8 сек. на загрузку штатного ядра с SSD - это много. Очень много. У меня с ноутбучного блина на 5400 далеко от начала диска - 6 - 7сек.
Systemd-analyze plot - делимся, сравниваем...
- Решено: 24
systemd-analyze plot - делимся, сравниваем...
- Решено: 4
Как то так http://imgh.us/123_4.svg
System: Host: wanoska Kernel: 3.16.0-4-amd64 x86_64 (64 bit gcc: 4.8.4)
Desktop: N/A Distro: Debian GNU/Linux 8
Machine: System: TOSHIBA product: Satellite C660D v: PSC20R-01501ERU
Mobo: TOSHIBA model: PWWBE v: 1.00
Bios: TOSHIBA v: 1.60 date: 01/10/2012
CPU: Dual core AMD E-450 APU with Radeon HD Graphics (-MCP-) cache: 1024 KB
flags: (lm nx sse sse2 sse3 sse4a ssse3 svm) bmips: 6583
Clock Speeds: 1: 1650 MHz 2: 825 MHz
Graphics: Card: Advanced Micro Devices [AMD/ATI] Wrestler [Radeon HD 6320]
bus-ID: 00:01.0
Display Server: X.Org 1.16.4 drivers: ati,radeon (unloaded: fbdev,vesa)
Resolution: 1366x768@59.99hz
GLX Renderer: Gallium 0.4 on AMD PALM
GLX Version: 3.0 Mesa 10.3.2 Direct Rendering: Yes
Audio: Card Advanced Micro Devices [AMD/ATI] SBx00 Azalia (Intel HDA)
Sound: Advanced Linux Sound Architecture v: k3.16.0-4-amd64
Network: Card-1: Qualcomm Atheros AR9285 Wireless Network Adapter (PCI-Express)
driver: ath9k bus-ID: 02:00.0
IF: wlan1 state: up mac: <filter>
Card-2: Realtek RTL8101E/RTL8102E PCI Express Fast Ethernet controller
driver: r8169 v: 2.3LK-NAPI port: e000 bus-ID: 01:00.0
IF: eth1 state: down mac: <filter>
Drives: HDD Total Size: 500.1GB (9.4% used)
ID-1: /dev/sda model: WDC_WD5000LPVX size: 500.1GB
Partition: ID-1: / size: 19G used: 4.6G (27%) fs: ext4 dev: /dev/sda1
ID-2: /home size: 437G used: 37G (9%) fs: ext4 dev: /dev/sda3
ID-3: swap-1 size: 3.87GB used: 0.00GB (0%) fs: swap dev: /dev/sda5
Sensors: System Temperatures: cpu: 53.0C mobo: N/A gpu: 53.0
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 163 Uptime: 1 day Memory: 850.0/3565.9MB
Init: systemd runlevel: 5 Gcc sys: 4.9.2
Client: Shell (bash 4.3.301) inxi: 2.1.28
bus-ID: 00:01.0
- Решено: 215
Ну и здесь отмечусь пожалуй, с новой осью - LM 18.2 Sonya BETA x64 Cinnamon (до начала настройки исходная была цифра в 9.972 сек)
https://imgh.us/index.php
От исходного состояния погасил:
Startup finished in 2.993s (kernel) + 1.391s (userspace) = 4.385s
chocobo@desktop ~ $ systemd-analyze blame
480ms dev-sdb1.device
260ms console-setup.service
163ms loadcpufreq.service
161ms accounts-daemon.service
160ms systemd-fsck@dev-disk-by\x2duuid-c7fa5a72\x2d3496\x2d4818\x2d9c
146ms systemd-update-utmp.service
143ms grub-common.service
142ms binfmt-support.service
135ms ntp.service
134ms systemd-udevd.service
134ms systemd-networkd.service
131ms lightdm.service
126ms thermald.service
120ms plymouth-read-write.service
107ms systemd-logind.service
105ms irqbalance.service
103ms gpu-manager.service
102ms dns-clean.service
102ms plymouth-quit-wait.service
85ms virtualbox-guest-utils.service
80ms ondemand.service
73ms upower.service
60ms speech-dispatcher.service
54ms systemd-udev-trigger.service
53ms keyboard-setup.service
51ms lm-sensors.service
50ms hddtemp.service
50ms iio-sensor-proxy.service
41ms console-kit-log-system-start.service
39ms systemd-user-sessions.service
36ms rsyslog.service
36ms systemd-journald.service
35ms systemd-tmpfiles-setup-dev.service
33ms colord.service
32ms udisks2.service
30ms systemd-tmpfiles-setup.service
30ms systemd-fsck@dev-disk-by\x2duuid-cb38ab47\x2d87ea\x2d4b78\x2da5
30ms systemd-modules-load.service
24ms alsa-restore.service
18ms avahi-daemon.service
17ms pppd-dns.service
17ms polkitd.service
16ms user@1000.service
14ms mnt-share.mount
14ms cpufrequtils.service
13ms plymouth-start.service
13ms systemd-sysctl.service
12ms dev-mqueue.mount
10ms systemd-journal-flush.service
8ms home.mount
7ms kmod-static-nodes.service
7ms systemd-random-seed.service
6ms systemd-remount-fs.service
6ms sys-kernel-debug.mount
5ms rc-local.service
5ms openvpn.service
5ms systemd-networkd-resolvconf-update.service
5ms sys-fs-fuse-connections.mount
5ms dev-hugepages.mount
4ms rtkit-daemon.service
4ms systemd-update-utmp-runlevel.service
3ms proc-sys-fs-binfmt_misc.mount
3ms ureadahead-stop.service
3ms resolvconf.service
2ms setvtrgb.service
2ms tmp.mount
- brltty.service
- apparmor.service
- lvm2-monitor.service
- networking.service
- ModemManager.service
- NetworkManager.service
- ufw.service
NM
как обычно настроил systemd-networkd
, ну и перебрал initrd
в lzop
-сжатие.-
Раньше грузилась быстрее, но с апгрейдом ядра и установкой amdgpu-pro.... Имею следующие показатели.
- Решено: 215
Grombixalo, apt-daily.service (12.775s) выделяется на общем фоне явным кандидатом на выпиливание.
ну и в общем некоторые сервисы не очень шустрят на запуск, диск не очень медленный отведен под корневую ФС?
- Решено: 24
Grombixalo, lvm используешь? app-armor - профили приложений настраиваешь? speech-dispetcher, brltty - со зрением плохо? Файерволл реально нужен? Блютус? Про ondemand - надоело объяснять, что это не нужно. Давно уже performance. Хочешь придерживать отзывчивость системы - дело твоё.
Доброго времени суток.
System: Host: doe Kernel: 4.8.5-040805-generic x86_64 (64 bit) Desktop: Cinnamon 3.2.7
Distro: Linux Mint 18.1 Serena
Machine: Mobo: Gigabyte model: Z87M-D3H v: x.x Bios: American Megatrends v: 11b date: 06/12/2014
CPU: Quad core Intel Core i5-4690 (-MCP-) cache: 6144 KB
clock speeds: max: 3900 MHz 1: 3849 MHz 2: 3870 MHz 3: 3897 MHz 4: 3870 MHz
Graphics: Card: Advanced Micro Devices [AMD/ATI] Hawaii PRO [Radeon R9 290]
Display Server: X.Org 1.18.4 drivers: ati,amdgpu (unloaded: fbdev,vesa,radeon)
Resolution: 1920x1080@60.00hz
GLX Renderer: AMD Radeon R9 200 Series GLX Version: 4.5.13474 - CPC 17.10.2
Audio: Card-1 Intel 8 Series/C220 Series High Definition Audio Controller
Card-2 Advanced Micro Devices [AMD/ATI] Hawaii HDMI Audio driver: snd_hda_intel
Sound: Advanced Linux Sound Architecture v: k4.8.5-040805-generic
Network: Card: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller driver: r8169
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: 9480:6b:99:95
Drives: HDD Total Size: 1448.3GB (5.4% used) ID-1: /dev/sda model: ST31000524AS size: 1000.2GB
ID-2: /dev/sdb model: Samsung_SSD_850 size: 128.0GB
ID-3: /dev/sdc model: WDC_WD3200BPVT size: 320.1GB
Partition: ID-1: / size: 28G used: 9.0G (35%) fs: ext4 dev: /dev/sdc3
ID-2: /boot size: 461M used: 150M (35%) fs: ext2 dev: /dev/sdc1
ID-3: /home size: 264G used: 62G (25%) fs: ext4 dev: /dev/sdc4
ID-4: swap-1 size: 2.00GB used: 0.00GB (0%) fs: swap dev: /dev/sdc2
Sensors: System Temperatures: cpu: 50.0C mobo: 27.8C gpu: 49.0
Info: Processes: 216 Uptime: 47 min Memory: 1953.5/15984.3MB
Client: Shell (bash) inxi: 2.2.35
Я конечно понимаю, что Вы владеете информацией. Но для меня, имеющего стаж пользования линукса, как пользователя - год и полностью самостоятельно его изучающего. Вы ругаетесь страшными словами.
Буду благодарен, если Вы соизволите дать расшифровку вашим "аббревиатурам".
А по русски. Не вести себя как малахольный, а помочь. Что я делаю не так и что мне делать? Не хотите учить, дайте ссылку где и что почитать. Не можете или не хотите, тогда что вы делаете на форуме линукса, где пропагандируется взаимопомощь и взаимовыручка? Не хотите объяснять, тогда вопрос тот же, то и выше, что Вы тут забыли?
З.Ы.https://youtu.be/KThkHX4rYwI
- Решено: 215
Grombixalo, можно перечитать саму эту тему, для начала.
Тут уже многое успели обговорить по сервисам и их влиянию.
http://imgh.us/123_5.svg
было 12 сек, но после отключения этих служб стало 7 сек:
Что еще можно отключить и не переборщил ли я отключив эти службы?
п.с. после удаления
apt-daily.service
NetworkManager-wait-online.service
apparmor.service
п.с. после удаления
ufw.service
время наоборот увеличилось на несколько сотых сек )))-
- Решено: 24
speech-dispatcher.service если со зрением всё в порядке. Можно и пакет gnome-orca удалить.
Да нет. Если NM не используешь.
gpu-manager.service для ноутов с дискреткой.
Установи systemadm для наглядности.
- Решено: 4
Только я в этих графиках ни фига не поняла
- Решено: 4
Это отчет у меня в формате .svk и форум не хочет его воспринимать
- Решено: 4
http://imgh.us/komp-4.4.0-53-generic.svg вот. и как результат?
