Артефактное изображение через VAAPI
Xen
15 янв 2021, 22:42
Всем привет!
Linux Mint 20.1 Mate x64
  Kernel: 5.4.0-62-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
  Desktop: MATE 1.24.0 Distro: Linux Mint 20.1 Ulyssa
  base: Ubuntu 20.04 focal
  Type: Laptop System: Acer product: TravelMate P215-51G v: V1.08
  serial: <filter>
  Mobo: KBL model: Leo_KL v: V1.08 serial: <filter>
  UEFI: American Megatrends v: 1.08 date: 08/13/2019
  ID-1: BAT0 charge: 43.7 Wh condition: 43.7/51.5 Wh (85%) model: AP18H8L
  status: Full
  Topology: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP
  arch: Kaby Lake rev: A L2 cache: 6144 KiB
  bogomips: 28800
  Speed: 1325 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 2688 2: 2902
  3: 2709 4: 2978 5: 2615 6: 3080 7: 2699 8: 2382
  Device-1: Intel UHD Graphics 620 vendor: Acer Incorporated ALI
  Device-2: NVIDIA GP108M [GeForce MX230] vendor: Acer Incorporated ALI
  driver: nvidia v: 460.32.03 bus ID: 01:00.0
  Display: x11 server: X.Org 1.20.9 driver: modesetting,nvidia
  unloaded: fbdev,nouveau,vesa resolution: 1920x1080~60Hz
  OpenGL: renderer: GeForce MX230/PCIe/SSE2 v: 4.6.0 NVIDIA 460.32.03
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Acer Incorporated ALI
  Device-2: C-Media USB Audio Device type: USB
  driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-4:4
  Sound Server: ALSA v: k5.4.0-62-generic
  vendor: Acer Incorporated ALI driver: r8169 v: kernel port: d000
  bus ID: 02:00.0
  Device-2: Intel Wireless 7265 driver: iwlwifi v: kernel port: d000
  bus ID: 03:00.0
  IF-ID-1: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
  Local Storage: total: 938.95 GiB used: 326.24 GiB (34.7%)
  ID-1: /dev/mmcblk0 type: USB model: SD size: 7.44 GiB
  ID-2: /dev/sda vendor: Toshiba model: MQ04ABF100 size: 931.51 GiB
  ID-1: / size: 46.68 GiB used: 18.59 GiB (39.8%) fs: ext4 dev: /dev/sda3
  ID-2: /home size: 46.68 GiB used: 17.79 GiB (38.1%) fs: ext4
  dev: /dev/sda4
  ID-3: swap-1 size: 16.39 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda5
  System Temperatures: cpu: 65.0 C mobo: 27.8 C gpu: nvidia temp: 60 C
  Processes: 315 Uptime: 5h 55m Memory: 15.50 GiB used: 5.52 GiB (35.6%)
  inxi: 3.0.38
Грубо говоря, хочу запустить ShadowTech (https://shadow.tech/), но всё упирается в необходимость аппаратного декодирования видео. Если выбрать декодирование через проц, то он грузится на 50%, что не очень-то. Видяхи две. Geforce MX230, которая не умеет VDPAU (я так понял с форума разработчиков Nvidia), и 620 Intel, который умеет VAAPI.
Поставил intel-media-va-driver-non-free. С ним через 620 работает, но:
Я пробовал обновиться максимально, Mesa и пр, но лучше не стало.
Подскажите, в чём может быть проблема?
Xen
16 янв 2021, 20:02
Даже так, наверное. Борода явно или из-за Prime, или из-за драйверов на Intel. С Prime ничего не сделаешь особо. Подскажите, как можно красиво переустановить все дрова на Intel, включая VAAPI? А то может я лишнего понаставил?
Whowka
Благодарил (а): 777 раз
16 янв 2021, 21:03
Xen, посмотриЗдесь
Вернуться в «Видеокарты»
