Добрый вечер.
Решл поставить на свой ноутбуук HP Pavilion 15-cw1026ur Linux Mint 20.3 Cinnamon
Но после установки нету звука в динамиках елси подключить наушники то звук есть. Перечитал несколько форумов но решения не нашел
inxi -SMA
Host: nota Kernel: 5.4.0-104-generic x86_64 bits: 64
Desktop: Cinnamon 5.2.7 Distro: Linux Mint 20.3 Una
Type: Laptop System: HP product: HP Pavilion Laptop 15-cw1xxx v: N/A
serial: 5CD024G9G7
Mobo: HP model: 8615 v: 46.30 serial: PJAFL038JDU0DA UEFI: AMI v: F.47
date: 08/27/2021
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor driver: N/A
Device-3: AMD Family 17h HD Audio driver: snd_hda_intel
Sound Server: ALSA v: k5.4.0-104-generic
Может подскажет кто как решить данную проблему. Спасибо
Нет звука в динамиках Realtek ALC295
sergei@nota:~$ pacmd list-cards
2 card(s) available.
index: 0
driver: <module-alsa-card.c>
owner module: 7
properties:
alsa.card = "0"
alsa.card_name = "HD-Audio Generic"
alsa.long_card_name = "HD-Audio Generic at 0xfe7c8000 irq 63"
alsa.driver_name = "snd_hda_intel"
device.bus_path = "pci-0000:04:00.1"
sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:04:00.1/sound/card0"
device.bus = "pci"
device.vendor.id = "1002"
device.vendor.name = "Advanced Micro Devices, Inc. [AMD/ATI]"
device.product.id = "15de"
device.product.name = "Raven/Raven2/Fenghuang HDMI/DP Audio Controller (Pavilion Laptop 15-cw1xxx)"
device.string = "0"
device.description = "Raven/Raven2/Fenghuang HDMI/DP Audio Controller (Pavilion Laptop 15-cw1xxx)"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
profiles:
output:hdmi-stereo: Digital Stereo (HDMI) Output (priority 5900, available: no)
output:hdmi-surround: Digital Surround 5.1 (HDMI) Output (priority 800, available: no)
output:hdmi-surround71: Digital Surround 7.1 (HDMI) Output (priority 800, available: no)
off: Off (priority 0, available: unknown)
active profile: <off>
ports:
hdmi-output-0: HDMI / DisplayPort (priority 5900, latency offset 0 usec, available: no)
properties:
device.icon_name = "video-display"
index: 2
owner module: 9
properties:
alsa.card = "2"
alsa.long_card_name = "HD-Audio Generic at 0xfe7c0000 irq 65"
device.bus_path = "pci-0000:04:00.6"
sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:04:00.6/sound/card2"
device.bus = "pci"
device.vendor.id = "1022"
device.vendor.name = "Advanced Micro Devices, Inc. [AMD]"
device.product.id = "15e3"
device.product.name = "Family 17h (Models 10h-1fh) HD Audio Controller (Pavilion Laptop 15-cw1xxx)"
device.string = "2"
device.description = "Family 17h (Models 10h-1fh) HD Audio Controller (Pavilion Laptop 15-cw1xxx)"
profiles:
input:analog-stereo: Analog Stereo Input (priority 32833, available: unknown)
output:analog-stereo: Analog Stereo Output (priority 39268, available: unknown)
output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (priority 39333, available: unknown)
active profile: <output:analog-stereo>
sinks:
alsa_output.pci-0000_04_00.6.analog-stereo/#0: Family 17h (Models 10h-1fh) HD Audio Controller (Pavilion Laptop 15-cw1xxx) Analog Stereo
sources:
alsa_output.pci-0000_04_00.6.analog-stereo.monitor/#1: Monitor of Family 17h (Models 10h-1fh) HD Audio Controller (Pavilion Laptop 15-cw1xxx) Analog Stereo
ports:
analog-input-internal-mic: Internal Microphone (priority 8900, latency offset 0 usec, available: unknown)
properties:
device.icon_name = "audio-input-microphone"
analog-input-mic: Microphone (priority 8700, latency offset 0 usec, available: no)
properties:
analog-output-speaker: Speakers (priority 10000, latency offset 0 usec, available: unknown)
properties:
device.icon_name = "audio-speakers"
analog-output-headphones: Headphones (priority 9900, latency offset 0 usec, available: no)
properties:
device.icon_name = "audio-headphones"
Запустить. можно из терминала
pavucontrol
А можно найти в меню, там что-то с настройками звука(не помню как называется)
Card: HD-Audio Generic F1: Help │
│ Chip: Realtek ALC295 F2: System information │
│ View: F3:[Playback] F4: Capture F5: All F6: Select sound card │
│ Item: Master [dB gain: -8,25] Esc: Exit │
│ ├──┤ ├──┤ ├──┤ └──┘ └──┘ Enabled └──┘ │
│ │OO│ │MM│ │OO│ │
│ 70 0<>0 97<>97 95<>95 53<>53 53<>53 │
│ < Master > Headphone Speaker PCM Mic Boost Auto-Mute Mode Internal Mic Boost │
│ │OO│ │MM│ │OO│ │
- Решено: 14
rogoznik, у меня без sudo выбирает не основную звуковую та что по умолчанию, а hdmi nvidia
я уже года три как не использую alsamixer, это так по памяти
