Linux Mint 20 XFCE. Не меняется время отображения grub.
Samail
06 авг 2020, 14:06
Здравствуйте.
Такая проблема: меню grub перед загрузкой ОС отображается 30 секунд и никак не получается эти 30 секунд поменять на 5.
Моя система (inxi -Fxz):
Kernel: 5.4.0-42-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
Desktop: Xfce 4.14.2 Distro: Linux Mint 20 Ulyana base: Ubuntu 20.04 focal
Type: Desktop Mobo: ASRock model: 970 Pro3 serial: <filter>
UEFI: American Megatrends v: P1.60 date: 10/12/2012
Topology: 6-Core model: AMD FX-6100 bits: 64 type: MCP arch: Bulldozer
rev: 2 L2 cache: 2048 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 39514
Speed: 1444 MHz min/max: 1400/3300 MHz Core speeds (MHz): 1: 1445 2: 1499
3: 1418 4: 1457 5: 1407 6: 1427
Device-1: AMD Cape Verde XT [Radeon HD 7770/8760 / R7 250X]
vendor: Micro-Star MSI driver: radeon v: kernel bus ID: 01:00.0
Display: x11 server: X.Org 1.20.8 driver: ati,radeon
OpenGL: renderer: AMD VERDE (DRM 2.50.0 5.4.0-42-generic LLVM 10.0.0)
v: 4.5 Mesa 20.1.4 - kisak-mesa PPA direct render: Yes
Device-1: AMD SBx00 Azalia vendor: ASRock driver: snd_hda_intel v: kernel
bus ID: 00:14.2
Device-2: AMD Oland/Hainan/Cape Verde/Pitcairn HDMI Audio [Radeon HD 7000
Series]
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus ID: 01:00.1
Device-3: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
bus ID: 2-2:2
Sound Server: ALSA v: k5.4.0-42-generic
vendor: ASRock driver: r8169 v: kernel port: d000 bus ID: 05:00.0
IF: enp5s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 942.70 GiB used: 436.88 GiB (46.3%)
ID-1: /dev/sda model: 512GB SSD size: 476.94 GiB
ID-2: /dev/sdb vendor: Hitachi model: HDP725050GLA360 size: 465.76 GiB
ID-1: / size: 46.57 GiB used: 13.24 GiB (28.4%) fs: btrfs dev: /dev/sda2
ID-2: /home size: 186.26 GiB used: 59.07 GiB (31.7%) fs: btrfs
dev: /dev/sda3
System Temperatures: cpu: 25.4 C mobo: N/A gpu: radeon temp: 37 C
Processes: 283 Uptime: 4h 11m Memory: 7.73 GiB used: 2.80 GiB (36.2%)
inxi: 3.0.38
Содержимое /etc/default/grub:
# /boot/grub/grub.cfg.
#   info -f grub -n 'Simple configuration'
GRUB_DEFAULT=0
GRUB_TIMEOUT_STYLE=hidden
GRUB_TIMEOUT=5
GRUB_CMDLINE_LINUX=""
#GRUB_TERMINAL=console
#GRUB_GFXMODE=640x480
#GRUB_DISABLE_LINUX_UUID=true
#GRUB_DISABLE_RECOVERY="true"
#GRUB_INIT_TUNE="480 440 1"
Читал, что это из-за UEFI.
06 авг 2020, 14:13
Samail писал(а):
06 авг 2020, 14:06
Нет. Чаще это проявляется при некорректном завершении работы системы.
Samail
06 авг 2020, 14:29
06 авг 2020, 14:13
Samail писал(а):
06 авг 2020, 14:06
Вот здесь прочитал: https://forums.linuxmint.com/viewtopic.php?t=287026
Пробовал первый способ - не помогло.
А как корректно завершить работу системы?
warning
Решено: 7
Благодарил (а): 161 раз
06 авг 2020, 22:56
Стоит спросить, а после того как поменяли 30сек на 5сек update-grub делали?
hw-probe: тыц!
07 авг 2020, 06:03
warning писал(а):
06 авг 2020, 22:56
Это решение похоже на лечение больной головы гильотиной.
Samail
14 авг 2020, 09:59
warning писал(а):
06 авг 2020, 22:56
Да.
Samail
01 сен 2020, 09:47
В-общем, проблему решил по той инструкции по ссылке из прошлого моего сообщения. В итоге решение было такое:
sudo sed -i "/recordfail_broken=/{s/1/0/}" /etc/grub.d/00_header
sudo -s update-grub
Строчку с префиксом "-s" только сейчас заметил.
01 сен 2020, 09:49
Samail писал(а):
01 сен 2020, 09:47
этот ключ тут вообще не в ворота
Samail
01 сен 2020, 09:57
01 сен 2020, 09:49
Samail писал(а):
01 сен 2020, 09:47
Главное, что это сработало: время отображения меню стало равняться указанному в /etc/default/grub
Вернуться в «Xfce»
