Правильная установка (разметка) Linux Mint 19.3
AliceCooper
Благодарил (а): 10 раз
26 май 2020, 03:25
System:    Host: user Kernel: 5.3.0-53-generic x86_64 bits: 64 compiler: gcc v: 7.5.0
           Desktop: MATE 1.22.2 wm: marco dm: LightDM Distro: Linux Mint 19.3 Tricia
           base: Ubuntu 18.04 bionic
Machine:   Type: Desktop System: ASUS product: All Series v: N/A serial: <filter>
           Mobo: ASUSTeK model: H81M-R v: Rev X.0x serial: <filter> UEFI: American Megatrends
           v: 3602 date: 03/26/2018
CPU:       Topology: Dual Core model: Intel Core i3-4170 bits: 64 type: MT MCP arch: Haswell
           rev: 3 L2 cache: 3072 KiB
           flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 29530
           Speed: 3691 MHz min/max: 800/3700 MHz Core speeds (MHz): 1: 3691 2: 3691 3: 3691
           4: 3691
Graphics:  Device-1: NVIDIA GM206 [GeForce GTX 950] vendor: Micro-Star MSI driver: N/A
           bus ID: 01:00.0 chip ID: 10de:1402
           Display: x11 server: X.Org 1.20.5 driver: fbdev,nouveau unloaded: modesetting,vesa
           compositor: marco resolution: 1024x768~76Hz
           OpenGL: renderer: llvmpipe (LLVM 9.0 256 bits) v: 3.3 Mesa 19.2.8 compat-v: 3.1
Audio:     Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: ASUSTeK
           driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:8c20
           Device-2: NVIDIA vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus ID: 01:00.1
           chip ID: 10de:0fba
           Sound Server: ALSA v: k5.3.0-53-generic
Network:   Device-1: Qualcomm Atheros AR9485 Wireless Network Adapter driver: ath9k v: kernel
           port: e000 bus ID: 03:00.0 chip ID: 168c:0032
           Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK
           driver: r8169 v: kernel port: d000 bus ID: 04:00.0 chip ID: 10ec:8168
Drives:    Local Storage: total: 935.24 GiB used: 63.02 GiB (6.7%)
           ID-1: /dev/sda vendor: Western Digital model: WD10EZRZ-00HTKB0 size: 931.51 GiB
           speed: 6.0 Gb/s serial: <filter>
           ID-2: /dev/sdb type: USB vendor: Kingston model: DataTraveler 102 size: 3.73 GiB
           serial: <filter>
Partition: ID-1: / size: 48.97 GiB used: 27.56 GiB (56.3%) fs: ext4 dev: /dev/dm-0
           ID-2: /home size: 284.24 GiB used: 35.45 GiB (12.5%) fs: ext4 dev: /dev/dm-2
           ID-3: swap-1 size: 2.00 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/dm-1
USB:       Hub: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 chip ID: 1d6b:0002
           Hub: 1-1:2 info: Intel ports: 4 rev: 2.0 chip ID: 8087:8008
           Hub: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 chip ID: 1d6b:0002
           Hub: 2-1:2 info: Intel ports: 6 rev: 2.0 chip ID: 8087:8000
           Hub: 3-0:1 info: Full speed (or root) Hub ports: 10 rev: 2.0 chip ID: 1d6b:0002
           Hub: 3-3:2 info: Full speed (or root) Hub ports: 4 rev: 2.0 chip ID: 214b:7250
           Device-1: 3-3.2:4 info: Kingston DataTraveler 102 type: Mass Storage
           driver: usb-storage rev: 2.0 chip ID: 0951:162d
           Device-2: 3-4:3 info: A4Tech XL-730K / XL-750BK / XL-755BK Mice type: Keyboard,Mouse
           driver: hid-generic,usbhid rev: 1.1 chip ID: 09da:9090
           Hub: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 chip ID: 1d6b:0003
Sensors:   System Temperatures: cpu: 41.0 C mobo: N/A
           Fan Speeds (RPM): cpu: 0
Repos:     No active apt repos in: /etc/apt/sources.list
           1: deb http: //mirror.yandex.ru/linuxmint-packages tricia main upstream import backport
           2: deb http: //mirror.corbina.net/ubuntu bionic main restricted universe multiverse
           3: deb http: //mirror.corbina.net/ubuntu bionic-updates main restricted universe multiverse
           4: deb http: //mirror.corbina.net/ubuntu bionic-backports main restricted universe multiverse
           5: deb http: //security.ubuntu.com/ubuntu/ bionic-security main restricted universe multiverse
           6: deb http: //archive.canonical.com/ubuntu/ bionic partner
Info:      Processes: 185 Uptime: 10m Memory: 7.71 GiB used: 1.45 GiB (18.8%) Init: systemd v: 237
           runlevel: 5 Compilers: gcc: 7.5.0 alt: 7 Client: Unknown python3.6 client inxi: 3.0.32
Пробовал автоматом, ручную, теперь дошел до LVM2 (GPT онли). Естественно, все ставил на чистый хард.
К сожалению, нет скринов и доп инфы кроме LVM2 (UPD позже)
У меня сейчас 1_террабайт хард и BIOS UEFI. Хочу уже на чем-то остановиться пока хард не запорол окончательно))
Решил установить Win7/10x64, а поверх него Linux и так использовать.
Какую методику установки и разметки лучше использовать и когда?
Целесообразно ли юзать PC (с одним хардом) для этого или лучше ноутбук?
BOREDOM IS THE FIRST STEP TO RELAPSE ©
AliceCooper
26 май 2020, 03:37
UPD:
LVM2 сначала пробовал автоматом, не понравилось при данном выборе установке весь диск использовался. Так как запутался в командах для сжатия и выделения/создания свободного/не размеченного пространства.
Теперь вот результат ручной:
lsblk
NAME              MAJ:MIN RM   SIZE RO TYPE MOUNTPOINT
sda                 8:0    0 931,5G  0 disk
├─sda1              8:1    0   512M  0 part /boot/efi
├─sda2              8:2    0 341,8G  0 part
│ ├─mint--vg-root 253:0    0    50G  0 lvm  /
│ ├─mint--vg-swap 253:1    0     2G  0 lvm  [SWAP]
│ └─mint--vg-home 253:2    0 289,8G  0 lvm  /home
└─sda3              8:3    0 341,8G  0 part
sdb                 8:16   1   3,7G  0 disk
PS тем кто хочет пробовать ОБЯЗАТЕЛЬНО сначала полностью изучите теорию LVM
Я изучал тут https://habr.com/ru/post/67283/ и тут http://xgu.ru/wiki/LVM
Сотрудник
26 май 2020, 08:36
AliceCooper, на канале YouTube есть видео по установке и настройке LVM.
Для примера мой снимок разметки обычных разделов для установки системы.
- /dev/sda1 - swap - раздел подкачки
- /dev/sda6 - для документов (без мусорных временных файлов)
dzhoser
26 май 2020, 10:54
Сотрудник, а зачем два раздела boot у Вас минт в legacy стоит?
Сотрудник
26 май 2020, 11:24
dzhoser, В режиме UEFI. Разделы sda3 - EFI раздел, sda4 - загрузчик ОС, sda5 - корневая файловая система. Раздел sda4 сделал отдельно потому что при загрузке с файловой системы XFS бывают проблемы и система не запускается, уже испытано много раз, а с файловой системой ext4 нет проблем с загрузкой ОС и корневой раздел можно форматировать в других ФС. Файловую систему XFS выбрал потому что использую виртуальную машину и размер файлов бывает от 1GB до 200GB.
dzhoser
26 май 2020, 11:30
А чем ext4 не устроила она вроде более 2ТБ поддерживает.
Сотрудник
26 май 2020, 11:56
XFS - ФС специально предназначена для больших файлов и я привык к этой ФС.
Adrian
Благодарил (а): 33 раза
26 май 2020, 14:16
Сотрудник писал(а):
26 май 2020, 11:56
Я тоже когда-то пробы ради поставил xfs на раздел жёсткого диска, где фильмы храню. Так и пользуюсь до сегодняшнего дня.
Но не знаю, есть ли смысл. Просто по инерции.
Да и при хорошем Интернете особо нет смысла фильмы на дисках хранить.
Благодарил (а): 406 раз
26 май 2020, 16:25
AliceCooper,
Под твои параметры системы/железа:
30 Gb - /
303 Gb - /home
8 Gb - swap
В таком порядке и всё вручную вез всяких там lvm (в пределах расширенного раздела разумеется).
P.S. 30 Гиг для корня вполне хватает, если правда не будешь заморачиваться с flat'ами и snap'ами.
swap - по размекру оперативки - это аксиома.
А остальное - под /home и вперёд жишь!
P.P.S. И уж коли задаешь такие вопросы, то не рискуй и не экспериментируй с файловыми системами. Ставь ext4, - уверяю тебя, кардинальной разнициы не ощутишь.
26 май 2020, 16:44
x230 писал(а):
26 май 2020, 16:25
30 Gb - /
Лучше 50 ГБ, а то потом прибежит и будет кричать что места не хватает, а чтоб расширить придется заморачиваться. Да и лишним не будет точно.
Благодарил (а): 54 раза
26 май 2020, 17:21
x230 писал(а):
26 май 2020, 16:25
Аксиома это только в смысле того, чтобы номинально работала функция сна/гибернации (которая не работает если своп меньше памяти). Так-то может быть и больше и меньше. Меньше - если памяти очень много, сон не нужен, и своп используется мало. Больше - если интенсивно используется куча громоздких программ, и виртуалки. Я, например, чаще всего 2х от оперативной памяти делаю. Чтобы с запасам хватило на все. Очень редко нужно, но пару раз реально потребовалось.
dzhoser
26 май 2020, 18:51
Внесу свои пять копеек.С точки зрения безопасности нужно деать так
/ 60 ГБ
/boot 300 МБ
/home Все оставшееся место
/tmp 10 ГБ
/var/tmp 10ГБ
Раздел /boot рекомендуется монтировать с опциями ro (перед обновлением ядра смонтировать в rw)
Разделы /home /tmp /var/tmp рекомендуется монтировать с опциями noexec,nodev,nosuid
swap можно сделать файлом, так легче менять размер
26 май 2020, 19:25
26 май 2020, 16:44
места не хватает
Я же обиновался на ентот счет: если не будет связываться с flat и snap ... Но вообще согласен, мало ли что... да и диск позволяет...
26 май 2020, 17:21
именно
26 май 2020, 17:21
Понимаю.
Но я ни разу не превысил половину от оперативки, - а оперативки у меня (на секундочку!) - всего 4 Гига! :hoho:
Последний раз редактировалось пользователем 1 x230; всего редактировалось раз: 26
27 май 2020, 07:18
dzhoser писал(а):
26 май 2020, 18:51
Точно, щас он вспомнит при установки обновлений про это, при условии что даже смотреть не будет что там обновляется.
Ну и от кого защищаться то :-D
Сотрудник
27 май 2020, 08:18
Для раздела /boot размер 300MB мало, вот вывод команды df -TH
Файл.система Тип Размер Использовано Дост Использовано% Cмонтировано в
/dev/sda5 - xfs 64G 61G 3,8G 95% /
/dev/sda2 jfs 8,0G 7,2M 8,0G 1% /tmp
/dev/sda4 ext4 3,8G 232M 3,5G 7% /boot
/dev/sda6 xfs 41G 9,1G 31G 23% /disk2
/dev/sda3 vfat 149M 9,0M 140M 7% /boot/efi
Я свои 8GB оперативной памяти загружаю почти полностью, запускаю сразу пять браузеров, каждый для выполнения отдельной задачи :smile:
27 май 2020, 08:20
Сотрудник писал(а):
27 май 2020, 08:18
https://youtu.be/1GIspRhOY-4
