport.cat i386
.. ftd2xx.h ftdibus.inf ftdiport.inf Static
./amd64:
. ftbusui.dll ftd2xx64.dll ftdibus.sys ftser2k.sys
.. ftcserco.dll ftd2xx.lib ftlang.dll ftserui2.dll
./i386:
. ftbusui.dll ftd2xx.dll ftdibus.sys ftser2k.sys
./Static:
. .. amd64 i386
./Static/amd64:
. .. ftd2xx.lib
./Static/i386:
. .. ftd2xx.lib
Ultimaker Cura его видеть не хочет, или я не знаю как это сделать. В установленных принтерах он тоже не добавлен. Как заставить Cura с ним работать ?
Решено: 43
Благодарил (а): 1759 раз
Сообщение WWolf » 14 мар 2023, 07:33
volp, ставить винду или виртуалку с виндой и работать...
volp
Сообщение volp » 14 мар 2023, 07:53
14 мар 2023, 07:33
:-D виндов у меня есть всяких, хочется же по феншую все сделать, тем более производитель заявил о поддержке в линуксе.
Решено: 43
Сообщение WWolf » 14 мар 2023, 08:10
volp, ну попробуй запустить под вайном... QinHeng Electronics HL-340 обычный компорт... но судя по библиотекам из комплекта, софт 99% будет пытаться работать через них со всеми вытекающими...
Благодарил (а): 803 раза
Сообщение rogoznik » 14 мар 2023, 08:22
volp, тут, вроде как, под MacOs запускают. Но думаю и под линукс должно получиться
