Глючит тачпад на Lenovo с новыми ядрами Linux Mint
IvAlAl
Благодарил (а): 3 раза
04 июн 2020, 21:10
На ноутбуке Lenovo G780 установлена Linux Mint параметры:
alex@Alex-Lenovo-G780:~$ inxi -Fxz
Host: Alex-Lenovo-G780 Kernel: 5.3.0-53-generic x86_64 bits: 64
compiler: gcc v: 7.5.0 Desktop: Xfce 4.14.1 Distro: Linux Mint 19.3 Tricia
base: Ubuntu 18.04 bionic
Type: Laptop System: LENOVO product: 20138 v: Lenovo G780 serial: <filter>
Mobo: LENOVO model: INVALID v: 31900004WIN8 STD SGL serial: <filter>
UEFI [Legacy]: LENOVO v: 5ECN92WW(V8.04) date: 09/14/2012
ID-1: BAT1 charge: 34.5 Wh condition: 34.6/38.9 Wh (89%)
model: LENOVO PABAS0241231 status: Unknown
Topology: Dual Core model: Intel Core i3-3110M bits: 64 type: MT MCP
arch: Ivy Bridge rev: 9 L2 cache: 3072 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 19157
Speed: 1197 MHz min/max: 1200/2400 MHz Core speeds (MHz): 1: 1198 2: 1218
3: 1197 4: 1197
Device-1: Intel 3rd Gen Core processor Graphics vendor: Lenovo
Device-2: NVIDIA GF108M [GeForce GT 635M] vendor: Lenovo driver: nvidia
v: 390.132 bus ID: 01:00.0
Display: x11 server: X.Org 1.19.6 driver: modesetting,nvidia
unloaded: fbdev,nouveau,vesa resolution: 1600x900~60Hz
OpenGL: renderer: GeForce GT 635M/PCIe/SSE2 v: 4.6.0 NVIDIA 390.132
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Lenovo
Device-2: NVIDIA GF108 High Definition Audio vendor: Lenovo
Sound Server: ALSA v: k5.3.0-53-generic
Device-1: Qualcomm Atheros AR8162 Fast Ethernet vendor: Lenovo driver: alx
v: kernel port: 2000 bus ID: 02:00.0
Device-2: Broadcom and subsidiaries BCM4313 802.11bgn Wireless Network
Adapter
driver: wl v: kernel port: 2000 bus ID: 03:00.0
Local Storage: total: 698.64 GiB used: 308.06 GiB (44.1%)
ID-1: /dev/sda vendor: Hitachi model: HTS547575A9E384 size: 698.64 GiB
ID-1: / size: 90.05 GiB used: 31.06 GiB (34.5%) fs: ext4 dev: /dev/sda7
ID-2: swap-1 size: 8.00 GiB used: 556 KiB (0.0%) fs: swap dev: /dev/sda6
System Temperatures: cpu: 59.0 C mobo: N/A gpu: nvidia temp: 64 C
Processes: 227 Uptime: 8d 19m Memory: 7.65 GiB used: 4.30 GiB (56.3%)
inxi: 3.0.32
До версии (включительно) ядра 5.0.0-37-generic тачпад работал отлично. После обновления ядра Linux Mint с тачпадом начались проблемы: на маленьком участке тачпада (середина нижней части) курсор реагирует как положено и перемещается по экрану, а на всех остальных участках - тачпад реагирует как прокрутка. Если при загрузки Linux Mint выбрать ядро 5.0.0-37-generic, то тачпад работает как положено, а с более новыми версиями ядра - проблема.
В последнее время возникла необходимость по долгу работать без мышки и глючный тачпад создает проблемы.
Помогите, пожалуйста, решить проблему с тачпадом. Все время откатываться на ядро 5.0.0-37-generic считаю не правильным выходом из сложившейся ситуации.
Благодарил (а): 1737 раз
04 июн 2020, 21:17
IvAlAl, так не обновляйся... Загрузись на старом, удали глючное и поставь запрет на обновление этого ядра... И жди когда регрессию победят... В чем проблема то?
IvAlAl
04 июн 2020, 21:27
04 июн 2020, 21:17
Спасибо за ответ. На Ваш взгляд это будет лучшим решением?
04 июн 2020, 21:34
IvAlAl, загрузите ядро из ветки 4.15 и проверьте тачпад , если будет работать , удалите ветку 5 и оставайтесь на 4.15 , она на пятую не перейдёт.
IvAlAl
04 июн 2020, 21:48
04 июн 2020, 21:34
Спасибо за ответ. Загрузился с версии ядра 4.15.101-generic. Тачпад работает нормально.
Подскажите, пожалуйста, как мне удалить ветку 5 и запретить обновляться на нее?
Последний раз редактировалось пользователем 1 IvAlAl; всего редактировалось раз: 4
04 июн 2020, 21:55
Менеджер обновлений - Вид - Ядра линукс - 4.15 . Установить , затем перезагрузить комп и в груб выбрать в дополнительных параметрах загрузку с этого ядра. Если тач работает , то можно опять в менеджере программ удалить ядра 5.0 и 5.3.
04 июн 2020, 22:04
Удалить имеющиеся ядра. Они по идее перестанут обновляться. Не на что будет :hoho:
IvAlAl
04 июн 2020, 22:33
04 июн 2020, 22:04
Спасибо за помощь. Последовал Вашему совету. Пока все работает хорошо.
