Не уходит в спящий режим
symon2014, это можно:
Host: genesis-Lenovo-G505 Kernel: 4.15.0-72-generic x86_64 bits: 64
compiler: gcc v: 7.4.0 Desktop: Cinnamon 4.2.4
Distro: Linux Mint 19.2 Tina base: Ubuntu 18.04 bionic
Type: Laptop System: ASUSTeK product: K55DR v: 1.0 serial: <filter>
Mobo: ASUSTeK model: K55DR v: 1.0 serial: <filter>
BIOS: American Megatrends v: 206 date: 03/20/2012
ID-1: BAT0 charge: 42.6 Wh condition: 43.2/51.7 Wh (83%)
model: K55 K55--47 status: Unknown
Topology: Quad Core model: AMD A10-4600M APU with Radeon HD Graphics
bits: 64 type: MCP arch: Piledriver rev: 1 L2 cache: 2048 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 18367
Speed: 1385 MHz min/max: 1400/2300 MHz Core speeds (MHz): 1: 1548 2: 1622
3: 1862 4: 1893
Device-1: AMD Trinity [Radeon HD 7660G] vendor: ASUSTeK driver: radeon
v: kernel bus ID: 00:01.0
Device-2: AMD Seymour [Radeon HD 6400M/7400M Series] driver: radeon
v: kernel bus ID: 01:00.0
Display: x11 server: X.Org 1.19.6 driver: ati,radeon
unloaded: fbdev,modesetting,vesa resolution: 1366x768~60Hz
OpenGL: renderer: AMD ARUBA (DRM 2.50.0 / 4.15.0-72-generic LLVM 8.0.0)
v: 4.3 Mesa 19.0.8 direct render: Yes
Device-1: AMD Trinity HDMI Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus ID: 00:01.1
Device-2: AMD FCH Azalia vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus ID: 00:14.2
Sound Server: ALSA v: k4.15.0-72-generic
Device-1: Qualcomm Atheros AR9485 Wireless Network Adapter
vendor: AzureWave driver: ath9k v: kernel port: f100 bus ID: 04:00.0
IF: wlp4s0 state: up mac: <filter>
vendor: ASUSTeK driver: r8169 v: 2.3LK-NAPI port: d000 bus ID: 05:00.0
IF: enp5s0 state: down mac: <filter>
Local Storage: total: 465.76 GiB used: 277.80 GiB (59.6%)
ID-1: /dev/sda vendor: Western Digital model: WD5000LPVT-24G33T1
ID-1: / size: 457.45 GiB used: 277.80 GiB (60.7%) fs: ext4 dev: /dev/sda1
- Решено: 21
Genesis писал(а): ↑10 дек 2019, 13:47colonel, да увеличил я swap, ещё вчера. Лучше не стало...
... складывается впечатление, что здесь я не увидел компетентных рекомендаций. Яркие тому подтверждения - во-первых, тот факт, что хотя вы уже сто раз повторили про увеличение swap'a, оно мне не помогло...
вообще то мой пост был адресован не вам , а процитированному форумчанину по теме размера свапа.
Вам я ещё ничего не советовал, ни сто раз ни даже ни одного раза.
В сообщении #41 было сказано о том что " Для нормальной работы" спящего режима (тема ведь названа "Не уходит в спящий режим" ) требуется наличие достаточного размера "свап", поскольку все данные и состояние ПК записывается на него.
При уходе в Ждущий режим данные и состояние ПК записываются в ОЗУ. Потому и работает с ОЗУ 8гб и 2гб свапе, и может , если не ошибаюсь работать и с отключенным свапом.
Вот такая вот разница спящего и ждущего режимов. Впрочем имеется некоторая путаница с названиями режимов в разных ОСях и дистрибутивах , где сон , где не сон про не сон, где приостановка и ждущий , а где гибернация или суспенд... бывает чёрт ногу сломит.
Тут ведь "не только лишь все мало кто может это сделать"
кто ж его знает как и чего вы гуглили и как задавали вопрос в поисковике.
Я не уверен даже что вы удосужились элементарно перевести в онлайн переводчике текст ошибки.
Не знаю имеется ли исчерпывающий ответ-решение по вашей проблеме но недолгое гугляндинение по таким ключевым словам ТЫЦ>>>
но , в частности, например, прочтение сообщения об ошибке
и содержание вот этих найденных поиском тем с первой же странички поисковикаFreezing of tasks failed after 20.009 seconds (1 tasks refusing to freeze, wq_busy=0):
Замораживание задач не удалось после 20.009 секунд (1 задачи отказываются замораживать, wq_busy=0):
ТЫЦ-ДЫЦ>>> и ТЫЦ-ДЫДЫЦ>>>
дают основание предполагать что сбой может вызывается каким либо запущенным приложением или процессом отказывающемся закрываться и соответственно записываться в ОЗУ при уходе в ожидание
И как там говорится - в логах "Обычно указывается, какое приложение вызвало сбой приостановки"
Просмотр по диагонали тем найденных поисковиком говорит что это может быть , например, и работа драйвера видеокарты или ещё какого устройства, и возможно подключения по самбе или ещё чего ...
Решения проблемы были и проведение очередного обновления и закрытие программ или процессов вызывающих сбой , перед тем как ПК отправляется в Ждущий режим.
попытаться найти по логам приложение\или процесс дающий сбой , возможно это будет вашим решением.Сообщение #34 Вчера, 10:0
Лог открыт, ошибку нужную вижу...... Что дальше?
colonel, снова открыл нужный лог, просматриваю. Похоже, нашёл нужный мне фрагмент:
Только мне опыта подобных дел не хватает, чтобы увидеть, какие процессы приводят к ошибке.
Dec 10 16:56:55 genesis-Lenovo-G505 NetworkManager[732]: <info> [1575986215.8049] device (wlp4s0): state change: activated -> deactivating (reason 'sleeping', sys-iface-state: 'managed')
Dec 10 16:56:56 genesis-Lenovo-G505 dbus-daemon[722]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.12' (uid=0 pid=732 comm="/usr/sbin/NetworkManager --no-daemon " label="unconfined")
Dec 10 16:56:56 genesis-Lenovo-G505 NetworkManager[732]: <info> [1575986216.0127] device (wlp4s0): state change: deactivating -> disconnected (reason 'sleeping', sys-iface-state: 'managed')
Dec 10 16:56:56 genesis-Lenovo-G505 avahi-daemon[756]: Withdrawing address record for fd22:96ee:10c3:0:49b7:c1a:8581:b7fa on wlp4s0.
Dec 10 16:56:56 genesis-Lenovo-G505 avahi-daemon[756]: Withdrawing address record for fd22:96ee:10c3:0:bdbc:6175:7ba:3f73 on wlp4s0.
Dec 10 16:56:56 genesis-Lenovo-G505 avahi-daemon[756]: Leaving mDNS multicast group on interface wlp4s0.IPv6 with address fd22:96ee:10c3:0:bdbc:6175:7ba:3f73.
Dec 10 16:56:56 genesis-Lenovo-G505 avahi-daemon[756]: Joining mDNS multicast group on interface wlp4s0.IPv6 with address fe80::837c:806d:2461:e711.
Dec 10 16:56:56 genesis-Lenovo-G505 avahi-daemon[756]: Registering new address record for fe80::837c:806d:2461:e711 on wlp4s0.*.
Dec 10 16:56:56 genesis-Lenovo-G505 avahi-daemon[756]: Withdrawing address record for fe80::837c:806d:2461:e711 on wlp4s0.
Dec 10 16:56:56 genesis-Lenovo-G505 kernel: [12505.700546] wlp4s0: deauthenticating from ac:84:c6:4f:76:fc by local choice (Reason: 3=DEAUTH_LEAVING)
Dec 10 16:56:56 genesis-Lenovo-G505 avahi-daemon[756]: Leaving mDNS multicast group on interface wlp4s0.IPv6 with address fe80::837c:806d:2461:e711.
Dec 10 16:56:56 genesis-Lenovo-G505 avahi-daemon[756]: Interface wlp4s0.IPv6 no longer relevant for mDNS.
Dec 10 16:56:56 genesis-Lenovo-G505 systemd[1]: Starting Network Manager Script Dispatcher Service...
Dec 10 16:56:56 genesis-Lenovo-G505 dbus-daemon[722]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Dec 10 16:56:56 genesis-Lenovo-G505 systemd[1]: Started Network Manager Script Dispatcher Service.
Dec 10 16:56:56 genesis-Lenovo-G505 nm-dispatcher: req:1 'connectivity-change': new request (1 scripts)
Dec 10 16:56:56 genesis-Lenovo-G505 nm-dispatcher: req:1 'connectivity-change': start running ordered scripts...
Dec 10 16:56:56 genesis-Lenovo-G505 NetworkManager[732]: <info> [1575986216.0538] dhcp4 (wlp4s0): canceled DHCP transaction, DHCP client pid 20204
Dec 10 16:56:56 genesis-Lenovo-G505 NetworkManager[732]: <info> [1575986216.0538] dhcp4 (wlp4s0): state changed bound -> done
Dec 10 16:56:56 genesis-Lenovo-G505 NetworkManager[732]: <info> [1575986216.0545] dhcp6 (wlp4s0): canceled DHCP transaction
Dec 10 16:56:56 genesis-Lenovo-G505 avahi-daemon[756]: Withdrawing address record for 192.168.1.81 on wlp4s0.
Dec 10 16:56:56 genesis-Lenovo-G505 avahi-daemon[756]: Leaving mDNS multicast group on interface wlp4s0.IPv4 with address 192.168.1.81.
Dec 10 16:56:56 genesis-Lenovo-G505 avahi-daemon[756]: Interface wlp4s0.IPv4 no longer relevant for mDNS.
Dec 10 16:56:56 genesis-Lenovo-G505 nm-dispatcher: req:2 'down' [wlp4s0]: new request (1 scripts)
Dec 10 16:56:56 genesis-Lenovo-G505 nm-dispatcher: req:2 'down' [wlp4s0]: start running ordered scripts...
Dec 10 16:56:56 genesis-Lenovo-G505 NetworkManager[732]: <info> [1575986216.0627] device (wlp4s0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Dec 10 16:56:56 genesis-Lenovo-G505 wpa_supplicant[731]: wlp4s0: CTRL-EVENT-DISCONNECTED bssid=ac:84:c6:4f:76:fc reason=3 locally_generated=1
Dec 10 16:56:57 genesis-Lenovo-G505 wpa_supplicant[731]: nl80211: deinit ifname=wlp4s0 disabled_11b_rates=0
Dec 10 16:56:57 genesis-Lenovo-G505 systemd[1]: Reached target Sleep.
Dec 10 16:56:57 genesis-Lenovo-G505 systemd[1]: Starting Suspend...
Dec 10 16:56:58 genesis-Lenovo-G505 systemd-sleep[16268]: Suspending system...
Dec 10 16:56:58 genesis-Lenovo-G505 kernel: [12507.800499] PM: suspend entry (deep)
Dec 10 16:56:59 genesis-Lenovo-G505 kernel: [12507.800503] PM: Syncing filesystems ... done.
Dec 10 16:57:03 genesis-Lenovo-G505 kernel: [12513.234995] [drm] PCIE GART of 1024M enabled (table at 0x0000000000162000).
Dec 10 16:57:03 genesis-Lenovo-G505 kernel: [12513.235090] radeon 0000:01:00.0: WB enabled
Dec 10 16:57:03 genesis-Lenovo-G505 kernel: [12513.235093] radeon 0000:01:00.0: fence driver on ring 0 use gpu addr 0x0000000040000c00 and cpu addr 0x000000002ddb3ae6
Dec 10 16:57:03 genesis-Lenovo-G505 kernel: [12513.235098] radeon 0000:01:00.0: fence driver on ring 3 use gpu addr 0x0000000040000c0c and cpu addr 0x000000005d61f388
Dec 10 16:57:03 genesis-Lenovo-G505 kernel: [12513.235841] radeon 0000:01:00.0: fence driver on ring 5 use gpu addr 0x0000000000072118 and cpu addr 0x000000001a04bb81
Dec 10 16:57:03 genesis-Lenovo-G505 kernel: [12513.252098] [drm] ring test on 0 succeeded in 2 usecs
Dec 10 16:57:03 genesis-Lenovo-G505 kernel: [12513.252109] [drm] ring test on 3 succeeded in 6 usecs
Dec 10 16:57:03 genesis-Lenovo-G505 kernel: [12513.428231] [drm] ring test on 5 succeeded in 2 usecs
Dec 10 16:57:03 genesis-Lenovo-G505 kernel: [12513.428241] [drm] UVD initialized successfully.
Dec 10 16:57:03 genesis-Lenovo-G505 kernel: [12513.428398] [drm] ib test on ring 0 succeeded in 0 usecs
Dec 10 16:57:03 genesis-Lenovo-G505 kernel: [12513.428535] [drm] ib test on ring 3 succeeded in 0 usecs
Dec 10 16:57:04 genesis-Lenovo-G505 kernel: [12514.082964] [drm] ib test on ring 5 succeeded
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12515.865326] Freezing user space processes ...
Dec 10 16:57:26 genesis-Lenovo-G505 rtkit-daemon[2448]: The canary thread is apparently starving. Taking action.
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865008] Freezing of tasks failed after 20.001 seconds (3 tasks refusing to freeze, wq_busy=0):
- Решено: 6
пульсаудио чтоль не засыпает?
а какие задачи не замораживаются?
Последний раз редактировалось пользователем 1 kobolt; всего редактировалось раз: 11
kobolt, а что он из себя представляет? Микшер, что ли, какой-нибудь?
UPD: Во всяком случае, да, все указанные команды подтвердили, что pulseaudio у меня есть.
kobolt, в то же самое время после указанной ошибки фиксируется следующее:
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865434] sensors D 0 30027 2175 0x00000004
Dec 10 16:57:26 genesis-Lenovo-G505 rtkit-daemon[2448]: Demoting known real-time threads.
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865440] Call Trace:
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865452] __schedule+0x24e/0x880
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865457] ? kernfs_fop_open+0x98/0x3a0
Dec 10 16:57:26 genesis-Lenovo-G505 rtkit-daemon[2448]: Successfully demoted thread 2527 of process 2447 (n/a).
Dec 10 16:57:26 genesis-Lenovo-G505 rtkit-daemon[2448]: Successfully demoted thread 2526 of process 2447 (n/a).
Dec 10 16:57:26 genesis-Lenovo-G505 rtkit-daemon[2448]: Successfully demoted thread 2447 of process 2447 (n/a).
Dec 10 16:57:26 genesis-Lenovo-G505 rtkit-daemon[2448]: Demoted 3 threads.
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865461] schedule+0x2c/0x80
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865464] schedule_preempt_disabled+0xe/0x10
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865467] __mutex_lock.isra.5+0x276/0x4e0
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865472] ? terminate_walk+0xe5/0x100
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865476] ? path_openat+0x65d/0x1960
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865479] __mutex_lock_slowpath+0x13/0x20
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865482] ? __mutex_lock_slowpath+0x13/0x20
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865484] mutex_lock+0x2f/0x40
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865490] thermal_zone_get_temp+0x6c/0x140
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865494] temp_input_show+0x2d/0x60
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865499] dev_attr_show+0x23/0x60
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865502] sysfs_kf_seq_show+0xa3/0x130
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865505] kernfs_seq_show+0x27/0x30
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865509] seq_read+0xe5/0x430
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865513] kernfs_fop_read+0x137/0x180
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865517] ? security_file_permission+0xa1/0xc0
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865521] __vfs_read+0x1b/0x40
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865523] vfs_read+0x8e/0x130
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865526] SyS_read+0x5c/0xe0
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865531] do_syscall_64+0x73/0x130
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865535] entry_SYSCALL_64_after_hwframe+0x3d/0xa2
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865539] RIP: 0033:0x7fa7b8900081
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865541] RSP: 002b:00007ffe22f34bb8 EFLAGS: 00000246 ORIG_RAX: 0000000000000000
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865544] RAX: ffffffffffffffda RBX: 0000561d2ee572a0 RCX: 00007fa7b8900081
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865546] RDX: 0000000000001000 RSI: 0000561d2ee50ab0 RDI: 0000000000000003
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865548] RBP: 0000000000000d68 R08: 0000000000000000 R09: 0000000000000000
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865549] R10: 0000561d2ee4f010 R11: 0000000000000246 R12: 00007fa7b8bd7760
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865551] R13: 00007fa7b8bd82a0 R14: 0000561d2ee572a0 R15: 0000000000000000
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865557] sensors D 0 8105 2175 0x00000004
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865560] Call Trace:
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865565] __schedule+0x24e/0x880
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865568] ? kernfs_fop_open+0x98/0x3a0
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865571] schedule+0x2c/0x80
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865574] schedule_preempt_disabled+0xe/0x10
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865577] __mutex_lock.isra.5+0x276/0x4e0
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865580] ? terminate_walk+0xe5/0x100
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865584] ? path_openat+0x65d/0x1960
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865587] __mutex_lock_slowpath+0x13/0x20
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865590] ? __mutex_lock_slowpath+0x13/0x20
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865593] mutex_lock+0x2f/0x40
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865597] thermal_zone_get_temp+0x6c/0x140
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865601] temp_input_show+0x2d/0x60
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865604] dev_attr_show+0x23/0x60
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865608] sysfs_kf_seq_show+0xa3/0x130
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865610] kernfs_seq_show+0x27/0x30
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865614] seq_read+0xe5/0x430
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865617] kernfs_fop_read+0x137/0x180
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865621] ? security_file_permission+0xa1/0xc0
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865624] __vfs_read+0x1b/0x40
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865627] vfs_read+0x8e/0x130
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865630] SyS_read+0x5c/0xe0
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865634] do_syscall_64+0x73/0x130
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865637] entry_SYSCALL_64_after_hwframe+0x3d/0xa2
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865639] RIP: 0033:0x7fc5e9768081
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865641] RSP: 002b:00007ffca307b6e8 EFLAGS: 00000246 ORIG_RAX: 0000000000000000
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865644] RAX: ffffffffffffffda RBX: 000055b8601332a0 RCX: 00007fc5e9768081
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865646] RDX: 0000000000001000 RSI: 000055b86012cab0 RDI: 0000000000000003
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865647] RBP: 0000000000000d68 R08: 0000000000000000 R09: 0000000000000000
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865649] R10: 000055b86012b010 R11: 0000000000000246 R12: 00007fc5e9a3f760
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865651] R13: 00007fc5e9a402a0 R14: 000055b8601332a0 R15: 0000000000000000
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865665] sensors D 0 16056 16055 0x00000004
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865668] Call Trace:
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865672] __schedule+0x24e/0x880
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865675] ? kernfs_fop_open+0x98/0x3a0
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865678] schedule+0x2c/0x80
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865681] schedule_preempt_disabled+0xe/0x10
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865683] __mutex_lock.isra.5+0x276/0x4e0
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865687] ? terminate_walk+0xe5/0x100
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865690] ? path_openat+0x65d/0x1960
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865694] __mutex_lock_slowpath+0x13/0x20
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865696] ? __mutex_lock_slowpath+0x13/0x20
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865699] mutex_lock+0x2f/0x40
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865703] thermal_zone_get_temp+0x6c/0x140
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865707] temp_input_show+0x2d/0x60
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865711] dev_attr_show+0x23/0x60
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865714] sysfs_kf_seq_show+0xa3/0x130
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865717] kernfs_seq_show+0x27/0x30
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865720] seq_read+0xe5/0x430
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865724] kernfs_fop_read+0x137/0x180
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865727] ? security_file_permission+0xa1/0xc0
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865730] __vfs_read+0x1b/0x40
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865733] vfs_read+0x8e/0x130
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865736] SyS_read+0x5c/0xe0
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865740] do_syscall_64+0x73/0x130
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865744] entry_SYSCALL_64_after_hwframe+0x3d/0xa2
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865745] RIP: 0033:0x7f3b7f1a0081
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865747] RSP: 002b:00007fffb893c3a8 EFLAGS: 00000246 ORIG_RAX: 0000000000000000
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865750] RAX: ffffffffffffffda RBX: 000055994826a2a0 RCX: 00007f3b7f1a0081
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865752] RDX: 0000000000001000 RSI: 0000559948263ab0 RDI: 0000000000000003
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865753] RBP: 0000000000000d68 R08: 0000000000000000 R09: 0000000000000000
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865755] R10: 0000559948262010 R11: 0000000000000246 R12: 00007f3b7f477760
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865756] R13: 00007f3b7f4782a0 R14: 000055994826a2a0 R15: 0000000000000000
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865772] OOM killer enabled.
Dec 10 16:57:26 genesis-Lenovo-G505 kernel: [12535.865773] Restarting tasks ... done.
Как вариант Меню-Параметры-О системе. В открывшемся окне - загрузить информацию о системе. В браузере откроется страница с результатом. Скопируй и помести сюда.
Пы сы Тоже нихрена не уходит в спящий режим. Ни с кнопки ни с крышки.
Люблю это дело...
Интересный у вас образ действия: если что-то не ладиться, просто молча бросить всё на половине, не отвечать ни на какие вопросы - мол, так и должно быть. Гениально!
Я понимаю, для того, чтобы помочь мне разобраться в моей проблеме, вам нужна конфигурация со всеми логами. Но я никак не могу её вывести. С чем это может быть связано, никто мне здесь так внятно и не ответил. Посему ещё раз хочу уточнить: я обратился к компетентным специалистам или просто к записным "знатокам"?
- Решено: 37
Не провоцируй , здесь сообщество а не техподдержка , которую ты оплатил.
По теме. У тебя диск с системой перенесён другого ноута. Возможно что то не срослось. Я советовал тебе выделить место на диске и поставить туда такую же систему для проверки , повторю ещё раз.
Что могло не срастись сейчас, если диск с другого ноутбука был переставлен ещё весной? Я это как причину в принципе не рассматривал именно потому, что не бывает такого - месяцев 8-9 ноутбук работал с пользованным другим ноутбуком жёстким диском, а потом ему вдруг что-то разонравилось.
А почему мне некогда ставить вторую систему, я уже пояснял.
- Решено: 37
Всё , в плоть до бага в последних обновлениях для твоего железа. Ты же ждёшь , когда тебе подарят волшебную кнопку.
Вот она , пользуйся. http://button.dekel.ru/
symon2014, а других, менее времязатратных способов понять, что происходит, не осталось? Или в этой системе каждый баг уникален для каждого пользователя настолько, что общего алгоритма решения проблем не существует?
Короче: устанавливать вторую систему на жёсткий диск я не могу - мне некогда этим заниматься. Вывести данные о конфигурации тоже не получается. Поскольку без всего этого проблемы не решить, попробуем двигаться последовательно.
Какие бывают причины неправильной работы вывода информации о системе в консоли и в графическом режиме?
Из приведённого выше содержания лога можно делать хоть какие-то выводы?
- Решено: 37
В терминале железо можно посмотреть
lspci
, lsusb
, sudo lshw
. И попробуй перейти на 5 линейку ядер. Возможно твои радеоны плохо совместимы с ядром.-
- Решено: 21
".... настоятельно рекомендую внимательно прочитать и обдумать вот это:
https://sitengine.ru//smart-question-ru.html "
(с) После установки linux mint, слетел биос (Пост slant #90727)
вот это и должен найти автор топика
по записям в логе
пусть ищет чего у него нового было сделано на ноуте перед тем как "В последние дни ждущий режим перестал работать" , и возможно в сети в которую он вероятно подключен ,что у него было установлено, какие программы , какие задачи в планировщике, резервные копирования , синхронизации и тд,.
если не хочет разбираться с логами и\или включать мозги, то пусть перед уходом в ждущий экспериментальным путём ищет мешающее "замораживанию" и уходу в ждущий, то что нужно отключить для нормального и быстрого ухода в гибернацию (сон или ожидание)
Ему лучше всех знать что у него на компе установлено , что включено, и как подключено.
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 15h (Models 10h-1fh) Processor Root Complex
00:01.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Trinity [Radeon HD 7660G]
00:01.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Trinity HDMI Audio Controller
00:02.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Family 15h (Models 10h-1fh) Processor Root Port
00:10.0 USB controller: Advanced Micro Devices, Inc. [AMD] FCH USB XHCI Controller (rev 03)
00:11.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode]
00:12.0 USB controller: Advanced Micro Devices, Inc. [AMD] FCH USB OHCI Controller (rev 11)
00:12.2 USB controller: Advanced Micro Devices, Inc. [AMD] FCH USB EHCI Controller (rev 11)
00:13.0 USB controller: Advanced Micro Devices, Inc. [AMD] FCH USB OHCI Controller (rev 11)
00:13.2 USB controller: Advanced Micro Devices, Inc. [AMD] FCH USB EHCI Controller (rev 11)
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 14)
00:14.2 Audio device: Advanced Micro Devices, Inc. [AMD] FCH Azalia Controller (rev 01)
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 11)
00:14.4 PCI bridge: Advanced Micro Devices, Inc. [AMD] FCH PCI Bridge (rev 40)
00:14.7 SD Host controller: Advanced Micro Devices, Inc. [AMD] FCH SD Flash Controller
00:15.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Hudson PCI to PCI bridge (PCIE port 0)
00:15.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Hudson PCI to PCI bridge (PCIE port 1)
00:15.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Hudson PCI to PCI bridge (PCIE port 2)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 15h (Models 10h-1fh) Processor Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 15h (Models 10h-1fh) Processor Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 15h (Models 10h-1fh) Processor Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 15h (Models 10h-1fh) Processor Function 3
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 15h (Models 10h-1fh) Processor Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 15h (Models 10h-1fh) Processor Function 5
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Seymour [Radeon HD 6400M/7400M Series] (rev ff)
04:00.0 Network controller: Qualcomm Atheros AR9485 Wireless Network Adapter (rev 01)
05:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 07)
Bus 002 Device 002: ID 13d3:5710 IMC Networks UVC VGA Webcam
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 007: ID 1bcf:0005 Sunplus Innovation Technology Inc. Optical Mouse
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Отчего бы и нет, только как это делается?
