Наши инсталляции Linux Mint
Какие версии ОС вы используете в повседневности
Linux Mint 18+ (Новое, значит лучшее)
43
61%
Linux Mint 17.x (Стабильность оттачиваемая годами)
15
21%
LMDE2 (Поближе к дебиановским корням)
3
4%
Другие дистрибутивы (DEB/RPM/Source-based)
9
13%
Всего голосов: 70
#41
10 фев 2018, 15:59
vir0id@15-bw0xx ~ $ inxi -Fxz
System:    Host: 15-bw0xx Kernel: 4.13.0-26-generic x86_64 (64 bit gcc: 5.4.0)
           Desktop: MATE 1.18.0 (Gtk 3.18.9-1ubuntu3.3) Distro: Linux Mint 18.3 Sylvia
Machine:   System: HP product: HP Laptop 15-bw0xx v: Type1ProductConfigId
           Mobo: HP model: 8330 v: 27.28 Bios: Insyde v: F.13 date: 09/07/2017
CPU:       Dual core AMD A9-9420 RADEON R5 5 COMPUTE CORES 2C+3G (-MCP-) cache: 2048 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm) bmips: 11977
           clock speeds: max: 3000 MHz 1: 1800 MHz 2: 2400 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] Device 98e4 bus-ID: 00:01.0
           Display Server: X.Org 1.18.4 drivers: ati,amdgpu (unloaded: fbdev,vesa,radeon)
           Resolution: 1366x768@60.02hz
           GLX Renderer: AMD STONEY (DRM 3.18.0 / 4.13.0-26-generic, LLVM 5.0.0)
           GLX Version: 3.0 Mesa 17.2.4 Direct Rendering: Yes
Audio:     Card-1 Advanced Micro Devices [AMD] Device 157a driver: snd_hda_intel bus-ID: 00:09.2
           Card-2 Advanced Micro Devices [AMD/ATI] Device 15b3 driver: snd_hda_intel bus-ID: 00:01.1
           Sound: Advanced Linux Sound Architecture v: k4.13.0-26-generic
Network:   Card-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
           driver: r8169 v: 2.3LK-NAPI port: 3000 bus-ID: 02:00.0
           Card-2: Realtek Device d723 driver: rtl8723de v: v5.1.1.8_21285.20171026 port: 2000 bus-ID: 03:00.0
           IF: wlo1 state: up speed: N/A duplex: N/A mac: <filter>
Drives:    HDD Total Size: 1000.2GB (18.8% used) ID-1: /dev/sda model: WDC_WD10JPVX size: 1000.2GB
Partition: ID-1: / size: 157G used: 16G (11%) fs: ext4 dev: /dev/sda6
           ID-2: /home size: 289G used: 155G (57%) fs: ext4 dev: /dev/sda7
           ID-3: swap-1 size: 5.10GB used: 0.00GB (0%) fs: swap dev: /dev/sda5
Sensors:   System Temperatures: cpu: 47.0C mobo: 20.0C gpu: 0.0
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 212 Uptime: 2 days Memory: 3798.4/7439.3MB Init: systemd runlevel: 5 Gcc sys: 5.4.0
ikrost
Благодарил (а): 831 раз
#42
11 фев 2018, 11:07
Чёто я не врубаюсь, до команды sensors нужно что-то установить?
#43
11 фев 2018, 11:10
ikrost, проверь есть ли пакет lm-sensors, он у нас идет в базовой поставке дистрибутива
ikrost
#44
11 фев 2018, 11:15
11 фев 2018, 11:10
lm-sensors
Есть. Но ввожу команду сенсорс он гордо пишет:
$ sensors
No sensors found!
Make sure you loaded all the kernel drivers you need.
Try sensors-detect to find out which these are.
#45
11 фев 2018, 11:22
ikrost писал(а):
11 фев 2018, 11:15
Try sensors-detect
Послушай умную машину - sudo sensors-detect :hoho:
ikrost
#46
11 фев 2018, 11:41
11 фев 2018, 11:22
Ежкин кот, я до конца и не дочитывал :)
BadBird
Благодарил (а): 175 раз
#47
28 фев 2018, 12:18
Как то так:
System:    Host: Home Kernel: 4.13.0-36-generic x86_64 (64 bit gcc: 5.4.0)
           Desktop: Xfce 4.12.3 (Gtk 2.24.28) Distro: Ubuntu 16.04 xenial
Machine:   Mobo: Gigabyte model: M68MT-S2P v: x.x
           Bios: Award v: F1 date: 12/24/2010
CPU:       Quad core AMD Phenom II X4 850 (-MCP-) cache: 2048 KB
           flags: (lm nx sse sse2 sse3 sse4a svm) bmips: 26518
           clock speeds: max: 3300 MHz 1: 2000 MHz 2: 800 MHz 3: 2000 MHz
           4: 2000 MHz
Graphics:  Card: NVIDIA GF104 [GeForce GTX 460 SE] bus-ID: 02:00.0
           Display Server: X.Org 1.19.5 driver: nvidia
           Resolution: 1920x1080@60.00hz
           GLX Renderer: GeForce GTX 460 SE/PCIe/SSE2
           GLX Version: 4.6.0 NVIDIA 390.25 Direct Rendering: Yes
Audio:     Card-1 NVIDIA GF104 High Definition Audio Controller
           driver: snd_hda_intel bus-ID: 02:00.1
           Card-2 NVIDIA MCP61 High Definition Audio
           driver: snd_hda_intel bus-ID: 00:05.0
           Sound: Advanced Linux Sound Architecture v: k4.13.0-36-generic
Network:   Card: NVIDIA MCP61 Ethernet
           driver: forcedeth port: f000 bus-ID: 00:07.0
           IF: enp0s7 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives:    HDD Total Size: 659.8GB (45.5% used)
           ID-1: /dev/sda model: TS128GSSD370S size: 128.0GB
           ID-2: /dev/sdb model: SATA_32GB_SSD size: 31.7GB
           ID-3: /dev/sdc model: WDC_WD5000AAKX size: 500.1GB
Partition: ID-1: / size: 20G used: 9.3G (50%) fs: ext4 dev: /dev/sdb1
Sensors:   System Temperatures: cpu: 22.5C mobo: N/A gpu: 0.0:42C
Info:      Processes: 182 Uptime: 31 min Memory: 1146.7/7975.9MB
