Винда с линем не могут поделить монитор - срутся меж собой
djsantehnik
Благодарил (а): 24 раза
25 окт 2020, 08:12
Имеем две ос на машине линь 19,3 - 64 и вин7 - 32 монитор Asus ms227n (монитору три дня, достался нахаляву, предыстории нет)
Host: kostusha-Aspire-XC-105 Kernel: 5.4.0-48-generic x86_64 bits: 64
compiler: gcc v: 7.5.0 Desktop: Cinnamon 4.4.8
Type: Desktop Mobo: Acer model: Aspire XC-105 serial: <filter>
BIOS: American Megatrends v: P11-A3L date: 07/10/2013
Topology: Quad Core model: AMD A4-5000 APU with Radeon HD Graphics
bits: 64 type: MCP arch: Jaguar rev: 1 L2 cache: 2048 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 11978
Speed: 923 MHz min/max: 800/1500 MHz Core speeds (MHz): 1: 799 2: 799
3: 799 4: 799
Device-1: AMD Kabini [Radeon HD 8330] vendor: Acer Incorporated ALI
driver: radeon v: kernel bus ID: 00:01.0
Display: x11 server: X.Org 1.20.8 driver: ati,radeon
unloaded: fbdev,modesetting,vesa resolution: 1680x1050~60Hz
OpenGL: renderer: AMD KABINI (DRM 2.50.0 5.4.0-48-generic LLVM 10.0.0)
v: 4.5 Mesa 20.0.8 direct render: Yes
Device-1: AMD Kabini HDMI/DP Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel bus ID: 00:01.1
Device-2: AMD FCH Azalia vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel bus ID: 00:14.2
Sound Server: ALSA v: k5.4.0-48-generic
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: e000
bus ID: 02:00.0
Local Storage: total: 585.00 GiB used: 102.10 GiB (17.5%)
ID-1: /dev/sda vendor: Seagate model: ST3500418AS size: 465.76 GiB
ID-2: /dev/sdb model: ORICO N300 128GB size: 119.24 GiB
ID-1: / size: 54.75 GiB used: 15.14 GiB (27.7%) fs: ext4 dev: /dev/sdb1
ID-2: /home size: 182.34 GiB used: 86.95 GiB (47.7%) fs: ext4
dev: /dev/sda2
ID-3: swap-1 size: 5.59 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda1
System Temperatures: cpu: 50.5 C mobo: N/A gpu: radeon temp: 50 C
Processes: 193 Uptime: 10m Memory: 7.22 GiB used: 1.95 GiB (27.0%)
inxi: 3.0.32
Вобщем такая ситуация: если загрузить винду и сделать сброс настроек монитора (кнопками монитора), то все отлично - приглашение биоса, граб, заставка и рс винды - все по центру при множественных перезагрузках винды, но как только переходим в линь то его стол уезжает влево (картинка 4)
если загрузить линь и сделать сборс настроек монитора (кнопками монитора), то все отлично с рс линя, а вот приглашение биоса, граб, рабочий стол винды (но не заставка - она всегда по центру) - уезжает вправо.
и так до той поры покы не сделаешь сборс настроек монитора в другой системе - в чем может быть проблема
Планирую поставить карту, и посмотреть на другом мониторе (но там до этого такого не было) на развитие проблемы
извиняюсь завспышку
djsantehnik
25 окт 2020, 10:16
поставил nvidia GT 520 смещение между системами пропало
25 окт 2020, 15:22
Это норма если подключение по VGA кабелю - там аналоговый сигнал, его параметры отличаются от карты к карте, и разные режимы вывода (разрешение, частота обновления) тоже влияют. Только подбирать, или каждый раз монитор тыкать (не даром на всех мониторах тех времен кнопочка auto появилась для подстройки).
Вернуться в «Видеокарты»
