Не удается подружить Mint с wi-fi по неопытности.
deede
08 сен 2020, 13:19
Добрый день!
Имеется адаптер для wi-fi dexp wfa-1301 и две системы на одном ssd: win 10 и linux mint 20.
на win10 данный адаптер без проблем работает, linux не предлагает доступных wi-fi сетей.
Информация о системе:
deede@deedepc:~/Загрузки$ inxi -Fxz
System:    Kernel: 5.4.0-45-generic x86_64 bits: 64 compiler: gcc v: 9.3.0 Desktop: Xfce 4.14.2 Distro: Linux Mint 20 Ulyana
           base: Ubuntu 20.04 focal
Machine:   Type: Desktop Mobo: ASRock model: 970DE3/U3S3 serial: <filter> BIOS: American Megatrends v: P1.00 date: 03/05/2012
CPU:       Topology: 8-Core model: AMD FX-8120 bits: 64 type: MCP arch: Bulldozer rev: 2 L2 cache: 2048 KiB
           flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 49698
           Speed: 1769 MHz min/max: 1400/3100 MHz Core speeds (MHz): 1: 1738 2: 1709 3: 1503 4: 1424 5: 1626 6: 1666 7: 1553
           8: 1565
Graphics:  Device-1: AMD Pitcairn PRO [Radeon HD 7850 / R7 265 / R9 270 1024SP] vendor: Hightech Information System
           driver: radeon v: kernel bus ID: 01:00.0
           Display: x11 server: X.Org 1.20.8 driver: ati,radeon unloaded: fbdev,modesetting,vesa resolution: 1920x1080~60Hz
           OpenGL: renderer: AMD PITCAIRN (DRM 2.50.0 5.4.0-45-generic LLVM 10.0.0) v: 4.5 Mesa 20.0.8 direct render: Yes
Audio:     Device-1: Advanced Micro Devices [AMD/ATI] SBx00 Azalia vendor: ASRock driver: snd_hda_intel v: kernel
           bus ID: 00:14.2
           Device-2: AMD Oland/Hainan/Cape Verde/Pitcairn HDMI Audio [Radeon HD 7000 Series]
           vendor: Hightech Information System driver: snd_hda_intel v: kernel bus ID: 01:00.1
           Device-3: GN Netcom Jabra BIZ 2300 type: USB driver: jabra,snd-usb-audio,usbhid bus ID: 3-3:3
           Sound Server: ALSA v: k5.4.0-45-generic
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASRock driver: r8169 v: kernel port: e800
           bus ID: 04:00.0
           IF-ID-1: ppp0 state: unknown speed: N/A duplex: N/A mac: N/A
           IF-ID-2: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
Drives:    Local Storage: total: 1.38 TiB used: 31.67 GiB (2.2%)
           ID-1: /dev/sda vendor: Patriot model: P200 512GB size: 476.94 GiB
           ID-2: /dev/sdb vendor: Seagate model: ST1000DM003-9YN162 size: 931.51 GiB
Partition: ID-1: / size: 109.50 GiB used: 29.84 GiB (27.3%) fs: ext4 dev: /dev/sda2
           ID-2: /home size: 91.17 GiB used: 1.83 GiB (2.0%) fs: ext4 dev: /dev/sda3
Sensors:   System Temperatures: cpu: 23.1 C mobo: N/A gpu: radeon temp: 40 C
Info:      Processes: 309 Uptime: 8h 11m Memory: 7.76 GiB used: 3.93 GiB (50.7%) Init: systemd runlevel: 5 Compilers:
           gcc: 9.3.0 Shell: bash v: 5.0.17 inxi: 3.0.38
Из диагностики Собрал вывод логов при отключении/подключении адаптера, найденный для него драйвера и как пытался их установить, определение usb устройства, определение wi-fi интерфейса.
deede@deedepc:~/Загрузки$ sudo dmesg
[29617.264239] usb 1-1.4: USB disconnect, device number 8
[29619.632216] usb 1-1.4: new high-speed USB device number 9 using ehci-pci
[29619.841393] usb 1-1.4: New USB device found, idVendor=0bda, idProduct=b812, bcdDevice= 2.10
[29619.841399] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[29619.841402] usb 1-1.4: Product: 802.11ac NIC
[29619.841405] usb 1-1.4: Manufacturer: Realtek
[29619.841407] usb 1-1.4: SerialNumber: 123456
deede@deedepc:~/Загрузки$ lsusb
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 002: ID 1e71:170e NZXT NZXT USB Device
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 009: ID 0bda:b812 Realtek Semiconductor Corp. <--- Это он.
Bus 001 Device 004: ID 09da:0260 A4Tech Co., Ltd. KV-300H Isolation Keyboard
Bus 001 Device 002: ID 1a40:0101 Terminus Technology Inc. Hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 003: ID 0b0e:2304 GN Netcom Jabra BIZ 2300
Bus 003 Device 002: ID 0458:003a KYE Systems Corp. (Mouse Systems) NetScroll+ Mini Traveler / Genius NetScroll 120
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 009 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 008 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
deede@deedepc:~/Загрузки$ iwconfig
lo        no wireless extensions.
ppp0      no wireless extensions.
tun0      no wireless extensions.
enp4s0    no wireless extensions.
В Системе на данный момент поднято два vpn для работы, что добавляет лишние интерфейсы.
Установить пробовал скачав с https://github.com/abperiasamy/rtl8812AU_8821AU_linux и прочитав README установить через dkms.conf
Также пробовал вариант с вводом sudo apt install rtl8812au-dkms
Оба прошли без ошибок, но не дали никаких изменений.
Как выглядит данный адаптер я приложил во вложениях. Также вложил скрин графического интерфейса, касаемо ethernet соединения.
В линукс новенький, разобраться читая форумы за три дня, увы, не получилось.Так и сижу на проводном соединении.
В связи с этим прошу сопровождать команды - описанием, а советы - командами. Спасибо за понимание и помощь заранее!
:tux:
Если я не приложил чего-то важного, то я либо не знал, как это вывести, либо перенервничал, пока писал этот пост т.к. редко прошу о помощи.
Решение Chocobo » 08 сен 2020, 15:28
deede, мы тут покумекали и поняли, что ты собираешь не тот драйвер похоже.
RTL8812bu - твоя железка, не au :smile:
08 сен 2020, 13:26
Покажи
sudo lshw -C network
rfkill list
08 сен 2020, 13:33
deede, lsmod | grep rtl покажи
deede
08 сен 2020, 13:33
08 сен 2020, 13:26
Покажи
rfkill list
deede@deedepc:~/Загрузки$ sudo lshw -C network
[sudo] пароль для deede:
*-network
описание: Ethernet interface
продукт: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
производитель: Realtek Semiconductor Co., Ltd.
физический ID: 0
сведения о шине: pci@0000:04:00.0
логическое имя: enp4s0
версия: 06
серийный №: bc:5f:f4:38:7f:c5
capacity: 1Gbit/s
разрядность: 64 bits
частота: 33MHz
возможности: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
конфигурация: autonegotiation=on broadcast=yes driver=r8169 duplex=full firmware=rtl8168e-3_0.0.4 03/27/12 ip=192.168.0.239 latency=0 link=yes multicast=yes port=MII speed=100Mbit/s
ресурсы: IRQ:18 ioport:e800(размер=256) память:fdfff000-fdffffff память:fdff8000-fdffbfff
rfkill list
deede@deedepc:~/Загрузки$ rfkill list
deede
08 сен 2020, 13:34
08 сен 2020, 13:33
Пусто
deede@deedepc:~/Загрузки$ lsmod | grep rtl
08 сен 2020, 13:38
deede писал(а):
08 сен 2020, 13:34
Пусто
хм... а не для kms пробовал для начала?
deede
08 сен 2020, 13:41
08 сен 2020, 13:38
deede писал(а):
08 сен 2020, 13:34
Пусто
не понял, к сожалению(
Объясни, пожалуйста, подробнее. :thumbs:
08 сен 2020, 13:44
deede, собрать не через dkms, а просто как в секции "Compiling for Ubuntu (16.04) and Debian (9)"... и посмотреть что скажет на строчке sudo modprobe -a rtl8812au
08 сен 2020, 13:45
deede, скачай отсюда https://github.com/jeremyb31/rtl8812au-1
deede
08 сен 2020, 13:48
08 сен 2020, 13:44
Сейчас на строчке тихо.
deede@deedepc:~/Загрузки$ sudo modprobe -a rtl8812au
А вот как собрать не дошло. Погуглил, но пока все равно не дошло что требуется сделать. :blush:
08 сен 2020, 13:55
deede писал(а):
08 сен 2020, 13:48
ты по диоганали что ли свою ссылку читал? :) читаешь секцию "Compiling for Ubuntu (16.04) and Debian (9)" и копипастишь в терминал команды
deede
08 сен 2020, 14:00
08 сен 2020, 13:55
deede писал(а):
08 сен 2020, 13:48
Извини за глупость, но наверное да.
Если я правильно понимаю, то речь идет о каком-то блоке на данном форуме.
Можно прямую ссыль? Поиск данной строчки по данному сайту и гуглу на что-то конкретное не выводит.
deede
08 сен 2020, 14:02
08 сен 2020, 13:45
Пробую.. пока что не удачно судя по логам. Пытаюсь разобраться, как поставить его.
deede@deedepc:~/Рабочий стол/rtl8812au-1-5.3.4$ sudo ./dkms-install.sh
About to run dkms install steps...
cp: не удалось выполнить stat для 'стол/rtl8812au-1-5.3.4': Нет такого файла или каталога
Creating symlink /var/lib/dkms/rtl8812au/5.3.4/source ->
/usr/src/rtl8812au-5.3.4
DKMS: add completed.
Kernel preparation unnecessary for this kernel. Skipping...
Building module:
cleaning build area...
'make' -j8 KVER=5.4.0-45-generic KSRC=/lib/modules/5.4.0-45-generic/build......(bad exit status: 2)
Error! Bad return status for module build on kernel: 5.4.0-45-generic (x86_64)
Consult /var/lib/dkms/rtl8812au/5.3.4/build/make.log for more information.
Building module:
Finished running dkms install steps.
08 сен 2020, 14:02
deede, ты прикалываешься что ли? :) ты привёл ссылку на github, https://github.com/abperiasamy/rtl8812A ... d-debian-9
08 сен 2020, 14:02
08 сен 2020, 14:03
deede, ты прикалываешься что ли. Тебе говорят про ссылку, которую ты оставил в 1 сообщении
deede писал(а):
08 сен 2020, 13:19
Там есть раздел Compiling for Ubuntu (16.04) and Debian (9). Читай и выполняй.
08 сен 2020, 14:04
deede, и не собирай на рабочем столе ничего :)
deede
08 сен 2020, 14:16
08 сен 2020, 14:03
deede писал(а):
08 сен 2020, 13:19
АААААААААААААААААА. Спасибо)
Нет, не прикылаюсь. Я не из тех, кто по приколу бы совет просил.
Извините за тупость, спасибо за наставление. Сейчас почитаю!
deede
08 сен 2020, 14:25
Извините, что я так затупил, но впрямь не понял, что речь идет о разделе на гитхабе.
Сделал так https://paste.ubuntu.com/p/hWDCMXhQHC/
На этом моменте я так понял мы скачали и распаковали.
Дальше я выполнил и пусто.
deede@deedepc:/tmp/t4u/rtl8812AU_8821AU_linux-master$ sudo modprobe -a rtl8812au
Я забыл что-то наверн или снова не понял?
08 сен 2020, 14:29
deede, пропустил 2 этапа
Install kernel headers
Compile and install from source
