как настроить печать на мфу Canon.
h221
Благодарил (а): 13 раз
Сообщение h221 » 24 сен 2022, 18:56
Kernel: 5.15.0-48-generic x86_64 bits: 64 compiler: gcc v: 11.2.0
Desktop: Cinnamon 5.4.12 Distro: Linux Mint 21 Vanessa
base: Ubuntu 22.04 jammy
Type: Desktop System: Gigabyte product: N/A v: N/A
serial: <superuser required>
Mobo: Gigabyte model: 970A-DS3P serial: <superuser required>
UEFI: American Megatrends v: FD date: 02/26/2016
Info: quad core model: AMD FX-4100 bits: 64 type: MT MCP arch: Bulldozer
rev: 2 cache: L1: 192 KiB L2: 4 MiB L3: 8 MiB
Speed (MHz): avg: 1421 high: 1428 min/max: 1400/3600 boost: enabled
cores: 1: 1425 2: 1417 3: 1428 4: 1415 bogomips: 28932
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
Device-1: AMD Oland PRO [Radeon R7 240/340 / Radeon 520]
vendor: Micro-Star MSI driver: radeon v: kernel bus-ID: 01:00.0
Device-2: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-1:2
Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: ati,radeon
unloaded: fbdev,modesetting,vesa gpu: radeon resolution: 1920x1080~60Hz
OpenGL: renderer: AMD OLAND (LLVM 13.0.1 DRM 2.50 5.15.0-48-generic)
v: 4.5 Mesa 22.0.5 direct render: Yes
Device-1: AMD SBx00 Azalia vendor: Gigabyte driver: snd_hda_intel v: kernel
bus-ID: 00:14.2
Device-2: AMD Oland/Hainan/Cape Verde/Pitcairn HDMI Audio [Radeon HD 7000
Series]
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 01:00.1
Device-3: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-1:2
Sound Server-1: ALSA v: k5.15.0-48-generic running: yes
vendor: Gigabyte driver: r8169 v: kernel port: d000 bus-ID: 03:00.0
IF: enp3s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: lxcbr0 state: down mac: <filter>
Bluetooth:
Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) type: USB
driver: btusb v: 0.8 bus-ID: 4-5:2
bt-v: 2.1 lmp-v: 4.0
Local Storage: total: 775.03 GiB used: 77.94 GiB (10.1%)
ID-1: /dev/sda model: SSD 512GB size: 476.94 GiB
ID-2: /dev/sdb vendor: Hitachi model: HTS543232A7A384 size: 298.09 GiB
ID-1: / size: 467.89 GiB used: 38.97 GiB (8.3%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 511 MiB used: 5.2 MiB (1.0%) fs: vfat
dev: /dev/sda1
Swap:
System Temperatures: cpu: 13.2 C mobo: N/A gpu: radeon temp: 35.0 C
Processes: 227 Uptime: 3h 20m Memory: 15.59 GiB used: 1.76 GiB (11.3%)
Init: systemd runlevel: 5 Compilers: gcc: 11.2.0 Packages: 3116 Shell: Bash
v: 5.1.16 inxi: 3.3.13
Не могу настроить печать на мфу canon pixma mg2540s. когда сканирую и печатаю через кнопку на принтере все отлично, ровно и четко.
Нужно было распечатать несколько файлов, принтер не печатал с левой стороны около 0.5 см. попробовал на других файлах тоже самое.(хотя в предварительном просмотре все ок было)(пошел распечатал в магазине у них все ок печатается).
Потом пытался настроить, но теперь стало еще хуже, печатает в "произвольном" месте.
в настройках поставил уменьшать страницу до границ, если нужно.
300 dpi,
и поставил галочку уместить на странице, больше вроде изменений не делал.
как вылечить все это дело?
sheridan
Решено: 14
Благодарил (а): 911 раз
Сообщение sheridan » 25 сен 2022, 04:35
h221, Для того чтобы помочь, необходимо понять в каком приложении был сделан документ (расширение .txt , .doc и.т.д),
Проверьте в настройках драйвера размер бумаги
