LinuxMint 20 xfce не показывает меню grub после upgrade
Maxim
#21
26 июл 2020, 13:25
30_os-prober
#! /bin/sh
set -e
# grub-mkconfig helper script.
# Copyright (C) 2006,2007,2008,2009 Free Software Foundation, Inc.
# GRUB is free software: you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation, either version 3 of the License, or
# (at your option) any later version.
# GRUB is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with GRUB. If not, see <http://www.gnu.org/licenses/>.
prefix="/usr"
exec_prefix="/usr"
datarootdir="/usr/share"
quick_boot="1"
export TEXTDOMAIN=grub
export TEXTDOMAINDIR="${datarootdir}/locale"
. "$pkgdatadir/grub-mkconfig_lib"
found_other_os=
adjust_timeout () {
if [ "$quick_boot" = 1 ] && [ "x${found_other_os}" != "x" ]; then
cat << EOF
set timeout_style=menu
if [ "\${timeout}" = 0 ]; then
set timeout=10
fi
EOF
fi
if [ "x${GRUB_DISABLE_OS_PROBER}" = "xtrue" ]; then
exit 0
fi
if [ -z "`which os-prober 2> /dev/null`" ] || [ -z "`which linux-boot-prober 2> /dev/null`" ] ; then
# missing os-prober and/or linux-boot-prober
exit 0
fi
OSPROBED="`os-prober | tr ' ' '^' | paste -s -d ' '`"
if [ -z "${OSPROBED}" ] ; then
# empty os-prober output, nothing doing
exit 0
fi
osx_entry() {
found_other_os=1
if [ x$2 = x32 ]; then
# TRANSLATORS: it refers to kernel architecture (32-bit)
bitstr="$(gettext "(32-bit)")"
else
# TRANSLATORS: it refers to kernel architecture (64-bit)
bitstr="$(gettext "(64-bit)")"
fi
# TRANSLATORS: it refers on the OS residing on device %s
onstr="$(gettext_printf "(on %s)" "${DEVICE}")"
cat << EOF
menuentry '$(echo "${LONGNAME} $bitstr $onstr" | grub_quote)' --class osx --class darwin --class os \$menuentry_id_option 'osprober-xnu-$2-$(grub_get_device_id "${DEVICE}")' {
EOF
save_default_entry | grub_add_tab
prepare_grub_to_access_device ${DEVICE} | grub_add_tab
cat << EOF
load_video
set do_resume=0
if [ /var/vm/sleepimage -nt10 / ]; then
if xnu_resume /var/vm/sleepimage; then
set do_resume=1
fi
fi
if [ \$do_resume = 0 ]; then
xnu_uuid ${OSXUUID} uuid
if [ -f /Extra/DSDT.aml ]; then
acpi -e /Extra/DSDT.aml
fi
if [ /kernelcache -nt /System/Library/Extensions ]; then
$1 /kernelcache boot-uuid=\${uuid} rd=*uuid
elif [ -f /System/Library/Kernels/kernel ]; then
$1 /System/Library/Kernels/kernel boot-uuid=\${uuid} rd=*uuid
xnu_kextdir /System/Library/Extensions
else
$1 /mach_kernel boot-uuid=\${uuid} rd=*uuid
if [ /System/Library/Extensions.mkext -nt /System/Library/Extensions ]; then
xnu_mkext /System/Library/Extensions.mkext
else
fi
fi
if [ -f /Extra/Extensions.mkext ]; then
xnu_mkext /Extra/Extensions.mkext
fi
if [ -d /Extra/Extensions ]; then
xnu_kextdir /Extra/Extensions
fi
if [ -f /Extra/devprop.bin ]; then
xnu_devprop_load /Extra/devprop.bin
fi
if [ -f /Extra/splash.jpg ]; then
insmod jpeg
xnu_splash /Extra/splash.jpg
fi
if [ -f /Extra/splash.png ]; then
insmod png
xnu_splash /Extra/splash.png
fi
if [ -f /Extra/splash.tga ]; then
insmod tga
xnu_splash /Extra/splash.tga
fi
fi
EOF
used_osprober_linux_ids=
wubi=
for OS in ${OSPROBED} ; do
DEVICE="`echo ${OS} | cut -d ':' -f 1`"
LONGNAME="`echo ${OS} | cut -d ':' -f 2 | tr '^' ' '`"
LABEL="`echo ${OS} | cut -d ':' -f 3 | tr '^' ' '`"
BOOT="`echo ${OS} | cut -d ':' -f 4`"
if UUID="`${grub_probe} --target=fs_uuid --device ${DEVICE%@*}`"; then
EXPUUID="$UUID"
if [ x"${DEVICE#*@}" != x ] ; then
EXPUUID="${EXPUUID}@${DEVICE#*@}"
fi
if [ "x${GRUB_OS_PROBER_SKIP_LIST}" != "x" ] && [ "x`echo ${GRUB_OS_PROBER_SKIP_LIST} | grep -i -e '\b'${EXPUUID}'\b'`" != "x" ] ; then
echo "Skipped ${LONGNAME} on ${DEVICE} by user request." >&2
continue
fi
fi
BTRFS="`echo ${OS} | cut -d ':' -f 5`"
if [ "x$BTRFS" = "xbtrfs" ]; then
BTRFSuuid="`echo ${OS} | cut -d ':' -f 6`"
BTRFSsubvol="`echo ${OS} | cut -d ':' -f 7`"
fi
if [ -z "${LONGNAME}" ] ; then
LONGNAME="${LABEL}"
fi
# os-prober returns text string followed by optional counter
CLASS="--class $(echo "${LABEL}" | LC_ALL=C sed 's,[[:digit:]]*$,,' | cut -d' ' -f1 | tr 'A-Z' 'a-z' | LC_ALL=C sed 's,[^[:alnum:]_],_,g')"
gettext_printf "Found %s on %s\n" "${LONGNAME}" "${DEVICE}" >&2
case ${BOOT} in
chain)
case ${LONGNAME} in
Windows*)
if [ -z "$wubi" ]; then
if [ -x /usr/share/lupin-support/grub-mkimage ] && \
/usr/share/lupin-support/grub-mkimage --test; then
wubi=yes
else
wubi=no
fi
fi
if [ "$wubi" = yes ]; then
echo "Skipping ${LONGNAME} on Wubi system" >&2
continue
fi
esac
found_other_os=1
cat << EOF
menuentry '$(echo "${LONGNAME} $onstr" | grub_quote)' $CLASS --class os \$menuentry_id_option 'osprober-chain-$(grub_get_device_id "${DEVICE}")' {
EOF
if [ x"`${grub_probe} --device ${DEVICE} --target=partmap`" = xmsdos ]; then
cat << EOF
parttool \${root} hidden-
EOF
fi
case ${LONGNAME} in
Windows\ Vista*|Windows\ 7*|Windows\ Server\ 2008*)
cat << EOF
drivemap -s (hd0) \${root}
EOF
esac
cat <<EOF
chainloader +1
EOF
efi)
found_other_os=1
EFIPATH=${DEVICE#*@}
DEVICE=${DEVICE%@*}
cat << EOF
menuentry '$(echo "${LONGNAME} $onstr" | grub_quote)' $CLASS --class os \$menuentry_id_option 'osprober-efi-$(grub_get_device_id "${DEVICE}")' {
EOF
save_default_entry | sed -e "s/^/\t/"
prepare_grub_to_access_device ${DEVICE} | sed -e "s/^/\t/"
cat <<EOF
chainloader ${EFIPATH}
EOF
linux)
LINUXPROBED="`linux-boot-prober btrfs ${BTRFSuuid} ${BTRFSsubvol} 2> /dev/null | tr ' ' '^' | paste -s -d ' '`"
else
LINUXPROBED="`linux-boot-prober ${DEVICE} 2> /dev/null | tr ' ' '^' | paste -s -d ' '`"
fi
prepare_boot_cache=
boot_device_id=
is_top_level=true
title_correction_code=
OS="${LONGNAME}"
for LINUX in ${LINUXPROBED} ; do
LROOT="`echo ${LINUX} | cut -d ':' -f 1`"
LBOOT="`echo ${LINUX} | cut -d ':' -f 2`"
LLABEL="`echo ${LINUX} | cut -d ':' -f 3 | tr '^' ' '`"
LKERNEL="`echo ${LINUX} | cut -d ':' -f 4`"
LINITRD="`echo ${LINUX} | cut -d ':' -f 5`"
LPARAMS="`echo ${LINUX} | cut -d ':' -f 6- | tr '^' ' '`"
if [ -z "${LLABEL}" ] ; then
LLABEL="${LONGNAME}"
fi
if [ "${LROOT}" != "${LBOOT}" ]; then
LKERNEL="${LKERNEL#/boot}"
LINITRD="${LINITRD#/boot}"
fi
if [ -z "${prepare_boot_cache}" ]; then
prepare_boot_cache="$(prepare_grub_to_access_device ${LBOOT} | grub_add_tab)"
[ "${prepare_boot_cache}" ] || continue
fi
found_other_os=1
recovery_params="$(echo "${LPARAMS}" | grep 'single\|recovery')" || true
counter=1
while echo "$used_osprober_linux_ids" | grep 'osprober-gnulinux-$LKERNEL-${recovery_params}-$counter-$boot_device_id' > /dev/null; do
counter=$((counter+1));
done
if [ -z "$boot_device_id" ]; then
boot_device_id="$(grub_get_device_id "${DEVICE}")"
fi
used_osprober_linux_ids="$used_osprober_linux_ids 'osprober-gnulinux-$LKERNEL-${recovery_params}-$counter-$boot_device_id'"
if [ "x$is_top_level" = xtrue ] && [ "x${GRUB_DISABLE_SUBMENU}" != xy ]; then
cat << EOF
menuentry '$(echo "$OS $onstr" | grub_quote)' $CLASS --class gnu-linux --class gnu --class os \$menuentry_id_option 'osprober-gnulinux-simple-$boot_device_id' {
EOF
printf '%s\n' "${prepare_boot_cache}"
cat << EOF
linux ${LKERNEL} ${LPARAMS}
EOF
if [ -n "${LINITRD}" ] ; then
cat << EOF
initrd ${LINITRD}
EOF
fi
cat << EOF
EOF
echo "submenu '$(gettext_printf "Advanced options for %s" "${OS} $onstr" | grub_quote)' \$menuentry_id_option 'osprober-gnulinux-advanced-$boot_device_id' {"
is_top_level=false
fi
title="${LLABEL} $onstr"
cat << EOF
menuentry '$(echo "$title" | grub_quote)' --class gnu-linux --class gnu --class os \$menuentry_id_option 'osprober-gnulinux-$LKERNEL-${recovery_params}-$boot_device_id' {
EOF
save_default_entry | sed -e "s/^/$grub_tab$grub_tab/"
printf '%s\n' "${prepare_boot_cache}" | grub_add_tab
cat << EOF
EOF
cat << EOF
initrd ${LINITRD}
EOF
fi
cat << EOF
EOF
if [ x"$title" = x"$GRUB_ACTUAL_DEFAULT" ] || [ x"Previous Linux versions>$title" = x"$GRUB_ACTUAL_DEFAULT" ]; then
replacement_title="$(echo "Advanced options for ${OS} $onstr" | sed 's,>,>>,g')>$(echo "$title" | sed 's,>,>>,g')"
quoted="$(echo "$GRUB_ACTUAL_DEFAULT" | grub_quote)"
title_correction_code="${title_correction_code}if [ \"x\$default\" = '$quoted' ]; then default='$(echo "$replacement_title" | grub_quote)'; fi;"
grub_warn "$(gettext_printf "Please don't use old title \`%s' for GRUB_DEFAULT, use \`%s' (for versions before 2.00) or \`%s' (for 2.00 or later)" "$GRUB_ACTUAL_DEFAULT" "$replacement_title" "gnulinux-advanced-$boot_device_id>gnulinux-$version-$type-$boot_device_id")"
fi
done
if [ x"$is_top_level" != xtrue ]; then
echo '}'
fi
echo "$title_correction_code"
macosx)
if [ "${UUID}" ]; then
OSXUUID="${UUID}"
osx_entry xnu_kernel 32
osx_entry xnu_kernel64 64
fi
hurd)
found_other_os=1
cat << EOF
menuentry '$(echo "${LONGNAME} $onstr" | grub_quote)' --class hurd --class gnu --class os \$menuentry_id_option 'osprober-gnuhurd-/boot/gnumach.gz-false-$(grub_get_device_id "${DEVICE}")' {
EOF
grub_device="`${grub_probe} --device ${DEVICE} --target=drive`"
mach_device="`echo "${grub_device}" | sed -e 's/(\(hd.*\),msdos\(.*\))/\1s\2/'`"
grub_fs="`${grub_probe} --device ${DEVICE} --target=fs`"
case "${grub_fs}" in
*fs) hurd_fs="${grub_fs}" ;;
*) hurd_fs="${grub_fs}fs" ;;
esac
cat << EOF
multiboot /boot/gnumach.gz root=device:${mach_device}
module /hurd/${hurd_fs}.static ${hurd_fs} --readonly \\
--multiboot-command-line='\${kernel-command-line}' \\
--host-priv-port='\${host-port}' \\
--device-master-port='\${device-port}' \\
--exec-server-task='\${exec-task}' -T typed '\${root}' \\
'\$(task-create)' '\$(task-resume)'
module /lib/ld.so.1 exec /hurd/exec '\$(exec-task=task-create)'
EOF
minix)
cat << EOF
menuentry "${LONGNAME} (on ${DEVICE}, Multiboot)" {
EOF
cat << EOF
multiboot /boot/image_latest
EOF
# TRANSLATORS: %s is replaced by OS name.
gettext_printf "%s is not yet supported by grub-mkconfig.\n" " ${LONGNAME}" >&2
esac
done
adjust_timeout
Maxim
#22
26 июл 2020, 13:26
30_uefi-firmware
#! /bin/sh
set -e
# Copyright (C) 2012 Free Software Foundation, Inc.
prefix="/usr"
exec_prefix="/usr"
. "${datarootdir}/grub/grub-mkconfig_lib"
efi_vars_dir=/sys/firmware/efi/vars
EFI_GLOBAL_VARIABLE=8be4df61-93ca-11d2-aa0d-00e098032b8c
OsIndications="$efi_vars_dir/OsIndicationsSupported-$EFI_GLOBAL_VARIABLE/data"
if [ -e "$OsIndications" ] && \
[ "$(( $(printf 0x%x \'"$(cat $OsIndications | cut -b1)") & 1 ))" = 1 ]; then
LABEL="UEFI Firmware Settings"
gettext_printf "Adding boot menu entry for UEFI Firmware Settings\n" >&2
cat << EOF
menuentry '$LABEL' \$menuentry_id_option 'uefi-firmware' {
fwsetup
EOF
fi
Maxim
#23
26 июл 2020, 13:26
40_custom
#!/bin/sh
exec tail -n +3 $0
# This file provides an easy way to add custom menu entries. Simply type the
# menu entries you want to add after this comment. Be careful not to change
# the 'exec tail' line above.
menuentry "Android CM 14" {
set root='(hd0,2)'
linux /cm-x86-14.1-r3/kernel quiet root=/dev/ram0 androidboot.selinux=permissive buildvariant=userdebug SRC=/cm-x86-14.1-r3
initrd /cm-x86-14.1-r3/initrd.img
Maxim
#24
26 июл 2020, 13:27
41_custom
#!/bin/sh
cat <<EOF
if [ -f \${config_directory}/custom.cfg ]; then
source \${config_directory}/custom.cfg
elif [ -z "\${config_directory}" -a -f \$prefix/custom.cfg ]; then
source \$prefix/custom.cfg;
fi
EOF
#25
26 июл 2020, 13:49
Maxim, нифига себе вывалил. Что это там у тебя творится , в частности в custom -ах ?
#26
26 июл 2020, 13:50
Вроде бы стандартно - более или менее, главное что grub сам вашу вторую систему нашел и меню сформировано. Просто не показывает его почему-то. Возможно и не поможет, но давайте начнем с классики:
В /etc/default/grub добавьте
GRUB_HIDDEN_TIMEOUT_QUIET=false
GRUB_HIDDEN_TIMEOUT=0
и сделайте sudo update-grub
Maxim
#27
26 июл 2020, 17:32
slant, не работает.
В LM 20 beta была проблема с постоянной видимостью меню grub. Её решили, но видимо в обратную сторону.
#28
26 июл 2020, 18:02
Maxim, выведи сюда свой /etc/default/grub и вывод sudo update-grub
Maxim
#29
26 июл 2020, 18:13
symon2014, в первом моём сообщении на картинках посмотри, пожалуйста.
#30
26 июл 2020, 18:22
Maxim, Я там видел , но если ты делал что то , могли произойти изменения , так что не старые картинки подставляй , а выполни 2 команды и их вывод покажи здесь. И ты не ответил про custom
Maxim
#31
26 июл 2020, 18:38
symon2014, ничего не изменилось и все custom родные (я с ними ничего не делал), кроме 40_custom.Думаю, что не в них дело.
#32
26 июл 2020, 18:56
Maxim писал(а):
26 июл 2020, 18:38
Вот что за привычка. Я не это просил.
#34
26 июл 2020, 19:31
Maxim писал(а):
26 июл 2020, 19:23
Решение
Это не решение , а костыль . Но если тебе подходит , то пусть.
Вернуться в «Xfce»
