Как нормально запустить видео
ut_wlad
09 окт 2020, 18:05
Добрый день!
Вопрос к знатокам - как нормально запустить видео. Имею черный экран как с флешки так и после установки. Параметр nomodeset помогает, но разрешение экрана низкое. Пытаюсь поставить LM Cinnamon 19.3
результаты inxi -Fxz
  Host: vlad-HP-Compaq-8000-Elite-SFF-PC Kernel: 5.0.0-32-generic x86_64
  bits: 64 compiler: gcc v: 7.4.0 Desktop: Cinnamon 4.4.8
  Type: Desktop System: Hewlett-Packard product: HP Compaq 8000 Elite SFF PC
  v: N/A serial: <filter>
  Mobo: Hewlett-Packard model: 3646h serial: <filter> BIOS: Hewlett-Packard
  v: 786G7 v01.02 date: 10/22/2009
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse charge: 55%
  status: Discharging
  Device-2: hidpp_battery_1 model: Logitech K520 charge: 70%
  status: Discharging
  Topology: Dual Core model: Intel Core2 Duo E8500 bits: 64 type: MCP
  arch: Penryn rev: A L2 cache: 6144 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 ssse3 vmx bogomips: 12635
  Speed: 3159 MHz min/max: 1998/3166 MHz Core speeds (MHz): 1: 3159 2: 3159
  Device-1: Intel 4 Series Integrated Graphics vendor: Hewlett-Packard
  driver: N/A bus ID: 00:02.0
  Display: x11 server: X.Org 1.19.6 driver: fbdev unloaded: modesetting,vesa
  resolution: 1280x1024~77Hz
  OpenGL: renderer: llvmpipe (LLVM 10.0.1 128 bits)
  v: 4.5 Mesa 20.3.0-devel (git-2b977ad 2020-10-06 bionic-oibaf-ppa)
  Device-1: Intel 82801JD/DO HD Audio vendor: Hewlett-Packard
  Device-1: Intel 82567LM-3 Gigabit Network vendor: Hewlett-Packard
  driver: e1000e v: 3.2.6-k port: 1100 bus ID: 00:19.0
  IF: enp0s25 state: down mac: <filter>
  Device-2: Qualcomm Atheros AR9485 Wireless Network Adapter driver: ath9k
  v: kernel port: 11e0 bus ID: 30:00.0
  IF: wls2 state: up mac: <filter>
  Local Storage: total: 55.90 GiB used: 12.23 GiB (21.9%)
  ID-1: /dev/sda model: SPCC Solid State Disk size: 55.90 GiB
  ID-1: / size: 54.77 GiB used: 12.23 GiB (22.3%) fs: ext4 dev: /dev/sda1
  System Temperatures: cpu: 52.0 C mobo: N/A
  Processes: 173 Uptime: 10m Memory: 5.76 GiB used: 1.04 GiB (18.0%)
  inxi: 3.0.32
Версию 18.3 тоже пробовал ставить - тот же результат
10 окт 2020, 07:06
ut_wlad писал(а):
09 окт 2020, 18:05
Для начала обновить систему.
Благодарил (а): 794 раза
10 окт 2020, 08:30
Должно нормально запускаться, т.к. драйвер в ядре.
ut_wlad, попробуй минт 17.3. Ну и я посоветовал бы версию с MATE или XFCE. Cinnamon очень требователен к видяхе, а в твоем случае слабовата она.
10 окт 2020, 11:25
10 окт 2020, 08:30
На похожем железе когда-то Минт 13 х32 замечательно работала с Корицей.
Тут дело вот в этом -
ut_wlad писал(а):
09 окт 2020, 18:05
Потому что предназначено для разрабов и тестеров, коим ТС даже близко не является. И не понимает в принципе, что для его металлолома всё уже давно придумано, оттестировано и используется.
10 окт 2020, 11:46
Unborn писал(а):
10 окт 2020, 11:25
Думаю корица тех времен была менее требовательна.
А вот оибафа я что-то и не приметил
