Длительная остановка при загрузке файлов на USB
Isemann
Благодарил (а): 2 раза
08 сен 2022, 19:40
Linux Mint 21 Vanessa Cinnamon x64
Kernel: 5.15.0-47-generic x86_64 bits: 64 compiler: gcc v: 11.2.0
Desktop: Cinnamon 5.4.12 Distro: Linux Mint 21 Vanessa
base: Ubuntu 22.04 jammy
Type: Desktop System: ASUS product: N/A v: N/A serial: <superuser required>
Mobo: ASUSTeK model: PRIME H510M-K v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 1203
date: 10/27/2021
Info: 6-core model: 11th Gen Intel Core i5-11400F bits: 64 type: MT MCP
arch: Rocket Lake rev: 1 cache: L1: 480 KiB L2: 3 MiB L3: 12 MiB
Speed (MHz): avg: 800 min/max: 800/4400 cores: 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
bogomips: 62208
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Device-1: NVIDIA TU117 [GeForce GTX 1650] vendor: Gigabyte driver: nvidia
v: 515.65.01 bus-ID: 01:00.0
Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: nvidia
unloaded: fbdev,modesetting,nouveau,vesa gpu: nvidia
resolution: 1920x1080~144Hz
OpenGL: renderer: NVIDIA GeForce GTX 1650/PCIe/SSE2
v: 4.6.0 NVIDIA 515.65.01 direct render: Yes
Device-1: Intel Tiger Lake-H HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3
Device-2: NVIDIA vendor: Gigabyte driver: snd_hda_intel v: kernel
bus-ID: 01:00.1
Sound Server-1: ALSA v: k5.15.0-47-generic running: yes
Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6
Local Storage: total: 1.17 TiB used: 253.15 GiB (21.2%)
ID-1: /dev/nvme0n1 vendor: A-Data model: SWORDFISH size: 232.89 GiB
temp: 40.9 C
ID-2: /dev/sda vendor: Western Digital model: WD10EZEX-00BBHA0
ID-3: /dev/sdb type: USB model: USB DISK 2.0 size: 28.91 GiB
ID-1: / size: 93.31 GiB used: 14.37 GiB (15.4%) fs: ext4
dev: /dev/nvme0n1p3
ID-2: /boot/efi size: 486 MiB used: 5.2 MiB (1.1%) fs: vfat
dev: /dev/nvme0n1p1
ID-3: /home size: 117.43 GiB used: 11.55 GiB (9.8%) fs: ext4
dev: /dev/nvme0n1p5
Swap:
ID-1: swap-1 type: partition size: 15.26 GiB used: 101.8 MiB (0.7%)
dev: /dev/nvme0n1p4
System Temperatures: cpu: 27.8 C mobo: N/A gpu: nvidia temp: 36 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 56%
Processes: 313 Uptime: 1h 40m Memory: 15.46 GiB used: 2.96 GiB (19.1%)
Init: systemd runlevel: 5 Compilers: gcc: 11.2.0 Packages: 2620 Shell: Bash
v: 5.1.16 inxi: 3.3.13
Загрузка файла объемом 1.5 - 2Гб на USB занимает несколько секунд, но затем происходит остановка на 99% на 5-10 минут. Как можно решить данную проблему?
demonlibra
Благодарил (а): 29 раз
08 сен 2022, 21:14
У меня так же.
На сколько я понимаю, это не проблема, а нюансы работы с носителем.
Если на флешке присутствует светодиод, то можно наблюдать активность.
2 Гбайт - 10 минут
Примерная скорость записи 3.5 Мбайт/сек.
Уверены, что Ваша флешка может записывать данные быстрее.
Последний раз редактировалось пользователем 1 demonlibra; всего редактировалось раз: 8
Контекстное меню Nemo
08 сен 2022, 21:17
Isemann, настройки - диски - отключить кэш и узреть реальную скорость записи на флэшку... а так оно в кэш скинуло, и из него потихоньку пишет на тормознутую флэшку...
там же можно уменьшить кэш...
08 сен 2022, 21:20
Isemann писал(а):
08 сен 2022, 19:40
А ты думал что запись на флешку 1.5-2 ГБ реально занимает несколько секунд? На винде такое видел? Нет. Так почему тут должно быть иначе?
Damian
Благодарил (а): 24 раза
09 сен 2022, 00:00
Isemann писал(а):
08 сен 2022, 19:40
А в чём вобще проблема копирование происходит?происходит там же не просто один процесс копирования происходит ещё и другие процессы с этим связанные идут которые вы не видите.Всё должно завершиться.
Sova
Благодарил (а): 35 раз
09 сен 2022, 08:59
Я на Раче кэш урезал. Быстрее не стало, но меньше душевных терзаний при отмонтировании флешек.
09 сен 2022, 09:47
Sova писал(а):
09 сен 2022, 08:59
Быстрее не стало
Так и не должно было
demonlibra
09 сен 2022, 13:11
08 сен 2022, 21:17
У меня при выборе флешки "Настройки привода" не доступны.
09 сен 2022, 13:26
demonlibra, ну тогда в параметрах монтирования добавить sync, так как по дефолту идёт async
demonlibra
09 сен 2022, 13:42
И так работает. Что-то мне лень лезть разбираться.
Sova
09 сен 2022, 14:37
09 сен 2022, 09:47
Это очевидно. Тут просто психология: когда долго скидывается - ничего страшного, а вот если долго отмонтируется - начинает напрягать (вдруг ошибка какая)
Isemann
16 сен 2022, 09:47
08 сен 2022, 21:17
SWAP это кэш?
16 сен 2022, 10:09
Isemann, кэш, но не тот и не для того :-D
16 сен 2022, 17:03
Isemann писал(а):
16 сен 2022, 09:47
SWAP это кэш?
Кэш. Кэш диска включается/выключается через "Настройки - Диски", далее найдите в выпадающем меню "Настройки привода" (по-моему, справа) и перейдите в "Кэш записи".
Greey
Благодарил (а): 16 раз
16 сен 2022, 18:13
Isemann писал(а):
08 сен 2022, 19:40
Когда-то с LM 18 было такое же непонимание. Оказалось, система выводила сообщение, что скопировано, а фактически производила копирование и по-умолчанию не показывала графического окна копирования. Вроде, в LM 20 это исправили и теперь в панели при копировании должно висеть сообщение, и если по нему щёлкнуть на DE появится окно копирования.
На моей 8 Гб Kingston Datatraveler на Linux (ext4) почти в 2 раза быстрее, чем на Windows (ntfs). Запись (6.5 мб/с против 3.5 мб/с и чтение (27 мб/с против 12.5 мб/с) Дисковая утилита так показывает. Запись образа на неё в 1.3 Гб занимает порядка 3.5 минуты.
16 сен 2022, 21:49
Greey писал(а):
16 сен 2022, 18:13
Ключевая фраза в цитате автора темы: "Загрузка файла объемом 1.5 - 2Гб на USB занимает несколько секунд". Необходимо учесть, что несколько это меньше чем 10. Но даже в случае 10 секунд скорость записи 1,5-2 ГБ по арифметике должна составить 150-200 Мегабайт в секунду. Может быть когда-нибудь технологии до такого и дойдут, но уж точно не при моей жизни.
Certion
16 сен 2022, 23:01
Никак. это сделано специально, что бы потом не говорили, что данные на флешку загруились не полностью (невсе данные)....
Углублятса не буду, потому как это зависит от железа на котором вы работаете (память, кеш, флешка-её скорость передачи и т.д).
Да эта "фича" очень напрягает, только потому шо нет окна загрузки (ты просто не видишь, сколько же это будет длится).
Не важно, какая флешка - должно появляться окно загрузки(НЕ В ОКНЕ СООБЩЕНИЙ), что бы человек понимал, сколько же ему ждать !!!
ДА, ЭТО НАПРЯГАЕТ ОСОБЕННО ЕСЛИ НА ФЛЕШКЕ НЕТ ИНДИКАТОРА...
