как сделать свое разрешение экрана для экрана входа в систему?
h221
Благодарил (а): 13 раз
Сообщение h221 » 29 июл 2022, 07:06
Характеристики системы:
Kernel: 5.4.0-122-generic x86_64 bits: 64 compiler: gcc v: 9.4.0
Desktop: Cinnamon 5.2.7 Distro: Linux Mint 20.3 Una
base: Ubuntu 20.04 focal
Type: Desktop System: Gigabyte product: N/A v: N/A serial: <filter>
Mobo: Gigabyte model: 970A-DS3P serial: <filter> UEFI: American Megatrends
v: FD date: 02/26/2016
Topology: Quad Core model: AMD FX-4100 bits: 64 type: MCP arch: Bulldozer
rev: 2 L2 cache: 2048 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 28934
Speed: 1456 MHz min/max: 1400/3600 MHz Core speeds (MHz): 1: 1560 2: 1424
3: 1419 4: 1616
Device-1: AMD Oland PRO [Radeon R7 240/340] vendor: Micro-Star MSI
driver: radeon v: kernel bus ID: 01:00.0
Display: x11 server: X.Org 1.20.13 driver: ati,radeon
unloaded: fbdev,modesetting,vesa resolution: 1920x1080_60.00~60Hz
OpenGL: renderer: AMD OLAND (DRM 2.50.0 5.4.0-122-generic LLVM 12.0.0)
v: 4.5 Mesa 21.2.6 direct render: Yes
Device-1: AMD SBx00 Azalia vendor: Gigabyte driver: snd_hda_intel
v: kernel bus ID: 00:14.2
Device-2: AMD Oland/Hainan/Cape Verde/Pitcairn HDMI Audio [Radeon HD 7000
Series]
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus ID: 01:00.1
Device-3: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
bus ID: 3-4:2
Sound Server: ALSA v: k5.4.0-122-generic
vendor: Gigabyte driver: r8169 v: kernel port: d000 bus ID: 03:00.0
IF: enp3s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 886.82 GiB used: 30.06 GiB (3.4%)
ID-1: /dev/sda model: SSD 512GB size: 476.94 GiB
ID-2: /dev/sdb vendor: Hitachi model: HTS543232A7A384 size: 298.09 GiB
ID-3: /dev/sdc vendor: Smartbuy model: SSD 120GB size: 111.79 GiB
ID-1: / size: 467.89 GiB used: 9.52 GiB (2.0%) fs: ext4 dev: /dev/sda2
System Temperatures: cpu: 23.1 C mobo: N/A gpu: radeon temp: 41 C
Processes: 213 Uptime: 28m Memory: 15.66 GiB used: 1.34 GiB (8.6%)
Init: systemd runlevel: 5 Compilers: gcc: 9.4.0 Shell: bash v: 5.0.17
inxi: 3.0.38
не было в списке разрешений экрана моего разрешения, сделал исполняемый файл с кодом
#!/bin/bash
xrandr --newmode "1920x1080_60.00"  173.00  1920 2048 2248 2576  1080 1083 1088 1120 -hsync +vsync
xrandr --addmode VGA-0 1920x1080_60.00
получилось изменить разрешение рабочего стола, после загрузки системы и ввода пароля, но само окно входа в систему осталось с очень низким разрешением, как сделать нужное мне разрешение экрана?
Решение h221 » 31 июл 2022, 13:24
файле /etc/default/grub в параметр GRUB_CMDLINE_LINUX_DEFAULT добавить drm.edid_firmware=edid/1920x1080.bin
пример:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash drm.edid_firmware=edid/1920x1080.bin"
и обновить конфиг grub'a:
sudo update-grub
перезагрузиться. после этого твой скрипт в автозагрузке будет не нужен
помог человек с ответов, все решилось, нормальное разрешение, ура!!!
Благодарил (а): 802 раза
Сообщение rogoznik » 29 июл 2022, 08:02
h221 писал(а):
29 июл 2022, 07:06
Написать systemd.unit, который будет отрабатывать после graphical.target и будет запускать этот скрипт. И запуск этого скрипта в сеансе пользователя, в теории, уже не понадобиться
h221
Сообщение h221 » 29 июл 2022, 08:26
29 июл 2022, 08:02
h221 писал(а):
29 июл 2022, 07:06
спасибо за ответ, к сожалению мой уровень компьютерного мастерства(копировать-вставить) не позволяет мне этого сделать без подробных инструкций, установил вчера linux mint и возился с разрешением экрана часов 10. был бы рад ссылкам или инструкциям, которые помогут осуществить написанное выше. :-D :-D :-D
FreeStyler
Решено: 7
Благодарил (а): 772 раза
Сообщение FreeStyler » 29 июл 2022, 08:42
h221, дык всё просто сёрчится же https://search.brave.com/search?q=%D1%8 ... ce=desktop
deadmau5 - Harmonic Mix
h221
Сообщение h221 » 29 июл 2022, 16:58
FreeStyler писал(а):
29 июл 2022, 08:42
за пару часов загугливания понял, что нужно создать текстовый файл в etc/systemd/system/
примерно такого содержания
[Unit]
Description=custom_resolution
After=graphical.target
[Service]
Type=simple
ExecStart=/home/km/binarniki/load_screen.sh #путь к исполняемому файлу
Restart=always
 [Install]
WantedBy=multi-user.target
помогите исправить. не работает.
Последний раз редактировалось пользователем 1 h221; всего редактировалось раз: 29
Сообщение rogoznik » 29 июл 2022, 17:21
h221, скрипт лучше положить куда-нибудь в /usr/local/bin, а то не хватит прав для исполнения. А так выглядит нормально
h221
Сообщение h221 » 29 июл 2022, 17:49
переложил скрипт в /usr/local/bin
выдает(не работает)
● custom_resolution.service - custom_resolution
     Loaded: loaded (/etc/systemd/system/custom_resolution.service; enabled; vendor preset: enabled)
     Active: failed (Result: exit-code) since Fri 2022-07-29 20:47:42 MSK; 4s ago
    Process: 2226 ExecStart=/usr/local/bin/load_screen.sh (code=exited, status=1/FAILURE)
   Main PID: 2226 (code=exited, status=1/FAILURE)
июл 29 20:47:42 km-3429 systemd[1]: custom_resolution.service: Scheduled restart job, restart counter is at 5.
июл 29 20:47:42 km-3429 systemd[1]: Stopped custom_resolution.
июл 29 20:47:42 km-3429 systemd[1]: custom_resolution.service: Start request repeated too quickly.
июл 29 20:47:42 km-3429 systemd[1]: custom_resolution.service: Failed with result 'exit-code'.
июл 29 20:47:42 km-3429 systemd[1]: Failed to start custom_resolution.
Благодарил (а): 55 раз
Сообщение slant » 29 июл 2022, 17:50
29 июл 2022, 17:21
... для системной задачи, которой иксы не нужны. Но не для xrandr.
Суть проблемы в том, что xrandr работает от пользователя, из уже запущенной графической сессии. А вышепредставленный юнит будет запускаться от root, вне иксов. Разумеется, xrandr оттуда работать нифига не будет.
Запихивать вызов этого скрипта надо куда-то в display manager или greeter оного, точнее - в их настройки, если оные позволяют.
h221
Сообщение h221 » 29 июл 2022, 17:54
29 июл 2022, 17:50
как это можно сделать?
Сообщение slant » 29 июл 2022, 18:46
Если ничего не поменялось в минте используется lightdm. По нему вот тут: https://wiki.archlinux.org/title/LightD ... %B8%D0%B9)
h221
Сообщение h221 » 29 июл 2022, 19:41
Дальше хотел поменять разрешение через файл xorg, создал его через консоль с отключением lightdm, после ребута соответственно lightdm не включился, при включении появляется занчек загрузки, а дальше только черный экран и мигающая черточка, консоль не включается, как исправить??? И включить lightdm. :write:
Сообщение slant » 29 июл 2022, 19:53
xorg.conf если, речь о нем, давно не используется в современных дистрибутивах. Удаляйте.
Если иксы не стартуют, то к текстовой консоли можно получить доступ через комбинацию Ctrl+Alt+F2 (на самом деле - обычно от F1 до F6, по консоли на каждой. Но вторая чаще всего свободна.)
h221
Сообщение h221 » 30 июл 2022, 05:08
29 июл 2022, 19:53
Не помогает, везде черный экран и мигающая черточка сверху.
Сообщение slant » 30 июл 2022, 07:41
Тогда у вас проблема куда глубже, чем не работающий lightdm.
Возможно, здесь уже переустановить проще будет, для вашего уровня подготовки.
А так - теперь вам нужно загрузится через live, и убрать то, что вы нахимичили в системе.
h221
Сообщение h221 » 31 июл 2022, 12:42
В общем забил я на это дело, в интернете везде советуют править xorg и lightdm конфиги, но в указанных местах из гайдов таких конфигов нету.
Посоветовали "к параметрам ядра добавить строку
drm.edid_firmware=edid/1920x1080.bin" вообще без понятия как это сделать и будет ли работать вообще. Если есть дельные советы по этому поводу пишите.
h221
Сообщение h221 » 31 июл 2022, 13:24
пример:
sudo update-grub
dkpost3
Благодарил (а): 9 раз
Сообщение dkpost3 » 31 июл 2022, 16:25
я тут игрался с попыткой 2к в 4к перековать, и неделю он даже был 4к. Ну раз так, думаю и разгерцовку надо выкрутить. сжег контроллер к ху***м)))) аккуратнее
h221
Сообщение h221 » 31 июл 2022, 16:49
dkpost3 писал(а):
31 июл 2022, 16:25
Так у меня 1920x1080 из коробки было, просто кабель порвал родной vga(поставил на него стол), в магазине кабель спросил хороший, в итоге подсунули без пинов, которые edid передают. На винде из дров выставлялось разрешение, а тут интерфейса под дрова амд нет.
dkpost3
Сообщение dkpost3 » 31 июл 2022, 17:37
h221 писал(а):
31 июл 2022, 16:49
dkpost3 писал(а):
31 июл 2022, 16:25
)) это просто забавный случай из жизни
