не правильно работает тачпад
zip1888
#21
25 май 2020, 14:54
dzhoser писал(а):
25 май 2020, 10:56
А драйвер тачпада у Вас стоит sudo apt-get install xserver-xorg-input
пишет нет такого: не найден кандидат на установку.
установлен xserver-xorg-input-all; xserver-xorg-input-synaptics
dzhoser
#22
25 май 2020, 16:27
Покажите cat usr/share/X11/xorg.conf.d/50-synaptics.conf
zip1888
#23
25 май 2020, 16:43
dzhoser писал(а):
25 май 2020, 16:27
через терминал почему-то не открывает: Нет такого файла или каталога. вручную открыл
# Example xorg.conf.d snippet that assigns the touchpad driver
# to all touchpads. See xorg.conf.d(5) for more information on
# InputClass.
# DO NOT EDIT THIS FILE, your distribution will likely overwrite
# it when updating. Copy (and rename) this file into
# /etc/X11/xorg.conf.d first.
# Additional options may be added in the form of
# Option "OptionName" "value"
Section "InputClass"
Identifier "touchpad catchall"
Driver "synaptics"
MatchIsTouchpad "on"
# This option is recommend on all Linux systems using evdev, but cannot be
# enabled by default. See the following link for details:
# http://who-t.blogspot.com/2010/11/how-t ... rrors.html
MatchDevicePath "/dev/input/event*"
EndSection
Identifier "touchpad ignore duplicates"
MatchOS "Linux"
MatchDevicePath "/dev/input/mouse*"
Option "Ignore" "on"
EndSection
# This option enables the bottom right corner to be a right button on clickpads
# and the right and middle top areas to be right / middle buttons on clickpads
# with a top button area.
# This option is only interpreted by clickpads.
Identifier "Default clickpad buttons"
MatchDriver "synaptics"
Option "SoftButtonAreas" "50% 0 82% 0 0 0 0 0"
Option "SecondarySoftButtonAreas" "58% 0 0 15% 42% 58% 0 15%"
EndSection
# This option disables software buttons on Apple touchpads.
Identifier "Disable clickpad buttons on Apple touchpads"
MatchProduct "Apple|bcm5974"
Option "SoftButtonAreas" "0 0 0 0 0 0 0 0"
EndSection
dzhoser
#24
25 май 2020, 18:32
cp /usr/share/X11/xorg.conf.d/50-synaptics.conf /etc/X11/xorg.conf.d/50-synaptics.conf
sudo reboot
zip1888
#25
25 май 2020, 22:08
dzhoser писал(а):
25 май 2020, 18:32
sudo reboot
пишет: евозможно создать обычный файл........Нет такого файла или каталога
я правильно понимаю, надо скопировать 50-synaptics.conf из /usr/share/X11/xorg.conf.d/ в /etc/X11/xorg.conf.d/?
dzhoser
#26
25 май 2020, 22:15
Да нужно просто скопировать, возможно у вас нет прав на эту операцию вы через sudo делаете?
zip1888
#27
25 май 2020, 23:19
dzhoser писал(а):
25 май 2020, 22:15
в каталоге /etc/X11/ не было папки /xorg.conf.d/. я ее создал и файл прекрасно скопировался. перезагрузил, все по старенькому...
dzhoser
#28
26 май 2020, 10:09
Попробуйте в файл /usr/share/X11/xorg.conf.d/50-synaptics.conf
В секцию добавить опцию выделенную жирным
Option "ClickPad" "true"
EndSection
zip1888
#29
26 май 2020, 22:44
dzhoser писал(а):
26 май 2020, 10:09
EndSection
сделал. раньше на левой кнопке была прокрутка вместе с выделением (файлы выделять и открывать я мог), теперь же осталась только прокрутка. выделение и открытие файлов не работает, но окна перетаскивать зажимая эту кнопку могу
dzhoser
#30
27 май 2020, 22:00
А у вас какая оболочка? Cinnamon?
zip1888
#31
31 май 2020, 00:00
dzhoser писал(а):
27 май 2020, 22:00
mate
abulaev2008
Благодарил (а): 24 раза
#32
05 июн 2020, 15:20
zip1888, https://wiki.archlinux.org/index.php/To ... ptics#MATE изучал? Обрати внимание на МАТЕ
