"Mint 20 Cinnamon" на внешнем HDD диске.
konstantin
Благодарил (а): 33 раза
22 дек 2020, 16:31
Linux Mint 20 Cinnamon 64-bit -- основная Операционная Система ;
Windows 10 Education 64-bit (версия 1903) -- вторая Операционная Система ;
Ноутбук ASUS K53SD ;
О компьютере:
bkl@bkl-K53SD:~$ inxi -Fxz
Kernel: 5.4.0-58-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
Desktop: Cinnamon 4.6.7 Distro: Linux Mint 20 Ulyana
base: Ubuntu 20.04 focal
Type: Laptop System: ASUSTeK product: K53SD v: 1.0 serial: <filter>
Mobo: ASUSTeK model: K53SD v: 1.0 serial: <filter>
BIOS: American Megatrends v: K53SD.205 date: 03/06/2012
ID-1: BAT0 charge: 55.0 Wh condition: 56.3/57.2 Wh (98%)
model: ASUSTek K53--52 status: Unknown
Topology: Dual Core model: Intel Core i3-2310M bits: 64 type: MT MCP
arch: Sandy Bridge rev: 7 L2 cache: 3072 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 16761
Speed: 798 MHz min/max: 800/2100 MHz Core speeds (MHz): 1: 798 2: 798
3: 798 4: 798
vendor: ASUSTeK driver: i915 v: kernel bus ID: 00:02.0
Device-2: NVIDIA GF119M [GeForce 610M] vendor: ASUSTeK driver: nvidia
v: 390.138 bus ID: 01:00.0
Display: x11 server: X.Org 1.20.8 driver: modesetting,nvidia
unloaded: fbdev,nouveau,vesa resolution: 1366x768~60Hz, 1440x900~60Hz
OpenGL: renderer: GeForce 610M/PCIe/SSE2 v: 4.6.0 NVIDIA 390.138
vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 00:1b.0
Device-2: C-Media Audio Adapter type: USB
driver: hid-generic,snd-usb-audio,usbhid bus ID: 2-1.2.4:5
Sound Server: ALSA v: k5.4.0-58-generic
Device-1: Qualcomm Atheros AR9285 Wireless Network Adapter
vendor: AzureWave AW-NB037H 802.11bgn driver: ath9k v: kernel port: d000
bus ID: 03:00.0
Device-2: Qualcomm Atheros AR8151 v2.0 Gigabit Ethernet vendor: ASUSTeK
driver: atl1c v: 1.0.1.1-NAPI port: 9000 bus ID: 05:00.0
IF: enp5s0 state: down mac: <filter>
Device-3: Qualcomm Atheros AR3011 Bluetooth type: USB driver: btusb
bus ID: 1-1.1:5
Local Storage: total: 2.11 TiB used: 372.13 GiB (17.2%)
ID-1: /dev/sda vendor: Toshiba model: MQ01ABD032 size: 298.09 GiB
ID-2: /dev/sdb type: USB vendor: Toshiba model: External USB 3.0
ID-1: / size: 111.26 GiB used: 48.80 GiB (43.9%) fs: ext4 dev: /dev/sda6
ID-2: swap-1 size: 3.78 GiB used: 12.5 MiB (0.3%) fs: swap dev: /dev/sda5
System Temperatures: cpu: 65.0 C mobo: N/A gpu: nvidia temp: 62 C
Fan Speeds (RPM): cpu: 3000
Processes: 223 Uptime: 3h 01m Memory: 3.62 GiB used: 1.60 GiB (44.2%)
inxi: 3.0.38
bkl@bkl-K53SD:~$
Насколько штатным случаем считается установка "Mint 20 Cinnamon" на внешний HDD диск , который подключается к компьютеру(ноутбуку) через USB-3.0 ?
Имеется ли тогда поддержка from the Mint Team ?
Нет ли каких подводных камней в таком применении Операционной Системы "Mint 20" или "Mint 20.1" ?
22 дек 2020, 16:35
Поболтать зашёл?
22 дек 2020, 17:13
konstantin, ставь куда хочешь - хоть на флешку, хоть на внешний диск. Всем пофиг на какой носитель ты ее установишь. Есть только один момент - когда обращаешься за помощью нужно уточнять как установлена система
22 дек 2020, 17:23
22 дек 2020, 17:13
Не учи людей плохому. В отличи от полноценного внешнего диска, простая флешка для такого не слишком подходит.
22 дек 2020, 17:13
Не всем. Мне флешки жалко. :)
22 дек 2020, 17:46
22 дек 2020, 17:23
Я только объяснил что ОС можно ставить на любой носитель и никто за это ему, по сути, в поддержке не откажет.
22 дек 2020, 17:23
Мне флешки жалко
Так че чужие-то флешки жалеть? Хотят они извращений - флаг им в руки
