Восстановление настроек после перехода на минорную версию
Gnom7
01 ноя 2019, 13:17
1. Linux Mint 19.1 Cinnamon x64, Linux Mint 19.2 Cinnamon x64
2.
Host: home Kernel: 4.15.0-66-generic x86_64 bits: 64 compiler: gcc
v: 7.4.0 Desktop: Cinnamon 4.0.10 Distro: Linux Mint 19.1 Tessa
base: Ubuntu 18.04 bionic
Type: Desktop System: Gigabyte product: N/A v: N/A serial: <filter>
Mobo: Gigabyte model: H61M-DS2 serial: <filter> BIOS: American Megatrends
v: F7 date: 03/23/2012
Device-1: hidpp_battery_0 model: Logitech MX Ergo Multi-Device Trackball
charge: 55% status: Discharging
Topology: Quad Core model: Intel Core i5-2500 bits: 64 type: MCP
arch: Sandy Bridge rev: 7 L2 cache: 6144 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 26339
Speed: 3306 MHz min/max: 1600/3700 MHz Core speeds (MHz): 1: 3411 2: 3299
3: 3387 4: 3374
vendor: Gigabyte driver: i915 v: kernel bus ID: 00:02.0
Display: x11 server: X.Org 1.19.6 driver: modesetting unloaded: fbdev,vesa
resolution: 1600x900~60Hz
OpenGL: renderer: Mesa DRI Intel Sandybridge Desktop v: 3.3 Mesa 18.2.8
vendor: Gigabyte driver: snd_hda_intel v: kernel bus ID: 00:1b.0
Sound Server: ALSA v: k4.15.0-66-generic
vendor: Gigabyte driver: r8169 v: 2.3LK-NAPI port: e000 bus ID: 02:00.0
Device-2: Realtek RTL8192CU 802.11n WLAN Adapter type: USB
driver: rtl8192cu bus ID: 1-1.1:3
IF: wlx14cc201f79af state: up mac: <filter>
Local Storage: total: 372.62 GiB used: 217.19 GiB (58.3%)
ID-1: /dev/sda vendor: Samsung model: HD080HJ size: 74.53 GiB
ID-2: /dev/sdb vendor: Seagate model: ST320DM000-1BD14C size: 298.09 GiB
ID-1: / size: 292.41 GiB used: 166.97 GiB (57.1%) fs: ext4 dev: /dev/sdb1
System Temperatures: cpu: 29.8 C mobo: 27.8 C
Processes: 198 Uptime: 4d 2h 04m Memory: 3.75 GiB used: 1.39 GiB (37.1%)
inxi: 3.0.27
Здравствуйте! На данный момент у меня стоит Linux Mint 19.1 Cinnamon x64, я хочу отформатировать жесткий диск и установить Linux Mint 19.2 Cinnamon x64 плюс Lubuntu и Windows 10 на отформатированный диск. Суть в том, что не хочу заново настраивать свежеустановленную систему Linux Mint 19.2. Подскажите, если сделать снимок системы на Linux Mint 19.1, то его можно приминять к Linux Mint 19.2?
Решение slant » 01 ноя 2019, 13:32
Нет. Снимок системы сохраняет состояние на момент снимка. Полностью.
Если вас не устраивает штатный механизм апгрейда с 19.1 до 19.2 без переустановки, то для сохранения максимума настроек вам нужно сохранить содержимое каталога /home/username и потом вернуть его на новой системе (username - ваше имя пользователя).
01 ноя 2019, 13:32
