Kernel: 5.15.0-67-generic x86_64 bits: 64 compiler: gcc v: 11.3.0
Desktop: Xfce 4.16.0 Distro: Linux Mint 21.1 Vera base: Ubuntu 22.04 jammy
Type: Desktop System: Gigabyte product: A320M-H v: N/A
serial: <superuser required>
Mobo: Gigabyte model: A320M-H-CF v: x.x serial: <superuser required>
UEFI-[Legacy]: American Megatrends v: F50 date: 11/28/2019
Info: 6-core model: AMD Ryzen 5 1600 bits: 64 type: MT MCP arch: Zen rev: 1
cache: L1: 576 KiB L2: 3 MiB L3: 16 MiB
Speed (MHz): avg: 1826 high: 3369 min/max: 1550/3200 boost: enabled
cores: 1: 1477 2: 1375 3: 1374 4: 1546 5: 1398 6: 1547 7: 3369 8: 1356
9: 3121 10: 2338 11: 1474 12: 1547 bogomips: 76646
Device-1: NVIDIA GP107 [GeForce GTX 1050] vendor: Micro-Star MSI
driver: nvidia v: 525.85.05 bus-ID: 08:00.0
Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: nvidia
unloaded: fbdev,modesetting,nouveau,vesa gpu: nvidia
resolution: 1680x1050~60Hz
OpenGL: renderer: NVIDIA GeForce GTX 1050/PCIe/SSE2
v: 4.6.0 NVIDIA 525.85.05 direct render: Yes
Device-1: NVIDIA GP107GL High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 08:00.1
Device-2: AMD Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus-ID: 0a:00.3
Sound Server-1: ALSA v: k5.15.0-67-generic running: yes
vendor: Gigabyte driver: r8169 v: kernel port: f000 bus-ID: 07:00.0
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 1.81 TiB used: 181.86 GiB (9.8%)
ID-1: /dev/nvme0n1 model: NX-512 size: 476.94 GiB temp: 40.9 C
ID-2: /dev/sda vendor: Seagate model: ST1000DM003-1CH162 size: 931.51 GiB
ID-3: /dev/sdb vendor: Kingston model: SA400S37480G size: 447.13 GiB
ID-1: / size: 475.94 GiB used: 181.63 GiB (38.2%) fs: btrfs
dev: /dev/nvme0n1p3
ID-2: /boot size: 1006.7 MiB used: 232.6 MiB (23.1%) fs: ext2
dev: /dev/nvme0n1p2
ID-3: /home size: 475.94 GiB used: 181.63 GiB (38.2%) fs: btrfs
dev: /dev/nvme0n1p3
Swap:
Alert: No swap data was found.
System Temperatures: cpu: 16.8 C mobo: N/A gpu: nvidia temp: 39 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 35%
Processes: 332 Uptime: 32m Memory: 15.57 GiB used: 3.73 GiB (24.0%)
Init: systemd runlevel: 5 Compilers: gcc: 11.3.0 Packages: 2074 Shell: Bash
v: 5.1.16 inxi: 3.3.13
dev: /dev/nvme0n1p3
dev: /dev/nvme0n1p2
dev: /dev/nvme0n1p3
Swap:
Видеокарта:
Модель: Mesa/X.org llvmpipe (LLVM 15.0.6, 256 bits)
Версия драйвера: 4.5 (Compatibility Profile) Mesa 22.2.5
Версия OpenGL: 4.5
Глубина цвета: 24 бит/пиксель
Частота обновления: 59 Гц
ID производителя: 0x10de
ID карты: 0x1c81
Версия неизвестна
Кол-во экранов: 1
Количество логических видеокарт: 1
Разрешение осн. экрана: 1680 x 1050
Разрешение рабочего стола: 1680 x 1050
Размер осн. экрана: 18.62" x 11.65" (21.93" diag)
47.3cm x 29.6cm (55.7cm diag)
Осн. шина: PCI Express 16x
Размер видеопамяти не определен
Поддерживаемое сглаживание: 2x 4x 8x 16x
Версия OpenGL: 4.5
ID карты: 0x1c81
Версия неизвестна
Кол-во экранов: 1
Видеокарта:
Модель: NVIDIA Corporation NVIDIA GeForce GTX 1050/PCIe/SSE2
Версия драйвера: 4.6.0 NVIDIA 525.78.01
Версия OpenGL: 4.6
ID карты: 0x1c81
Версия неизвестна
Кол-во экранов: 1
Осн. видеопамять: 2048 МБ
Версия OpenGL: 4.6
ID карты: 0x1c81
Версия неизвестна
Кол-во экранов: 1
