Sep 9 11:56:51 deedepc kernel: [ 9228.846045] RTW: issue_nulldata(wlx00e04c3cc461) to 0c:80:63:5f:69:40, ch:40, 3/3 in 1532 ms
Sep 9 11:56:51 deedepc kernel: [ 9228.861790] RTW: wlx00e04c3cc461 cmd=57,2,0 process_time=3084
Sep 9 11:56:52 deedepc kernel: [ 9230.414099] RTW: issue_probereq_ex(wlx00e04c3cc461) to 0c:80:63:5f:69:40, ch:40, 3/3 in 1556 ms
Sep 9 11:56:54 deedepc kernel: [ 9231.950067] RTW: issue_nulldata(wlx00e04c3cc461) to 0c:80:63:5f:69:40, ch:40, 3/3 in 1536 ms
Sep 9 11:56:54 deedepc kernel: [ 9231.963252] RTW: wlx00e04c3cc461 cmd=57,2,0 process_time=3104
Sep 9 11:56:56 deedepc kernel: [ 9233.518054] RTW: issue_probereq_ex(wlx00e04c3cc461) to 0c:80:63:5f:69:40, ch:40, 3/3 in 1556 ms
Sep 9 11:56:57 deedepc kernel: [ 9235.053935] RTW: issue_nulldata(wlx00e04c3cc461) to 0c:80:63:5f:69:40, ch:40, 3/3 in 1536 ms
Sep 9 11:56:57 deedepc kernel: [ 9235.069096] RTW: wlx00e04c3cc461 cmd=57,2,0 process_time=3104
Sep 9 11:56:59 deedepc kernel: [ 9236.621994] RTW: issue_probereq_ex(wlx00e04c3cc461) to 0c:80:63:5f:69:40, ch:40, 3/3 in 1556 ms
Sep 9 11:57:00 deedepc kernel: [ 9238.157895] RTW: issue_nulldata(wlx00e04c3cc461) to 0c:80:63:5f:69:40, ch:40, 3/3 in 1536 ms
Sep 9 11:57:00 deedepc kernel: [ 9238.171062] RTW: wlx00e04c3cc461 cmd=57,2,0 process_time=3104
Sep 9 11:57:02 deedepc kernel: [ 9239.725877] RTW: issue_probereq_ex(wlx00e04c3cc461) to 0c:80:63:5f:69:40, ch:40, 3/3 in 1556 ms
Sep 9 11:57:03 deedepc kernel: [ 9241.261921] RTW: issue_nulldata(wlx00e04c3cc461) to 0c:80:63:5f:69:40, ch:40, 3/3 in 1536 ms
Sep 9 11:57:03 deedepc kernel: [ 9241.261923] RTW: linked_status_chk(wlx00e04c3cc461) disconnect or roaming
Sep 9 11:57:03 deedepc kernel: [ 9241.261934] RTW: report_del_sta_event(wlx00e04c3cc461) 0c:80:63:5f:69:40 mac_id=0, enqueue:1, res:1
Sep 9 11:57:03 deedepc kernel: [ 9241.276397] RTW: wlx00e04c3cc461 cmd=57,2,0 process_time=3104
Sep 9 11:57:03 deedepc kernel: [ 9241.276898] RTW: rtw_set_ps_mode(wlx00e04c3cc461) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
Sep 9 11:57:03 deedepc kernel: [ 9241.276901] RTW: rtl8822b_set_FwPwrMode_cmd(wlx00e04c3cc461): HW port id=0
Sep 9 11:57:03 deedepc kernel: [ 9241.276905] RTW: rtl8822b_set_FwPwrMode_cmd(wlx00e04c3cc461): fw ps mode = LPS, drv ps mode = 2, rlbm = 1 , smart_ps = 2, allQueueUAPSD = 0
Sep 9 11:57:03 deedepc kernel: [ 9241.305650] RTW: rtw_sta_mstatus_disc_rpt(wlx00e04c3cc461) - mac_id=0
Sep 9 11:57:03 deedepc kernel: [ 9241.309384] RTW: wlx00e04c3cc461 wakeup macid=0, ori reg_0x4d4=0x00000000
Sep 9 11:57:03 deedepc kernel: [ 9241.310258] RTW: rtw_hal_set_bssid wlx00e04c3cc461- hw port -0 BSSID: 00:00:00:00:00:00
Sep 9 11:57:03 deedepc kernel: [ 9241.311010] RTW: rtw_free_assoc_resources-wlx00e04c3cc461 tgt_network MacAddress=0c:80:63:5f:69:40 ssid=TP-Link_693E_5G
Sep 9 11:57:03 deedepc kernel: [ 9241.311019] RTW: rtw_release_macid(wlx00e04c3cc461) if1, mac_addr:0c:80:63:5f:69:40 macid:0
Sep 9 11:57:03 deedepc kernel: [ 9241.311022] RTW: free disconnecting network of scanned_queue
Sep 9 11:57:03 deedepc kernel: [ 9241.311509] RTW: rtw_set_ps_mode(wlx00e04c3cc461) Leave 802.11 power save - WIFI-LPS_CTRL_DISCONNECT
Sep 9 11:57:03 deedepc kernel: [ 9241.311511] RTW: rtl8822b_set_FwPwrMode_cmd(wlx00e04c3cc461): HW port id=0
Sep 9 11:57:03 deedepc kernel: [ 9241.311513] RTW: rtl8822b_set_FwPwrMode_cmd(wlx00e04c3cc461): fw ps mode = ACTIVE, drv ps mode = 0, rlbm = 0 , smart_ps = 0, allQueueUAPSD = 0
Sep 9 11:57:03 deedepc kernel: [ 9241.343880] RTW: wlx00e04c3cc461 sleep m0=0x00000002, ori reg_0x4d4=0x00000000
Sep 9 11:57:08 deedepc kernel: [ 9245.671947] RTW: wlx00e04c3cc461 wakeup m0=0x00000002, ori reg_0x4d4=0x00000002
Sep 9 11:57:08 deedepc kernel: [ 9245.672070] RTW: survey done event(0) band:0 for wlx00e04c3cc461
Sep 9 11:57:08 deedepc kernel: [ 9245.672089] RTW: rtw_indicate_scan_done(wlx00e04c3cc461)
Sep 9 11:57:08 deedepc kernel: [ 9245.675055] RTW: wlx00e04c3cc461 sleep m0=0x00000002, ori reg_0x4d4=0x00000000
Sep 9 11:57:12 deedepc kernel: [ 9249.964111] RTW: wlx00e04c3cc461 wakeup m0=0x00000002, ori reg_0x4d4=0x00000002
Sep 9 11:57:12 deedepc kernel: [ 9249.964236] RTW: survey done event(0) band:0 for wlx00e04c3cc461
Sep 9 11:57:12 deedepc kernel: [ 9249.964247] RTW: rtw_free_assoc_resources-wlx00e04c3cc461 tgt_network MacAddress=0c:80:63:5f:69:40 ssid=TP-Link_693E_5G
Sep 9 11:57:12 deedepc kernel: [ 9249.964248] RTW: free disconnecting network of scanned_queue failed due to pwlan== NULL
Sep 9 11:57:12 deedepc kernel: [ 9249.964255] RTW: rtw_cfg80211_indicate_disconnect(wlx00e04c3cc461)
Sep 9 11:57:12 deedepc kernel: [ 9249.964257] RTW: rtw_cfg80211_indicate_disconnect(wlx00e04c3cc461) call cfg80211_disconnected
Sep 9 11:57:12 deedepc kernel: [ 9249.964269] RTW: rtw_indicate_scan_done(wlx00e04c3cc461)
Sep 9 11:57:12 deedepc kernel: [ 9249.964274] RTW: rtw_reset_securitypriv(wlx00e04c3cc461) - End to Disconnect
Sep 9 11:57:12 deedepc kernel: [ 9249.964306] RTW: cfg80211_rtw_del_key(wlx00e04c3cc461) key_index=0, addr=(null)
Sep 9 11:57:12 deedepc kernel: [ 9249.964309] RTW: cfg80211_rtw_del_key(wlx00e04c3cc461) key_index=1, addr=(null)
Sep 9 11:57:12 deedepc kernel: [ 9249.964311] RTW: cfg80211_rtw_del_key(wlx00e04c3cc461) key_index=2, addr=(null)
Sep 9 11:57:12 deedepc kernel: [ 9249.964312] RTW: cfg80211_rtw_del_key(wlx00e04c3cc461) key_index=3, addr=(null)
Sep 9 11:57:12 deedepc kernel: [ 9249.964313] RTW: cfg80211_rtw_del_key(wlx00e04c3cc461) key_index=4, addr=(null)
Sep 9 11:57:12 deedepc kernel: [ 9249.964315] RTW: cfg80211_rtw_del_key(wlx00e04c3cc461) key_index=5, addr=(null)
Sep 9 11:53:15 deedepc systemd-resolved[812]: message repeated 5 times: [ Server returned error NXDOMAIN, mitigating potential DNS violation DVE-2018-0001, retrying transaction with reduced feature level UDP.]
Sep 9 11:57:12 deedepc wpa_supplicant[902]: wlx00e04c3cc461: CTRL-EVENT-DISCONNECTED bssid=0c:80:63:5f:69:40 reason=0
Sep 9 11:57:12 deedepc kernel: [ 9249.964958] RTW: rtw_ndev_notifier_call(wlx00e04c3cc461) state:4
Sep 9 11:57:12 deedepc wpa_supplicant[902]: wlx00e04c3cc461: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
Sep 9 11:57:12 deedepc NetworkManager[841]: <info> [1599627432.4521] device (wlx00e04c3cc461): supplicant interface state: completed -> disconnected
Sep 9 11:57:12 deedepc NetworkManager[841]: <info> [1599627432.4522] device (p2p-dev-wlx00e04c3cc461): supplicant management interface state: completed -> disconnected
Sep 9 11:57:12 deedepc kernel: [ 9250.064895] RTW: cfg80211_rtw_scan(wlx00e04c3cc461)
Sep 9 11:57:12 deedepc kernel: [ 9250.064906] RTW: rtw_cfg80211_set_probe_req_wpsp2pie(wlx00e04c3cc461) listen channel - country:XX, class:81, ch:6
Sep 9 11:57:12 deedepc kernel: [ 9250.068099] RTW: wlx00e04c3cc461 sleep m0=0x00000002, ori reg_0x4d4=0x00000000
Sep 9 11:57:12 deedepc NetworkManager[841]: <info> [1599627432.5504] device (wlx00e04c3cc461): supplicant interface state: disconnected -> scanning
Sep 9 11:57:12 deedepc NetworkManager[841]: <info> [1599627432.5505] device (p2p-dev-wlx00e04c3cc461): supplicant management interface state: disconnected -> scanning
Sep 9 11:57:13 deedepc ntpd[981]: Deleting interface #55 wlx00e04c3cc461, 192.168.0.104#123, interface stats: received=69, sent=78, dropped=0, active_time=493 secs
Sep 9 11:57:13 deedepc ntpd[981]: Deleting interface #58 wlx00e04c3cc461, fe80::6976:b803:f606:d14c%28#123, interface stats: received=0, sent=0, dropped=0, active_time=491 secs
Sep 9 11:57:16 deedepc kernel: [ 9254.371781] RTW: wlx00e04c3cc461 wakeup m0=0x00000002, ori reg_0x4d4=0x00000002
Sep 9 11:57:16 deedepc kernel: [ 9254.371905] RTW: survey done event(0) band:0 for wlx00e04c3cc461
Sep 9 11:57:16 deedepc kernel: [ 9254.371914] RTW: rtw_indicate_scan_done(wlx00e04c3cc461)
Sep 9 11:57:20 deedepc nm-openvpn[18456]: WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Sep 9 11:57:20 deedepc nm-openvpn[18456]: TCP/UDP: Preserving recently used remote address: [AF_INET]178.49.148.227:1194
Sep 9 11:57:20 deedepc nm-openvpn[18456]: UDP link remote: [AF_INET]178.49.148.227:1194
Sep 9 11:57:21 deedepc kernel: [ 9259.373680] RTW: cfg80211_rtw_scan(wlx00e04c3cc461)
Sep 9 11:57:21 deedepc kernel: [ 9259.376865] RTW: wlx00e04c3cc461 sleep m0=0x00000002, ori reg_0x4d4=0x00000000
Sep 9 11:57:26 deedepc kernel: [ 9263.659795] RTW: wlx00e04c3cc461 wakeup m0=0x00000002, ori reg_0x4d4=0x00000002
Sep 9 11:57:26 deedepc kernel: [ 9263.659920] RTW: survey done event(0) band:0 for wlx00e04c3cc461
Sep 9 11:57:26 deedepc kernel: [ 9263.659930] RTW: rtw_indicate_scan_done(wlx00e04c3cc461)
Sep 9 11:57:27 deedepc NetworkManager[841]: <warn> [1599627447.3440] device (wlx00e04c3cc461): link timed out.
Sep 9 11:57:27 deedepc NetworkManager[841]: <info> [1599627447.3441] device (wlx00e04c3cc461): state change: activated -> failed (reason 'ssid-not-found', sys-iface-state: 'managed')
Sep 9 11:57:27 deedepc dbus-daemon[839]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.9' (uid=0 pid=841 comm="/usr/sbin/NetworkManager --no-daemon " label="unconfined")
Sep 9 11:57:27 deedepc systemd[1]: Starting Network Manager Script Dispatcher Service...
Sep 9 11:57:27 deedepc ntpd[981]: error resolving pool 1.ubuntu.pool.ntp.org: Name or service not known (-2)
Sep 9 11:57:27 deedepc NetworkManager[841]: <warn> [1599627447.3723] device (wlx00e04c3cc461): Activation: failed for connection 'TP-Link_693E_5G'
Sep 9 11:57:27 deedepc systemd[1]: Started Network Manager Script Dispatcher Service.
Sep 9 11:57:27 deedepc NetworkManager[841]: <info> [1599627447.3754] vpn-connection[0x563e09fd06f0,2e042b71-72bb-414d-bb3d-079dbfbebf50,"OpenVPN",0]: VPN plugin: state changed: stopping (5)
Sep 9 11:57:27 deedepc NetworkManager[841]: <info> [1599627447.3755] vpn-connection[0x563e09fd06f0,2e042b71-72bb-414d-bb3d-079dbfbebf50,"OpenVPN",0]: VPN plugin: state changed: stopped (6)
Sep 9 11:57:27 deedepc NetworkManager[841]: <warn> [1599627447.3780] dns-sd-resolved[04a21e745918ef1d]: send-updates failed to update systemd-resolved: GDBus.Error:org.freedesktop.resolve1.NoSuchLink: Link 29 not known
Sep 9 11:57:27 deedepc NetworkManager[841]: <info> [1599627447.3875] device (tun0): state change: activated -> unmanaged (reason 'unmanaged', sys-iface-state: 'removed')
Sep 9 11:57:27 deedepc nm-dispatcher[19439]: run-parts: failed to stat component /etc/network/if-post-down.d/avahi-daemon: No such file or directory
Sep 9 11:57:27 deedepc NetworkManager[841]: <info> [1599627447.3946] manager: NetworkManager state is now DISCONNECTED
Sep 9 11:57:27 deedepc NetworkManager[841]: <info> [1599627447.4069] device (wlx00e04c3cc461): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
Sep 9 11:57:27 deedepc kernel: [ 9264.927509] RTW: rtw_ndev_notifier_call(wlx00e04c3cc461) state:4
Sep 9 11:57:27 deedepc avahi-daemon[832]: Withdrawing address record for fe80::6976:b803:f606:d14c on wlx00e04c3cc461.
Sep 9 11:57:27 deedepc avahi-daemon[832]: Leaving mDNS multicast group on interface wlx00e04c3cc461.IPv6 with address fe80::6976:b803:f606:d14c.
Sep 9 11:57:27 deedepc avahi-daemon[832]: Interface wlx00e04c3cc461.IPv6 no longer relevant for mDNS.
Sep 9 11:57:27 deedepc nm-dispatcher[19454]: run-parts: failed to stat component /etc/network/if-post-down.d/avahi-daemon: No such file or directory
Sep 9 11:57:27 deedepc NetworkManager[841]: <info> [1599627447.4334] dhcp4 (wlx00e04c3cc461): canceled DHCP transaction
Sep 9 11:57:27 deedepc NetworkManager[841]: <info> [1599627447.4334] dhcp4 (wlx00e04c3cc461): state changed bound -> done
Sep 9 11:57:27 deedepc NetworkManager[841]: <info> [1599627447.4339] dhcp6 (wlx00e04c3cc461): canceled DHCP transaction
Sep 9 11:57:27 deedepc NetworkManager[841]: <info> [1599627447.4339] dhcp6 (wlx00e04c3cc461): state changed timeout -> done
Sep 9 11:57:27 deedepc avahi-daemon[832]: Withdrawing address record for 192.168.0.104 on wlx00e04c3cc461.
Sep 9 11:57:27 deedepc avahi-daemon[832]: Leaving mDNS multicast group on interface wlx00e04c3cc461.IPv4 with address 192.168.0.104.
Sep 9 11:57:27 deedepc avahi-daemon[832]: Interface wlx00e04c3cc461.IPv4 no longer relevant for mDNS.
Sep 9 11:57:27 deedepc kernel: [ 9264.960483] RTW: cfg80211_rtw_scan(wlx00e04c3cc461)
Sep 9 11:57:27 deedepc kernel: [ 9264.963611] RTW: wlx00e04c3cc461 sleep m0=0x00000002, ori reg_0x4d4=0x00000000
Sep 9 11:57:27 deedepc nm-dispatcher[19460]: run-parts: failed to stat component /etc/network/if-post-down.d/avahi-daemon: No such file or directory
Sep 9 11:57:30 deedepc ntpd[981]: error resolving pool 2.ubuntu.pool.ntp.org: Name or service not known (-2)
Sep 9 11:57:31 deedepc kernel: [ 9269.270422] RTW: wlx00e04c3cc461 wakeup m0=0x00000002, ori reg_0x4d4=0x00000002
Sep 9 11:57:31 deedepc kernel: [ 9269.270546] RTW: survey done event(0) band:0 for wlx00e04c3cc461
Sep 9 11:57:31 deedepc kernel: [ 9269.270554] RTW: rtw_indicate_scan_done(wlx00e04c3cc461)
Sep 9 11:57:32 deedepc NetworkManager[841]: <info> [1599627452.1481] device (wlx00e04c3cc461): supplicant interface state: scanning -> inactive
Sep 9 11:57:32 deedepc NetworkManager[841]: <info> [1599627452.1484] device (p2p-dev-wlx00e04c3cc461): supplicant management interface state: scanning -> inactive
Sep 9 11:57:32 deedepc kernel: [ 9269.669722] RTW: cfg80211_rtw_scan(wlx00e04c3cc461)
Sep 9 11:57:32 deedepc kernel: [ 9269.672736] RTW: wlx00e04c3cc461 sleep m0=0x00000002, ori reg_0x4d4=0x00000000
