Чёрные артефакты в wine на видеокарте Intel
Модератор: WWolf
Stivux
11 май 2020, 15:36
Здравствуйте, как можно побороть чёрные артефакты в wine на видеокарте Intel?
  Host: Lenovo-ideapad-110-15IBR Kernel: 5.3.0-51-generic x86_64 bits: 64
  compiler: gcc v: 7.5.0 Desktop: Cinnamon 4.4.8
  Type: Laptop System: LENOVO product: 80T7 v: Lenovo ideapad 110-15IBR
  serial: <filter>
  Mobo: LENOVO model: 00RD15IPG076 v: SDK0J40679 WIN serial: <filter>
  UEFI: LENOVO v: 1GCN23WW date: 09/05/2017
  ID-1: BAT0 charge: 16.1 Wh condition: 16.1/22.6 Wh (71%)
  model: SANYO L15S3A02 status: Full
  Topology: Quad Core model: Intel Pentium N3710 bits: 64 type: MCP
  arch: Airmont rev: 4 L2 cache: 1024 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 12800
  Speed: 1558 MHz min/max: 480/2560 MHz Core speeds (MHz): 1: 2560 2: 2560
  3: 1894 4: 1940
  Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx
  Integrated Graphics
  vendor: Lenovo driver: i915 v: kernel bus ID: 00:02.0
  Display: x11 server: X.Org 1.20.5 driver: modesetting unloaded: fbdev,vesa
  resolution: 1366x768~60Hz
  OpenGL: renderer: Mesa DRI Intel HD Graphics 405 (BSW)
  v: 4.6 Mesa 20.2.0-devel (git-a92a483 2020-05-10 bionic-oibaf-ppa)
  Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series
  High Definition Audio
  vendor: Lenovo driver: snd_hda_intel v: kernel bus ID: 00:1b.0
  Sound Server: ALSA v: k5.3.0-51-generic
  Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
  vendor: Lenovo driver: ath10k_pci v: kernel port: 2040 bus ID: 02:00.0
  Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Lenovo
  driver: r8169 v: kernel port: 1000 bus ID: 03:00.0
  Device-3: Atheros type: USB driver: btusb bus ID: 1-4:4
  Local Storage: total: 931.51 GiB used: 49.47 GiB (5.3%)
  ID-1: /dev/sda vendor: Seagate model: ST1000LM024 HN-M101MBB
  size: 931.51 GiB temp: 31 C
  ID-1: / size: 62.63 GiB used: 7.98 GiB (12.7%) fs: ext4 dev: /dev/sda2
  ID-2: /home size: 794.90 GiB used: 41.48 GiB (5.2%) fs: ext4
  dev: /dev/sda3
  ID-3: swap-1 size: 4.10 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda6
  System Temperatures: cpu: 56.0 C mobo: N/A
  Processes: 187 Uptime: 15m Memory: 3.76 GiB used: 1.66 GiB (44.1%)
  inxi: 3.0.32
winehq-stable 5.0
11 май 2020, 16:13
Stivux писал(а):
11 май 2020, 15:36
Так вроде они никак не связаны. В смысле может ты укажешь программу , которую запускаешь.
Stivux
11 май 2020, 16:17
11 май 2020, 16:13
Stivux писал(а):
11 май 2020, 15:36
MS Office 2007
11 май 2020, 16:33
Stivux, Извини , 3 гига тянуть не буду , чтоб посмотреть на оффис в вайне. :sry:
Stivux
11 май 2020, 16:57
11 май 2020, 16:33
Какие 3 гига? 350 Мб
11 май 2020, 17:05
Stivux, откуда мне знать где ты его скачал. Я открыл ближайшую ссылку , она мне выставила на скачку 2,9 , я и успокоился . Подожди , может кто заглянет.
11 май 2020, 17:15
Он кажется при установке притянул весь оффис , гад. :-D
Stivux
11 май 2020, 17:25
11 май 2020, 17:15
А при сворачивании/разворачивании есть артефакты?
11 май 2020, 17:30
Stivux, при открытии вверху вместо панели чернота , но она быстро исчезает. Ты про это?
11 май 2020, 17:33
Надо в настройках вайна подкрутить и не будет этой черноты. Искать в winecfg
Stivux
11 май 2020, 17:41
11 май 2020, 17:30
Ага
Вернуться в «Wine»
