Kernel: 5.17.14-xanmod1 x86_64 bits: 64 compiler: N/A Desktop: Xfce 4.16.0
Distro: Linux Mint 20.3 Una base: Ubuntu 20.04 focal
Type: Desktop System: Intel product: X79 v: N/A serial: <filter>
Mobo: Intel model: X79Turbo v: V1.x serial: <filter>
UEFI: American Megatrends v: X79QN003 date: 05/28/2021
Topology: 8-Core model: Intel Xeon E5-2689 0 bits: 64 type: MT MCP
arch: Sandy Bridge rev: 7 L2 cache: 20.0 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 83008
Speed: 1402 MHz min/max: 1200/2601 MHz Core speeds (MHz): 1: 1402 2: 1566
3: 1899 4: 1543 5: 1992 6: 1538 7: 1513 8: 1538 9: 1521 10: 2068 11: 1373
12: 2242 13: 1329 14: 1553 15: 2512 16: 1549
Device-1: AMD Lexa PRO [Radeon 540/540X/550/550X / RX 540X/550/550X]
driver: amdgpu v: kernel bus ID: 03:00.0
Display: x11 server: X.Org 1.20.13 driver: amdgpu,ati
unloaded: fbdev,modesetting,vesa tty: N/A
OpenGL: renderer: AMD Radeon RX 550 / 550 Series (polaris12 LLVM 12.0.0
DRM 3.44 5.17.14-xanmod1)
v: 4.6 Mesa 22.1.1 direct render: Yes
Device-2: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / RX 560/560X]
driver: snd_hda_intel v: kernel bus ID: 03:00.1
Sound Server: ALSA v: k5.17.14-xanmod1
Device-1: Realtek RTL810xE PCI Express Fast Ethernet driver: r8169
v: kernel port: d000 bus ID: 07:00.0
IF: enp7s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 711.51 GiB used: 96.09 GiB (13.5%)
ID-1: /dev/sda vendor: Samsung model: P3-256 size: 238.47 GiB
ID-2: /dev/sdb type: USB model: 058f 6387 size: 7.28 GiB
ID-3: /dev/sdc type: USB vendor: Seagate model: ST9500424AS
ID-1: / size: 233.18 GiB used: 85.68 GiB (36.7%) fs: ext4 dev: /dev/sda2
System Temperatures: cpu: 32.0 C mobo: N/A gpu: amdgpu temp: 37 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1751
Processes: 379 Uptime: 2h 27m Memory: 15.55 GiB used: 4.74 GiB (30.5%)
Init: systemd runlevel: 5 Compilers: gcc: 9.4.0 Shell: bash v: 5.0.17
inxi: 3.0.38
Установил WIne по инструкции с этого сайта https://any-key.net/wine-linux-mint-20/
Установка программы прошла успешно, запускаю программу,ничего не происходит, запускаю повторно выходит следующее окно (скрин 2):
+ в диспетчере задач отображается как запущенная
wine-7.0
Почему интерфейс программы не отображается ?
Как сделать чтоб отображался ?
