Не запускается программа piper. Невозможно подключиться к ratbag
_Pokoi_
Решено: 6
Благодарил (а): 9 раз
14 июн 2022, 16:08
Kernel: 5.4.0-117-generic x86_64 bits: 64 compiler: gcc v: 9.4.0
Desktop: Xfce 4.16.0 Distro: Linux Mint 20.3 Una base: Ubuntu 20.04 focal
Type: Desktop System: Intel product: X79 v: N/A serial: <filter>
Mobo: Intel model: X79Turbo v: V1.x serial: <filter>
UEFI: American Megatrends v: X79QN003 date: 05/28/2021
Topology: 8-Core model: Intel Xeon E5-2689 0 bits: 64 type: MT MCP
arch: Sandy Bridge rev: 7 L2 cache: 20.0 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 83004
Speed: 1197 MHz min/max: 1200/3600 MHz Core speeds (MHz): 1: 1197 2: 1197
3: 1197 4: 1196 5: 1197 6: 1197 7: 1197 8: 1197 9: 1197 10: 1197 11: 1197
12: 1197 13: 1197 14: 1197 15: 1197 16: 1197
Device-1: AMD Lexa PRO [Radeon 540/540X/550/550X / RX 540X/550/550X]
driver: amdgpu v: kernel bus ID: 03:00.0
Display: x11 server: X.Org 1.20.13 driver: amdgpu,ati
unloaded: fbdev,modesetting,vesa tty: N/A
OpenGL: renderer: Radeon RX550/550 Series (POLARIS12 DRM 3.35.0
5.4.0-117-generic LLVM 12.0.0)
v: 4.6 Mesa 21.2.6 direct render: Yes
Device-2: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / RX 560/560X]
driver: snd_hda_intel v: kernel bus ID: 03:00.1
Sound Server: ALSA v: k5.4.0-117-generic
Device-1: Realtek RTL810xE PCI Express Fast Ethernet driver: r8169
v: kernel port: d000 bus ID: 07:00.0
IF: enp7s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 245.75 GiB used: 11.90 GiB (4.8%)
ID-1: /dev/sda vendor: Samsung model: P3-256 size: 238.47 GiB
ID-2: /dev/sdb type: USB model: 058f 6387 size: 7.28 GiB
ID-1: / size: 233.24 GiB used: 11.89 GiB (5.1%) fs: ext4 dev: /dev/sda2
System Temperatures: cpu: 33.0 C mobo: N/A gpu: amdgpu temp: 38 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1764
Processes: 360 Uptime: 12m Memory: 15.55 GiB used: 2.06 GiB (13.2%)
Init: systemd runlevel: 5 Compilers: gcc: 9.4.0 Shell: bash v: 5.0.17
inxi: 3.0.38
Не запускается.
Gtk-Message: 18:04:48.222: Failed to load module "xapp-gtk3-module"
Пробовал переустановить пакет gir1.2-xapp-1.0 по совету с этого сайта https://forum.manjaro.org/t/failed-to-l ... dule/46039 , не помогло.
Что делать?
Решение Chocobo » 14 июн 2022, 16:46
Вообще да, свеженький и нужен, но оттуда билдить может быть не оч интересно.
Попробуй добавить ппа https://launchpad.net/~libratbag-piper/ ... ratbag-git
и поставить оба пакета уже с него, libratbag и piper
14 июн 2022, 16:18
Попробуй доставить еще пачку
libxapp-dev xapps-common libxapp1 python3-xapp
Благодарил (а): 1737 раз
14 июн 2022, 16:18
_Pokoi_, показывай
which ratbagd
which ratbagctl
_Pokoi_
Решено: 6
14 июн 2022, 16:26
14 июн 2022, 16:18
libxapp-dev: команда не найдена
_Pokoi_
Решено: 6
14 июн 2022, 16:28
14 июн 2022, 16:18
_Pokoi_, показывай
which ratbagd
which ratbagctl
После первой и после второй команды ничего не происходило
14 июн 2022, 16:30
_Pokoi_, apt install ratbagd
_Pokoi_
Решено: 6
14 июн 2022, 16:33
14 июн 2022, 16:30
Установил пакет, но теперь вот так ))))
14 июн 2022, 16:34
_Pokoi_, а если sudo piper ? :-D
_Pokoi_
Решено: 6
14 июн 2022, 16:36
14 июн 2022, 16:34
sudo piper
sudo: piper: команда не найдена
14 июн 2022, 16:37
WWolf, хренью маемся, оно ж тут в флетпаке)
_Pokoi_
Решено: 6
14 июн 2022, 16:40
14 июн 2022, 16:34
ratbagctl list
No devices available.
14 июн 2022, 16:40
_Pokoi_, Давай от обратного, какую мышу хочешь с ним подружить?
_Pokoi_
Решено: 6
14 июн 2022, 16:40
14 июн 2022, 16:40
Logitech g102 Lightsync
_Pokoi_
Решено: 6
14 июн 2022, 16:44
14 июн 2022, 16:40
может с офф. репозитория скачать?
14 июн 2022, 16:46
14 июн 2022, 16:48
Chocobo, да просто пользователя надо прописать к допступу, КМК... поэтому и хотел проверить через sudo...
_Pokoi_, ну а как она называется? то и запускай
_Pokoi_
Решено: 6
14 июн 2022, 16:54
14 июн 2022, 16:46
Спасибо, мужик все работает :smile:
Вау, даже настройка цвета работает вообще супер
Вернуться в «Общие вопросы по системе»
