Проблема с логином
rut
Благодарил (а): 31 раз
Проблема с логином
20 авг 2020, 18:03
Linux Mint 19.3 Tricia 64-разрядный, MATE
Вывод inxi
Host: pk-Lenovo-G50-45 Kernel: 5.4.0-42-generic x86_64 bits: 64
compiler: gcc v: 7.5.0 Desktop: MATE 1.22.2 Distro: Linux Mint 19.3 Tricia
base: Ubuntu 18.04 bionic
Type: Laptop System: LENOVO product: 80E3 v: Lenovo G50-45
serial: <filter>
Mobo: LENOVO model: Lancer 5B2 serial: <filter> UEFI: LENOVO
v: A2CN40WW(V2.08) date: 08/21/2015
ID-1: BAT1 charge: 23.7 Wh condition: 23.7/28.5 Wh (83%)
model: LENOVO PABAS0241231 status: Full
Topology: Quad Core model: AMD A8-6410 APU with AMD Radeon R5 Graphics
bits: 64 type: MCP arch: Puma rev: 1 L2 cache: 2048 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 15969
Speed: 1084 MHz min/max: 1000/2000 MHz Core speeds (MHz): 1: 1162 2: 1155
3: 1182 4: 1127
Device-1: AMD Mullins [Radeon R4/R5 Graphics] vendor: Lenovo
driver: radeon v: kernel bus ID: 00:01.0
Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430 / R7
M520]
vendor: Lenovo driver: radeon v: kernel bus ID: 01:00.0
Display: x11 server: X.Org 1.19.6 driver: ati,radeon
unloaded: fbdev,modesetting,vesa resolution: 1366x768~60Hz
OpenGL: renderer: AMD KABINI (DRM 2.50.0 5.4.0-42-generic LLVM 10.0.0)
v: 4.5 Mesa 20.0.8 direct render: Yes
Device-1: AMD Kabini HDMI/DP Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus ID: 00:01.1
Device-2: AMD FCH Azalia vendor: Lenovo driver: snd_hda_intel v: kernel
bus ID: 00:14.2
Sound Server: ALSA v: k5.4.0-42-generic
Device-1: Realtek RTL8723BE PCIe Wireless Network Adapter vendor: Lenovo
driver: rtl8723be v: kernel port: 3000 bus ID: 02:00.0
vendor: Lenovo driver: r8169 v: kernel port: 2000 bus ID: 03:00.0
Local Storage: total: 465.76 GiB used: 92.34 GiB (19.8%)
ID-1: /dev/sda vendor: Crucial model: CT500MX500SSD1 size: 465.76 GiB
ID-1: / size: 91.48 GiB used: 27.31 GiB (29.9%) fs: ext4 dev: /dev/sda5
ID-2: /home size: 300.59 GiB used: 65.00 GiB (21.6%) fs: ext4
dev: /dev/sda6
ID-3: swap-1 size: 9.31 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda7
System Temperatures: cpu: 44.6 C mobo: N/A
GPU: device: radeon temp: 47 C device: radeon temp: 44 C
Processes: 262 Uptime: 1h 39m Memory: 10.68 GiB used: 5.11 GiB (47.8%)
inxi: 3.0.32
pk@pk-Lenovo-G50-45:~$
Вывод hw probe не выдам, сейчас поймете почему.
Итак, вздумалось мне сменить пароль на вход в минт.
Сменил пароль через меню "Обо мне". Сначала понятно попросило ввести старый пароль, ввел старый, перешел к двум строкам, где вводится новый и подтверждение нового, разумеется это тоже ввел все на автомате. Не ругалось ничего нигде. Правда при этом, не обратил внимание каккой язык стоит при наборе, так как старый пароль полностью цифровой, а вот новый полностью текстовый. Получается я прошел первое окно и потом это же самое окно вылезло второй раз. Туда я ввожу уже новый пароль и система его не принимает, ввожу старый, его тоже не принимает. Быстро отключил хранители экрана и прочие блокировки, чтобы оставаться в системе как можно дольше. Команду sudo выполнить не могу, так как не проходит ни старый пароль , ни новый , и не новый ( даже при русской раскладке) . Не ужели дело попахивает на ровном месте перестановкой минты. Тайм машин тоже хочет пароль , чтобы стартануть, откатится не получиться. Что делать ?
Решение slant » 20 авг 2020, 20:55
У современных линуксов пароль живет в /etc/shadow в 90% случаев, и минт в них входит. Это простой текстовый файл, куда можно влезть простым текстовым редактором вроде nano или xed. Так что вручную поменять пароль не так уж сложно. Но чтобы этот файл открыть - нужны права root (даже на чтение), а это значит что придется грузится в live систему с флешки, монтировать туда hdd, и уже тогда лезть через sudo xed .../etc/shadow
Пароль там хранится в виде хеша, так что сравнить с ним другой пароль прогнанный через такой же механизм хеширования можно (т.е. сравниваются два хеша а не сам пароль с образцом), а вот расшифровать обратно - не очень. Потому можно заменить пароль но не узнать какой он был (если хотя бы 6 знаков длинны было, а то и перебор может справится - программы есть).
Посему далее классический алгоритм действий:
1. Понять какой алгоритм хеширования используется (md5, sha256, sha512)
2. Сгенерировать хеш соответствующего типа утилитой.
3. Вписать его в shadow нужному пользователю.
В shadow хеши начинаются с "$" и цифры - если 1 - это MD5, если 5 - sha256, если 6 - sha512.
Далее генерим хеш:
openssl passwd -6 mynewpass - "-6" - это указание использовать sha512; в общем-то цифра из предыдущего пункта.
А можно схитрить - прямо в live системе завести отдельного пользователя с вашим же именем (или другим - не принципиально), таким же как в установленной системе, и задать ему пароль командами:
sudo useradd myusername
sudo passwd myusername
После чего открыть /etc/shadow live системы и взять сгенерированый хеш оттуда.
Остается только вписать полученный хеш в shadow установленной системы. Важно - не всю строчку (если делали через adduser) а только хеш пароля. А то могут быть нежданчики. :)
Каждая строчка в shadow состоит из нескольких полей разделенных двоеточием. Пароль (хеш) - второе поле.
Проблема с логином
20 авг 2020, 18:08
Ctrl+Alt+F1 ?
rut
Проблема с логином
20 авг 2020, 18:12
При ctrl alt f1 погас экран. Теперь пишу с телефона. Что это было эпик файл , нажатие этих клавиш фактически закончилось перегрузкой. . Все теперь только режим гостя
Последний раз редактировалось пользователем 1 rut; всего редактировалось раз: 20
Проблема с логином
20 авг 2020, 18:15
rut, ctrl + alt + f7 - вернёшься обратно
это было переключение консолей...
зачем саймон посоветовал - хз :-D
вспомнить пароль совсем не вариант? :)
Последний раз редактировалось пользователем 1 WWolf; всего редактировалось раз: 20
rut
Проблема с логином
20 авг 2020, 18:16
WWolf, машина перегрузилась, только гест вход теперь
Проблема с логином
20 авг 2020, 18:17
rut, :hoho: ребут в однопользовательский режим
rut
Проблема с логином
20 авг 2020, 18:20
WWolf, так я пароль и не забывал , он просто не проходит , хотя прошел подтверждение при его установке. У меня нет вариантов других паролей, все происходило по свежему, не то что бы я его забыл.
Проблема с логином
20 авг 2020, 20:55
Далее генерим хеш:
Проблема с логином
20 авг 2020, 21:00
А, еще добавлю - не пробуйте упростить себе жизнь просто стерев хеш совсем. Отсутствие хеша - это пустой пароль... вот только пустой пароль = запрет интерактивного входа. Т.е. не войдете все равно. :)
Проблема с логином
20 авг 2020, 21:22
rut
Проблема с логином
20 авг 2020, 21:26
slant,
Вот думал, здорово бы было, если бы slant отозвался :thumbs: . Как всегда, все на высшем методическом уровне разжевано и объяснено. И да, Вы правы после прочтения первого поста, сразу созрел план прописать пустую строку, меня пароль сам по себе не интересует, мне бы провалиться в мою рабочую систему По уставу благодарность уходит в карму. О решении отмечусь завтра, так как это моя рабочая станция осталась в офисе.
Проблема с логином
20 авг 2020, 21:54
symon2014, Тоже вариант, но как-то во вторую очередь у меня вспоминается обычно. Может потому, что кое-где не работает (нет загрузки в одиночном режиме под root), хотя в большинстве случаев, вполне.
rut
Проблема с логином
21 авг 2020, 21:49
slant,
Подскажите, смену рута пароля поборол. А как поступить с этим несоответсвием ключей
Проблема с логином
21 авг 2020, 21:53
seahorse
rut
Проблема с логином
21 авг 2020, 22:30
вообщем выводы. пароли надо менять в терминале.
Попробовал понять в чем вышел косяк. Запустил смену паролей в терминале через passwd в рабочей системе. Ввел тот же самый новый устанавливаемый пароль, на котором все полетело в прошлый раз. И через консоль увидел такое Bad: new password is too simple
, хотя при смене пароля через "Обо мне" таких сообщений не поступало.
Проблема с логином
21 авг 2020, 22:32
new password is too simple --- новый пароль слишком простой
Проблема с логином
22 авг 2020, 10:47
rut писал(а):
21 авг 2020, 22:30
Это вообще не проблема. Это просто тебя проинформировали что твой пароль слишком простой
Проблема с логином
24 авг 2020, 10:54
загруз с флешки -> чрут -> пишем юзеру пароль.
Вернуться в «Безопасность»
