Мини комп Minisforum UM560.
ilikethat
Решено: 10
Благодарил (а): 130 раз
03 ноя 2022, 18:15
Добрый вечер!
Взял вот такую штуку. Мини комп Minisforum UM560:
Брал здесь Магазин на али
Вот так выглядит железо
Kernel: 5.15.0-52-generic x86_64 bits: 64 compiler: gcc v: 11.2.0 Desktop: Cinnamon 5.4.12
tk: GTK 3.24.33 wm: Mutter dm: LightDM Distro: Linux Mint 21 Vanessa base: Ubuntu 22.04 jammy
Type: Desktop System: BESSTAR TECH product: UM560 v: N/A serial: <superuser required>
Mobo: BESSTAR TECH model: F6BFC serial: <superuser required> UEFI: American Megatrends LLC.
v: 5.19 date: 07/01/2022
Info: 6-core model: AMD Ryzen 5 5625U with Radeon Graphics bits: 64 type: MT MCP arch: Zen 3
rev: 0 cache: L1: 384 KiB L2: 3 MiB L3: 16 MiB
Speed (MHz): avg: 3621 high: 4342 min/max: 400/4388 boost: enabled cores: 1: 3473 2: 3473
3: 3473 4: 3469 5: 4342 6: 4340 7: 3473 8: 3474 9: 3481 10: 3472 11: 3472 12: 3521
bogomips: 55096
Device-1: AMD Barcelo driver: amdgpu v: kernel pcie: speed: 8 GT/s lanes: 16 ports:
active: HDMI-A-1 empty: DP-1,DP-2,HDMI-A-2 bus-ID: 03:00.0 chip-ID: 1002:15e7
Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: amdgpu,ati
unloaded: fbdev,modesetting,vesa gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96
Monitor-1: HDMI-A-0 mapped: HDMI-A-1 model: LG (GoldStar) TV res: 1920x1080 dpi: 30
diag: 1836mm (72.3")
OpenGL: renderer: AMD RENOIR (LLVM 13.0.1 DRM 3.42 5.15.0-52-generic) v: 4.6 Mesa 22.0.5
Device-1: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel v: kernel pcie:
speed: 8 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:1637
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor driver: N/A pcie: speed: 8 GT/s
lanes: 16 bus-ID: 03:00.5 chip-ID: 1022:15e2
Device-3: AMD Family 17h HD Audio vendor: Realtek driver: snd_hda_intel v: kernel pcie:
speed: 8 GT/s lanes: 16 bus-ID: 03:00.6 chip-ID: 1022:15e3
Sound Server-1: ALSA v: k5.15.0-52-generic running: yes
Device-1: Intel Ethernet I225-V driver: igc v: kernel pcie: speed: 5 GT/s lanes: 1 port: N/A
bus-ID: 01:00.0 chip-ID: 8086:15f3
IF: eno1 state: down mac: <filter>
Device-2: MEDIATEK driver: mt7921e v: kernel pcie: speed: 5 GT/s lanes: 1 port: N/A
bus-ID: 02:00.0 chip-ID: 14c3:0608
Bluetooth:
Device-1: MediaTek Wireless_Device type: USB driver: btusb v: 0.8 bus-ID: 3-3:2
chip-ID: 0e8d:0608
Report: hciconfig ID: hci0 rfk-id: 0 state: down bt-service: enabled,running rfk-block:
hardware: no software: yes address: <filter>
Local Storage: total: 447.13 GiB used: 14.91 GiB (3.3%)
ID-1: /dev/sda vendor: Crucial model: CT480BX500SSD1 size: 447.13 GiB speed: 6.0 Gb/s
serial: <filter>
ID-1: / size: 191.45 GiB used: 14.91 GiB (7.8%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 284.4 MiB used: 5.2 MiB (1.8%) fs: vfat dev: /dev/sda1
Swap:
ID-1: swap-1 type: file size: 2 GiB used: 0 KiB (0.0%) priority: -2 file: /swapfile
USB:
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0 speed: 480 Mb/s
chip-ID: 1d6b:0002
Hub-2: 1-2:2 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1 speed: 480 Mb/s chip-ID: 2109:2822
Hub-3: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s chip-ID: 1d6b:0003
Hub-4: 2-2:2 info: VIA Labs USB3.1 Hub ports: 4 rev: 3.2 speed: 10 Gb/s chip-ID: 2109:0822
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0 speed: 480 Mb/s
chip-ID: 1d6b:0002
Device-1: 3-3:2 info: MediaTek Wireless_Device type: Bluetooth driver: btusb rev: 2.1
speed: 480 Mb/s chip-ID: 0e8d:0608
Device-2: 3-4:3 info: Microsoft Nano Transceiver v1.0 for Bluetooth type: Keyboard,Mouse,HID
driver: hid-generic,usbhid rev: 2.0 speed: 12 Mb/s chip-ID: 045e:0745
Hub-6: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s chip-ID: 1d6b:0003
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 42.0 C
Repos:
Packages: 2239 apt: 2235 flatpak: 4
No active apt repos in: /etc/apt/sources.list
1: deb http: //packages.linuxmint.com vanessa main upstream import backport
2: deb http: //archive.ubuntu.com/ubuntu jammy main restricted universe multiverse
3: deb http: //archive.ubuntu.com/ubuntu jammy-updates main restricted universe multiverse
4: deb http: //archive.ubuntu.com/ubuntu jammy-backports main restricted universe multiverse
5: deb http: //security.ubuntu.com/ubuntu/ jammy-security main restricted universe multiverse
Processes: 308 Uptime: 5h 0m Memory: 30.78 GiB used: 2.04 GiB (6.6%) Init: systemd v: 249
runlevel: 5 Compilers: gcc: 11.3.0 alt: 11 Client: Unknown python3.10 client inxi: 3.3.13
Забрал сегодня утром. Брал без RAM и диска.
Так что добавил память(покупалась для апгрейда ноута) и старый SATA SSD.
Можно вставить 1 Sata + 1 m2 NVME, и 2 слота памяти DDR4 SODIM.
Для разборки нужно открутить 4 болтика. Пока крутил - один потерял. :-D
Сначала удалось загрузится в Linux mint 20.3, но решил ставить 21-ю. Скачал, закатал на флешку с Ventoy. Вставил обратно.
И тут система начинает глючит и 21-й Mint не стартует. :blink2: Начал пробовать другие дистрибутивы. Manjaro виснет. :cray2:
Загрузился в 10 винду, не видит диска!
Тут я начал что-то подозревать, раскрутил обратно. Выпал шлейф SATA! :blush: Он не стандартный и вставлен в плату снизу вверх. Видимо первый раз я вставил его слабо, потом подергал комп, шлейф частично выпал.
Сейчас все хорошо, накатил 21-й Mint. Wifi обнаружился сам. По ощущениям, быстродействие как мой ноутбук.
Подключен у телевизору и беспроводной клавиатуре\мышке.
Кому интересно спрашивайте!
03 ноя 2022, 19:35
ilikethat писал(а):
03 ноя 2022, 18:15
Так логично. Железо то ноутбучное
03 ноя 2022, 20:03
Неплохая домашняя машинка, мне по душе подобный форм-фактор.
Что с охлаждением, активное?
ilikethat
Решено: 10
03 ноя 2022, 20:11
Chocobo, да 1 ноутбучный вентилятор. В биосе показывает 1200-1300 оборотов при 40-50*С, это толи 25, толи 35% от максимума. Его неслышно.
Белый Кролик
Решено: 10
Благодарил (а): 354 раза
04 ноя 2022, 21:10
Нравится твой агрегат. :thumbs:
ilikethat писал(а):
03 ноя 2022, 18:15
Это по нашему. :-D
ilikethat
Решено: 10
04 ноя 2022, 22:12
Белый Кролик, если после сборки остались детали, но прибор работает, то это лишние детали. :-D
Hakkond
Благодарил (а): 2 раза
23 мар 2023, 20:39
Здравствуйте. Заинтересовала данная модель, спасибо за информацию. Как за полгода практически показывает себя неттоп, если конечно он еще у вас? Спасибо за ответы.
Начал познавать Linux благодаря SteamOS осенью 2022 года...
ilikethat
Решено: 10
24 мар 2023, 07:43
Hakkond, почти живой, работает. :-D
Перестал работать wifi модуль. Не сам по себе, а после того как я полез внутрь и тестил новый SSD на нем.
Купил новый модуль wifi. Вставил, ни в какую не хочет крепится одна из антенн к модулю! Приклеил скотчем :joke: работает!
Теперь думаю, что и прошлый модуль рабочий, просто антенна отвалилась. :blush:
Рекомендую быть очень аккуратным, когда разбирать будите.
demonlibra
Благодарил (а): 29 раз
24 мар 2023, 08:13
ilikethat писал(а):
03 ноя 2022, 18:15
И даже винда была лицензионная? ))
Контекстное меню Nemo
Hakkond
24 мар 2023, 08:24
@ilikethat Как раз собираюсь брать для так сказать изыскательств, мне wi-fi нужен не будет. Хочу изредка egpu на нем использовать, когда нет на стоке сидеть. У вас Telegram есть? Хотелось бы больше вопросов задать, если можно.
Hakkond
24 мар 2023, 08:26
demonlibra писал(а):
24 мар 2023, 08:13
ilikethat писал(а):
03 ноя 2022, 18:15
Привет земляк, вроде неттопы пустые поставляются без винды, ключ они не вшивают, а на накопитель сразу развертывают систему и ОЕМ ключ юзают.
ilikethat
Решено: 10
24 мар 2023, 11:06
demonlibra, я брал "голый", без SSD и памяти. Винды естественно не было.
