Ничего такого. Просто я искал инфу про KDENeon и яндекс мне выдал эту страницу. Мне там комменты понравились
dja@dja-laptop:~$ inxi -Fxz
System: Kernel: 5.4.0-66-generic x86_64 bits: 64 compiler: gcc v: 9.3.0 Desktop: Xfce 4.14.2 Distro: Linux Mint 20.1 Ulyssa
base: Ubuntu 20.04 focal
Machine: Type: Laptop System: ASUSTeK product: X541UVK v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X541UVK v: 1.0 serial: <filter> UEFI: American Megatrends v: X541UVK.308 date: 01/30/2018
Battery: ID-1: BAT0 charge: 18.7 Wh condition: 28.2/34.6 Wh (82%) model: ASUSTeK ASUS Battery status: Charging
CPU: Topology: Dual Core model: Intel Core i3-6006U bits: 64 type: MT MCP arch: Skylake rev: 3 L2 cache: 3072 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 15999
Speed: 500 MHz min/max: 400/2000 MHz Core speeds (MHz): 1: 500 2: 500 3: 500 4: 500
Graphics: Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: ASUSTeK driver: i915 v: kernel bus ID: 00:02.0
Device-2: NVIDIA GM108M [GeForce 920MX] vendor: ASUSTeK driver: nouveau v: kernel bus ID: 01:00.0
Display: x11 server: X.Org 1.20.9 driver: modesetting unloaded: fbdev,vesa
resolution: 1920x1080~60Hz, 1280x1024~60Hz
OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 20.2.6 direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 00:1f.3
Sound Server: ALSA v: k5.4.0-66-generic
Network: Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: ASUSTeK driver: r8169 v: kernel port: d000
bus ID: 02:00.2
IF: enp2s0f2 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives: Local Storage: total: 931.51 GiB used: 423.01 GiB (45.4%)
ID-1: /dev/sda vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB temp: 38 C
Partition: ID-1: / size: 47.81 GiB used: 6.75 GiB (14.1%) fs: ext4 dev: /dev/sda2
ID-2: /home size: 191.57 GiB used: 69.4 MiB (0.0%) fs: ext4 dev: /dev/sda4
ID-3: swap-1 size: 8.79 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda3
Sensors: System Temperatures: cpu: 35.5 C mobo: N/A gpu: nouveau temp: 39 C
Fan Speeds (RPM): cpu: 2000
Info: Processes: 189 Uptime: 3m Memory: 7.66 GiB used: 628.6 MiB (8.0%) Init: systemd runlevel: 5 Compilers: gcc: 9.3.0
Shell: bash v: 5.0.17 inxi: 3.0.38
dja@dja-laptop:~$
