С чем может быть связана эта проблема?
Kernel: 5.15.0-53-generic arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
Desktop: Cinnamon v: 5.4.12 Distro: Linux Mint 21 Vanessa
base: Ubuntu 22.04 jammy
Type: Laptop System: Acer product: Aspire 5750G v: V1.21
serial: <superuser required>
Mobo: Acer model: JE50_HR serial: <superuser required> BIOS: Acer v: 1.21
date: 08/09/2012
ID-1: BAT0 charge: 44.7 Wh (100.0%) condition: 44.7/48.8 Wh (91.5%)
volts: 12.3 min: 11.1 model: PANASONIC Li_Ion_4000mA status: full
Info: dual core model: Intel Core i3-2350M bits: 64 type: MT MCP
arch: Sandy Bridge rev: 7 cache: L1: 128 KiB L2: 512 KiB L3: 3 MiB
Speed (MHz): avg: 2185 high: 2295 min/max: 800/2300 cores: 1: 1856 2: 2295
3: 2295 4: 2295 bogomips: 18358
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
vendor: Acer Incorporated ALI driver: i915 v: kernel arch: Gen-6
bus-ID: 00:02.0
Device-2: NVIDIA GF108M [GeForce 610M] vendor: Acer Incorporated ALI
driver: N/A arch: Fermi bus-ID: 01:00.0
Device-3: Alcor Micro Acer Integrated Webcam type: USB driver: uvcvideo
bus-ID: 1-1.3:3
Display: x11 server: X.Org v: 1.21.1.3 with: Xwayland v: 22.1.1 driver: X:
loaded: modesetting unloaded: fbdev,vesa dri: crocus gpu: i915
resolution: 1366x768~60Hz
API: OpenGL v: 3.3 Mesa 22.0.5 renderer: Mesa Intel HD Graphics 3000 (SNB
GT2) direct render: Yes
vendor: Acer Incorporated ALI 6 driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0
Device-2: NVIDIA GF108 High Definition Audio vendor: Acer Incorporated ALI
Sound API: ALSA v: k5.15.0-53-generic running: yes
Sound Server-1: PulseAudio v: 15.99.1 running: yes
Sound Server-2: PipeWire v: 0.3.48 running: yes
Device-1: Broadcom NetLink BCM57785 Gigabit Ethernet PCIe
vendor: Acer Incorporated ALI driver: tg3 v: kernel port: N/A
bus-ID: 02:00.0
IF: enp2s0f0 state: down mac: <filter>
Device-2: Qualcomm Atheros AR9287 Wireless Network Adapter
vendor: Foxconn T77H167.00 driver: ath9k v: kernel bus-ID: 03:00.0
Local Storage: total: 223.57 GiB used: 12.5 GiB (5.6%)
ID-1: /dev/sda vendor: Kingston model: SA400S37240G size: 223.57 GiB
ID-1: / size: 218.51 GiB used: 12.49 GiB (5.7%) fs: ext4 dev: /dev/sda3
ID-2: /boot/efi size: 512 MiB used: 5.2 MiB (1.0%) fs: vfat dev: /dev/sda2
Swap:
ID-1: swap-1 type: file size: 2 GiB used: 307.5 MiB (15.0%) file: /swapfile
System Temperatures: cpu: 54.0 C mobo: N/A
Processes: 251 Uptime: 1h 44m Memory: 3.69 GiB used: 2.79 GiB (75.7%)
Init: systemd target: graphical (5) Compilers: gcc: 11.3.0 Packages: 2252
Shell: Bash v: 5.1.16 inxi: 3.3.23
date: 08/09/2012
bus-ID: 00:02.0
bus-ID: 1-1.3:3
bus-ID: 00:1b.0
bus-ID: 02:00.0
Swap:
