System: Host: sinicyn-To-be-filled-by-O-E-M Kernel: 5.0.0-32-generic x86_64 bits: 64 compiler: gcc v: 7.4.0 Desktop: Cinnamon 4.4.5 wm: muffin dm: LightDM Distro: Linux Mint 19.3 Tricia base: Ubuntu 18.04 bionic Machine: Type: Desktop System: Gigabyte product: N/A v: N/A serial: <filter> Chassis: type: 3 serial: <filter> Mobo: Gigabyte model: F2A68HM-S1 v: x.x serial: <filter> BIOS: American Megatrends v: FB date: 04/09/2015 CPU: Topology: Dual Core model: AMD A4-7300 APU with Radeon HD Graphics bits: 64 type: MCP arch: Piledriver rev: 1 L2 cache: 1024 KiB flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 15173 Speed: 1797 MHz min/max: 1800/3800 MHz Core speeds (MHz): 1: 1796 2: 1796 Graphics: Device-1: AMD Richland [Radeon HD 8470D] vendor: Gigabyte driver: radeon v: kernel bus ID: 00:01.0 chip ID: 1002:9996 Display: x11 server: X.Org 1.20.4 driver: modesetting unloaded: fbdev,vesa alternate: ati resolution: 1280x1024~60Hz OpenGL: renderer: AMD ARUBA (DRM 2.50.0 / 5.0.0-32-generic LLVM 8.0.0) v: 4.3 Mesa 19.0.8 compat-v: 3.1 direct render: Yes Audio: Device-1: AMD FCH Azalia vendor: Gigabyte driver: snd_hda_intel v: kernel bus ID: 00:14.2 chip ID: 1022:780d Sound Server: ALSA v: k5.0.0-32-generic Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte driver: r8169 v: kernel port: e000 bus ID: 01:00.0 chip ID: 10ec:8168 IF: enp1s0 state: down mac: <filter> Device-2: Realtek RTL8188EUS 802.11n Wireless Network Adapter type: USB driver: r8188eu bus ID: 1-5:2 chip ID: 0bda:8179 IF: wlx60e3270ce156 state: up mac: <filter> Drives: Local Storage: total: 149.05 GiB used: 63.00 GiB (42.3%) ID-1: /dev/sda vendor: Seagate model: ST3160815AS size: 149.05 GiB speed: 1.5 Gb/s serial: <filter> Partition: ID-1: / size: 14.15 GiB used: 5.74 GiB (40.6%) fs: ext4 dev: /dev/sda5 ID-2: /home size: 20.36 GiB used: 870.9 MiB (4.2%) fs: ext4 dev: /dev/sda7 ID-3: swap-1 size: 3.81 GiB used: 268 KiB (0.0%) fs: swap dev: /dev/sda6 Sensors: System Temperatures: cpu: 3.4 C mobo: N/A gpu: radeon temp: 3 C Fan Speeds (RPM): N/A Repos: No active apt repos in: /etc/apt/sources.list Active apt repos in: /etc/apt/sources.list.d/chrome.list 1: deb [arch=amd64] http: //dl.google.com/linux/chrome/deb/ stable main Active apt repos in: /etc/apt/sources.list.d/google-chrome.list 1: deb [arch=amd64] http: //dl.google.com/linux/chrome/deb/ stable main Active apt repos in: /etc/apt/sources.list.d/official-package-repositories.list 1: deb http: //packages.linuxmint.com tricia main upstream import backport #id:linuxmint_main 2: deb http: //archive.ubuntu.com/ubuntu bionic main restricted universe multiverse 3: deb http: //archive.ubuntu.com/ubuntu bionic-updates main restricted universe multiverse 4: deb http: //archive.ubuntu.com/ubuntu bionic-backports main restricted universe multiverse 5: deb http: //security.ubuntu.com/ubuntu/ bionic-security main restricted universe multiverse 6: deb http: //archive.canonical.com/ubuntu/ bionic partner Info: Processes: 194 Uptime: 1h 40m Memory: 3.06 GiB used: 1.19 GiB (38.8%) Init: systemd v: 237 runlevel: 5 Compilers: gcc: 7.4.0 alt: 7 Client: Unknown python3.6 client inxi: 3.0.32
Установка драйвера видеокарты
Автор темы - Сообщения: 3
Добрый день! Проблема такая: Скачал драйвер для видеокарты с официального сайта АМД под linux. Файл с расширением "run". Когда запускаю как исполняемый файл через терминал, все идёт нормально. Затем требует ввести пароль, но я не могу его ввести, т.к поле терминала не реагирует на клавиатуру и не отображается никаких символов (звездочек тоже), вообще ничего. Как в данном случае ввести пароль и установить драйвер. Я просто новичок в Linux.
Звездочки просто не отображаются - это нормально.
Не поставишь ты этот драйвер на эту ОС.
Его можно было легко поставить в версии 17.х.
С бубном поставить в версии 18.х
В версии 19.х - не поставить совсем.
Твоя видяха старая. Остается использовать только свободный драйвер из поставки ядра
Понял. А драйвер под Ubuntu AMD Catalyst™ 15.9 Proprietary Ubuntu 14.04 x86_64 Video Driver for Graphics Accelerators, тоже На сайте Amd, может поставится или нет?
