Помогите избавиться от аврийного режима.
1o4ka
Благодарил (а): 23 раза
08 дек 2022, 18:30
После установки обновлений, 8 декабря, не могу войти в cinnamon.
LM 21x64
Сinnamon
Железо:
$ inxi -Fxz
Kernel: 5.15.0-52-generic x86_64 bits: 64 compiler: gcc v: 11.2.0
Desktop: Cinnamon 5.4.12 Distro: Linux Mint 21 Vanessa
base: Ubuntu 22.04 jammy
Type: Desktop Mobo: Gigabyte model: H81M-S2PV serial: <superuser required>
UEFI: American Megatrends v: F9 date: 08/11/2015
Info: dual core model: Intel Pentium G3420 bits: 64 type: MCP arch: Haswell
rev: 3 cache: L1: 128 KiB L2: 512 KiB L3: 3 MiB
Speed (MHz): avg: 2642 high: 3191 min/max: 800/3200 cores: 1: 2094
2: 3191 bogomips: 12770
Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
vendor: Gigabyte driver: i915 v: kernel bus-ID: 00:02.0
Device-2: NVIDIA GM107 [GeForce GTX 750] vendor: Palit Microsystems
driver: nouveau v: kernel bus-ID: 01:00.0
Device-3: Sunplus Innovation HD 720P webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 3-4:3
Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: modesetting
unloaded: fbdev,vesa gpu: nouveau resolution: 1920x1080~60Hz
OpenGL: renderer: NV117 v: 4.3 Mesa 22.0.5 direct render: Yes
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
driver: snd_hda_intel v: kernel bus-ID: 00:03.0
Device-2: Intel 8 Series/C220 Series High Definition Audio
vendor: Gigabyte driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Device-3: NVIDIA GM107 High Definition Audio [GeForce 940MX]
vendor: Palit Microsystems driver: snd_hda_intel v: kernel bus-ID: 01:00.1
Device-4: Sunplus Innovation HD 720P webcam type: USB
Sound Server-1: ALSA v: k5.15.0-52-generic running: yes
vendor: Gigabyte driver: r8169 v: kernel port: d000 bus-ID: 03:00.0
Device-2: Ralink MT7601U Wireless Adapter type: USB driver: mt7601u
bus-ID: 3-1:2
IF: wlx1cbfcef72bfe state: up mac: <filter>
Local Storage: total: 1.35 TiB used: 52.69 GiB (3.8%)
ID-1: /dev/sda vendor: Patriot model: Burst Elite 480GB size: 447.13 GiB
ID-2: /dev/sdb vendor: Toshiba model: DT01ACA050 size: 465.76 GiB
ID-3: /dev/sdc vendor: Toshiba model: DT01ACA050 size: 465.76 GiB
ID-4: /dev/sdd type: USB model: USB DISK 2.0 size: 7.22 GiB
ID-1: / size: 97.97 GiB used: 12.02 GiB (12.3%) fs: ext4 dev: /dev/sda5
ID-2: /boot/efi size: 96 MiB used: 30.3 MiB (31.5%) fs: vfat
dev: /dev/sda1
ID-3: /home size: 245.44 GiB used: 40.56 GiB (16.5%) fs: ext4
dev: /dev/sda7
Swap:
ID-1: swap-1 type: partition size: 16.6 GiB used: 0 KiB (0.0%)
dev: /dev/sda6
ID-2: swap-2 type: partition size: 8 GiB used: 0 KiB (0.0%)
dev: /dev/sdb5
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nouveau temp: 40.0 C
Processes: 223 Uptime: 23h 29m Memory: 15.52 GiB used: 3.56 GiB (22.9%)
Init: systemd runlevel: 5 Compilers: gcc: 11.3.0 Packages: 2719 Shell: Bash
v: 5.1.16 inxi: 3.3.13
(железо списано из предыдущего моего поста)
При входе в систему появляется надпись:
You are in emergency mode. After logging in, type "journalctl -xb" to view system logs, "systemctl reboot" to reboot, "systemctl default" or "exit" to boot into default mode.
перевод:
Вы находитесь в аварийном режиме. После входа введите «journalctl -xb» для просмотра системных журналов, «systemctl reboot» для перезагрузки, «systemctl default» или «exit» для загрузки в режим по умолчанию.
При вводе "journalctl -xb" выскакивает длиннющая портянка, от которой не могу избавиться. Приходится перезагружать комп принудительно.
При вводе "systemctl reboot" не происходит ничего. Опять появляется текст, приведённый выше.
При вводе «systemctl default» появляется заставка входа в ОС, но в саму ОС зайти не получается. После ввода пароля появляется опять заставка входа в ОСу. Но зато есть возможность перезагрузить комп программно.
При вводе «exit» не происходит ничего. Опять появляется текст, приведённый выше.
Помогите справиться с ситуацией. Что можно применить?
...bis dat qui cito dat
Белый Кролик
Решено: 10
Благодарил (а): 354 раза
08 дек 2022, 19:17
Я понял только что у тебя в ПК две видеокарты невидия, причем вторая от ноутбука. :crazy: Загружен драйвер modesetting вместо nvidia (или хотя бы nouveau) или что там у зеленых. Переустанови драйвер видеокарты.
1o4ka
08 дек 2022, 19:22
Белый Кролик писал(а):
08 дек 2022, 19:17
Как? Я в ОСу зайти не могу.
Белый Кролик
Решено: 10
08 дек 2022, 19:25
1o4ka, из командной строки в которой вводишь journalctl -xb и прочее.
Белый Кролик
Решено: 10
08 дек 2022, 19:27
sudo apt purge nvidia- *
sudo apt install xserver-xorg-video-nouveau
systemctl reboot
1o4ka
08 дек 2022, 19:52
08 дек 2022, 19:27
Ответ системы:
Чтение списков пакетов... Готово
Построение дерева зависимостей... Готово
Чтение информации о состоянии... Готово
Пакет "nvidia" не установлен, поэтому не может быть удалён
Е: Невозможно найти пакет Desktop
08 дек 2022, 19:27
Уже установлен пакет xserver-xorg-video-nouveau самой новой версии (1:1.0.17-2build1)
08 дек 2022, 19:27
systemctl reboot
Ответ системы:
Ара Магеддон
Решено: 18
Благодарил (а): 37 раз
09 дек 2022, 01:47
nouveau уже установлен, но по какой-то причине не запускается, что для него весьма характерно.
Тут можно попробовать установить проприетарный драйвер из командной строки: apt install nvidia-driver-525 и перезагрузиться. Как вариант - поставить версию драйвера постарее, например 510 (которая шла "из коробки"), или 470. Также в репозиториях появились открытые версии последних драйверов, из пока ставить не стоит: тоже часто не взлетают.
Сотрудник
09 дек 2022, 09:29
1o4ka, А timeshift не может вернуть систему в рабочее состояние, программу создали чтобы при проблемах всё исправить? Если сделаны снимки рабочей системы и есть загрузочная флешка c LM, можно из снимка вернуть систему в рабочий вид, порядок действий Видео
1o4ka
09 дек 2022, 10:50
Ара Магеддон писал(а):
09 дек 2022, 01:47
Не могу перейти на русский расклад клавы. Система сообщает, какие пакеты будут установлены и т.д. Потом пишет:
Хотите продолжить? [Д/н]
Надо ответить на русском языке (ввести Д)
По умолчанию, для переключения клавы, у меня назначены Shift + Alt. Не срабатывает.
Также, никакие известные мне сочетания клавиш не срабатывают.
09 дек 2022, 11:05
1o4ka, можно ответить yes
yarichin
09 дек 2022, 11:24
1o4ka писал(а):
09 дек 2022, 10:50
Ничего вводить не надо , большая буква - значение по умолчанию , просто нажать энтер.
1o4ka
09 дек 2022, 14:26
09 дек 2022, 01:47
К сожалению, номер не прошёл. Во время установки - одни игноры да ошибки:
не удалось разрешить "archive.ubuntu.com"
09 дек 2022, 14:36
1o4ka, inxi -r покажи и рассказвай что пытался поставить...
1o4ka
09 дек 2022, 15:07
09 дек 2022, 14:36
Пытался поставить проприетарный драйвер из командной строки: apt install nvidia-driver-525.
1o4ka
09 дек 2022, 16:49
Сотрудник писал(а):
09 дек 2022, 09:29
Этот номер тоже не прошёл. Хотя, на видео всё рассказано весьма неплохо. После восстановления (копия у меня имеется), при в ходе в ОС появляется:
перевод:
09 дек 2022, 17:09
1o4ka
09 дек 2022, 17:35
rogoznik,
это - проще всего.
Буквально сегодня у простого пользователя произошло тоже самое, исходя из представленного вами поста.
Такое сообщение крайне редко появляется просто так, чтобы можно было решить вопрос входом в систему.
Получается, не так уж крайне редко.
Что-то я заметил, в последнее время (в этом году), начали часто "лететь" ОСы от Линукса. Первой была Федора. Постояла два месяца, завалилась. Вторым -- LM.
За неполные полгода две операционки накрылись.
Как-то жалко собственных трудов.
rogoznik, а ведь я в ОС особо не лезу. Работает, да и ладно. А она, вдруг, "ни с того, ни с сего..." Почему завалилась моя ОСа? Как разобраться?
Ара Магеддон
Решено: 18
09 дек 2022, 17:40
1o4ka писал(а):
09 дек 2022, 15:07
Вот патченый xorg-server из РРА очень подходит на роль одного из подозреваемых, как в крахе системы, так и невозможности установки драйвера из-за путаницы в версиях и зависимостях.
Гипотетически, можно попробовать отключить этот PPA, удалив соответсвующий файл, а дальше
apt update, apt autoclean u apt install --reinstall xorg-server.
Это набор команд для идеальной ситуации, если всё вдруг "починится" с первого раза. Но, подозреваю, в реальности всё будет несколько сложнее. Там уже нужно будет решать проблемы по мере поступления.
09 дек 2022, 17:49
1o4ka писал(а):
09 дек 2022, 15:07
а ты уверен что он умеет работать с
1o4ka писал(а):
08 дек 2022, 18:30
425-430 вроде были последние, в которых экспериментально поддерживались... сейчас же вроде 390 и выше не даёт брать...
1o4ka писал(а):
09 дек 2022, 17:35
по Станиславскому - Не верю! Что б само ни с того, ни с сего :-D
1o4ka
09 дек 2022, 17:52
09 дек 2022, 17:40
Что отключить и каким образом? Подробней, плз.
