не удается обновить пакеты
Baldie27
Благодарил (а): 9 раз
Сообщение Baldie27 » 02 дек 2022, 15:59
Linux Mint 21 x86_64
Не удается обновить некоторые пакеты. Проблема вылезает периодически с разными пакетами.
Kernel: 5.15.0-56-generic x86_64 bits: 64 compiler: gcc v: 11.3.0
Desktop: Cinnamon 5.4.12 Distro: Linux Mint 21 Vanessa
base: Ubuntu 22.04 jammy
Type: Laptop System: HP product: HP 255 G7 Notebook PC
v: Type1ProductConfigId serial: <superuser required>
Mobo: HP model: 87CE v: 51.27 serial: <superuser required> UEFI: Insyde
v: F.35 date: 02/02/2021
ID-1: BAT1 charge: 32.8 Wh (79.6%) condition: 41.2/40.9 Wh (100.6%)
volts: 12.0 min: 11.3 model: Hewlett-Packard PABAS0241231
status: Discharging
Info: dual core model: AMD Athlon Silver 3050U with Radeon Graphics
bits: 64 type: MCP arch: Zen/Zen+ note: check rev: 1 cache: L1: 192 KiB
L2: 1024 KiB L3: 4 MiB
Speed (MHz): avg: 1330 high: 1401 min/max: 1400/2300 boost: enabled
cores: 1: 1401 2: 1260 bogomips: 9182
Device-1: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
vendor: Hewlett-Packard driver: amdgpu v: kernel bus-ID: 03:00.0
Device-2: Cheng Uei Precision Industry (Foxlink) HP TrueVision HD Camera
type: USB driver: uvcvideo bus-ID: 1-6.1:5
Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: amdgpu,ati
unloaded: fbdev,modesetting,vesa gpu: amdgpu resolution: 1920x1080~60Hz
OpenGL: renderer: AMD RAVEN2 (LLVM 13.0.1 DRM 3.42 5.15.0-56-generic)
v: 4.6 Mesa 22.0.5 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 03:00.1
vendor: Hewlett-Packard driver: snd_pci_acp3x v: kernel bus-ID: 03:00.5
Device-3: AMD Family 17h HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 03:00.6
Sound Server-1: ALSA v: k5.15.0-56-generic running: yes
vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus-ID: 01:00.0
IF: eno1 state: down mac: <filter>
Device-2: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw_8821ce v: N/A port: 2000
bus-ID: 02:00.0
Bluetooth:
Device-1: Realtek Bluetooth 4.2 Adapter type: USB driver: N/A
bus-ID: 1-6.3:6
Local Storage: total: 238.47 GiB used: 80.29 GiB (33.7%)
ID-1: /dev/sda vendor: Micron model: MTFDDAV256TDL-1AW1ZABHA
ID-1: / size: 74.54 GiB used: 14.15 GiB (19.0%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 488 MiB used: 5.2 MiB (1.1%) fs: vfat
dev: /dev/sda1
ID-3: /home size: 143.16 GiB used: 66.13 GiB (46.2%) fs: ext4
dev: /dev/sda4
Swap:
ID-1: swap-1 type: partition size: 15.18 GiB used: 0 KiB (0.0%)
dev: /dev/sda3
System Temperatures: cpu: 20.0 C mobo: 10.0 C gpu: amdgpu temp: 41.0 C
Processes: 226 Uptime: 1h 11m Memory: 5.74 GiB used: 1.95 GiB (34.0%)
Init: systemd runlevel: 5 Compilers: gcc: 11.3.0 Packages: 2480 Shell: Bash
v: 5.1.16 inxi: 3.3.13
Крайний пример:
$ sudo apt dist-upgrade
Построение дерева зависимостей… Готово
Расчёт обновлений… Готово
Следующие пакеты будут оставлены в неизменном виде:
libfprint-2-2 libglib2.0-0 libglib2.0-0:i386 libglib2.0-bin libglib2.0-data
Обновлено 0 пакетов, установлено 0 новых пакетов, для удаления отмечено 0 пакетов, и 5 пакетов не обновлено.
Переустновил 21 недавно. На 20ке таких проблем не вылезало. Стоит что-то делать или забить? Спасибо!
sheridan
Решено: 14
Благодарил (а): 915 раз
Сообщение sheridan » 02 дек 2022, 16:16
Baldie27, пакеты из основных реп или сторонние?
Baldie27
Сообщение Baldie27 » 02 дек 2022, 16:23
да, основные. сторонние репы не ставил, на всякий случай сбросил настройки на стандартные
В сети
Решено: 43
Благодарил (а): 1753 раза
Сообщение WWolf » 02 дек 2022, 16:36
Baldie27,
sudo aptitude upgrade
обновит... Хз что за фигня, постоянно последнее время такое
Baldie27
Сообщение Baldie27 » 02 дек 2022, 16:42
02 дек 2022, 16:36
Baldie27,
Да, обновилось, спасибо. Фигня действительно странная, надеюсь, пофиксят в обновлении
demonlibra
Благодарил (а): 29 раз
Сообщение demonlibra » 02 дек 2022, 18:19
Baldie27 писал(а):
02 дек 2022, 15:59
То не проблема
apt policy libglib2.0-0
libglib2.0-0:
  Установлен: 2.72.1-1
  Кандидат:   2.72.4-0ubuntu1
  Таблица версий:
     2.72.4-0ubuntu1 500 (поэтапно 60%)
Ключевое здесь (поэтапно 60%)
Контекстное меню Nemo
Решено: 19
Благодарил (а): 1341 раз
Сообщение hellonet » 03 дек 2022, 03:59
Не знаю правильно или нет, но я делаю сначала
затем
sudo apt-get upgrade
и после этого
sudo apt autoremove
Устанавливаются и обновляются все пакеты и затем ненужные автоматически удаляются. При этом высвобождается очень много места на диске:
sudo apt autoremove
Следующие пакеты будут УДАЛЕНЫ:
linux-headers-5.15.0-50 linux-headers-5.15.0-50-generic
linux-image-5.15.0-50-generic linux-modules-5.15.0-50-generic
linux-modules-extra-5.15.0-50-generic
Обновлено 0 пакетов, установлено 0 новых пакетов, для удаления отмечено 5 пакетов, и 0 пакетов не обновлено.
После данной операции объём занятого дискового пространства уменьшится на 584 MB.
Хотите продолжить? [Д/н] y
demonlibra
Сообщение demonlibra » 03 дек 2022, 05:32
Использую сценарий
#!/bin/bash
sudo apt autoremove --yes
echo -e "------------------------------------------------\n"
sleep 1
echo -e "Удаление старых пакетов\nsudo apt autoclean\n"
sudo apt autoclean
sleep 1
while [[ $result != 0 ]]
	do
		result=0
		dialog --title "Обновление системы" --ok-label "Да" --cancel-label "Нет" --pause "\nВыполнить обновление списка пакетов?\n         sudo apt update" 11 40 5
		if [ $? = 0 ]
			then
				clear
				echo -e "Обновление списка пакетов\nsudo apt update\n"
				sudo apt update
				result=$(($? + $result))
			else
				clear
		fi
		echo -e "Проверка и исправление зависимостей\nsudo apt install -f\n"
		sudo apt install -f
		upgradable=`sudo aptitude -F "%p %V perenos" search ~U`
		upgradable=${upgradable//perenos/\\n}
		strings=`echo -e $upgradable | wc -l`
		maxlength=`echo -e $upgradable | wc -L`
		maxlength=$(($maxlength + 5))
		if [ "$strings" != "1" ]
			then
				strings=$(($strings + 12))
				dialog --title "Обновление системы" --ok-label "Да" --cancel-label "Нет" --pause "\nВыполнить обновление пакетов?\n\nsudo apt full-upgrade\n\n$upgradable" $strings $maxlength 5
				if [ $? = 0 ]
					then
						clear
						echo -e "Обновление пакетов\nsudo apt full-upgrade\n"
						sudo apt full-upgrade --yes
					else
						clear
				fi
			else ugrade_text="\n     Обновлений не обнаружено"
		fi
		if [ $result = 0 ]
			then
				dialog --title "Обновление системы" --msgbox "\n        Завершено успешно$ugrade_text" 7 40
			else
				dialog --title "Обновление завершено с ошибками" --ok-label "Да" --cancel-label "Нет" --pause "\n    Повторить процедуру обновления?" 10 45 5
				if [ $? = 1 ]
					then break
				fi
		fi
done
Решено: 33
Благодарил (а): 87 раз
Сообщение madesta » 03 дек 2022, 17:07
У меня бывали случаи насчёт невозможности обновления некоторых пакетов, но лечилось кнопкой "Проверить обновления". Предположил, что за время, в течение которого "не заметил" или "не обновил" прилетели обновленные пакеты, а предлагаемая процедура обновления базировалась на уже устаревшей информации.
sveta13
Благодарил (а): 62 раза
Сообщение sveta13 » 03 дек 2022, 17:53
Всё просто, у меня такая же хрень на 21-м LM :smile:
sudo apt install libglib2.0-0
ну и так далее:
sudo apt upgrage и dist upgrage не помогут.
Удачи :bravo:
Debian 13 xfce:LM-22.3 xfce:
Решено: 19
Сообщение hellonet » 04 дек 2022, 04:21
sveta13 писал(а):
03 дек 2022, 17:53
У меня как то было что-то подобное пару лет назад уж и не помню на каком дистрибе. Около сотни обновлений не хотели устанавливаться. Пытался по одному устанавливать вручную. Такое непотребство после восьмого или девятого обновления надоело. помогло всё-таки
sveta13 писал(а):
03 дек 2022, 17:53
sudo apt upgrage
Или sudo apt-get upgrade и sudo apt-get update.
Точно не помню
Сотрудник
Сообщение Сотрудник » 04 дек 2022, 04:48
Я команды обновления для удобства сохранил в текстовом файле и при обновлении копирую из файла в терминал:
Получение прав root (далее sudo добавлять не надо)
sudo su
Поиск обновлений
apt update
Полное обновление системы
apt dist-upgrade
Удаление старых версий и неиспользуемых программ
apt autoremove
Поиск и обновление списка установленных программ
apt update
Обновление загрузчика системы
update-grub
Перезагрузка
reboot
Решено: 19
Сообщение hellonet » 04 дек 2022, 05:12
Сотрудник писал(а):
04 дек 2022, 04:48
Ещё удобнее было бына основе этого скрипт написать, сохранить в текстовом файле и сделать файл исполняемым, да ещё к нему и кнопку запуска сделать на панель
demonlibra
Сообщение demonlibra » 04 дек 2022, 05:51
Сотрудник
Сообщение Сотрудник » 04 дек 2022, 06:26
hellonet писал(а):
04 дек 2022, 05:12
Я над созданием скрипта не думал, привык смотреть какие сообщения и возможные ошибки появляются при обновлении в терминале.
demonlibra
Сообщение demonlibra » 04 дек 2022, 09:45
Сценарий можно вызывать с отображением терминала
gnome-terminal --geometry=115x25 --hide-menubar --title "update" -- bash -c $HOME/.scripts/upgrade.sh
Ара Магеддон
Решено: 18
Благодарил (а): 37 раз
Сообщение Ара Магеддон » 09 дек 2022, 01:02
Это новая фича Убунты, поэтапное обновление. Смысл в том, чтобы новые пакеты с потенциально возможными проблемами получали не только лишь все, а сначала лишь часть пользователей. И если все нормально, критических багов не обнаружено и форумы поддержки не завалениы криками о помощи, то пакет рассылается всем остальным. Идея не нова, Microsoft так уже бог знает сколько лет делает. И, как по мне, идея полезная.
Но вы можете эту функцию и отключить, воспользовавшись советом отсюда.
